-07 Jetta and egr change
zak69
C?ID=326872
Hi, new here and from Finland so try to understand my poor english :)
So. i changed egr valve and it runs very unstable after that, of course.
Then i did tba adaptation and tried to do also egr adaptation but it shows error in last box where the values are.
Valve itself is new and for sure right one, and don´t know what to do next.
Maybe have to put some basic settings to both first, but how is the question?
edit: i would put codes here but i forget to send it from my laptop to home.........
Please post an Auto-Scan so people can see exactly what engine/ECU this car has.
zak69
C?ID=326872
So, yesterday i changed the egr valve, drive home couple of miles and while driving the engine light show up.
When i get home engine wobbles and run badly at idle speed.
Chassis Type: 1K (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72 76
VIN: WVWZZZ1KZ7M001334   Mileage: 356800km-221705miles
Address 01: Engine        Labels: 03C-906-056-BAG.lbl
   Part No SW: 03C 906 056 DP    HW: Hardware No
   Component: MED9.5.10       G00 9029
   Revision: 66H08---    Serial number: VWZ7Z0F4116953
   Coding: 0000072
   VCID: 74B121BE82B01517660-8020
001031 - EGR Sensor 2
               P0407 - 004 - Signal too Low
                    Mileage: 356806 km
                    Time: 19:33:53
                    Temperature: 35.0°C
Readiness: 1110 0101
   Revision: 00H11001
   Coding: 0002689
   VCID: 73B322A287BE122F7FA-8026
   Part No: 1K0 820 047 DQ
   Component: Climatic PQ35   090 0505
   VCID: 76B51BB694CC0707584-8022
Address 09: Cent. Elect.        Labels:. 3C0-937-049-23-M.lbl
   Part No SW: 3C0 937 049 P    HW: 3C0 937 049 P
   Revision: 00H46000    Serial number: 00000000352858
   Coding: 08078E2700041500470A00000F000000000959035C0000
   VCID: 3635DBB6D44C4707984-8062
   Subsystem 1 - Part No: 1K1 955 119 C  Labels: 1KX-955-119.CLB
   Component: Wischer VW350  013  0402
   Coding: 00063445
   Shop #: WSC 00066
   Component: 2J AIRBAG VW8   020 2300
   Revision: 05020000    Serial number: 0038PD0JBEU.
   Coding: 0012874
   VCID: 3D27C49AF17A945F59E-8068
   Subsystem 1 - Serial number: 6332MSME0E661B009
   Subsystem 2 - Serial number: 6342MSME0E0B33126
   Subsystem 3 - Serial number: 6351HSME096C6137B
   Subsystem 4 - Serial number: 6361HSME0960221B%
   Part No SW: 1K0 953 549 AP    HW: 1K0 953 549 AP
   Component: Lenksäulenmodul 636 0070
   Coding: 0000041
   VCID: 00597D6EC60839B7728-8054
   Part No SW: 1K0 920 863 A    HW: 1K0 920 863 A
   Component: KOMBIINSTRUMENT 3HL 1610
   Revision: V0003000    Serial number: VWZ7Z0F4116953
   Coding: 0023103
   Shop #: WSC 00011 888 06946
   VCID: 290F00CA15F218FF056-807C
   Part No SW: 1K0 907 530 H    HW: 1K0 907 951
   Component: J533__Gateway   H12 0150
   Revision:   H12       Serial number: 31001064140558
   Coding: 3D3F074007001002
   VCID: 2C01F9DE1A000DD7FE0-8078
   Component: IMMO            3HL 1610
   Part No SW: 1K0 959 701 Q    HW: 1K0 959 793 M
   Component: J386  TUER-SG FT    1125
   Revision: 11006001    Serial number: 00000006168601
   Coding: 0000180
   VCID: 3C21C99EEA609D576E0-8068
   Part No: 1K1 909 144 K
   VCID: 3333E2A2C73E522FBFA-8066
   Component:    KSG PQ35 G2  020 0202
   Coding: 00900A000106087F2D0484056008CF01E0FCA0
   Shop #: WSC 00020 210 01865
   VCID: 03537262D71E22AF6FA-8056
   Part No SW: 1K0 959 702 Q    HW: 1K0 959 792 M
   Component: J387  TUER-SG BT    1125
   Revision: 11006001    Serial number: 00000523268606
   Coding: 0000436
   Part No: 1K0 035 186 R
   Component: Radio GR0       019 0023
   Revision: 0001905S    Serial number: VWZ2Z2F1346091
   Coding: 0040400
   VCID: 3537DCBAC94A4C1F91E-8060
   Part No SW: 1K0 959 703 P    HW: 1K0 959 795 G
   Component: J388   TUER-SG HL   1115
   Revision: 11005001    Serial number: 00000000064349
   Coding: 0000144
   Part No SW: 1K0 959 704 P    HW: 1K0 959 794 G
   Component: J389   TUER-SG HR   1115
   Revision: 11005001    Serial number: 00000000062352
   Coding: 0000144
   VCID: 3E25C396FC7C8F47404-806A
Address 76: Park Assist        Labels: 1K0-919-283.lbl
   Part No: 1K0 919 283 A
   Component: 12 Einparkhilfe     0101
   VCID: 2D07F4DA211A04DFE9E-8078
End----(Elapsed Time: 01:13, VBatt start/end: 11.9V/11.9V. VIgn 11.8V)-----
So what to do next, thanks advance for any help :thumbs:
Is there any other chances than bad wiring or faulty valve, and how to measure the wirings?
zak69
C?ID=326872
Any ideas??? Thinking of checking that egr cable if looks ok, and then read codes again. And try to reset them, also from engine side if visible there.
zak69
C?ID=326872
I tried to clear fault code from engine module, but it always keep coming back.
Then i tried again egr adaptation and now it went through, weird.
After that i read codes and little different came from egr.....
   Coding: 0000072
               P0407 - 004 - Signal too Low - Intermittent
                    Mileage: 356806 km
                    Time: 15:58:27
                    Temperature: 6.0°C
   Revision: 00H11001
   Coding: 0002689
   Coding: 00063445
   Shop #: WSC 00066
   Coding: 0012874
   Coding: 0000041
   Coding: 0023103
   Coding: 0000180
   Coding: 0000436
   Coding: 0040400
   Coding: 0000144
   Coding: 0000144
End----(Elapsed Time: 01:11, VBatt start/end: 11.8V/11.8V. VIgn 11.7V)-----
I managed to clear all codes after that, and values from tba and egr was like this :
Address 01: Engine (03C 906 056 DP)
16:33:20 Group 074: Exhaust Gas Recirculation (EGR) Valve Alignment
0.780 V Potentiometer (G212) Zero Position
0.800 V Potentiometer (G212) Actual Position
ADP. O.K. Potentiometer (G212) Status
16:32:15 Group 060: Throttle Body Alignment
15.6 % Throttle Valve Sensor 1 (G187)
84.0 % Throttle Valve Sensor 2 (G188)
0 Throttle Adaptation Steps Counter
ADP. O.K. Throttle Body Alignment Status
After that i started car and let it run til normal temp. It run wobbling, and rpm was not steady.
Then i read the codes and this it :
   Coding: 0000072
Readiness: 1010 0101
   Revision: 00H11001
   Coding: 0002689
   Coding: 00063445
   Shop #: WSC 00066
   Coding: 0012874
   Coding: 0000041
   Coding: 0023103
   Coding: 0000180
   Coding: 0000436
   Coding: 0040400
   Coding: 0000144
   Coding: 0000144
End----------(Elapsed Time: 01:11, VBatt start/end: 12.6V/12.6V)-----------
So what next???
zak69
C?ID=326872
Any ideas what to do next? Is there still some wrong values or something in those two components?
HMC
C?ID=28246
Hi Zak 69,
"So, yesterday i changed the egr valve,". Genuine VAG EGR?
Regards HMC
zak69
C?ID=326872
Hi Zak 69,
Regards HMC
No, it was some stock?? part (sorry, don't know the right word) but looked serial number from real.oem and it's a right one for sure.
I've been also tryin to find values for those wirings so i can measure if they are ok.
HMC
C?ID=28246
Get a genuine one, aftermarket parts especially electronics, cannot be trusted now.
Regards HMC
zak69
C?ID=326872
Regards HMC
Maybe so.
Took a test drive while ago with different speed and rpm's, little uneven with cruisecontrol and when parking idle was really unstable.
Read the codes and nothing, so question is : shouldn't there be some codes if valve or wirings are faulty????
zak69
C?ID=326872
Car starts ok, but rpm's won't keep steady when giving throttle. So could it be some air leak or something, but still no codes when tested??
zak69
C?ID=326872
No sense at all in this.......next i'm gonna change that old egr back and see if it makes any difference. Hope so, and then i'm ready to admit that nothing else than original parts from here on.
zak69
C?ID=326872
So this is solved!! Faulty egr valve was that new one, funny and weird because vcds shows no incorrect data or values at any point. I put back the old one and runs like new, there was also steering assist, abs, tyre pressure and esp lights after that because of removing battery cable. All those went away after 300m drive.
Vag227
Europe
C?ID=205536
Hello, yes especially egr, air mass flow meter and lambda sensors on petrol cars, I would suggest to use original parts. Sometimes aftermarket make problem worse as it was with old defective part.
Best regards ,
John
zak69
C?ID=326872
Best regards ,
John
Now i have to agree that 100% :)
