Memory function start/stop system MLBevo (Audi A6 2019)
X-iT
C?ID=369786
Hi Guys,
I'm trying to figure out how to activate the memory function for the start/stop system of a brand new car (Audi A6 2019) which is on the MLBevo platform.
I would like the car to remember the start/stop setting so when it's switched off it stays off, also the next day.
I read numerous posts about this topic for the older platform but don't know it's already possible/discovered with VCDS. I did use the latest beta as the support for 2019 vehicles has been improved.
Can you guys help?
Below is the autoscan (there are some fault codes I need to investigate too)
Wednesday,15,May,2019,11:17:44:03600
VCDS Version: 19.4.0.0 (x64)  HEX-V2 CB: 0.4504.4
Data version: 20190411 DS307.0
VIN: WAUZZZF22KN077918   License Plate:
Mileage: 3370km   Repair Order:
Chassis Type: F2-AU58 (4N1)
Scan: 01 02 03 09 15 16 17 19 22 36 42 44 46 47 52 5F 6D 80 81 A5
          BB BC D6 D7
VIN: WAUZZZF22KN077918   Mileage: 3370km-2094miles
80-Batt. reg. aux. accum. -- Status: OK 0000
Address 01: Engine (J623-DKNA)       Labels: None
   Part No SW: 4K0 906 259     HW: 06L 907 425 C
   Component: R4 2.0l TFSI  H15 0003
   Revision: --H15---
   Coding: 126540322326050B34082000000400000000000000000000
   ASAM Dataset: EV_ECM20TFS0204K0906259 001005
   ROD: EV_ECM20TFS0204K0906259.rod
   VCID: 6E843A9F2017E4775D7-803A
33322 - Camera control module
          U107A 00 [032] - No communication
                    Mileage: 2321 km
                    Date: 2019.05.02
                    Time: 13:30:27
                    Engine speed: 1195.75 /min
                    Normed load value: 34.9 %
                    Vehicle speed: 12 km/h
                    Coolant temperature: 96 ∞C
                    Intake air temperature: 29 ∞C
                    Voltage terminal 30: 13.632 V
                    Unlearning counter according OBD: 17
                    LF_MVB_PDU_INTC_DIAG_8: 53248
                    LF_MVB_PDU_INTC_DIAG_9: 967
                    LF_MVB_PDU_INTC_DIAG_10: 64528
                    LF_MVB_PDU_INTC_DIAG_11: 0
                    LF_MVB_PDU_INTC_DIAG_13: 12288
                    LF_MVB_BUS_INTC_DIAG: 256
Address 02: Auto Trans (J217)       Labels:* None
   Part No SW: 4K0 927 153 F    HW: 0HK 927 156 B
   Component: 0CJ 20TFSIRdW H01 0004
   Revision: --H01---    Serial number: 0000001758
   Coding: 000001
   ASAM Dataset: EV_TCMDL382021 002031
   ROD: EV_TCMDL382021_AU58.rod
   VCID: 3038E4E7FAA3B2870FB-8064
   Subsystem 1 - Part No SW: 0CK 927 152 AA    HW: 0CK 321 281 L
   Component: V553 MTFP  003 0576
   Serial number: 75145041180325000153
   Part No SW: 4K0 907 379 P    HW: 4K0 907 379 A
   Component: ESP9 Plus     H06 0854
   Coding: 14AA41972CA90A9D11A74892208552D2F5B9C0288234508812044A4BAF9D03
   ASAM Dataset: EV_ESP9BOSCHCMP 004011
   ROD: EV_ESP9BOSCHCMP_004_AU65.rod
   VCID: 42DCBE2F440F3017E9F-8016
   Part No SW: 4N0 907 063 GG    HW: 4N0 907 063 AG
   Component: BCM1 MLBevo   H10 0653
   Coding: 07000143C13900DD0704870898AF8C68130B3310000600970101080039321C810A450A324256010800000100000100180000000000010100000000000000000000
   ASAM Dataset: EV_BCM1BOSCHAU651 014010
   ROD: EV_BCM1BOSCHAU651_014.rod
   VCID: 79AE19C36959B3CFF85-802C
   Subsystem 1 - Part No SW: 4K1 955 119     HW: 4K1 955 119
   Component: J400FRWISCH  063 0740
   Serial number: 00000001811230401432
   Coding: 7DC727
   Serial number: 22363663X81A955555A0
   Coding: 02006E
   Light switch:
   Subsystem 3 - Part No SW: 4K1 941 501     HW: 4K1 941 501
   Component: E1 - LTM  H05 0053
   Serial number: 16S12.01.1900302189
   Subsystem 4 - Part No SW: 8W0 857 511     HW: 8W0 857 511
   Serial number: GX1CE130101823811046
   Interior Light Module:
   Subsystem 5 - Part No SW: 4K0 947 135 B    HW: 4K0 947 135 B
   Component: Dachmodul  H42 0413
   Serial number: C00167670
   Coding: 0D0104
65826 - Comfort System CAN Bus (SAE Medium Speed Bus)
          U0011 00 [008] - Performance
          [Comfort data bus: No communication]
                    Fault Frequency: 40
                    Reset counter: 104
                    Mileage: 15 km
                    Date: 2019.03.16
                    Time: 09:03:04
                    average_Voltage_terminals: 11.90 V
                    Outside air temperature sensor-Resistance: 0.00 kOhm
                    Outside air temperature sensor-Outside air temperature on CAN: 11.50 ∞C
                    interior_temperature: 8.50 ∞C
                    Vehicle speed: 0.00 km/h
                    Terminal control-Terminal 75 status: OFF
                    Terminal control-Terminal 15 status signal: OFF
                    Terminal control-Terminal 15 via CAN: OFF
65828 - Databus
          [Comfort system central control module: no signal/communication]
                    Fault Frequency: 57
                    Reset counter: 104
                    Mileage: 15 km
                    Date: 2019.03.16
                    Time: 09:03:01
   Part No SW: 4N0 959 655 Q    HW: 4N0 959 655 Q
   Component: AirbagVW31    H09 2720
   Serial number: 003YZM02BA1W
   Coding: AACCF0C00CC00000985400FFF00D40AC00C5
   ASAM Dataset: EV_AirbaVW31SMEAU65x 001032
   ROD: EV_AirbaVW31SMEAU65x_VW53.rod
   VCID: 4ACC960F7C3FE85721F-801E
   Belt Pretensioner left:
   Subsystem 1 - Part No SW: 4N0 980 945 A    HW: 4N0 980 945 A
   Component: BeltPretRevFL  H10 0115
   Serial number: 00AI2019012375300000
   Coding: 04F001
   Belt Pretensioner right:
   Subsystem 2 - Part No SW: 4N0 980 946 A    HW: 4N0 980 946 A
   Component: BeltPretRevFR  H10 0115
   Serial number: 00AI2019013337600000
   Coding: 04F001
   Subsystem 3 - Part No SW: -----------    HW: 480 002 201 19
   Serial number: 35700000000E2035773D
   Subsystem 4 - Part No SW: -----------    HW: 480 002 201 19
   Serial number: 3580000000008C45773J
   Subsystem 5 - Part No SW: -----------    HW: 480 032 201 19
   Component: SideSensor_Dr  002 0149
   Serial number: 351001C18F5D6D70AC8Y
   Subsystem 6 - Part No SW: -----------    HW: 480 032 201 19
   Component: SideSensor_Pr  002 0149
   Serial number: 352001C18F552C913FFS
   Subsystem 7 - Part No SW: -----------    HW: 480 031 701 19
   Component: FrontSensor_D  002 0149
   Serial number: 355001C18B39E9E0E87
   Front Sensor Passenger:
   Subsystem 8 - Part No SW: -----------    HW: 480 031 701 19
   Component: FrontSensor_P  002 0149
   Serial number: 356001C18B31AE4079BK
   Pedestrian Protection Center:
   Subsystem 9 - Part No SW: -----------    HW: 480 032 201 19
   Component: PedP_Sensor_C  002 0149
   Serial number: 230001C18408BE010E6%
   Subsystem 10 - Part No SW: -----------    HW: 480 001 101 19
   Serial number: I0M00000000EBC1547BJ
   Subsystem 11 - Part No SW: -----------    HW: 480 001 101 19
   Serial number: I0N000000001CC1547B8
1069312 - Databus
          [NWD: zFAS common DTC Timeout]
                    Reset counter: 89
                    Mileage: 2321 km
                    Date: 2019.05.02
                    Time: 13:30:27
   Part No SW: 4N0 907 129 AB    HW: 4N0 907 129 AB
   ROD: EV_SMLSKLOAU736_VW53.rod
   VCID: 71BE21E33129FB8F405-8024
   Part No SW: 4K0 920 790 C    HW: 4K0 920 790 C
   Component: FBenRDWACC--- H11 0153
   Coding: 85A438C2E88000080D23E1609080080008002000
   ASAM Dataset: EV_DashBoardAU65X 001017
   ROD: EV_DashBoardAU65X_VW53.rod
   VCID: 2D06FD93ED91DF6F24D-8078
   Part No SW: 4N1 907 468 AL    HW: 4N1 907 468 AB
   Component: Gateway       H14 0044
   Revision: AA000002    Serial number: 028AA790019114
   Coding: 020100050020064029870000005B0132CC3A000710000000097D078E10000000
   ASAM Dataset: EV_CGateCONTIAU491 003170
   ROD: EV_CGateCONTIAU491_003_AU58.rod
   VCID: 025C7E2F048FF017A9F-8056
   Subsystem 1 - Part No SW: 4K0 951 523 H    HW: 4K0 951 523 H
   Component: E221__MFL  H06 0003
   Serial number: 00000000000000000000
   Subsystem 2 - Part No SW: 4K0 915 181     HW: 4K0 915 181
   Serial number: 741863120019012301F0
Address 22: AWD (J492)       Labels:* None
   Part No SW: 4K0 927 755 A    HW: 0CJ 927 749 A
   Component: C8_DL3_N_SD1  H01 0007
   Serial number: 18233A4743
   Coding: 110C0000
   ASAM Dataset: EV_AWDCQUOD31 001052
   ROD: EV_AWDCQUOD31.rod
   VCID: 3332EBEB0BB5899F729-8066
   Part No SW: 4M4 959 760     HW: 4M4 959 760
   Component: MEM-FS        009 0044
   Serial number: 00000359481330
   Coding: 005812400000B4010003010101010000000000000000000000000000004000
   ROD: EV_SCMDriveSideCONTIAU736_VW38.rod
   Part No SW: 4M1 959 593 D    HW: 4M1 959 593 D
   Component: TSG FS001 0188
   Serial number: YE007RLK01182
   Coding: 001FDB0152000480A001B002
   ROD: EV_DCU2DriveSideMAXHCONT_VW27.rod
   VCID: 3E24CADF30F754F78D7-806A
   Part No SW: 4N0 909 144 D    HW: 4N0 909 144 A
   Component: EPS_MLBEVO2BS H21 0504
   Coding: 94002101010000
   ASAM Dataset: EV_EPSVWBSAU426 009015
   ROD: EV_EPSVWBSAU426_009.rod
   VCID: 313EE1E3F1A9BB8F005-8064
   Part No SW: 4N0 907 064 CP    HW: 4N0 907 064 P
   Component: BCM2 MLBevo H14 0163
   Coding: 013400002FB100E06309A0000400880203030000804B06502F04000000040030001F0100000F11
   ASAM Dataset: EV_BCM2CONTIAU651 009009
   ROD: EV_BCM2CONTIAU651_009_AU58.rod
   VCID: 7F5AF7DB777D9DFFC61-802A
   Ignition key:
   Subsystem 2 - Part No SW: 5Q0 951 177     HW: 5Q0 951 172
   Serial number: 000000000ZY183333JU4
   Subsystem 3 - Part No SW: 5Q0 951 605 A    HW: 5Q0 951 605 A
   Serial number: 00000000000046280967
   Rear Light Left 1:
   Subsystem 4 - Part No SW: 4K0 945 217     HW: 4K0 945 217
   Component: SHL_li1  004 0002
   Serial number: 00000000000000725465
   Rear Spoiler Adjustment:
   Rear Light Left 2:
   Subsystem 6 - Part No SW: 4K5 945 093 C    HW: 4K5 945 093 C
   Component: SHL_li2  004 0002
   Serial number: 00000000000000736393
   Rear Light Right 1:
   Subsystem 7 - Part No SW: 4K0 945 218     HW: 4K0 945 218
   Component: SHL_re1  004 0002
   Serial number: 00000000000000708750
   Rear Light Right 2:
   Subsystem 8 - Part No SW: 4K5 945 094 C    HW: 4K5 945 094 C
   Component: SHL_re2  004 0002
   Serial number: 00000000000000716064
   Part No SW: 4N0 035 223 C    HW: 4N0 035 223
   Component: MIB2_amp_P_D5 H01 0170
   Revision: 00000001    Serial number: AUZ8ZAJ7D00CJF+
   Coding: 0185020000AAAA2FAA0000010000
   ASAM Dataset: EV_AMPMst16C1Gen2pALPI 001006
   ROD: EV_AMPMst16C1Gen2pALPI.rod
   VCID: 241018B7BE5B1E27FB3-8070
   Part No SW: 4M1 959 592 D    HW: 4M1 959 592 D
   Component: TSG BFS001 0188
   Serial number: YE007RLA1730C
   Coding: 001FDB015E000480A001B000
   ROD: EV_DCU2PasseSideMAXHCONT_VW27.rod
   VCID: 3D26CDD33DF14FEF94D-8068
   Part No SW: 4K0 035 063 B    HW: 4K0 035 063 A
   Component: MU-H-LND-EU   046 2538
   Coding: 0185020100000000C3111102C00800102F0001E403F00800CE
   ASAM Dataset: EV_MUHigGen2pALPI 001001
   ROD: EV_MUHigGen2pALPI_AU27.rod
   VCID: 221C1EAFA44F101789F-8076
   Subsystem 1 - Part No: V03 959 804 BF
   Component: MIB2P_EU_Q318  0321
   Subsystem 2 - Part No SW: 4K0 919 605 A    HW: 4K0 919 605 A
   Component: DU AU58x High  H42 0144
   Serial number: INX00105111800060438
   Subsystem 3 - Part No: V03 959 800 EG
   Component: Gracenote2  1009
   Volume Control 1:
   Subsystem 4 - Part No SW: 4K1 919 616 A    HW: 4K1 919 616 A
   Component: LSR-D5/C8  H33 0108
   Serial number: 00004419000002106009
   Display Unit 5 For Multimedia System:
   Subsystem 5 - Part No SW: 4K0 919 603 A    HW: 4K0 919 603
   Component: DU AU58x Bot  H41 0144
   Serial number: INX00101121800080251
   Media socket:
   Subsystem 6 - Part No SW: 4N0 035 736 A    HW: 4N0 035 736
   Component: MediaConnectH  014 0133
   Serial number: 051800799560006
6192 - Display Module 2 for Multimedia System
          B1298 FC [008] - Haptic Unit Defective
                    Reset counter: 96
                    Mileage: 2642 km
                    Date: 2019.05.07
                    Time: 10:06:32
                    Voltage terminal 30: 13.2 V
   Part No SW: 4M0 959 107 D    HW: 4M0 959 107 A
   Component: HDSG-Modul    H13 0170
   Revision: --------    Serial number: A2-C737-6252-2
   Coding: 1250
   ASAM Dataset: EV_DeckLidCONTIAU736 001016
   ROD: EV_DeckLidCONTIAU736_AU38.rod
   VCID: 3430E8F70EBB8EA76B3-8060
Address 80: Batt. reg. aux. accum. (A1)       Labels: None
   Part No SW: 4K0 915 101     HW: 4K0 915 101
   Component: MQ-BMS        H20 0126
   Serial number: 18000104719003
   ASAM Dataset: EV_BMS12VLiIonSDIAU49X 001001
   ROD: EV_BMS12VLiIonSDIAU49X.rod
   VCID: 609854A7EAC34207DFB-8034
   Part No SW: 4K1 713 041 H    HW: 4K1 713 041 H
   Component: GSM-LL H14 0051
   Serial number: 18.353 40696
   ASAM Dataset: EV_GSMKAMAU581 001005
   ROD: EV_GSMKAMAU581.rod
   VCID: 28080C87C273FA47D7B-807C
Address A5: Frt Sens. Drv. Assist (J1121)       Labels:* None
   Part No SW: 4KE 907 107 AA    HW: 4N0 907 107 F
   Component: zFAS Var A    H08 0291
   Coding: 0401820000000000000006000040042C189D56000000000000000000000000000019000000000000000000000000000000000000000000000000800000000000000078D0008000B000000000000000000080400000B0
   ASAM Dataset: EV_ZFASAU516 001003
   ROD: EV_ZFASAU516_001_AU58.rod
   VCID: 7EA40ADF707794F7CD7-802A
2117659 - Internal Fault
          B200F F9 [008] - Unknown Error Elaboration
          [OS detect an fatal runtime error]
                    Reset counter: 89
                    Mileage: 2299 km
                    Time: 00:00:00
                    Platform_zFAS_Error_Handler_Master-ErrorHandlerMaster: 00 00 6E 11 00 00 00 00 00 00 00 00 00 00 00 00
                    Platform_zFAS_Error_Handler_SSH-ErrorHandlerSSH: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
                    Platform_zFAS_Error_Handler_SRH-ErrorHandlerSRH: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
2114786 - Databus
          [TSK_08_TSK_Status_EA]
                    Reset counter: 89
                    Mileage: 2321 km
                    Date: 2019.05.02
                    Time: 13:30:28
221284 - Front Camera for Driver Assist Systems
          C12B3 FD [008] - View Temporarily Restricted
          [temp view limitations]
                    Mileage: 13 km
                    Date: 2019.02.22
                    Time: 14:14:34
                    EyeQ temperatures-CPU: -40 ∞C
                    EyeQ temperatures-VPM: 26 ∞C
                    Vehicle speed: 40.00 km/h
                    Front camera: blinding detection-Status: not active
                    Front camera: blinding detection-Blinding detected by light assistance assessment module: No
                    Front camera: blinding detection-Blinding detected by road sign recognition assessment module: No
                    Front camera: blinding detection-Blinding detected by pedestrian recognition assessment module: No
                    Front camera: blinding detection-Blinding detected by lane recognition assessment module: No
                    Front camera: blinding detection-Blinding detected by object recognition assessment module: No
                    Front camera: blinding detection-Blinding detected by distance regulation assessment module: No
                    Front camera: blinding detection-Blinding detected by road profile estimation assessment module: Yes
                    Front camera: blinding detection-Blinding detected by free space recognition assessment module: No
                    Front camera: blinding detection-Request for window defogger for front sensor system due to blinding: Yes
                    Front camera: blinding detection-Glare detected: No
                    Front camera: blinding detection-free view detected once: Yes
   Part No SW: 4M1 959 595 D    HW: 4M1 959 595 D
   Component: TSG HFS003 0188
   Serial number: YE007RL82920D
   Coding: 000FD90100000480A000B000
   VCID: 40D8B4274A032207FFB-8014
   Component: TSG HBFS003 0188
   Serial number: YE007RL821235
Address D6: Light Ctrl Left 2 (A31)       Labels: None
   Part No SW: 4K0 941 592 BC    HW: 4K0 941 592 B
   Component: LMS_MLBevo    H11 0031
   ASAM Dataset: EV_LMSLeftHELLAAU58X 001013
   ROD: EV_LMSLeftHELLAAU58X_AU38.rod
   VCID: 72BC2EEF342FC097B9F-8026
   Dynamic left front turn signal:
   Subsystem 1 - Part No SW: 4K0 941 035     HW: 4K0 941 035
   Component: M134DynTurnFL  003 0004
   Serial number: 22111800017037001011
Address D7: Light Ctrl Right 2 (A27)       Labels: None
   ASAM Dataset: EV_LMSRightHELLAAU58X 001013
   ROD: EV_LMSRightHELLAAU58X_AU38.rod
   Dynamic right front turn signal:
   Subsystem 1 - Part No SW: 4K0 941 036     HW: 4K0 941 036
   Component: M135DynTurnFR  003 0004
   Serial number: 23111800017153001011
End----------(Elapsed Time: 01:48, VBatt start/end: 13.2V/13.1V)-----------
I'm not sure anyone has figured out a solution for this one yet, and I doubt Audi made it easy, since they went to all the trouble of adding a 48V Li-ion system to help with start/stop and energy recuperation.
DV52
C?ID=194404
uwe: I hate to be APITA, but to repeat a previous point - why not forget about trying to second-guess what the boffins @ Audi have designed and instead use the facility that (I assume) is already fitted to the car: the native SS ON/OFF switch (isn't the solution to this problem simply to replicate the action of the SS ON/OFF switch through an external automated device)?
At it's simplest - isn't all that's needed here a relay with a simple timer- like this. And if more sophisticated functionality is needed (like remembering the previous ignition ON/OFF state) - isn't this as easy as a triggering circuit accross the SS switch via an Arduino chip (like a Digispark) and a program like this?
Have you looked at the interior of a 2019 A6? There are very few hardware switches in it. It's mostly touch-screen stuff now. I'm not close to one right now, but my recollection is that Start/Stop is a "soft" switch in that car.
X-iT
C?ID=369786
Uwe: you are correct, its on the lower touch screen. When you touch it, a red bar appears on top of it. Not close to the car right now so can't send a picture...
X-iT
C?ID=369786
hadez16
C?ID=289891
Deactivating StartStop was possible in those MLBevo cars where HVAC unit was seperated in Unit 08.
Audi A6 4K does not have a Unit 08, it was integrated in BCM Unit 09 and the required adaptation channel vanished.
MasterTommy
Amsterdam
C?ID=295586
I have no clue how it works in the US, but in the EU a lot of taxes on cars (both buying and owning one) are based partly on the emissions of a vehicle. Since start-stop is used in determining the emission label, it seems reasonable to assume legislation demands such an emission-related system to be part of the engine software and deemed as-is, with any change to the engine software voiding the type approval. The button in the interior could be regarded somewhat similar to a stability control off switch; you can turn it off if you get into a specific situation that demands it, but in general its not meant to be off.
