I have replaced my injectors with new ones. The new ones idle rough anywhere below 850 RPM. Any RPM above that is OEM smooth.
How can I do the injector coding, or the calibration myself using VCDS?
Tuesday,14,January,2020,20:37:24:39976VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 19.6.2.0 (x64)
Dealer/Shop Name: Matthew Taylor
VIN: WVWZZZ1KZ8W111078 License Plate:
Chassis Type: 1K-VW35 (7N0)
Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 55 56 77
VIN: WVWZZZ1KZ8W111078 Mileage: 189770km-117917miles
77-Telephone -- Status: Sporadic communication error 1000
Address 01: Engine Labels:. 06F-907-115-AXX.clb
Part No SW: 1K0 907 115 R HW: 8P0 907 115 B
Component: 2.0l R4/4V TFSI 0020
Revision: 5BH16--- Serial number: VWX7Z0G83NA8OV
Coding: 040300101C070160
Shop #: WSC 66565 257 00032
VCID: 354FD8585CDD5EE744-8060
000054 - Oxygen (Lambda) Sensor B1 S2: Heating Circuit
P0036 - 004 - Malfunction / Open Circuit
Mileage: 189756 km
Time: 08:06:36
RPM: 835 /min
Load: 25.9 %
Temperature: 91.0°C
Temperature: 66.0°C
Absolute Pres.: 1000.0 mbar
Voltage: 13.462 V
Readiness: 0110 0001
Part No SW: 02E 300 044 J HW: 02E 927 770 AD
Component: GSG DSG 082 1407
Revision: 05108020 Serial number: 00001009061622
Shop #: WSC 04940 001 00001
VCID: 1C192DFCDF37EFAF5B-8048
Part No SW: 1K0 907 379 AC HW: 1K0 907 379 AC
Revision: 00H11001
Coding: 0004738
VCID: 73CB2640122900D7AA-8026
Part No SW: 5K0 907 044 ES HW: 5K0 907 044 ES
Component: Climatronic H18 1112
Revision: 00001004
Coding: 0000014002
Shop #: WSC 12345 123 61029
VCID: 0021798C9B9F2B4FA7-8054
U1111 00 [009] - -
Reset counter: 207
Mileage: 189756 km
Time: 08:06:28
9479189 - Signal Line for Air Quality Sensor
B10A4 15 [009] - Open or Short to Plus
Reset counter: 207
Mileage: 189756 km
Time: 08:06:28
Revision: 00H54000 Serial number: 01000007456322
Coding: F78F8B270004800047140A001400008000197E075C00010C000000000000
VCID: 71C72C48683532C758-8024
Subsystem 1 - Part No: 1K2 955 119 E Labels: 1KX-955-119.CLB
Component: Wischer 300807 021 0501
Coding: 00039861
Shop #: WSC 12345
Subsystem 2 - Part No: 1K0 955 559 AF Labels: 1K0-955-559-AF.CLB
Component: RLS 130907 046 0204
Coding: 00208933
Shop #: WSC 12345
01502 - Bulb for Rear Fog; Left (L46)
Reset counter: 207
Mileage: 189766 km
Date: 2005.09.13
Time: 31:63:63
Voltage: 13.25 V
Part No SW: 1K0 909 605 T HW: 1K0 909 605 T
Component: 3A AIRBAG VW8 020 2300
Revision: 05020000 Serial number: 0038PD1FKU0T
Coding: 0013121
Shop #: WSC 01269 785 00200
VCID: 3D5FC07864ED86A78C-8068
Subsystem 1 - Serial number: 6332MSME2C406B29H
Subsystem 2 - Serial number: 6342MSME2C42223ED
Subsystem 3 - Serial number: 6352QSME3D213635D
Subsystem 4 - Serial number: 6362QSME3C0B0C41L
00655 - Seat Belt Tensioner Igniter; Passenger Side (N154)
01228 - Airbag Cut-Off Switch for Passenger Side (E224)
02756 - Redundant signal path of Airbag cut-off switch - front passenger side (E224)
00589 - Airbag Igniter 1; Passenger Side (N131)
Part No SW: 1K0 953 549 AQ HW: 1K0 953 549 AQ
Component: J0527 036 0070
Coding: 0012122
VCID: 01277C8858952247A8-8054
Component: E0221 002 0010
Part No SW: 1K6 920 974 HW: 1K6 920 974
Component: KOMBIINSTRUMENT VDD 1216
Revision: V0002000 Serial number: VWX7Z0G83NA8OV
Coding: 0006103
Part No SW: 7N0 907 530 M HW: 1K0 907 951
Component: J533 Gateway H42 1623
Revision: H42 Serial number: 030312F2002329
Coding: 350001
VCID: 3A55CB64B5C3B19FA9-806E
Reset counter: 247
Mileage: 189767 km
Time: 08:50:27
Component: IMMO VDD 1216
Part No SW: 1K0 959 701 M HW: 1K0 959 701 M
Component: Tuer-SG 006 120B
Coding: 0000564
Shop #: WSC 11111 111 45799
VCID: 3851D16C4BCFA38F5F-806C
00912 - Window Regulator Switch; Front Left (E40)
00109 - Left Mirror Turn Signal Lamp (L131)
Part No: 1K0 909 144 P
Component: EPS_ZFLS Kl. 207 3305
Revision: 00H22000
Shop #: WSC 00028 028 00001
VCID: 3753D25046D1ACF756-8062
Part No SW: 1K0 959 433 BT HW: 1K0 959 433 BT
Component: KSG PQ35 G2 020 0204
Revision: 00020000 Serial number: 00000000000000
Coding: 98900A085103007F42040F0FF00A5A0690BC00
VCID: 032B768042893057BA-8056
01134 - Alarm Horn (H12)
Reset counter: 206
Mileage: 189756 km
Time: 08:06:37
Part No SW: 1K0 959 702 M HW: 1K0 959 702 M
Coding: 0000564
VCID: 3957D46870C5BA87A0-806C
Address 55: Headlight Range Labels: 1T0-907-357.lbl
Part No: 1T0 907 357
Component: Dynamische LWR 0003
Coding: 0000003
Shop #: WSC 00000 785 00200
VCID: 74C9255C172707EFB3-8020
Part No SW: 1K0 035 180 AE HW: 1K0 035 180 AE
Component: Radio Prem-8 H02 0016
Revision: -----16S Serial number: VWZ4Z7L3180243
Coding: 01000401000005
VCID: 63EB560062C99057DA-8036
Reset counter: 206
Mileage: 189756 km
Time: 08:06:39
02633 - Antenna for Satellite Tuner
Reset counter: 206
Mileage: 189756 km
Time: 08:06:39
Reset counter: 206
Mileage: 189756 km
Time: 08:06:39
Address 77: Telephone
End-------------------------(Elapsed Time: 01:21)--------------------------
