VW Transporter T6, Address 18 Aux.Heat --- Adaptation FAIL
VWT6
C?ID=295527
Adaptations fail on Module 18, Aux. Heater. (Webasto Thermo Top Evo)
As per "screenshots" below.
Module accepts security code 20103 (verified that doesn't accept "wrong" code).
Tried a few different adaptation channels with same results.
Tried adaptation value above and below set value to eliminate hitting possibly min/max limit.
Tried also on another similar van with same results. :banghead:
Messages from VCDS (pop-up windows):
Security Access - 16
| Security access sucessful
| Security access accepted!
| OK
Adaptation.. select adaptation channel...
| VCDS
| Old value
| 5.0 C
| New value
| 4.0 C
| Replace?
| Yes No
| ERROR
| Invalid message length or invalid format
| OK
Any ideas, anything I can provide? :confused:
Auto-Scan attached.
Wednesday,11,April,2018,14:18:26:38894
VCDS Version: 18.2.0.3 (x64)  HEX-V2 CB: 0.4417.4
VIN: WV1ZZZ7HZJH14xxxx   License Plate:
Chassis Type: 7H-VN75 (7E0)
Scan: 01 02 03 04 08 09 10 13 15 17 18 19 20 22 25 55 5F 61 69 6E
          0B
VIN: WV1ZZZ7HZJH14xxxx   Mileage: 0km-0miles
6E-Ctrl Head Roof -- Status: OK 0000
Address 01: Engine (2D2D2-CXEB)       Labels:. 04L-907-309-V2.clb
   Part No SW: 04L 906 056 KN    HW: 04L 907 445 A
   Component: R4 2.0l BTD   H03 3776
   Revision: 23101001
   Coding: 0025401C437601080000
   Shop #: WSC 02762 790 50316
   ASAM Dataset: EV_ECM20BTD03004L906056KN 004004
   ROD: EV_ECM20BTD03004L906056KN_004.rod
   VCID: 035085BD1B9C66FF6FA-8056
Readiness: N/A
   Part No SW: 0BT 300 012 C    HW: 0BH 927 711 G
   Component: DSG DQ500-7A  H11 5302
   Revision: 00H11V01
   ROD: EV_TCMDQ500021_VW36.rod
   VCID: 2F38190DE794329FDB2-807A
Address 03: ABS Brakes (J104)       Labels:. 7E0-907-37x-MK100ESC.clb
   Part No SW: 7E0 907 379 Q    HW: 7E0 907 379 N
   Component: ESC           H06 0133
   Revision: 00000000    Serial number: 60508000001018
   Coding: 557EC09865668682AA7C0379A684619678F700
   ROD: EV_Brake1ESCCONTIVN75XGP2_011.rod
   VCID: 40DA4AB14A0ABDE7328-8014
   Component: LENKW.SENSOR  H07 0070
   Serial number: 24021813471358
   Coding: 01
   ROD: EV_LWSKLOVW25X.rod
   VCID: 7EA6F449707E0B17004-802A
Address 08: Auto HVAC (J301)       Labels:| 7E5-907-047.clb
   Part No SW: 7E0 907 047 AC    HW: 7E0 907 047 AC
   Component: Climatic-T5   H22 0708
   Revision: 00001002
   Coding: 0000000003
   ROD: EV_ClimaT5Basis.rod
   VCID: 6B80CD1D130C8EBFB7A-803E
Address 09: Cent. Elect. (J519)       Labels:. 7E0-937-BCM-V1.clb
   Part No SW: 7E0 937 090 C    HW: 7E0 937 090 C
   Component: BCM PQ25 Max4 H82 0752
   Revision: B9082001    Serial number: 4000 049181011
   Coding: A0A8393A0A61341393284F402CEB8FF4C0947389604579603304003F0860
   Shop #: WSC 02762 022 681950
   VCID: 2B000D1DD30C4EBFF7A-807E
   Subsystem 1 - Part No: 5K7 955 559 C  Labels: 5K7-955-559.CLB
   Component: RLS 020318 04  47  0106
   Coding: 0228EE
   Subsystem 2 - Part No SW: 7E0 959 801 M    HW: 7E0 959 801 M
   Component: J386__TSG_FT  004 0653
   Serial number: KU0KU026021880570604
   Coding: 0400A0
   Subsystem 3 - Part No SW: 7E0 959 802 M    HW: 7E0 959 802 M
   Component: J387__TSG_BT  004 0653
   Serial number: KU0KU005031880640028
   Coding: 1400A0
   Subsystem 4 - Part No: 7E1 951 172
   Subsystem 5 - Part No: 1K0 951 605 F
   Component: LIN BACKUP HO  H01 0008
   Subsystem 6 - Part No: 7E1 951 172
   Subsystem 7 - Part No SW: 7E0 959 442 A    HW: 7E0 959 442 A  Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H02 0103
   Serial number: 39180000194210038075
   Coding: B5FFFF
Address 10: Park/Steer Assist (J446)       Labels:| 7E0-919-475.clb
   Part No SW: 7E0 919 475 AA    HW: 7N0 919 475
   Component: PARKHILFE 8K  H06 0212
   Revision: --------    Serial number: 28261802500414
   Coding: 31810C
   ASAM Dataset: EV_VW75XParkAssis8K 001012
   ROD: EV_VW75XParkAssis8K_001_VN75.rod
   VCID: 71BCDF753120646F8D6-8024
Address 13: Auto Dist. Reg (J428)       Labels:| 7N0-907-572.clb
   Part No SW: 7N0 907 572 C    HW: 7E0 907 572
   Component: ACC Bosch PQx H03 0211
   Serial number: 1702180442A533
   Coding: 00005800FE0779
   Shop #: WSC 01383 790 50316
   ASAM Dataset: EV_ACCBEGVW361 001006
   ROD: EV_ACCBEGVW361_VW32.rod
   VCID: 36362C6918CE0357984-8062
   Part No SW: 7E0 959 655 K    HW: 7E0 959 655 K
   Component: VW10Airbag01R 010 0018
   Revision: --------    Serial number: 003EM000CMPC
   Coding: 000000000000000000000000000000003152
   Shop #: WSC 02164 790 50316
   ASAM Dataset: EV_AirbaVW10BPAVW12X 001028
   VCID: 3E26344930FECB17404-806A
   Serial number: 3495ZRB400S5BOJEK1HM
   Serial number: 3505ZRB404R556M48O6T
   Part No SW: 7E0 920 870 S    HW: 7E0 920 870 S
   Component: KOMBI         H03 1107
   Coding: 140F010300
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A05733
   VCID: 392C275529D0EC2F756-806C
Address 18: Aux. Heat (J364)       Labels:| 7E0-963-27X-18.clb
   Part No SW: 7E0 963 272 B    HW: 7E0 963 272 B
   Component: STH-T5GP2     003 0009
   Coding: 5901
   Shop #: WSC 28624 002 1048576
   ASAM Dataset: EV_AuxilParkiHeateWOST5G2 001013
   ROD: EV_AuxilParkiHeateWOST5G2.rod
   VCID: 2B000D1DD38C4EBFF7A-807E
   Component: R64 D208L  004 0402
   Serial number: 00000000000000399683
Address 19: CAN Gateway (J533)       Labels:. 7E0-909-901.clb
   Part No SW: 7E0 909 901     HW: 7E0 937 090 C
   Component: GW-K-CAN TP20 H82 0752
   Revision: B9082001
   Coding: 042207
   VCID: 688AB211027AA5A7DA8-803C
Address 20: High Beam Assist. (J844)       Labels:| 8S0-857-511.clb
   Part No SW: 7E0 857 511 F    HW: 7E0 857 511 C
   Component: FLA           H10 0003
   Revision: AA001001
   Coding: 040400E200000000000000
   ASAM Dataset: EV_HighBeamAssisAU316 001004
   ROD: EV_HighBeamAssisAU316.rod
   VCID: 2D040305ED98408FE9E-8078
   Part No SW: 0AY 907 554 L    HW: 0CQ 525 130 A
   Component: Haldex4Motion H53 7620
   Serial number: HA1-00023.01.18
   Coding: 0505
   VCID: 54F276E1AE723147860-8000
   Component: IMMO          H03 1107
   VCID: 6A8EC8191CF697B7CCC-803E
Address 55: Headlight Range (J431)       Labels:. 6R0-907-357.clb
   Part No SW: 6R0 907 357 C    HW: 6R0 907 357 B
   Component: AFS-ECU       005 0050
   Coding: 0FCA020001000000
   Shop #: WSC 02748 790 50316
   ASAM Dataset: EV_HeadlRegulVWLWRCC 002006
   ROD: EV_HeadlRegulVWLWRCC.rod
   VCID: 3A2E38592CD6E7377CC-806E
   Part No SW: 5C0 035 680 F    HW: 5C0 035 680 F
   Component: MU-S-N-ER     H41 0468
   Serial number: VWZAZ2U0642180
   Coding: 065700013C00000011110001000808001F0100D4002001004F
   ROD: EV_MUStd4CTSAT_VW27.rod
   VCID: 2412E621BE5281C7360-8070
   Part No SW: 7E0 907 534     HW: 7E0 937 090 C
   Component: Batt.regelung H82 0752
   Coding: 330B1A73
   Shop #: WSC 02762 790 00000
   Subsystem 1 - Part No SW: 7E0 915 181 K    HW: 7E0 915 181 K
   Serial number: 7588570000180225037D
   Part No SW: 1K0 907 383 H    HW: 1K0 907 383 G
   Component: Anhaenger     H12 0130
   Revision: 3B001001    Serial number: 00000471905037
   Coding: 410D000103000000
   VCID: 323E1079F4261F77B4C-8066
Address 6E: Ctrl Head Roof (J702)       Labels:. 7E5-919-037-W2.clb
   Part No SW: 7E5 919 037 J    HW: 7E5 919 037 J
   Component: Dachdisplay   H17 0200
   Revision: 1010013S    Serial number: 537494
   Coding: 000103
   Shop #: WSC 02759 790 00000
   VCID: 382A2251125AF5278A8-806C
End----------(Elapsed Time: 02:06, VBatt start/end: 12.3V/12.2V)-----------
Hmm, CB: 0.4417. Please update that to the current one on the Beta Channel, 0.4422.
If it behaves the same way, I'm going to suppose Eric will want Debug files.
VWT6
C?ID=295527
Thanks for prompt response. Updated the HEX-V2, it's now at 0.4422. The behaviour is still the same :(.
In addition to the earlier exited from VCDS, turned ignition off, wait, ignition on, restarted the VCDS, module 18, but did NOT log into module with the security code, and the ERROR message is still the same.
I did separate recordings from both cases above using debug 1024, and emailed them to support@ross-tech.com :popcorn:
Dana
Western PA, USA
Thanks for the files. We will either reply to that email or report back in this thread if we need any additional information or testing.
VWT6
C?ID=295527
Bumping up an old challenge + adding a new strangeness of same module.
When I tick manually all the measurements as in the picture, I can save the measurement values then into a log file as expected.
And saving selection of those 12 into a file works fine, all of them are in there (xxxx.u18, attached).
But reloading the xxxx.u18 file results missing the boxed ones - I need to manually tick them again to get the readings.
GO1Vc5W
The problem being - even though the boxed values are in the xxxx.u18 they just don't get ticked when the setup is reloaded. Not a high priority thing, just letting you know. The autoscan as earlier above.
IDE00025
IDE00310-MAS05093
IDE00588
IDE01263
IDE01834
IDE06625-IDE00371
IDE06625-MAS05018
IDE06625-MAS05019
IDE06625-MAS05020
IDE06625-MAS05021
IDE06625
IDE06625
Eric
HC800000
Interesting case. It's not often that we see multiple IDExxxxx with the same xxxxx like that, compounded with IDExxxxx-MASyyyyy.
VCDS was (re)applying the IDE06625s to your previous IDE06625-MASyyyyy selections. It would even have applied them to an IDE06625-MASyyyyy you hadn't saved.
I've fixed it, but understand VCDS still won't be able to make a difference between IDE06625 and IDE06625 :) So if you have both saved, it will select both, but if you have only one saved, no matter whether first IDE06625 or second IDE06625, it will always select the first one.
VWT6
C?ID=295527
Thank you very much for your prompt response. And yes, I do understand the challenge to differentiate the two IDE06625's from each other :D.
Anyways, still on my wishlist is the capability to log more than "only" 12 measurement values. The speed of the HEX-V2 would definitely allow meaningful data collection even then ;)
Thanks again.
Eric
HC800000
For the original issue... it looks like the control module is sending one more byte in the adaptation value (during the read) than it expects to receive (during the write, based on our UDS data). VCDS always sends back the same number of bytes it originally read from the module, just modifying the ones relevant to the changes made by the user. I am note sure how confident I would be in modifying that behavior without having that module to test ODIS on.
VWT6
C?ID=295527
I see... let me know if there is something I could try. Any use if a VW garage would try the same just to see if their tool can handle this?
Anyways, at the moment no real need to tweak the heater.
Thanks again.
VWT6
C?ID=295527
The fix - verified now. Beta 19.1 + CB:0.4502. Thanks again.
VWT6
C?ID=295527
More details sent to Support@Ross-Tech.com
VWT6
C?ID=295527
Here is another piece to the original challenge:
(1) Adaptation of channel “IDE06688-Auxil. heater activation” was accepted.
(2) However, the original example to adapt channel “IDE06690-MAS05059-Auxil. heat control parameters-Lower temperature threshold: ambient temperature” still failed as described on first post.​
VCDS Version: 19.6.2.0 (x64) HEX-V2 CB: 0.4513.4 Data version: 20190930 DS308.0​
Meanwhile, how to unlock this heater?
Haven’t happened yet but would be nice to be prepared… Seems that the method described in http://wiki.ross-tech.com/wiki/index.php/02251 is not available.​
Adaptation map attached.
;SW:7E0-963-272-B   HW:7E0-963-272-B ---  Aux. Heat
;Component:STH-T5GP2     003 0009	 Coding:5801
;EV_AuxilParkiHeateWOST5G2	1013	EV_AuxilParkiHeateWOST5G2.rod
;Monday	23	December
;VCDS Version: Release 19.6.2 (x64)  Data version: 20190930 DS308.0
;VCID: 2B000D1DD38C4EBF4C5-807E
IDE00470-Initial fuel filling	Yes 	1
IDE06640-MAS01167-Transfer fuel pump-Actuation time	20 s	5
IDE06640-MAS05078-Transfer fuel pump-Minimum tank level	0 l	5
IDE06640-MAS05079-Transfer fuel pump-Fuel reserve amount	200 ml	5
IDE06640-MAS05080-Transfer fuel pump-Maximum standing time	0.0 H	5
IDE06640-MAS05689-Transfer fuel pump-Activation delay	10 s	5
IDE06642-MAS05071-Coolant change-over valve-Temperature difference: engine/parking heater	5 °C	4
IDE06642-MAS05072-Coolant change-over valve-Maximum engine rpm	2500 /min	4
IDE06642-MAS05073-Coolant change-over valve-Residual heat: threshold	55 °C	4
IDE06642-MAS05074-Coolant change-over valve-Note engine rpm	No 	4
IDE06686-Insufficient voltage threshold	11.3 V	1
IDE06687-CO2 adjustment	185	1
IDE06688-Auxil. heater activation	active 	1
IDE06689-Low voltage detection: time limit	20.0 s	1
IDE06690-MAS05059-Auxil. heat control parameters-Lower temperature threshold: ambient temperature	5.0 °C	11
IDE06690-MAS05060-Auxil. heat control parameters-Upper temperature threshold: ambient temperature	10.0 °C	11
IDE06690-MAS05062-Auxil. heat control parameters-Lower temperature threshold: coolant temperature via CAN	72 °C	11
IDE06690-MAS05063-Auxil. heat control parameters-Upper temperature threshold: coolant temperature via CAN	88 °C	11
IDE06690-MAS05064-Auxil. heat control parameters-Lower temperature threshold for partial load after full load	75 °C	11
IDE06690-MAS05065-Auxil. heat control parameters-Lower temperature threshold for starting from control pause	76 °C	11
IDE06690-MAS05066-Auxil. heat control parameters-Upper temperature threshold for full load after partial load	80 °C	11
IDE06690-MAS05067-Auxil. heat control parameters-Upper temperature threshold for control pause	86 °C	11
IDE06690-MAS05068-Auxil. heat control parameters-Temperature threshold for control mode	78 °C	11
IDE06691-MAS05064-Parking heat control parameters-Lower temperature threshold for partial load after full load	60 °C	7
IDE06691-MAS05065-Parking heat control parameters-Lower temperature threshold for starting from control pause	64 °C	7
IDE06691-MAS05066-Parking heat control parameters-Upper temperature threshold for full load after partial load	80 °C	7
IDE06691-MAS05067-Parking heat control parameters-Upper temperature threshold for control pause	86 °C	7
IDE06691-MAS05068-Parking heat control parameters-Temperature threshold for control mode	80 °C	7
IDE06691-MAS05069-Parking heat control parameters-Temperature threshold for activation of fresh air blower	45 °C	7
IDE06691-MAS05070-Parking heat control parameters-Control behavior	Continuous 	7
IDE06692-Note request for aux. heater from A/C system	Do not ignore 	1
IDE06693-Evaluate air pressure via CAN	Yes 	1
IDE06694-MAS05076-Minimum burn time-Time	160 s	2
IDE06694-MAS05077-Minimum burn time-Temperature threshold offset	1 °C	2
IDE07160-MAS04357-Control module switch-off: switch-off time-Time 1	140 min	2
IDE07160-MAS04358-Control module switch-off: switch-off time-Time 2	20 min	2
IDE11873-MAS13407-Extended pump activation-Outside temperature below limiting value	15.0 °C	4
IDE11873-MAS13408-Extended pump activation-Outside temperature above limiting value	17.0 °C	4
IDE11873-MAS13409-Extended pump activation-Engine temperature lower limiting value	35 °C	4
IDE11873-MAS13410-Extended pump activation-Engine temperature upper limiting value	30 °C	4
MAS01488-recirc. pump	12750 /min	1
MAS05075-Evaluate ethanol content	No 	1
MAS09096-Recirc. pump locking mechan.	1	1
ENG119729-activacion_of_simulated_flamme_run_for_emv_measuring	No 	1
ENG119721-development_data_on_CAN	not active 	1
Elapsed Time: 00:05
Mika_M
C?ID=183725
For unlocking, maybe there is something in basic settings? Like in MQB cars, where basic setting "Disengaging heater" is used to unlock heater.
VWT6
C?ID=295527
Thanks, there indeed is the selection "Disengaging heater" available. Definitely will try if/when it gets locked.
