- Joined
- Jun 28, 2016
- Messages
- 98
- Reaction score
- 31
- Location
- San Diego USA
- VCDS Serial number
- C?ID=281154
Hi, new to the forum and to computer controlled VWs. Background: I bought this 2007 GTI not running. PO said it just quit at a light and that was it. It sat for 9 months with no battery. I bought a battery and I started doing research and checking things. I replaced the spark plugs, crank sensor, cam sensor, and HPFP cam follower. Ran compression test, checked good. 130ish on all 4 (207K miles). Changed oil, new filter, checked for spark and fuel pressure, checked fuses, cleaned the MAF. No obvious cracks in intake tubes. Engine cranks and fires a couple times then nothing, just keeps cranking. Same results with starter fluid. OBDII codes wouldn't read so I bought a VCDS from Ross-Tech. The output tells me MAF, intake leak, or bad injectors (or all 3!). I will check the MAF with my multi meter tonight. Any thoughts?
Chassis Type: 1K (1K0)
Scan: 01 02 03 08 09 0F 15 16 17 19 1C 25 42 44 46 52 55 56 65
VIN: WVWFV71K37W16XXXX Mileage: 333150km-207009miles
Address 01: Engine Labels: 06F-907-115-AXX.clb
Part No SW: 1K0 907 115 H HW: 8P0 907 115 B
Component: 2.0l R4/4V TFSI 0020
Revision: 5BH15--- Serial number: VWZ7Z0G8013765
Coding: 0403010A1C070160
Shop #: WSC 01279 067 57207
VCID: 2B7BF8198AC3C266FB-807E
P0300 - 008 - - Intermittent
Fault Status: 00111000
Mileage: 332939 km
Time: 19:57:33
RPM: 889 /min
Load: 25.5 %
Temperature: 86.0°C
Temperature: 65.0°C
Absolute Pres.: 990.0 mbar
Voltage: 13.081 V
008583 - Bank 1; System too Lean at Idle
P2187 - 004 - - Intermittent
Fault Status: 00110100
Mileage: 333058 km
Time: 05:03:23
RPM: 1050 /min
Load: 15.3 %
Speed: 6.0 km/h
Temperature: 78.0°C
Temperature: 57.0°C
Voltage: 12.954 V
008825 - Leak in Air Intake System
P2279 - 002 - - Intermittent
Fault Status: 00110010
Mileage: 333058 km
Time: 05:03:36
RPM: 895 /min
Load: 15.7 %
Temperature: 78.0°C
Temperature: 58.0°C
Voltage: 12.954 V
000256 - Mass Air Flow Sensor (G70)
P0100 - 004 - Supply Voltage - Intermittent
Mileage: 333157 km
Temperature: 27.0°C
Temperature: 28.0°C
Voltage: 12.192 V
Readiness: 0110 0101
Address 02: Auto Trans Labels: 02E-927-770.lbl
Part No SW: 02E 300 043 Q HW: 02E 927 770 AE
Component: GSG DSG 070 1306
Revision: 04607000 Serial number: 00000612040951
Shop #: WSC 01279 785 00200
VCID: 2265153DFD09032E48-8076
18243 - Pressure Control Valve 5 (N233)
P1835 - 000 - Short to Plus - Intermittent
Fault Frequency: 255
Reset counter: 8
Mileage: 308178 km
19143 - Unexpected / Implausible Mechanical Gear Disengagement
P2711 - 005 - - Intermittent
Fault Status: 00100101
Reset counter: 37
Mileage: 312318 km
Part No SW: 1K0 907 379 AC HW: 1K0 907 379 AC
Revision: 00H11001
Coding: 0021122
VCID: 73CB20791273DAA673-8026
Part No: 1K0 820 047 GS
Component: Climatic PQ35 120 0606
VCID: 7BDB08593A2392E62B-802E
00532 - Supply Voltage B+
Address 09: Cent. Elect. Labels: 3C0-937-049-23-H.lbl
Part No SW: 3C0 937 049 AE HW: 3C0 937 049 AE
Component: Bordnetz-SG H52 2002
Revision: 00H52000 Serial number: 00000006559540
Coding: 178D8F214004150047140000001400000028770B5C0001
Shop #: WSC 22580 444 57677
VCID: 6CF93B054F4D055EB2-8038
Component: Wischer 201206 020 0501
Coding: 00038805
Shop #: WSC 22580
Reset counter: 38
Mileage: 333157 km
Date: 2005.09.13
Time: 31:63:63
Voltage: 8.90 V
Part No SW: 8E0 035 593 H HW: 8E0 035 593 H
Component: SDAR SIRIUS H06 0080
Revision: 00000000 Serial number: AUZ4Z7F0024301
VCID: 2E7DF10DB9D1B74EDC-807A
Reset counter: 38
Mileage: 333157 km
Time: 06:17:28
Voltage: 8.30 V
Reset counter: 38
Mileage: 333157 km
Time: 00:03:47
Voltage: 8.40 V
Reset counter: 216
Mileage: 105914 km
Time: 13:42:53
02788 - Internal Communications Error
Reset counter: 253
Mileage: 333157 km
Time: 19:11:35
Bin. Bits: 00000000
Bin. Bits: 00000001
01304 - Radio
Reset counter: 38
Mileage: 333157 km
Time: 00:01:34
Part No SW: 1K0 909 605 AB HW: 1K0 909 605 AB
Component: 5L AIRBAG VW8R 034 8000
Revision: 05034000 Serial number: 003B6D07R6RE
Coding: 0013644
Shop #: WSC 01269 785 00200
Subsystem 1 - Part No: 1K0 959 339 G
Component: BF-Gewichtsens. 007 0007
Subsystem 2 - Serial number: 6332MSME151A07522
Subsystem 3 - Serial number: 6342MSME156A6B6EV
Subsystem 4 - Serial number: 6352QSME1C76133DN
Subsystem 5 - Serial number: 6362QSME1E183E4D-
Subsystem 6 - Serial number: 63727SME0B640C2E9
Subsystem 7 - Serial number: 63827SME0B771B200
00591 - Seat Belt Switch; Driver (E24)
010 - Open or Short to Plus - Intermittent - MIL ON
02513 - Belt Force Sensor for Seat Occupied Recognition (G453)
003 - Mechanical Failure - Intermittent - MIL ON
008 - Implausible Signal - Intermittent - MIL ON
01587 - Igniter 2 for Airbag; Drivers Side (N250)
001 - Upper Limit Exceeded - Intermittent - MIL ON
Part No SW: 1K0 953 549 AG HW: 1K0 953 549 AG
Component: J0527 636 0070
Coding: 0012122
VCID: 77D31469060BB6864F-8022
Component: E0221 002 0010
Part No SW: 1K6 920 973 A HW: 1K6 920 973 A
Component: KOMBIINSTRUMENT VDD 1610
Revision: V0003000 Serial number: VWZ7Z0G8013765
Coding: 0007207
Shop #: WSC 22580 444 53700
VCID: 3147EA71A8EFA8B6C1-8064
9 Faults Found:
Reset counter: 38
Mileage: 333157 km
Time: 00:03:21
00771 - Fuel Level Sensor (G)
Fault Status: 00101010
Fault Frequency: 9
Reset counter: 38
Mileage: 332184 km
Time: 06:09:43
Reset counter: 38
Mileage: 333157 km
Time: 00:04:17
Reset counter: 38
Reset counter: 38
Reset counter: 38
Reset counter: 38
Reset counter: 38
Fault Frequency: 9
Reset counter: 38
Mileage: 332184 km
Time: 06:09:43
Address 19: CAN Gateway Labels: 1K0-907-530-V2.clb
Part No SW: 1K0 907 530 K HW: 1K0 907 951
Component: J533__Gateway H04 0021
Revision: H04 02 Serial number: 070107F1001226
Coding: 7F8F03600F000000
VCID: 2F43EC09BEDBBE46D7-807A
Reset counter: 37
Mileage: 333157 km
Time: 00:04:17
Part No SW: 1K6 919 879 HW: 1K6 919 879
Component: Kompass 001 0003
Revision: 00001000 Serial number: 1225223T1QSF03
VCID: 7DDF064124379CD615-8028
Component: IMMO VDD 1610
01176 - Key
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN3.lbl
Part No SW: 1K0 959 701 M HW: 1K0 959 701 M
Component: Tuer-SG 005 0983
Coding: 0001077
VCID: 3851D7554B9579FE86-806C
Part No: 1K1 909 144 L
Component: EPS_ZFLS Kl.074 H07 1806
Shop #: WSC 00000 028 00001
VCID: 3449E36557FD9D9EAA-8060
Mileage: 333150 km
Temperature: 17.0°C
Voltage: 6.00 V
Voltage: 5.80 V
Address 46: Central Conv. Labels: 1K0-959-433-MAX.clb
Part No SW: 1K0 959 433 CT HW: 1K0 959 433 CT
Component: KSG PQ35 RDK 052 0218
Revision: 00052000 Serial number: 00000000000000
Coding: 139006885103281B0904058FB0080A04889C00
Shop #: WSC 22580 444 999999
VCID: 042973A547DDED1E5A-8050
Fault Frequency: 61
Reset counter: 38
Mileage: 330689 km
Time: 04:39:02
Reset counter: 38
Mileage: 333157 km
Time: 00:04:16
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.lbl
Part No SW: 1K0 959 702 M HW: 1K0 959 702 M
Coding: 0001076
VCID: 3957D251709F60F679-806C
Address 55: Headlight Range Labels: 1T0-907-357.lbl
Part No: 1T0 907 357
Component: Dynamische LWR 0003
Coding: 0000003
VCID: 74C92365177DDD9E6A-8020
00070 - Starting Battery Voltage
Part No SW: 1K0 035 180 G HW: 1K0 035 180 G
Component: Radio PM6 017 0023
Revision: 00017000 Serial number: VWZ5Z7F2121101
Coding: 0040401
VCID: 24691325E71D0D1E3A-8070
Fault Frequency: 7
Reset counter: 37
Mileage: 333157 km
Time: 09:00:23
Component: RDK 0440
Coding: 0100101
End-------------------------(Elapsed Time: 01:16)--------------------------
