Coding for passat abs bosch 5.7
hamod_00
New Member
Middle East
HN1-013096 (2nd hand?)
hi for all
can any one help please to coding abs bosch 5.7 for passat
itry many coding and login code without successful
thanks
this log file
Monday,25,June,2018,09:21:45:50475
VCDS Version: 18.2.1.2  HEX-NET CB: 0.4411.4
VIN: WVWZZZ3BZ2P222992   License Plate:
Chassis Type: 3B (3A - VW Passat B4 (1994 > 1997))
Scan: 01 02 03 08 15 25 41
Address 01: Engine        Labels: 038-906-019-AVF.lbl
   Part No: 038 906 019 EP
   Component: 1,9l R4 EDC 0000AG  1464
   Coding: 00001
   Shop #: WSC 00028
   VCID: 699A4BCF11BCC90C90-4B1E
   WVWZZZ3BZ2P222992     VWZ7Z0A4196145
18261 - Powertrain Data Bus
            P1853 - 35-10 - Implausible Message from ABS Controller - Intermittent
18027 - Glow Plug Relay (J52)
            P1619 - 35-10 - Open or Short to Ground - Intermittent
18044 - Powertrain Data Bus
            P1636 - 35-00 - Missing Message from Airbag Controller
18057 - Powertrain Data Bus
            P1649 - 35-00 - Missing Message from ABS Controller
Readiness: 0 0 X X X
Address 02: Auto Trans        Labels: 01V-927-156.lbl
   Part No: 3B0 927 156 S
   Component: AG5 01V 1.9l-PD RdW 2224
   Coding: 00103
   Shop #: WSC 00028
   VCID: 3620D0B3108256F4CD-5160
18265 - Load Signal
            P1857 - 35-10 - Error Message from ECU - Intermittent
17087 - Brake Switch (F)
            P0703 - 35-10 - Electrical Malfunction - Intermittent
Address 03: ABS Brakes        Labels: 4B0-614-517.lbl
   Part No: 4B0 614 517 G
   Component: ABS/ESP front       3428
   Coding: 00000
   VCID: 250207FFBD242D6C74-51F2
            66-10 - Not Matched - Intermittent
            35-00 -  -
Address 08: Auto HVAC        Labels: 3Bx-907-044.lbl
   Part No: 3B1 907 044 K
   Component: CLIMATRONIC B5GP    0010
   Coding: 17000
   Shop #: WSC 00028
   VCID: 291A0BCFD13C090C50-5184
6 Faults Found:
00818 - Sensor for Evaporator Outlet Temperature (G263)
            30-00 - Open or Short to Plus
00797 - Sunlight Photo Sensor (G107)
01271 - Positioning Motor for Temperature Flap (V68)
            35-10 -  -  - Intermittent
            35-00 -  -
01273 - Fresh Air Blower (V2)
            79-00 - Please Check Fault Codes
End----(Elapsed Time: 01:17, VBatt start/end: 12.0V/12.0V. VIgn 11.9V)-----
Vehicle Identification No.WVWZZZ3BZ2P222992
Modelpassat sedan
PA
Date of production27.09.2001
Year2002
Sales type3B3165
Engine CodeAVF
Transmission CodeEYF
x
Special editionsE0AWithout special action equipment
Lockable wheel bolts1PAStandard wheel bolts
Vehicle class differentiation units/platform components0DEInstallation differentiation for build status of vehicle class B5 (VW Passat)
Emission standard0GEEmission standard EU3
Trailer hitch1D0without trailer towing
airbag4UEdriver and front passanger airbags
Automatic transmission indicator light9FBAutomatic transmission indicator light
Aktivkohlebehälter / Ottopartikelfilter1E0Without activated charcoal canister
Storage compartment7N0Without overhead storage compartment
Aerials8L3roof antenna
Exterior mirror setting6XNExterior mirrors, power-adjustable/ separately heated
Left exterior mirror5SLLeft exterior mirror, aspherical
Right exterior mirror5RQRight exterior mirror: convex
Alternative drive system0K0Without alternative drive system
Drive type1X0Front-wheel drive
Outside temperature display9Y0Without outdoor temperature gage
Equipment levelsA8SStandard equipment
Brake type in rear1KDDisc brakes in rear
batteriesJ0RBattery 380 A (80 Ah)
Brake type, front1ZCDisc brakes in front (Geomet D)
Controls (steering wheel/steering column)4LAWithout control element
Beverage holders4M6Beverage holders
Component part sets with country-specific design requirementsB0Abuild parts set without county specific documentatio
floor covering3MQIbolours floor covering
Brake systems1ATelectronic satbility programme -ESP-
Owner's manuals0VFInformation kit in English
Heated washer nozzles9T0Without heated washer nozzles
CD ROM/DVD/SD card7QAWithout CD/DVD for navigation
CD changer/CD player7A0Without CD changer/CD player
Chrome packageQJ0Without aluminum/chrome work package
General operating permit, alterationsC04Operating permit, alteration
Shock absorption/suspension, chassis1BAFederung/Daempfung, standard
Roof rails/roof load rack3S0Without roof rails/roof load rack
Roof insert/convertible top3FAroof without cut out
Load-through hatch/ski bag3X0without load through system
Insert for the filling up of unleaded fuel/fuel type2G0Without insert for the filling up of fuel
Theft protection system7AAElectronic immobilizer
Inserts5MADecorative inserts
Interference suppression8E2Local interference suppression for FM/AM radio reception
Park distance control7X0Without park distance control
Manufacturing sequence differentiation0FGMosel manufacturing sequence
window regulator4R3Power windows with comfort operation
fire extinguisher6A0without fire extinguisher
Malfunction display9HAWithout additional malfunction display
Headlight activation8K0Without special driving light switching
Antifreeze1C1Antifreeze up to -25 degree Celsius tolerance up to -30 degree C
Vehicle specificationsF0ANo special purpose vehicle, standard equipment
throttle control0L2accelerator pedal with electronic modul
Alternators8GLAlternator 120 A
Transmission types/gearshift mechanisms0G7tiptronic
Transmission shafts, rear axle1YAWithout transmission shafts f. rear axle
Transmission shafts1WDTransmission shaft for tripod joints
Weight category rear axle0YDWeight range 4 installation control only, no requirement forecast
Weight category front axle0JKWeight category front axle weight range 10
Base engineT9J4-cylinder diesel engine 1.9 l unit 038.K
Luggage netting/pocket on backrest(s)4U5Luggage pockets on backrest
cruise control system8T0Without cruise control system (CCS)
Exterior noise suppression measures2B1additional noise dampener
Garage door openerVC0without Garage door opener
Transmission specificationsG0FFive-speed automatic transmission
Cruise control system and speed limiter6Y0without speed warning system
glove box4Z2glove box, lockable
Center high-mounted stop light8R1Center high-mounted stop lamp
handle for hand brake lever6PAHand brake lever handle in plastic
Rear seats3NZRear bench seat, not split, split backrest, folding
Heating and air-conditioning system9AKClimatronic with impact pressure control, CFC-free
Headlamps8BGTwin-headlamps for driving on the right, with integrated high beam
Instrument clustersU0CInstrument cluster with tachometer, clock and km/h speedometer
Breakaway interior rearview mirror4L2Breakaway interior rearview mirror, dimming
Sticker (customized or special edition)0KAWithout decals and emblems
Body styleK8BNotchback
Luggage compartment floor covering6SDLuggage compartment floor covering in needle-punched nonwoven (dimensionally stable)
Cassette and CD storage unit4W0without cassette / CD tray
Child seatsQA0without child seat
Climatic zones0Y1Standard climatic zones
headrest for seat, rear3Q1headrest for seat, rear
Head restraints3J7Tilt- and height-adjustable head restraints for front seats
Fuel quantity for initial filling1Z0Initial standard fuel filling
Body measures5C0Without special body measures
Catalytic converter control8KAwithout catalyst control
Front license plate bracket6W1Front license plate carrier (large)
Paint preservative/transit coating5K1Transit coating (wax)
Paint coatingFB3Surface, interior trim, soft-touch paint
Rear cargo area3GKWithout add. lower section for luggage comp. floor
Steering system arrangementL0LLeft-hand drive
Reading lamp8S4Two reading lights front, two rear
steering1N1Power steering
Lumbar support7P4Manually adjustable lumbar support in front seats
steering wheels2PQSteering wheel for airbag system
Speaker installation8RE4 speakers (passive)
Headlight range control8Q1Headlight range control
Center armrest6E3Front center armrest
Multi-function display/trip computer9Q0Without multi-function display/ trip computer
Engine cooling8Z6Engine cooling, version 2
Engine specificationsD3E4-cyl. turbo diesel engine 1.9 L/96 KW TDI Unit injector, EU3 Basic engine is: T9J
Left vanity mirror4SDVanity mirror, left, illuminated
Right vanity mirror4TDVanity mirror, right, illuminated
Navigation device7Q0without navigation system
rear fog lamp8TCRear fog light for driving on the right
Front fog lamp/additional headlamp8WAWithout fog lights
Rear of platform module base4P1Rear floor panel module, type 2
Hubcaps1NCFull wheel covers
WheelsC5ESteel wheels 6J x 15 ET 37
Radios8AAwithout radio
Smoker's/non-smoker's package9JBSmoker's package, ashtrays in front and rear
Tire pressure monitoring system7K0Without tyre pressure monitor
tireH6S195/65 R15 V tyres
Tire suppliersV0ATires without specification of tire brand
Spare wheel/breakdown kit1G2Spare wheel with full tyre, steel
Restraint systems, front3QT3-point seat belts in front, with tensioner and height adjustment
PH2air con "Climatronic", free of cfc
SQ5
Side airbag4X3Side airbag in front, with curtain airbag
Gearshift knob/handle6Q1Gearshift knob/handle in plastic
Special labels/plates0SCLabels in English
Tail lamp assemblies8SARear combination lamp, standard design
Materials of low flammability4Q1Materials of low flammability
Seat belt check9P0without press button buckle with warning contact
Center rear seat belts3C3Lap belt with retractor for the center rear seat
Gearshift boot/cover6R0Gearshift boot for automatic transmission
seat coversN0UCut pile seat covering
Seat adjustment3L3Manual height adjustment for front seats
seat heater4A0without seat heater
Safety certificate0LAWithout special labels safety certificates
Side lights8F2side-mounted turn signals
Voice enhancerVX0Without voice enhancer
Side and rear windows4KCSide and rear windows in heat-insulating glass
Protective side molding4B1Protective side molding
Sunroof roller blind for rear/side windows3Y0without roller blind
Supertone system and tone sequence control9J0Without supertone system and tone sequence control
power outlet7B612-volt socket(s)
Bumper2JBStandard bumpers
parking light warning lamp8NAwithout parking light warning lamp
Headlamp washer system8X0Without headlamp washer system
Windshield wiper intermittent control/ light/rain sensor8N4Windshield wiper intermittent control with potentiometer (four speeds)
Nameplate set1DG"TDI" (PD) lettering set
Special alarm systems9A0Without taxi alarm system
Mass damper for steering wheels1Q1Mass damper for steering wheel, 26.5Hz
Door and lid locking system4K3Central locking w/ radio remote control, interior controls and SAFELOCK
Type approval countries/countries with special requirementsB22Type approval country Israel
Carrier frequency for remote control5D1Carrier frequency 433.92 MHz
Partition3CAwithout partition
Door and side trim panels3LDdoor and side trim panels
TV reception/digital radio receptionQV0without TV/digital radio reception
Assembly parts for engine (drive bearing)1VGAssembly part for 4-cyl. engine
Front underbody guard1SAWithout additional front underbody guard
Identification plates1EYSpecial identification label with weight data, but without general operating permit (ROW)
First aid kit / warning triangle1T2warning triangle
Two-way radio installation preparation9D0without prepared for two way radio system
Front seatsQ2Jconvenience seat
Preparation for rotating beacon/siren combination9F0Without preparation for rotating beacon/siren combination
Telephone / telematics9W0Without car phone preparation/ installation
LongLife Service RegimeQG2LongLife Service Regime cannot be activated
Heat accumulator system/auxiliary heater7E0W/o heat accumulator/auxiliary heating
Windshield Glass4GHWindshield in heat-insulating glass with sunshield
Additional tires (snow tires)2WAwithout spare tyre
floor mats0TAwithout floor mats
Decorative trims4ZBBright decorative trims
Additional body panels, side6EPAdditional stone guard body covers
Additional child seat anchors3B4Child seat anchors for child seat system ISOFIX
Duty-free tires1V0Without duty-free and cost-free tires
Additional dust seals6U0Without additional seals outside
Auxiliary heating system9M0Without auxiliary heater/parking heater
With the PR Codes data, we can refer to this Wiki Page and deduce the following:
Login:
0?xxx: Chassis - 9 = VW Passat
0x?xx: Brakes - 5 = (PR-1LB/1LE/1ZC)
0xx?x: Engine - 5 = (PR-T5X/T4N/T9J*/T6T/T1K/T1E/T7F*) (*with Brakes: PR-1LB/1LE/1ZC)
0xxx?: Transmission - 7 = Automatic (PR-G0E/G0F/G0Q)
So the Login is 09557
Coding:
0?xxx: Chassis - 4 = VW Passat
0x?xx: Brakes - 2 = (PR-1LB/1LE/1ZC)
0xx?x: Engine - 5 = (PR-T5X/T4N/T9J*/T6T/T1K/T1E/T7F*) (* with Brakes: PR-1LB/1LE/1ZC)
So the Coding is 04257
Now watch this video:
Indeed your Excellency..... ;)
hamod_00
New Member
Middle East
ok thanks its work my freind
