- Joined
- Sep 22, 2018
- Messages
- 13
- Reaction score
- 1
- Location
- Mexico City
- VCDS Serial number
- C?ID=326888
Dears
I install European led Tail Lights on VW jetta 2016 but as you know the bulb error message appear on the dashboard of the car i saw on Internet and it seems it is not possible to delete the bulb error if someone can confirm if we can erase that Bulb error ?
Thanks in advance
Thanks in advance
Tuesday,25,September,2018,21:17:16:37874
VCDS Version: 18.2.1.5 (x64) HEX-V2 CB: 0.4411.4
VIN: 3VW1W2AJ8GM374995 License Plate: MYK4448
Mileage: 35600km-22120mi Repair Order:
Chassis Type: AJ-VW36 (7E0)
Scan: 01 03 05 08 09 15 17 19 25 2B 56
VIN: 3VW1W2AJ8GM374995 Mileage: 35600km-22120miles
Address 01: Engine (CCC) Labels: 07K-906-055-CBT.clb
Part No SW: 07K 906 055 EC HW: 07K 907 309 B
Component: 2,5L 125KW G01 1401
Revision: T4H07--- Serial number:
Coding: 0000071
VCID: 73B3229677BC17BF7C6-8026
U1017 - 000 - - Intermittent
Mileage: 35243 km
Date: 2018.09.18
Time: 11:16:54
RPM: 2321 /min
Load: 32.1 %
Speed: 38.0 km/h
Temperature: 92.0°C
Temperature: 72.0°C
Absolute Pres.: 780.0 mbar
Address 03: ABS Brakes Labels:. 1K0-907-379-MK70M.clb
Part No SW: 1K0 907 379 AK HW: 1K0 907 379 AK
Component: MK70 M MASR 0106
Revision: 00H35001
Coding: 0020833
Shop #: WSC 00066 790 00014
VCID: 7BA30AB65FEC5FFF246-802E
Address 05: Acc/Start Auth. (J518) Labels:| 5K0-959-434.clb
Part No SW: 5K0 959 434 E HW: 5K0 959 434
Revision: 00092000 Serial number: 0396094799
Coding: 000F0F
Shop #: WSC 00066 000 00295
VCID: 372BD6862FC4BB9F80E-8062
Address 08: Auto HVAC Labels: 5C0-820-047.clb
Part No SW: 5C0 820 047 CR HW: 5C0 820 047 CR
Component: J301 Klimaanlage 0211
Revision: 2001401S Serial number: 00000003222248
VCID: 72BD279208A61EB7770-8026
Address 09: Cent. Elect. (J519) Labels:. 7E0-937-BCM-V1.clb
Part No SW: 7E0 937 189 HW: 7E0 937 189
Component: BCM PQ25 MMI3 H80 0736
Revision: BA080001 Serial number: 18007105160151
Coding: 73994BBA083B0700083920802C0A84D50DC6720E60C40020B1A010030844
Shop #: WSC 00066 123 12345
VCID: 71BF289E01A025AF8EA-8024
Subsystem 1 - Part No SW: 6R0 959 801 DF HW: 6R0 959 801 DF Labels: 6R0-959-801.CLB
Component: J386__TSG_FT 022 1466
Serial number: 14102743160311065331
Coding: 020000
Subsystem 2 - Part No SW: 6R0 959 802 DJ HW: 6R0 959 802 DJ Labels: 6R0-959-802.CLB
Component: J387__TSG_BT 022 1466
Serial number: 14102742160308062643
Coding: 020000
Subsystem 3 - Part No SW: 5K0 959 591 A HW: 6R0 959 591 D
Component: J245 PS41.402 H03 0004
Serial number: 0000FST000S10B400000
Coding: 180000
Subsystem 4 - Part No SW: 6C0 959 442 A HW: 6C0 959 442 A
Component: E221__MFL-TAT H06 0023
Serial number: 0481616030901588AD1B
Coding: 280000
Subsystem 5 - Part No SW: 6R0 959 811 T HW: 6R0 959 811 T
Component: J388__TSG_HL 022 1466
Serial number: 14102745160328233238
Subsystem 6 - Part No SW: 6R0 959 812 T HW: 6R0 959 812 T
Component: J389__TSG_HR 022 1466
Serial number: 14102744160330220310
Part No SW: 5C0 959 655 AF HW: 5C0 959 655 AF
Component: AirbagVW10 015 0614
Serial number: 003S2M088FNN
Coding: 00004341
ASAM Dataset: EV_AirbaVW10SMEVW360 001032
ROD: EV_AirbaVW10SMEVW360.rod
VCID: 76B51B82684E02975B8-8022
Subsystem 1 - Part No SW: 5K0 959 354 HW: 5K0 959 354
Serial number: 3572MSME5D4C0A57ZZZ6
Serial number: 3582MSME224C0A57ZZZ-
Subsystem 3 - Part No SW: 5K0 959 351 A HW: 5K0 959 351 A
Serial number: 3516KSME2A1F2F3CZZZ6
Serial number: 3526KSME302F2F3CZZZ%
Part No SW: 5C6 920 855 A HW: 5C6 920 855 A
Component: KOMBI H04 1007
Coding: 170B000000
Shop #: WSC 00066 790 00320
VCID: 2C01F9EAE6820847FDC-8078
Address 19: CAN Gateway (J533) Labels:. 7E0-909-901.clb
Part No SW: 7E0 909 901 HW: 7E0 937 189
Component: GW-K-CAN TP20 H80 0736
Revision: BA080001
Coding: 102200
VCID: 688945FA327AE467D94-803C
Date: 2018.01.20
Time: 00:00:00
Component: IMMO H04 1007
Coding: 000007
VCID: 6A8D3FF22CF6D677CF0-803E
Address 2B: Steer. Col. Lock (J764) Labels:| 5K0-905-861.clb
Part No SW: 5K0 905 861 D HW: 5K0 905 861 D
Component: ELV-PQ35 H22 0240
Revision: 00000000 Serial number: 16000060349004
Coding: 4100000000000000
ROD: EV_ELVMarquMPVW36X.rod
VCID: 313FE89EC1A065AFCEA-8064
Part No SW: 6RD 035 187 B HW: 6RD 035 187 B
Component: Radio 534 5314
Revision: -------- Serial number: VWZZZ4R6203904
Coding: 16000440040005
Shop #: WSC 00078 790 00217
VCID: 46D5AB4258AED2170B8-8012
Fault Status: 00111011
Reset counter: 204
Mileage: 32260 km
Date: 2018.01.19
Time: 18:08:17
Reset counter: 204
Mileage: 32260 km
Date: 2018.01.19
Time: 18:08:17
Reset counter: 204
Mileage: 32260 km
Date: 2018.01.19
Time: 18:08:17
Reset counter: 204
Mileage: 32260 km
Date: 2018.01.19
Time: 18:08:17
Reset counter: 40
Mileage: 34927 km
Date: 2018.08.16
Time: 10:17:58
End----------(Elapsed Time: 01:17, VBatt start/end: 14.3V/14.3V)-----------
