Audi side assist canbus connection
RussJ
C?ID=288662
I'm doing a retrofit of "Audi side Assist", otherwise known as blind spot warning, on my SQ5.
I've bought a loom and the necessary parts but have hit a snag.
The instructions say I should connect up the loom to a canbus gateway plug but the pin positions specified are already occupied by canbus wires, so I cant insert the supplied loom contacts.
Can I cut off the loom terminals and just splice into the existing canbus wires downstream of the connector so effectively connecting to the gateway?
Sorry if this is a daft question but I'm a bit out of my depth with canbus etc...
Russ
MasterTommy
Amsterdam
C?ID=295586
Yes, you can. However:
- Use a bare crimp contact to connect the wires. Soldering is a good alternative, but crimping is best. Do NOT use wire taps or any other ‘quick’ solutions, that will bite you later on.
- Isolate the points where you made modifications properly & reliably after you connect the wires.
- Make sure you are connecting to the correct can-bus network. There are multiple leaving the gateway (which is why you have a gateway).
RussJ
C?ID=288662
Thanks for your reply. I'll make sure I follow your advice re jointing.
Russ
RussJ
C?ID=288662
SQ5 Side Assist coding help please
I've installed all the hardware for my side assist retrofit but am stuck on the coding needed.
The instructions I have state:
"Go to Address 19 - Can Gateway - add address 3C
In Address 3C execute the following coding - 010311"
I've found and checked "3C" in the Gateway installations list but I can't see how to get at 3C in order to code it.
Can someone point me in the right direction please.
Russ
Morski
Cheshire UK
C?ID=90186
Post up some pics on how you made the CAN connections
RussJ
C?ID=288662
HI,
I've done the scan as requested - not a pretty sight! I haven't replaced all the panels yet as I wanted to see if everything was working before re-assembling the car trim.
I found 3C in the "Comfort/Conv" section but it appears I can't communicate with it yet.
I'm a newbie at VCDS and my only experience is changing a few parameters and invoking ADS so please keep things simple!
All help gratefully received!
Sunday,22,July,2018,20:49:11:63302
VCDS Version: 18.2.1.5 (x64)
VIN: WAUZZZ8R8FA079650   License Plate: CJ11RDJ
Mileage: 34030km-21145mi   Repair Order:
Chassis Type: 8R-AU48 (8R0)
Scan: 01 02 03 05 08 09 13 15 16 17 19 20 36 3C 42 44 46 47 52 53
          56 5C 5F 62 6C 6D 72 A9 C0
VIN: WAUZZZ8R8FA079650   Mileage: 34030km-21145miles
05-Acc/Start Auth. -- Status: Malfunction 1010
09-Cent. Elect. -- Status: Malfunction 1010
17-Instruments -- Status: Sporadic communication error 1000
36-Seat Mem. Drvr -- Status: Malfunction 1010
3C-Lane Change -- Status: Cannot be reached 1100
42-Door Elect, Driver -- Status: Malfunction 1010
44-Steering Assist -- Status: Sporadic communication error 1000
46-Central Conv. -- Status: Malfunction 1010
53-Parking Brake -- Status: Malfunction 1010
5C-Lane Maintain. -- Status: OK 0000
6C-Back-up Cam. -- Status: Malfunction 1010
6D-Trunk Elect. -- Status: Malfunction 1010
72-Door, Rear Right -- Status: Sporadic communication error 1000
Address 01: Engine (J623-CGQB)       Labels:. 059-907-401-V2.clb
   Part No SW: 8K5 907 589     HW: 4G0 907 589
   Component: 3.0BTD EDC17  H25 0004
   Revision: 57H25---
   Coding: 2A2A4032256603020000
   Shop #: WSC 06208 000 00000
   ASAM Dataset: EV_ECM30BTD0118K5907589 001007
   ROD: EV_ECM30BTD0118K5907589.rod
   VCID: 7EF275E8E10033B456-802A
9803 - No Communications with Parking Assist Control Module A
          U0159 00 [039] - -
                    Mileage: 34036 km
                    Date: 2018.07.21
                    Time: 07:30:59
                    Coolant temperature: 24 °C
                    Intake air temperature: 26 °C
                    Voltage terminal 30: 10.380 V
                    Cruise Control System (CCS): status-Bits 0-7: 52
                    selected gear-Bits 0-7: 0
5615 - Door Control Module - Driver's Door
          U0199 00 [036] - No Communications
                    Mileage: 34036 km
                    Date: 2018.07.21
                    Time: 00:04:33
                    Coolant temperature: 18 °C
                    Intake air temperature: 20 °C
                    Voltage terminal 30: 10.600 V
   Part No SW: 8R0 927 158 AE    HW: 0BK 927 156 AM
   Component: 0BK 30RTDIRdW H19 1007
   Revision: --H19---
   Coding: 000001
   VCID: 000E0B109BF4454424-8054
Address 03: ABS Brakes (J104)       Labels:. 8R0-907-379-V2.clb
   Part No SW: 8R0 907 379 AP    HW: 8R0 907 379 AP
   Component: ESP8 quattro  H09 0020
   Coding: 245DCC01
   Shop #: WSC 06335 000 00000
   VCID: 0E122528D9A02334A6-805A
                    Reset counter: 208
                    Mileage: 1048574 km
                    Hex Value: 0x0000
                    Hex Value: 0x0280
                    Hex Value: 0x001A
                    Hex Value: 0x8499
                    Hex Value: 0x0000
                    Reset counter: 208
                    Mileage: 34036 km
                    Date: 2018.07.21
                    Time: 00:04:33
                    Hex Value: 0x0000
                    Hex Value: 0x0782
                    Hex Value: 0x0003
                    Hex Value: 0x1F87
                    Hex Value: 0x0000
   Part No SW: 8K0 907 064 KH    HW: 8K0 907 064 KH
   Component: BCM2 2.0      H15 0711
   Coding: 05B54040000000000000
   VCID: 000E0B1093F4454424-8054
   Serial number: 3214000163027010
            013 - Check DTC Memory
                    Fault Status: 01101101
                    Fault Frequency: 13
                    Reset counter: 168
                    Mileage: 34036 km
                    Date: 2018.07.20
                    Time: 17:07:45
02811 - Control Module for Electronic Steering Column Lock (J764)
                    Reset counter: 208
                    Mileage: 34036 km
                    Date: 2018.07.21
                    Time: 11:22:41
03286 - Sensor for Contact with Door Handle; Front Right
                    Fault Status: 00100111
                    Reset counter: 208
   Part No SW: 8K2 820 043 AQ    HW: 8K2 820 043 AQ
   Revision: D1000000    Serial number: 01211120141279
   Coding: 3625028000
   VCID: 78FE63F0CB240D841C-802C
                    Reset counter: 208
                    Mileage: 34036 km
                    Date: 2018.07.21
                    Time: 00:04:32
                    Reset counter: 168
                    Mileage: 34036 km
                    Date: 2018.07.21
                    Time: 07:30:58
   Revision: 08016001    Serial number: 00000951648401
   Coding: 260000108074AFE00581404300001D0D0F9D470827090201000008004400030100000034000000
   Shop #: WSC 50664 002 104857
   Subsystem 1 - Part No SW: 8R2 955 119 A    HW: 8R2 955 119   Labels: 1KX-955-119.CLB
   Component: WWS416 140825  H12 0050
   Serial number: 90243015140820021300
   Coding: 01DD13
   Serial number: 23488562
   Coding: 02005C
   Subsystem 3 - Part No SW: 4H0 907 658     HW: 4H0 907 658
   Serial number: 37488D57000000000001
6 Faults Found:
                    Reset counter: 208
                    Reset counter: 208
01800 - Light Switch (E1)
                    Reset counter: 168
03280 - Switch Position of Light-Switch Knob
                    Reset counter: 168
                    Mileage: 34036 km
                    Date: 2018.07.21
                    Time: 11:12:12
                    Reset counter: 208
00576 - Terminal 15
                    Reset counter: 168
                    Mileage: 34036 km
                    Date: 2018.07.21
                    Time: 07:31:02
Address 13: Auto Dist. Reg (J428)       Labels: Redir Fail!
   Part No SW: 8R0 907 561 A    HW: 8R0 907 561 A
   Component: ACC3          H11 0100
   Coding: 007D8A
   VCID: 377CA0CC86BAC2FCD5-8062
Address 15: Airbags (J234)       Labels:| 8R0-959-655.clb
   Part No SW: 8R0 959 655 G    HW: 8R0 959 655 G
   Component: AirbagVW-AU10 H48 0610
   Serial number: 003JPDC21U3M
   Coding: 30473431313030303030554A305238523053
   ROD: EV_AirbaAU10SMEAU416.rod
   VCID: 489ED330F344BD04AC-801C
   Serial number: 6334MSME4A6B2B05M
   Serial number: 6352QSME5C484164L
   Serial number: 6362QSME5C4B216CV
   Serial number: 63732SME3449245C%
   Serial number: 63832SME714B487A9
9443091 - Driver's Side Airbag Crash Sensor
          B1017 15 [136] - Open or Short to Plus
                    Mileage: 34036 km
                    Date: 2018.07.21
                    Time: 00:04:32
9451049 - Crash sensor side airbag; passenger side
          B1036 29 [137] - Signal Implausible
                    Mileage: 34036 km
                    Date: 2018.07.21
                    Time: 10:37:16
9445397 - Key switch for deactivation of passenger-side airbag
          B1020 15 [137] - Open or Short to Plus
                    Mileage: 34036 km
                    Date: 2018.07.21
                    Time: 10:13:28
9446677 - Redundant signal path for airbag shut-off; passenger side
          B1025 15 [137] - Open or Short to Plus
                    Mileage: 34036 km
                    Date: 2018.07.21
                    Time: 10:13:30
   Revision: --------    Serial number: 90372NKI000FS
   Coding: 0000FF
   VCID: 4486C700C76C996440-8010
                    Reset counter: 208
                    Fault Frequency: 11
                    Reset counter: 168
                    Mileage: 34036 km
                    Date: 2018.07.21
                    Time: 10:13:26
                    Reset counter: 208
                    Mileage: 1048574 km
                    Reset counter: 40
                    Mileage: 1048574 km
Address 17: Instruments (J285)       Labels:. 8R0-920-xxx-17.clb
   Part No SW: 8R0 920 951     HW: 8R0 920 951
   Component: KOMBIINSTR.   H35 0567
   Revision: 00100000    Serial number: 03I32JJCF
   Coding: 33E7220047012600010000
   VCID: 74E657C0D74C69E430-8020
   Component: GW-BEM 5CAN-M H11 0060
   Revision: 1Z120030    Serial number: 3041Z14B190417
   Coding: 80CD07FF00
   VCID: 4C96EF20EF3C512488-8018
   Subsystem 1 - Part No SW: 8R0 915 181 C    HW: 8R0 915 181 C
   Component: J367-BDMHella  H07 8043
   Serial number: 4899974903
   Serial number: 14311000484011200410
16 Faults Found:
                    Reset counter: 208
                    Bin. Bits:    00000
                    Voltage: 12.20 V
                    Count: 7
                    Bin. Bits:    00000
                    Time: 0.40 s
                    Reset counter: 208
                    Bin. Bits:    00000
                    Voltage: 12.20 V
                    Count: 7
                    Bin. Bits:    00000
                    Time: 0.40 s
                    Reset counter: 208
                    Bin. Bits:    00000
                    Voltage: 12.20 V
                    Count: 7
                    Bin. Bits:    00000
                    Time: 0.40 s
01312 - Powertrain Data Bus
                    Reset counter: 208
                    Bin. Bits:    00000
                    Voltage: 12.20 V
                    Count: 7
                    Bin. Bits:    00000
                    Reset counter: 208
                    Bin. Bits:    00000
                    Voltage: 12.20 V
                    Count: 7
                    Bin. Bits:    00000
                    Time: 0.90 s
01964 - Control Module for Seat & Steering Column Memory (J136)
                    Reset counter: 208
                    Bin. Bits:    00000
                    Voltage: 12.20 V
                    Count: 7
                    Bin. Bits:    00000
                    Time: 0.90 s
                    Reset counter: 208
                    Bin. Bits:    00000
                    Voltage: 12.20 V
                    Count: 7
                    Bin. Bits:    00000
                    Time: 0.90 s
                    Reset counter: 208
                    Bin. Bits:    00000
                    Voltage: 12.20 V
                    Count: 7
                    Bin. Bits:    00000
                    Time: 0.90 s
00317 - Rear Lid Control Module (J605)
                    Reset counter: 208
                    Bin. Bits:    10000
                    Voltage: 12.20 V
                    Count: 7
                    Bin. Bits:    00000
                    Time: 1.90 s
00456 - Control Module for Access and Start Control (J518)
                    Reset counter: 208
                    Bin. Bits:    10000
                    Voltage: 12.20 V
                    Count: 7
                    Bin. Bits:    00000
                    Time: 1.90 s
                    Reset counter: 208
                    Bin. Bits:    10000
                    Voltage: 12.20 V
                    Count: 7
                    Bin. Bits:    00000
                    Time: 1.90 s
                    Reset counter: 208
                    Bin. Bits:    10000
                    Voltage: 12.20 V
                    Count: 9
                    Bin. Bits:    00000
                    Time: 4.90 s
02849 - Control Module for Lane Change Assistance (J769)
                    Reset counter: 168
                    Mileage: 34036 km
                    Date: 2018.07.21
                    Time: 05:57:54
                    Bin. Bits:    10111
                    Voltage: 11.50 V
                    Count: 6
                    Bin. Bits:    00000
                    Time: 25.40 s
            000 -  -  - Intermittent
                    Reset counter: 208
                    Mileage: 34036 km
                    Date: 2018.07.21
                    Time: 06:12:02
                    Bin. Bits:    10111
                    Voltage: 11.40 V
                    Count: 6
                    Reset counter: 168
                    Mileage: 34036 km
                    Date: 2018.07.21
                    Time: 10:37:18
                    Bin. Bits:    10111
                    Voltage: 11.40 V
                    Count: 6
                    Bin. Bits:    00000
                    Time: 25.40 s
                    Reset counter: 168
                    Mileage: 34036 km
                    Date: 2018.07.21
                    Time: 10:37:18
                    Bin. Bits:    10111
                    Voltage: 11.40 V
                    Count: 6
                    Bin. Bits:    00000
                    Time: 25.40 s
   Revision: AA001002
   Coding: 02022064747464545425363E00
   VCID: 7CF67FE0FF1C21A478-8028
   Part No SW: 8R0 959 760 D    HW: 8R0 959 760 B
   Component: MEM-FS        H07 0077
   Revision: AA000000    Serial number: 00000124832453
   Coding: 01781B00000000000000
   VCID: 428AC118DD78975472-8016
                    Reset counter: 208
                    Reset counter: 208
                    Reset counter: 208
Address 3C: Lane Change
   Component: TSG FA        H02 0510
   Revision:             Serial number: 0000126845640
   Coding: 011D12215E01440004
   VCID: 4FACF82C1E2A6A3CED-801A
                    Reset counter: 168
                    Mileage: 34036 km
                    Date: 2018.07.21
                    Time: 10:37:22
                    Reset counter: 168
                    Mileage: 34036 km
                    Date: 2018.07.21
                    Time: 10:37:22
01705 - Selection Switch for Mirror-Adjust (E48)
                    Reset counter: 208
                    Reset counter: 208
02123 - Door Warning Light / Entry Light
                    Fault Status: 00101100
                    Reset counter: 208
   Part No SW: 8R0 909 144 J    HW: 8R0 909 144 B
   Component: RCEPS         H41 0509
   Revision: 00001000    Serial number: 0009187955
   Coding: 100001010001
   ASAM Dataset: EV_RCEPSAU48X 008016
   ROD: EV_RCEPSAU48X_008.rod
   VCID: 3F8CC8ECA68AFABC1D-806A
   Revision: 00002001    Serial number: 0352486413
   Coding: 013B0E22A0B930958720053680040047
   Subsystem 3 - Part No SW: 7N0 959 591 B    HW: 7N0 959 591 B
   Component: J245EE04SKB03  H03 0090
   Subsystem 4 - Part No SW: 7N0 959 591 B    HW: 7N0 959 591 B
   Component: J394EE04SKB03  H03 0090
9 Faults Found:
02914 - Sensor 1 for Trunk/Hatch Closed (G525)
                    Fault Status: 00101010
                    Reset counter: 208
                    Mileage: 34036 km
                    Date: 2018.07.20
                    Time: 10:16:34
02915 - Sensor 2 for Trunk/Hatch Closed (G526)
                    Reset counter: 208
                    Mileage: 34036 km
                    Date: 2018.07.20
                    Time: 10:16:34
                    Reset counter: 208
                    Mileage: 34036 km
                    Date: 2018.07.20
                    Time: 17:07:45
                    Reset counter: 168
                    Mileage: 34036 km
                    Date: 2018.07.21
                    Time: 11:22:41
                    Reset counter: 168
                    Mileage: 34036 km
                    Date: 2018.07.21
                    Time: 11:22:41
                    Reset counter: 208
                    Reset counter: 208
                    Reset counter: 208
                    Fault Frequency: 10
                    Reset counter: 168
                    Mileage: 34036 km
                    Date: 2018.07.21
                    Time: 00:04:37
   Revision: 00005001    Serial number: 94813037454706
   VCID: 2D5082A474E6782CBF-8078
                    Reset counter: 168
                    Voltage: 12.00 V
                    Temperature: 28.0°C
                    Temperature: 28.0°C
                    Bin. Bits: 00000100
                    Fault Status: 00101011
                    Reset counter: 208
                    Voltage: 12.20 V
                    Temperature: 24.0°C
                    Temperature: 24.0°C
                    Bin. Bits: 00000100
00420 - Front Right DSP Midrange Speaker (R104)
                    Reset counter: 208
                    Voltage: 12.20 V
                    Temperature: 24.0°C
                    Temperature: 24.0°C
                    Bin. Bits: 00000100
Address 52: Door Elect, Pass.
   Part No SW: 8K0 907 801 N    HW: 8K0 907 801 J
   Component: EPB-4         H02 0005
   Revision: --------    Serial number: 20000000545768
   ROD: EV_ParkiBrake_AU48.rod
   VCID: 3A7AB9F8BDA8DF942A-806E
467968 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
                    Reset counter: 208
                    Mileage: 34036 km
                    Date: 2018.07.21
                    Time: 00:04:33
                    Voltage terminal 30: 10.8 V
                    Internal Fault ID: 208
                    Red operating lamp: OFF
                    Red warning lamp: OFF
                    Green operating lamp: OFF
                    Yellow warning lamp: OFF
                    Terminal 15 status: On
                    RWU: not active
                    DSD: not active
                    HTR: not active
                    ECD: not active
                    Auto Adjust: not active
   Part No SW: 4G0 035 061 Q    HW: 4G0 035 061
   Component: Radio U DAB   H60 0150
   Revision: AB001007    Serial number: 109K60E7992209
   Coding: 010103010000000001
   VCID: 2B548CBC4AF2761CA1-807E
Address 5C: Lane Maintain.        Labels: None
   Part No SW: 8T0 907 217 A    HW: 4E0 907 217 C
   Component: J759 HC             0040
   Revision: 00H08006    Serial number: 600214B2000165
   Coding: 0002204
   VCID: 377CA0CC46BAC2FCD5-8062
   Part No SW: 8R2 035 666 H    HW: 8R2 035 666 H
   Component: H-BN-EU       H48 0897
   Revision: --------    Serial number: 515K10E7503269
   Coding: 1A0101060205A9EF7D80CB5E00000403E40000020000000000
   Shop #: WSC 50664 002 1048576
   VCID: 3E72B5E8A980F3B416-806A
   Subsystem 1 - Part No: 8R0 060 884 CH
   Component: EUR 2014  2004
   Component: DU7 High  H42 0104
   Serial number: A130KZ0E3196812
   Serial number: 00000002055351
   Component: CD-Database  5950
                    Reset counter: 168
                    Mileage: 34036 km
                    Date: 2018.07.21
                    Time: 10:34:31
                    Bin. Bits: 00000100 00000000
                    Bin. Bits: 00000000 00000000
03278 - Functionality Limited due to Missing Messages
                    Reset counter: 168
                    Mileage: 34036 km
                    Date: 2018.07.21
                    Time: 07:31:07
                    Bin. Bits: 00001000 00000000
Address 62: Door, Rear Left
   Part No SW: 8R0 907 441 A    HW: 4L0 907 441 B
   Revision: --H09---    Serial number: 525PA8-J49A6JS
   Coding: 1020010
   VCID: 346697C057CC29E4F0-8060
                    Fault Frequency: 27
                    Reset counter: 208
                        Term 15 Off
                        Reverse OFF
                    Count: 3
                    Reset counter: 208
                        Term 15 Off
                        Reverse OFF
                    Count: 3
01327 - Control Module for Parking Aid (J446)
                    Reset counter: 168
                    Mileage: 34036 km
                    Date: 2018.07.21
                    Time: 07:31:04
                        Reverse OFF
                    Count: 3
   Part No SW: 8R0 827 851 D    HW: 8R0 827 851 D
   Component: J605  Master  H56 0330
   Revision: --------    Serial number: 8R0827851D
   VCID: 3D70B2E4A486E8AC0F-8068
   Subsystem 1 - Part No SW: 8R0 827 852 D    HW: 8R0 827 852 D
   Component: J756  Slave  H56 0330
   Serial number: 8R0827852D
   Component: TSG HR        H01 0510
   Revision:             Serial number: 0000126699217
   Coding: 010C12204001240004
   VCID: 4682DD08F150AB745E-8012
   Part No SW: 8R0 907 159     HW: 4H0 907 159 A
   Component: SAS-GEN 2     H06 0007
   Serial number: 141021202723
   VCID: 79F866F4F82E148C63-802C
Address C0: Act. for Ext. Noise (J943)       Labels: 4G0-907-160.clb
   Part No SW: 8R0 907 160     HW: 4G0 907 160 B
   Component: SAS-GEN 2 AGA H09 0002
   Serial number: 141021200750
   VCID: 71E85ED4A05E5CCCDB-8024
End-------------------------(Elapsed Time: 04:35)--------------------------
RussJ
C?ID=288662
No pics but I bared a 10mm section of wire on leads going to pins 7 and 17 of the gateway.
I then stripped the canbus wires in my new loom, wrapped them around the appropriate bared section, soldered them together and added a piece of heat shrink.
Seems to be the approved method...
Russ
MasterTommy
Amsterdam
C?ID=295586
Either you connected to the wrong can wires, or your 3C module is not getting power or ground.
myounus
Northwest UK
C?ID=321059
Try switching the car off for 10 mins and then back on to see if the car picks up the modules.
RussJ
C?ID=288662
I've spent the last two days checking and rechecking the loom connections. As you guys suggested, there were some errors so I've re-wired to match the diagrams in ESRA.
I'm pretty sure that its all correct now.
However, the 3C module still fails to respond to VCDS.
I'm coming round to the idea that one or both of the controllers are faulty. They were an eBay purchase and although the seller assured me that they worked fine I have my doubts...
Is there any way of testing these units, either on or off the car? I'd be happy to take them to a specialist if certain test rigs were required.
RussJ
C?ID=288662
One other thing I've noticed is that the small indicator LED in the on/off switch does not come on when I press it. Not sure if that will only work once the modules are coded.
MasterTommy
Amsterdam
C?ID=295586
You can test the master module by wiring up power ground and can-high/low directly to the pins on the VCDS cable and on the module. You’ll need to provide an external 12v power source to it as well. Then you should be able to get a reading when manually selecting the module in the control unit screen. You do not get to try different pins on this, if you put 12V on the wrong ping or hook up a can wire to a pin with 12v on it, you can usually throw away the module, the VCDS interface or both. So if you really found more than one error in you wiring like you said I do not reccomend you doing this.
myounus
Northwest UK
C?ID=321059
Can you please deleted all faults and re-scan the car and post the autoscan.
RussJ
C?ID=288662
I've run a full scan and deleted DTCs but some of them were persistent.
I then re-ran a scan and this is shown below.
When I looked at the installation list on 19 and clicked on 3c, there was a message saying that the module was uninitiated and offering 3 options - use default code, use existing code and manually code.
I chose "default"
I hope this helps...
ednesday,25,July,2018,17:36:05:63302
VIN: WAUZZZ8R8FA079650   License Plate: CJ55RDJ
   Revision: 57H25---
   Revision: --H19---
   Coding: 000001
   Coding: 245DCC01
   Coding: 3625028000
   Coding: 01DD13
   Coding: 02005C
   Component: E1 - LDS  H03 0031
   Serial number: 00000000001511146557
   Coding: 007D8A
   Serial number: 6344MSME4A596417K
                    Mileage: 34036 km
                    Date: 2018.07.24
                    Time: 07:18:49
                    Mileage: 34036 km
                    Date: 2018.07.24
                    Time: 07:18:49
   Coding: 0000FF
   Coding: 80CD07FF00
                    Reset counter: 168
                    Mileage: 34036 km
                    Date: 2018.07.24
                    Time: 07:18:48
                    Bin. Bits:    10111
                    Voltage: 12.50 V
                    Count: 6
                    Bin. Bits:    10000
                    Time: 25.40 s
   Revision: AA001002
                    Reset counter: 168
                    Mileage: 34036 km
                    Date: 2018.07.24
                    Time: 07:18:48
                    valid
                    Fault Status: 01101010
                    Reset counter: 168
                    Mileage: 34036 km
                    Date: 2018.07.24
                    Time: 07:18:47
                    Reset counter: 168
                    Mileage: 34036 km
                    Date: 2018.07.24
                    Time: 07:18:47
   Revision:             Serial number: 0000126704127
   VCID: 4E92E52819206334E6-801A
   Coding: 0002204
                    Reset counter: 168
                    Mileage: 34036 km
                    Date: 2018.07.24
                    Time: 07:18:53
   Component: TSG HL        H01 0510
   Revision:             Serial number: 0000126688328
   Coding: 1020010
End-------------------------(Elapsed Time: 04:29)--------------------------
Address 19,8R0 907 468 P,recoded (Installation List),from,FFF1742C0782850C,to,FFF1742C0782850C,,
myounus
Northwest UK
C?ID=321059
Hi Russ
Try manually coding the module. If it asks for a wsc then try 12345
RussJ
C?ID=288662
I spent yet another couple of days checking the wiring and re-trying VCDS but still no luck.
I had convinced myself that one or both of the modules were faulty and last night was scouring eBay for some replacements when I noticed that someone was advertising a unit describing it as a “master” when the part number corresponded to a ”slave” – or did it?
A search of online part catalogues revealed that it was indeed a master as advertised, which puzzled me, as on my car the same module was wired up as a slave.
Then I realised what had happened.
The position of the modules is fixed as they are “handed” and therefore can’t be attached to the bumper incorrectly
The written instructions I had showed the side assist bumper loom entering the car through a grommet on the drivers side, so I had followed that and fitted the loom to match, ie the connector with the short wires went to the drivers side and the extended wires ran across the bumper to connect up on the passengers side.
However, my Alibaba loom was wired the other way round, presumably LHD as opposed to RHD, and the short wires that should have connected to the master were actually connecting to the slave.
A quick swop of the modules proved I was right, VCDS connection was established and coding done.
This morning I reversed the bumper loom and brought it into the car via a grommet on the passengers side. Fortunately there was enough slack in the rest of the loom to avoid any need to extend it.
Irritatingly, after weeks of unbroken sunshine, its raining now so I can’t finish off the job!
So, many thanks to those who’ve tried to help and a slightly embarrassed apology for wasting your time.
Russ
myounus
Northwest UK
C?ID=321059
Hi Russ
You need to be careful not to bring the loom through the side with the exhaust on. When I retrofitted side assist / blind spot assist on a Golf Mk7 I removed the fitted grommet (under the car) for the park pilot wires and used a wider grommet so as to follow a standard pathway.
RussJ
C?ID=288662
I have an SQ5 so its got exhausts on both sides!
I was careful to zip-tie the loom so it couldn't touch anything hot.
I'm getting an error code on 3C which is telling me that both wing mirror side assist warning lights are either open circuit of shorted to positive.
I'm not sure what this means as according to ElsaWin, one side on the light is connected to a "30" source, which I assume means permanent 12v, and the other connects to the slave module.
When a vehicle is detected the slave drops the connection to earth which then flashes the warning light. I can do this manually by earthing the module wire.
Any idea what the problem is?
Russ
myounus
Northwest UK
C?ID=321059
Russ
The problem sounds like the wires are plugged the wrong way around in the mirror. Turn them around and see if the error goes away.
