Cannot access Meas. Blocks - 08
Sawdusty Dan
C?ID=345699
2011 Audi A8L, 4.2L, 57k miles / Using HEX-V2 and current software
Having a CEL fault saying my B2-S1 O2 sensor is rich and wanted to look at the state of the MAF/trim (Group-032, according to the wiki). I go to "01 - Engine" and find "Meas. Blocks - 08" is greyed out and not accessible. Am I missing a step somewhere? :banghead:
Didn't include a scan, as this looks like an interface issue to me.
Chrispy
C?ID=124808
Have you tried Advanced Measured Values?
Sawdusty Dan
C?ID=345699
Missed the UDS / non-UDS notation in the manual. Mine IS the 'UDS' version. RTFD.....
OK, I got into "Advanced Measuring Values" and did some poking around. The only 'fuel trim' related lines I found were for long-term, bank 1 and 2, so I looked at those. Both read and remained at 0% (NO deviation) while idling and through a drive. I also pulled up one for "Intake_manifold_model_air_mass_flow_filtered_value" and (using the wiki section on fuel trim as a guide) tested that. According to the wiki, it should run around 0.8 times the rated HP - my 2011 4.2L lists at 372HP - and it showed right around 300 g/m while running near redline in 2nd gear, which is fairly spot-on. Log below:
Sunday,10,March,2019,19:02:38:62207
VCDS Version: 18.9.1.0 (x64) HEX-V2 CB: 0.4436.4
VIN: WAURVAFD7BN019415 License Plate:
Mileage: 92973km-57770mi Repair Order:
Address 01: Engine (4H0 907 560 C)
19:02:30
IDE01869 Long-term fuel trim bank 1 at idle 0.00 %
IDE03794 Long-term fuel trim bank 2 at idle 0.00 %
ENG107045 Intake_manifold_model_air_mass_flow_filtered_value 13.6 kg/h
-I'm thinking my MAF is alright, due to that last bit.
-I also just changed both camshaft (intake) position sensors, with new Beck/Arnley ones.
-I recently changed the spark plugs (NGK 5547) and am 'pretty sure' the factory set gap was correct, though not 100%. I do know it was showing the cylinder misfire on 5/6/7/8 before the new plugs
-Air and oil filters changed at 55k service, as well
My current thought is whatever is causing the misfire is also causing the O2 sensor fault(s). Doesn't seem like the O2 sensors would go bad before 57k miles. Your thoughts???
Here's my latest autoscan:
Sunday,10,March,2019,18:56:23:62207
Chassis Type: FD-AU64 (4H0)
Scan: 01 02 03 05 06 08 09 0E 10 13 15 16 17 19 34 36 3B 3C 42 46
          47 52 53 56 5F 62 6C 6D 6F 72 7F 81 85 88 89 8B 8E 8F 90
VIN: WAURVAFD7BN019415   Mileage: 92973km-57770miles
7F-Inform. Electr. II -- Status: OK 0000
Address 01: Engine (------CDRA)       Labels:| 079-907-560-CFS.clb
   Part No SW: 4H0 907 560 C    HW: 4H0 907 560
   Component: 4.2l V8/4V    H07 0004
   Revision: N5H07---
   Coding: 0106000A290F0268
   Shop #: WSC 24219 444 100841
   ASAM Dataset: EV_ECM42FSI0114H0907560C 001005
   ROD: EV_ECM42FSI0114H0907560C.rod
   VCID: 2A0D01C94C7006A7E09-807E
10203 - Random/Multiple Cylinder Misfire Detected
          P0300 00 [032] - -
                    Mileage: 92944 km
                    Date: 2019.03.10
                    Time: 11:27:39
                    Engine speed: 1847.00 /min
                    Normed load value: 36.5 %
                    Vehicle speed: 51 km/h
                    Coolant temperature: 72 °C
                    Intake air temperature: 4 °C
                    Voltage terminal 30: 13.452 V
                    AFS dm: 103.2 kg/h
                    Median injection timing: 2.391 ms
                    Engine operating condition: Part. load
                    Engine operating condition-Test_Program_Channel 87: 6
10596 - Cylinder 6
          P0306 00 [032] - Misfire Detected
                    Mileage: 92944 km
                    Date: 2019.03.10
                    Time: 11:27:39
                    AFS dm: 103.2 kg/h
10597 - Cylinder 7
          P0307 00 [032] - Misfire Detected
                    Mileage: 92944 km
                    Date: 2019.03.10
                    Time: 11:27:39
                    Engine speed: 1751.50 /min
                    Normed load value: 36.1 %
                    Vehicle speed: 52 km/h
                    Voltage terminal 30: 13.853 V
                    AFS dm: 99.3 kg/h
                    Median injection timing: 1.349 ms
4120 - Oxygen (Lambda) Sensor B2 S1
          P2198 00 [175] - Signal too High (Rich)
                    Mileage: 92886 km
                    Date: 2019.03.09
                    Time: 10:34:05
                    Engine speed: 1858.50 /min
                    Vehicle speed: 112 km/h
                    Coolant temperature: 102 °C
                    Intake air temperature: 9 °C
                    Ambient air pressure: 950 mbar
                    Voltage terminal 30: 14.159 V
                    AFS dm: 94.4 kg/h
                    Median injection timing: 1.194 ms
Readiness: 0000 0101
   Part No SW: 4H1 927 158 AD    HW: 0BK 927 156 K
   Component: 0BK 42 FSIUSA H08 1006
   Revision: --H08---
   Coding: 000002
   ASAM Dataset: EV_TCMALX51011 002018
   ROD: EV_TCMALX51011.rod
   VCID: 72BDD9A9A4200E67989-8026
   Part No SW: 4H0 907 379 C    HW: 4H0 907 379 C
   Component: ESP PREMIUM   H10 0273
   Coding: 44E6F20022674F00E200
   Shop #: WSC 02311 785 00200
   ASAM Dataset: EV_ESPPremi 005006
   ROD: EV_ESPPremi_005_AU64.rod
   VCID: 323D19A964A04E67589-8066
   Part No SW: 4H0 907 064 DD    HW: 4H0 907 064 AD
   Component: BCM2 2.0      H24 0510
   Coding: 0D872000000000000000
   Shop #: WSC 44214 000 1048576
   VCID: 6E85CDD9B0982A877C1-803A
   Serial number: 2311000024788007
   Part No SW: 4H0 959 760 E    HW: 4H0 959 760 E
   Revision: AA000000    Serial number: 00001002340998
   Coding: C018320085043201010001010101112131313333283333
   Shop #: WSC 02313 785 00200
   VCID: 353722B5954E595F7DB-8060
Address 08: Auto HVAC (J255)       Labels:| 4H0-820-043.clb
   Part No SW: 4H0 820 043 E    HW: 4H0 820 043 E
   Component: Klima 3 Zonen H14 0063
   Coding: 4881232E8C
   VCID: 221DE9E93440DEE7A89-8076
0137 - Motor for  Right Side Window Defrost Flap
          B10D8 22 [009] - Signal Amplitude Too High
                    Reset counter: 199
                    Mileage: 92862 km
                    Date: 2019.03.09
                    Time: 10:02:32
0378 - Coolant Circulation Pump
          B10D0 04 [009] - Internal System Fault
                    Reset counter: 197
                    Mileage: 92880 km
                    Date: 2019.03.09
                    Time: 10:30:56
   Part No SW: 4H0 907 063 G    HW: 4H0 907 063
   Component: BCM1 2.0      H12 0092
   Revision: 11012002    Serial number: 00000000952604
   Coding: 09072091073C9FE18B000804A0003800C09CD308820001218001085C3B00
   VCID: 2C0107D146041897125-8078
   Subsystem 1 - Part No SW: 4H1 955 119 C    HW: 4H1 955 119 A  Labels: 1KX-955-119.CLB
   Component: WWS641 110209  H32 0040
   Serial number:         110220170843
   Coding: 0045F7
   Component: RLS  H04 0003
   Serial number: 10062711
   Coding: 025523
   Component: E1 - LDS  H07 0044
   Serial number: 14 02 2011  00000170
   Subsystem 4 - Part No SW: 4H0 907 410 A    HW: 4H0 907 410 A
   Component: USHL4.2  H30 0020
   Serial number: 0000001805569R0B7S06
   Serial number: 00000002021100010414
   Coding: 100000
   Serial number: 00000002021100010613
   Coding: 100000
   Subsystem 7 - Part No SW: 4H0 907 705 J    HW: 4H0 907 705 C
   Component: EVLS-SG  H08 0280
   Serial number: WA101933000000180409
   Coding: 020300
   Serial number: 1038C095000000000001
Address 0E: Media Player 1 (R161)       Labels: None
   Part No SW: 4H0 035 108 D    HW: 4H0 035 108
   Component: DVDCAlpine    H42 0180
   Revision: AA001001
   Coding: 020000
   VCID: 211FE6E531C6C5FFB13-8074
   Part No SW: 4H0 919 475 H    HW: 4H0 919 475 C
   Component: PARKHILFE ACC H07 0030
   Revision: 11001001    Serial number: 55901103502910
   Coding: 300902
   ASAM Dataset: EV_EPHVA18AU57X0000 001002
   ROD: EV_EPHVA18AU57X0000_001.rod
   VCID: 372B28BD8FC2AB4F6F7-8062
   Part No SW: 4H0 907 561 A    HW: 4H0 907 561
   Component: ACC3          H15 0160
   Coding: 3601020201
   ASAM Dataset: EV_AdaptCruisContrAU64X 001012
   ROD: EV_AdaptCruisContrAU64X_001.rod
   VCID: 290FFEC549760DBFE93-807C
10240 - Sensor for Automatic Distance Control
          [FAULT_BLR_BLK8_31]
                    Reset counter: 239
                    Mileage: 92948 km
                    Date: 2019.03.10
                    Time: 11:40:58
                    Control Module temperature: 20 °C
                    Voltage terminal 15: 14.413 V
                    Velocity_vehicle_reference: 8.47 m/s
                    Longitudinal_acceleration_vehicle_reference: 3.80 m/s²
   Part No SW: 4H0 959 655 D    HW: 4H0 959 655 D
   Component: Airbag10.43   H41 0041
   Revision: --------    Serial number: 003JS001215G
   Coding: 303143303230303030314A55304C34483053
   Subsystem 1 - Part No SW: 4H0 959 339     HW: 4H0 959 339
   Serial number: 5850000R1112701DMH
   Serial number: 3575HRB405V0ATOC80J2
   Serial number: 3585HRB405P09RF2FONA
   Serial number: 3515JRB404T0BTBGBG4Y
   Serial number: 3525JRB404P0BTBG2OJ2
   Serial number: 3554VRB40670AMH8NP70
   Serial number: 3564VRB40650AMH83GU-
   Part No SW: 4H0 953 568 B    HW: 4H0 953 568 B
   Component: Lenks.Modul   H08 0007
   Revision: --------    Serial number: 90815KB30001D
   Coding: 0004BC
   VCID: 323D19A964204E67589-8066
   Subsystem 1 - Part No SW: 4H0 951 528 L    HW: 4H0 951 528 L
   Component: E221 - MFL  H04 0009
   Serial number: 04 01 2011  33037865
   Part No SW: 4H0 920 980 C    HW: 4H0 920 980
   Component: TBenUSAACC--- H30 0309
   Revision: 26110011    Serial number: 658250111593003
   Coding: 0B4608015700D705020000
   ASAM Dataset: EV_RBD4K 004033
   ROD: EV_RBD4K.rod
   VCID: 2B0304CD438A1FAF1BF-807E
   Analog_clock:
   Subsystem 1 - Part No SW: 4H0 919 204 G    HW: 4H0 919 204 G
   Component: Analoguhr D4  H05 0224
   Serial number: 1110210000411
   Part No SW: 4H0 907 468 E    HW: 4H0 907 468 C
   Component: J533--Gateway H08 0204
   Revision: --------    Serial number: 00000000100444
   Coding: 00C1034A00
   ROD: EV_GatewUDS_AU57.rod
   VCID: 33331CAD9BBA476F53F-8066
   Subsystem 1 - Part No SW: 4H0 915 181     HW: 4H0 915 181
   Component: J367-BDM  H07 0140
   Serial number: 00000000005650565978
   Part No SW: 4H0 907 553 C    HW: 4H0 907 553
   Component: LUFE-DAEMPFER H17 0096
   Coding: 008002
   ASAM Dataset: EV_AirSuspe 003022
   ROD: EV_AirSuspe_VW51.rod
   VCID: 2C0107D146841897125-8078
   Revision: AA000000    Serial number: 00001002340431
   Coding: C0183B0085053201010001010101112131313333203333
   Part No SW: 4H0 907 637     HW: 4H0 907 637
   Component: SARA 6D       H02 0015
   Revision: --------    Serial number: EJ1BPA3100D31F0
   ASAM Dataset: EV_SARA 006014
   ROD: EV_SARA_006.rod
   VCID: 6C81C7D18604D897525-8038
   Part No SW: 4H0 907 566     HW: 4H0 907 566
   Component: J769  SWA MasterH02 0100
   Revision: 00H02000    Serial number: 6PZ 010 287-00
   VCID: 6D87CAD5B19ED19F45B-8038
   Subsystem 1 - Part No: 4H0 907 568
   Component: J770  SWA Slave H01 0100
   Subsystem 2 - Serial number: 6PZ 010 287-20
   Subsystem 3 - Serial number: 5F17.02.1100H010003CH10119ÿ
   Subsystem 4 - Serial number: H10119ÿ
   Part No SW: 4H0 959 793 E    HW: 4H0 959 793 E
   Component: TSG FA        H02 0162
   Revision: --------    Serial number: 0000113121958
   Coding: 011F1F205E0062C202000007
   VCID: 3B23348DB36A8F2F8BF-806E
   Revision: 00002001    Serial number: 0143183433
   Coding: 0106023A00FA7585B0B0C7C0020100000000000000000000000000000000
   Subsystem 1 - Part No SW: 4H0 959 719     HW: 4H0 959 719
   Component: GTO BF  H01 0070
   Serial number: 00000000000000019957
   Subsystem 3 - Part No SW: 4H0 959 591     HW: 4H0 959 591
   Component: J245 PS50.028  H06 0006
   Serial number:     WOO1122065Y
   Coding: 020200
   Subsystem 4 - Part No SW: 4H0 947 135 BK    HW: 4H0 947 135 BK
   Component: Dachelektroni  H11 0080
   Serial number: A2011000000000340718
   Subsystem 5 - Part No SW: 4H0 959 591 A    HW: 4H0 959 591 A
   Component: V252 PS009  H05 0004
   Serial number:     WOO1000BRQ$
   Part No SW: 4H0 035 465 A    HW: 4G0 035 465
   Component: BO G3 D4      H06 0150
   Revision: 04S00000    Serial number: 0012765
   VCID: 2411EFF12ED4D0D7DA5-8070
   Subsystem 1 - Part No SW: 4H0 035 466     HW: 4H0 035 466
   Component: BO D4 SLAVE  H51 0180
   Serial number: 00110100002197
   Part No SW: 4H0 959 792 E    HW: 4H0 959 792 E
   Component: TSG BF        H02 0162
   Revision: --------    Serial number: 0000113125040
   VCID: 3A2D3189BC50B627909-806E
   Revision: --------    Serial number: 00000000040905
   ROD: EV_ParkiBrake_VW51.rod
   Part No SW: 4H0 035 082 A    HW: 4H0 035 082
   Component: Radio U SIRIU H51 0068
   Revision: AB001007    Serial number: 155BJ0B7501060
   Coding: 020007010003000001
   VCID: 1F1BE01D07B2F30F877-804A
   Part No SW: 4H0 035 664 B    HW: 4H0 035 664
   Component: H-BN-NA       H48 0294
   Revision: --------    Serial number: 098B.0B7501792
   Coding: 020200000001F9EF7D128B0E00000003F400010000000000
   VCID: 2615F5F958E822C7C41-8072
   Subsystem 1 - Part No: 8R0 060 884 AC
   Component: NAR 2011  0503
   Subsystem 2 - Part No SW: 4H0 919 604 C    HW: 4H0 919 604 C
   Component: DU8 D4 SV NB  H46 0021
   Serial number: AUZ8ZDB1100CAJD
   Subsystem 3 - Part No SW: 4H1 919 600 D    HW: 4H1 919 600
   Component: E380 BDT D4  H09 0063
   Serial number: 00000000029306
   Component: CD-Database  2712
            000 -  -  - Intermittent
                    Reset counter: 237
                    Mileage: 92943 km
                    Date: 2019.03.10
                    Time: 11:13:00
                    Bin. Bits: 00000001 00000000
                    Bin. Bits: 00000000 00000000
01043 - Control Module; Incorrect Software Version
                    Fault Frequency: 106
                    Reset counter: 240
                    Mileage: 92973 km
                    Date: 2019.03.10
                    Time: 18:54:05
   Part No SW: 4H0 959 795 A    HW: 4H0 959 795 A
   Component: TSG HL        H04 0162
   Revision: --------    Serial number: 0000113074527
   Coding: 010F1F20400062C202000007
   VCID: 392F2E85B956BD3F993-806C
   Part No SW: 4H0 907 441     HW: 4H0 907 441
   Component: SG Rueckfahrkamera  0030
   Revision: --H04---    Serial number: 525 PA8J11D18L
   Coding: 1020003
   VCID: 6597B2F5696EE9DF0DB-8030
Address 6D: Trunk Elect. (----)       Labels:* None
   Part No SW: 4H0 959 107 P    HW: 4H0 959 107 M
   Component: HDSG-Modul    H11 0036
   Revision: 10011001    Serial number: 039100194
   Coding: 0210044100
   ROD: EV_DeckLidContrUnit.rod
   VCID: 3B23348DB3EA8F2F8BF-806E
Address 6F: Centr. Conv. II (J773)       Labels:* None
   Revision: --------    Serial number: 000000024159
   ASAM Dataset: EV_Ambie 001008
   ROD: EV_Ambie.rod
   VCID: 6393ACED6BDA97EFE3F-8036
   Component: TSG HR        H04 0162
   Revision: --------    Serial number: 0000113074718
Address 7F: Inform. Electr. II (J829)       Labels: None
   Part No SW: 4H0 035 774 B    HW: 4H0 035 774
   Component: H-BN-NA       H48 0295
   Revision: --------    Serial number: 108AP0B7501069
   Coding: 020200000001004001000004000013000000000000000000
   VCID: 2809FBC152FC34B7F6D-807C
   Subsystem 1 - Part No SW: 4H0 919 607     HW: 4H0 919 607
   Component: DU10 RSE  H41 0021
   Serial number: AUZ8ZDB1200745W
   Subsystem 2 - Part No SW: 4H0 919 607     HW: 4H0 919 607
   Serial number: AUZ8ZDB120074YI
   Subsystem 3 - Part No SW: 4H0 919 709 C    HW: 4H0 919 709 C
   Component: E499 BDT 2  H07 0019
   Serial number: 90238KBG0000Q
   Subsystem 5 - Part No: 8R0 060 884 AC
Address 81: Gear Shift (J587)       Labels: 3Y0-927-731.clb
   Part No SW: 4H1 927 731 A    HW: 4H1 927 731 A
   Component: GSM-LL        H05 0081
   Revision: 0L0D5012    Serial number: SN110120  0083
   ASAM Dataset: EV_GSM2x3Mono 001014
   ROD: EV_GSM2x3Mono.rod
   Part No SW: 4G0 907 217     HW: 4H0 907 217 A
   Component: DPC-SG        H24 0034
   Coding: E9060000
   ROD: EV_OnBoardCamerDPC.rod
   VCID: 6597B2F565EEE9DF0DB-8030
   Serial number: 00000003190402
   Coding: 764FF2
   ROD: EV_IVBDriveSideFrnt.rod
   VCID: 2F3B10DD7792638F377-807A
   Serial number: 00000003156502
   Coding: 364FF2
   Part No SW: 4H0 907 541 A    HW: 4H0 907 541
   Coding: 3601020201
   ASAM Dataset: EV_AdaptCruisContr2AU64X 001010
   ROD: EV_AdaptCruisContr2AU64X_001.rod
   VCID: 270BF8FD5F623BCFFF7-8072
   Part No SW: 4G0 907 107 B    HW: 4H0 907 107
   Component: BV-SG         H28 0034
   Serial number: 000040181102117
   Coding: 02A19A000111
   ASAM Dataset: EV_BC7 001001
   ROD: EV_BC7.rod
   VCID: 2517F2F5256E29DFCDB-8070
   Part No SW: 4H0 980 945     HW: 4H0 980 945
   Component: RGS-VL        H05 0070
   Coding: 0066F609031F007E070308014240C2010000
   ASAM Dataset: EV_RGS_L 002004
   ROD: EV_RGS_L.rod
   VCID: 6FBBD0DDB712238F777-803A
   Part No SW: 4H0 980 946     HW: 4H0 980 946
   Component: RGS-VR        H05 0070
   ASAM Dataset: EV_RGS_R 002004
   ROD: EV_RGS_R.rod
   VCID: 70B9D3A1AA2C3C776ED-8024
End----------(Elapsed Time: 03:26, VBatt start/end: 14.7V/14.5V)-----------
Dana
Western PA, USA
I would want to rule out the possibility that the HPFP on that bank isn't dumping fuel directly onto the camshafts and contaminating the oil resulting in both misfires and the bank specific rich DTC.
Next, searching Fuel Trim was logical and I'm not a fan of UDS engine controllers for this reason. Try searching OBD to locate results such as:
[*IDE00597-ENG167462*] Long term adaptation of mixture formation bank 1,OBD,
[*IDE00598-ENG167462*] Long term adaptation of mixture formation bank 2,OBD,
[*IDE00604-ENG167462*] Short term adaptation of mixture formation bank 1,OBD,
[*IDE00605-ENG167462*] Short term adaptation of mixture formation bank 2,OBD,
[*IDE02119-ENG167462*] Long term adaptation of oxygen sensor control: bank 1,OBD,
[*IDE04324-ENG167462*] Long term adaptation of oxygen sensor control: bank 2,OBD,
.. etc.
You should be able to locate all of the groups providing you with the big picture.
If the problem is confirmed bank specific, resolves itself after an oil change and you ruled out the possibility that injectors are leaking-down -or- the spark plugs are to blame .. the HPFP on that bank is the next easiest thing to rule out.
P.S. We can move this thread to the Car Repair sub-forum if you need any additional car-specific tips.
Dana
Western PA, USA
P.S. If "OBD" doesn't result in the above measuring values search for term instead.
