No issues before last week.
First had ABS pulsing when coming to a stop around 20 mph one time and no lights or tones until next start.
Could initially clear codes and again next start same codes and tones. ABS, Stability program, Parking brake malfunction and TPMS.
Then could not clear codes and would come right back upon attempting to clear.
Tried to remove inspect and clean left front speed sensor and it was so stuck I broke it trying gently to remove it.
Replaced with a new OEM one (2) days ago, cleared the codes and now pulses again usually one very brief set of pulses around 20 MPH most of the time on dry pavement.
Today codes came back, I cleared and they are staying cleared so far with pulsing.
Could my toothed ring be the problem and the old sensor while stuck was fine? Or is the module now suspect?
Does the pulsing I am getting alone cause the implausible signal fault I am getting in my auto scan?
Any advice to further prove out anything or adaptation needed for the new sensor would be appreciated.
Thanks.
Original Auto Scan before replacing sensor had the same faults.
Latest Auto scan below:
Thanks.
Friday,04,November,2016,13:00:58:05068
VCDS Version: 16.8.3.1
VIN: WA1CFAFPXBA081666 License Plate:
Mileage: 89300km-55488mi Repair Order:
Chassis Type: FP (8T0)
Scan: 01 02 03 05 08 09 15 16 17 19 42 46 47 52 53 56 62 69 72 77
VIN: WA1CFAFPXBA081666 Mileage: 89300km-55488miles
Address 01: Engine (DL0MA-CAEB) Labels: 06H-907-115-CAB.clb
Part No SW: 8R0 907 115 H HW: 8K2 907 115 D
Component: 2.0l R4/4V TF H19 0003
Revision: E1H19---
Coding: 0121010A290F0960
Shop #: WSC 08315 444 11710
ASAM Dataset: EV_ECM20TFS0118R0907115H 001006
ROD: EV_ECM20TFS0118K2907115AD.rod
VCID: 39732959B84A5E8ABB-806C
U1113 00 [036] - -
Mileage: 89297 km
Date: 2016.11.04
Time: 12:46:12
Engine speed: 1023.00 /min
Normed load value: 9.0 %
Vehicle speed: 12 km/h
Coolant temperature: 60 °C
Intake air temperature: 32 °C
Voltage terminal 30: 13.287 V
U1113 00 [036] - -
Mileage: 89297 km
Date: 2016.11.04
Time: 12:46:12
Address 02: Auto Trans (J217) Labels: 0BK-927-156.clb
Part No SW: 8R0 927 158 E HW: 0BK 927 156 N
Component: 0BK 20TFSIUSA H08 0010
Revision: --H08---
Coding: 001112
Shop #: WSC 06335 000 00000
ASAM Dataset: EV_TCMAL551211 001013
ROD: EV_TCMAL551211_001.rod
VCID: 3F874741A66E70BA85-806A
13856 - Wheel-Speed Signal from ABS Control Module
P1887 00 [036] - Implausible Signal
Mileage: 89297 km
Date: 2016.11.04
Time: 12:46:15
Address 03: ABS Brakes (J104) Labels: 8R0-907-379-V1.clb
Part No SW: 8R0 907 379 H HW: 8R0 907 379 H
Component: ESP8 quattro H06 0110
Coding: 129D10
VCID: 458B55A9CCB22A6ACF-8010
00283 - ABS Wheel Speed Sensor; Front Left (G47)
003 - Mechanical Failure - Intermittent - MIL ON
Fault Status: 10100011
Reset counter: 14
Mileage: 89297 km
Date: 2016.11.04
Time: 12:46:12
Hex Value: 0x0C00
Hex Value: 0x4002
Hex Value: 0x1243
Hex Value: 0xA8A8
Hex Value: 0x00FF
013 - Check DTC Memory
Fault Status: 01101101
Reset counter: 230
Mileage: 89297 km
Date: 2016.11.04
Time: 12:46:13
Hex Value: 0x0B40
Hex Value: 0x4302
Hex Value: 0x1216
Hex Value: 0x02A8
Hex Value: 0x00FF
Part No SW: 8K0 907 064 CR HW: 8K0 907 064 CR
Component: BCM2 2.0 H05 0435
Coding: 090500
VCID: 02018EB59D1CDD52AA-8056
Subsystem 1 - Part No SW: 8T0 959 754 A HW: 8T0 959 754 A
Component: FBSAUDIB8 IDG H60 0072
Serial number: 0811000008524012
Component: J764 ELV MLB H37 0042
Serial number: 2310000105260015
Fault Status: 00101101
Reset counter: 14
Mileage: 89297 km
Date: 2016.11.04
Time: 12:46:17
Part No SW: 8T1 820 043 AQ HW: 8T1 820 043 AQ
Component: KLIMA 3 ZONEN H08 0180
Revision: C1000000 Serial number: 01070220111270
Coding: 64002000
Shop #: WSC 06335 123 12345
VCID: 000584BD9310CF42BC-8054
Address 09: Cent. Elect. (J519) Labels: 8K0-907-063.clb
Part No SW: 8K0 907 063 P HW: 8K0 907 063 P
Component: BCM1 1.0 H30 0392
Revision: 10030001 Serial number: 00000000937946
Coding: 6F0020F1013CA7010000090300007F7F4F1C660802000161000000
VCID: 3C7D304DBF786BA2A0-8068
Subsystem 1 - Part No SW: 8R1 955 119 A HW: 8R1 955 119 Labels: 1KX-955-119.CLB
Component: WWS416 110122 H11 0050
Serial number: 90243014110114023324
Coding: 01DD13
Component: RLS H04 0003
Serial number: 11262475
Coding: 024D25
Subsystem 3 - Part No SW: 8K0 941 531 AS HW: 8K0 941 531 AS
Component: E1 - LDS H03 0031
Serial number: 00000000000102110032
Subsystem 4 - Part No SW: 8K0 907 410 C HW: 8K0 907 410 C
Component: HOMELINK H01 0010
Reset counter: 15
Mileage: 89297 km
Date: 2016.11.04
Time: 12:46:00
Address 15: Airbags (J234) Labels: 8R0-959-655.clb
Part No SW: 8R0 959 655 F HW: 8R0 959 655 F
Component: AirbagVW-AU10 H44 0610
Serial number: 003GPD0N102/
Coding: 303633313432303030304A55304C38523053
ROD: EV_AirbaAU10SMEAU416.rod
VCID: 47975FA1FEBE387A3D-8012
Subsystem 1 - Part No SW: 8R0 959 339 A HW: 8R0 959 339 A
Component: BF-Gewichtss. H02 0040
Serial number: 5810000R1100003Q67
Serial number: 6334MSME5B160A70D
Serial number: 6344MSME5B326267G
Serial number: 6352QSME3C065460D
Serial number: 6362QSME4701275EI
Serial number: 63732SME3E04036E0
Serial number: 63832SME6D0834461
Address 16: Steering wheel (J527) Labels: 8K0-953-568.clb
Component: Lenks.Modul H17 0014
Revision: -------- Serial number: 90372KAV00070
Coding: 000017
VCID: 3D7B3D49A46262AA97-8068
Component: E221 - MFL H04 0010
Reset counter: 14
Mileage: 89297 km
Date: 2016.11.04
Time: 12:46:12
Address 17: Instruments (J285) Labels: 8R0-920-xxx-17.clb
Part No SW: 8R0 920 950 K HW: 8R0 920 950 K
Component: KOMBIINSTR. H12 0258
Revision: 00000000 Serial number: EJU309Z1C
Coding: 8B1F22000300D705020000
VCID: 3E793A45A96479B28E-806A
Address 19: CAN Gateway (J533) Labels: 8T0-907-468.clb
Part No SW: 8T0 907 468 AB HW: 8T0 907 468 H
Component: GW-BEM 5CAN H06 0117
Revision: GB800053 Serial number: 5300G111298558
Coding: 00C303
VCID: 010381B9981AC64AB3-8054
Subsystem 1 - Part No SW: 8R0 915 181 HW: 8R0 915 181
Component: J367-BDM H07 0140
Serial number: 00000000005650447274
Address 42: Door Elect, Driver (J386) Labels: 8K0-959-793.clb
Part No SW: 8K0 959 793 M HW: 8K0 959 793 M
Component: TSG FA H12 0357
Revision: Serial number: 0000012178471
Coding: 011D03204000440004
VCID: 4A916695E5ACC51222-801E
Address 46: Central Conv. (J393) Labels: 8K0-907-064-46.clb
Revision: 00002001 Serial number: 0142687706
Coding: 0126063A20FA440084B0053200000000
Subsystem 1 - Part No SW: 8K0 959 719 B HW: 8K0 959 719
Component: GTO BF H01 0070
Serial number: 00000000000000355928
Reset counter: 14
Mileage: 89297 km
Date: 2016.11.04
Time: 12:46:17
Address 47: Sound System (J525) Labels: 8T0-035-223-ASC.clb
Part No SW: 8R0 035 223 F HW: 8R0 035 223 E
Component: DSP STD H11 0440
Revision: 00000000 Serial number: 00000000000001
Coding: 0203010102
VCID: 2F6717017E0E803A15-807A
Address 52: Door Elect, Pass. (J387) Labels: 8K0-959-792.clb
Part No SW: 8K0 959 792 M HW: 8K0 959 792 M
Component: TSG BF H12 0357
Revision: Serial number: 0004000216836
VCID: 49935999E0AACE0A2B-801C
Part No SW: 8K0 907 801 H HW: 8K0 907 801 H
Component: EPB Audi B8 H09 0100
Revision: 00000003 Serial number: 00000000857977
VCID: 346D186D9728A3E268-8060
Reset counter: 14
Mileage: 89297 km
Date: 2016.11.04
Time: 12:46:13
Voltage: 13.40 V
Count: 62
Speed: 10.0 km/h
Hex Value: 0x02E0
Hex Value: 0x0004
Hex Value: 0x0101
Address 56: Radio (J503) Labels: 8Tx-035-1xx-56.clb
Part No SW: 8T1 035 186 R HW: 8T1 035 186 R
Component: Con3 Sirius H06 0351
Revision: 00000009 Serial number: AUZ5Z6K1528606
Coding: 0502000201058500C359070000
VCID: 468952A5F1B42172C6-8012
Subsystem 1 - Part No SW: 8T0 919 603 F HW: 8T0 919 603 F
Component: Display
Address 62: Door, Rear Left (J388) Labels: 8K0-959-795.clb
Part No SW: 8K0 959 795 F HW: 8K0 959 795 F
Component: TSG HL H11 0357
Revision: Serial number: 0000112754547
Coding: 010C03204000240004
Address 69: Trailer (J345) Labels: 8K0-907-383.clb
Part No SW: 8K0 907 383 E HW: 8K0 907 383 E
Component: Anhaenger H07 0070
Revision: 1A001001 Serial number: 00000124854806
Coding: 0200000000000000
VCID: 366922658154B1F256-8062
Address 72: Door, Rear Right (J389) Labels: 8K0-959-795.clb
Component: TSG HR H11 0357
Revision: Serial number: 0000112754548
Part No SW: 8T0 862 336 E HW: 8T0 862 336 E
Component: FSE_256x BT H42 0650
Revision: 00000000 Serial number: 00000005108703
Coding: 0010370
VCID: 3D7B3D49646262AA97-8068
End-------------------------(Elapsed Time: 03:17)--------------------------
