VCDS Version: Release 15.7.1 (x64) Running on Windows 10 x64
Data version: 20150904
Thursday,29,October,2015,09:38:35:15363
Chassis Type: AJ (7N0)
Scan: 01 02 03 08 09 15 16 17 19 1C 25 2E 42 44 46 52 56 62 72 77
VIN: WVWHD7AJ6DW081984 Mileage: 52810km-32814miles
04-Steering Angle -- Status: Sporadic communication error 1000
Address 01: Engine (CBF) Labels: 06J-907-115-CBF.clb
Part No SW: 1K0 907 115 AT HW: 1K0 907 115 AK
Component: 2.0l R4/4V TFSI 0020
Revision: E3H26--- Serial number:
Coding: 040301081C070160
Shop #: WSC 78384 155 427622
VCID: 78D11B040BEF48FE65-802C
049446 - No Communications with Steering Angle Sender (G85)
U0126 - 000 - - Intermittent
000257 - Mass Air Flow Sensor (G70)
P0101 - 000 - Implausible Signal
Readiness: 1110 1101
Address 02: Auto Trans Labels: 02E-927-770.lbl
Part No SW: 02E 300 058 P HW: 02E 927 770 AL
Component: GSG DSG AG6 531 3513
Revision: 05653104 Serial number: 00001504092318
Shop #: WSC 04940 001 00001
VCID: 2773087896D117063C-8072
18036 - Powertrain Data Bus
P1628 - 000 - Missing Message from Steering Angle Sensor - Intermittent
Address 03: ABS Brakes (J104) Labels: 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 BL HW: 1K0 907 379 BL
Component: ESP MK60EC1 H31 0152
Revision: 00H31001
Coding: 114B600C492A80FB881406EC921D0141B70800
VCID: 7DDF0A10E4CD6DD636-8028
00003 - Control Module
013 - Check DTC Memory
Address 08: Auto HVAC (J301) Labels: 3C8-907-336.clb
Part No SW: 7N0 907 426 BH HW: 7N0 907 426 BH
Component: AC Manuell H20 0505
Revision: 00001018
Coding: 0010001002
VCID: 7BDB0408F2D963E608-802E
Address 09: Cent. Elect. (J519) Labels: 1K0-937-08x-09.clb
Part No SW: 1K0 937 086 T HW: 1K0 937 086 T
Component: BCM PQ35 M 111 0709
Revision: AB111709
Coding: 67190AB880772EC4C00A41C1640081EC4FB103EE435D8D60648860A40040
VCID: 41A7B6E0D8B5C93612-8014
Subsystem 1 - Part No: 5K1 955 119 Labels: 1KX-955-119.CLB
Component: Wischer 27071 26 0512
Coding: 009FB5
10 Faults Found:
010 - Open or Short to Plus
00984 - Left Tail Light (M4)
00985 - Right Tail Light (M2)
02661 - Wire for Speed Signal
Part No SW: 5C0 959 655 M HW: 5C0 959 655 M
Component: AirbagVW10G 014 0726
Serial number: 003L4R00HGAC
Coding: 00004737
ROD: EV_AirbaVW10SMEVW360_SE36.rod
VCID: 3C59C714B757A4DE41-8068
Subsystem 1 - Part No SW: 5K0 959 339 B HW: 5K0 959 339 B
Component: BF-Gewichtss. 006 0001
Serial number: ---0000R--00005J3A00
Serial number: 3572MSME4E1A6674ZZZ2
Serial number: 3582MSME4F332472ZZZY
Serial number: 3512QSME48231B7AZZZ.
Serial number: 3522QSME482D1F6CZZZA
Component: F.Sens.Fahr --- ----
Serial number: 35527SME135D3A2EZZZR
Component: F.Sens.Beif --- ----
Serial number: 35627SME0448372EZZZJ
Address 16: Steering wheel (J527) Labels: 5K0-953-569.clb
Part No SW: 5K0 953 507 AJ HW: 5K0 953 549 B
Component: Lenks.Modul 008 0080
Revision: -------- Serial number: 90440LGM001B4
Coding: 589A140000
ROD: EV_SMLSNGKUDS_SE36.rod
VCID: 78D11B04C3EF48FE65-802C
Subsystem 1 - Part No SW: 5K0 959 542 B HW: 5K0 959 542 B Labels: 3C8-959-537.CLB
Component: E221__MFL-TAS H30 0032
Serial number: 0054388
Part No SW: 5K6 920 973 C HW: 5K6 920 973 C
Component: KOMBI H05 0705
Coding: 270F01
VCID: 3753D8388E718786AC-8062
Address 19: CAN Gateway (J533) Labels: 7N0-907-530-V2.clb
Part No SW: 7N0 907 530 R HW: 7N0 907 530 H
Component: J533 Gateway H42 1632
Revision: H42 Serial number: 090812F2002532
Coding: 350002
VCID: 3FA3B018AE41BFC664-806A
Part No SW: 5N0 919 879 HW: 5N0 919 879
Component: Kompass 002 0002
Revision: 00002000 Serial number: 1225223RKEYE07
VCID: 7EDD0D1C29CB76CE2F-802A
Component: IMMO H05 0705
VCID: 6AF5314C8D43EA6EE3-803E
Address 2E: Media Player 3 (J650) Labels: 5N0-035-342.lbl
Part No SW: 5N0 035 342 F HW: 5N0 035 342 F
Component: SG EXT.PLAYER H18 0546
Revision: A1001003 Serial number: 7663253386
Coding: 010100
VCID: 2A75F14C45C32A6E23-807E
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN3.lbl
Part No SW: 5K0 959 701 B HW: 5K0 959 701 B
Component: Tuer-SG 009 2119
Coding: 0001204
VCID: 3147E620A81559B6E2-8064
Part No: 1K0 909 144 P
Component: EPS_ZFLS Kl. 74 3305
Revision: 00H22000
VCID: 3753D83846718786AC-8062
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.lbl
Part No SW: 5K0 959 702 B HW: 5K0 959 702 B
Coding: 0001204
VCID: 3245E92CAD1362AE9B-8066
Address 56: Radio (J503) Labels: 5M0-035-1xx-56.clb
Part No SW: 1K0 035 180 AE HW: 1K0 035 180 AE
Component: Radio Prem-8 H02 0016
Revision: -----16S Serial number: VWZ4Z7L3212222
Coding: 01000400040007
VCID: 63EB5C686269BB2620-8036
Part No SW: 5K0 959 703 D HW: 5K0 959 703 D
Component: Tuer-SG 007 2101
Coding: 0001168
Shop #: WSC 01357 011 1012552
VCID: 354FD2305C7D7596BE-8060
Part No SW: 5K0 959 704 D HW: 5K0 959 704 D
Coding: 0001168
VCID: 364DD53C417B7E8EB7-8062
Address 77: Telephone (J412) Labels: 7P6-035-730.clb
Part No SW: 7P6 035 730 K HW: 7P6 035 730 K
Component: TELEFON H15 3200
Revision: 1B001001 Serial number: 00007663247582
Coding: 0A10040000010100
ASAM Dataset: EV_UHVNA 002720
ROD: EV_UHVNA.rod
VCID: 3A55C10CBD639AEE53-806E
End-------------------------(Elapsed Time: 01:53)--------------------------
I'm not worried about the bulb or MAF codes.
