Swapping Bosch wet flooded battery to Varta AGM Battery (No BEM)
Nic_V8
C?ID=385619
Hi all, newbie here looking to replace my current wet flooded battery which has come to the end of it's days with a new Varta AGM battery. Unfortunately there is no BEM sticker on the battery and i am unsure how to code this battery in. Does anyone have experience with changing the battery from wet flooded to AGM? I will get an Auto Scan uploaded asap as not with the vehicle at the min, this is in a 2006 Audi Q7 4.2 fsi. Any help would be gratefully received, thanks.
IIRC, the Q7 of that vintage doesn't have much accommodation for different battery types.
But please do post an Auto-Scan so we can see exactly what kind of battery management this vehicle is equipped with.
Nic_V8
C?ID=385619
Wednesday,22,January,2020,10:58:43:34002
VIN: WAUZZZ4L07D045588   License Plate:
Mileage: 225820km-140318mi   Repair Order:
Chassis Type: 4L (4L0)
Scan: 01 02 03 05 07 08 09 0E 15 16 17 19 34 37 3C 42 46 47 4F 52
          55 56 57 61 62 65 6C 6D 6F 72 76 77
VIN: WAUZZZ4L07D045588   Mileage: 225820km-140318miles
0E-Media Player 1 -- Status: Malfunction 0010
57-TV Tuner -- Status: Malfunction 0010
Address 01: Engine        Labels:. 079-907-560-BAR.clb
   Part No SW: 4L0 910 560 B    HW: 4L0 907 560 A
   Component: 4.2l V8/4V FSI      0070
   Revision: 71H16---    Serial number:
   Coding: 01210003190F0560
   Shop #: WSC 00426 210 85987
   VCID: 270BFCEF93E5591FA8D-8072
002129 - Park/Neutral Switch Input Circuit
               P0851 - 004 - Short to GND - Intermittent
                    Fault Status: 00110100
                    Mileage: 225779 km
                    Temperature: 78.0°C
                    Temperature: 58.0°C
                    Absolute Pres.: 960.0 mbar
                    Voltage: 7.874 V
000048 - Oxygen (Lambda) Sensor B1 S1: Heating Circuit
               P0030 - 004 - Malfunction / Open Circuit
                    Mileage: 225779 km
                    Date: 2019.12.13
                    Time: 13:19:40
                    RPM: 1284 /min
                    Load: 45.5 %
                    Temperature: 3.0°C
                    Temperature: 6.0°C
                    Absolute Pres.: 1010.0 mbar
                    Voltage: 13.335 V
008196 - Intake Manifold Flap; Bank 1
               P2004 - 002 - Stuck Open - Intermittent
                    Mileage: 225780 km
                    Date: 2019.12.13
                    Time: 13:35:39
                    RPM: 819 /min
                    Load: 16.5 %
                    Temperature: 83.0°C
                    Temperature: 27.0°C
                    Voltage: 12.700 V
008197 - Intake Manifold Flap; Bank 2
               P2005 - 002 - Stuck Open - Intermittent
                    Mileage: 225780 km
                    Date: 2019.12.13
                    Time: 13:35:39
                    RPM: 819 /min
                    Load: 16.5 %
                    Temperature: 83.0°C
                    Temperature: 27.0°C
                    Voltage: 12.700 V
                    Temperature: -40.0°C
                    Absolute Pres.: 0.0 mbar
                    Voltage: 0.000 V
Readiness: 0110 1101
   Part No SW: 09D 927 750 FJ    HW: 09D 927 750 FJ
   Component: AL 750 6A           0938
   Revision: 00H52000    Serial number:
   Coding: 0000504
   Shop #: WSC 31414 790 00001
   VCID: 7BA3F09F3FED2DFF9C5-802E
Address 03: ABS Brakes        Labels:. 4L0-910-517-V1.clb
   Part No SW: 4L0 910 517 A    HW: 4L0 614 517 A
   Component: ESP ALLRAD MK25E1   0130
   Revision: 00H21001
   Coding: 0021553
   VCID: 2809FFD39EFB5667A17-807C
                    Reset counter: 81
                    Mileage: 225779 km
                    Date: 2019.12.13
                    Time: 12:58:30
                    Count: 14337
                    Count: 128
                    Count: 34304
                    Reset counter: 0
                    Mileage: 225779 km
                    Count: 128
                    Count: 15105
                    Count: 297
                    Count: 28928
   Component: FBSAUDIC6 ELV   H31 0220
   Revision: 31050601    Serial number: 10601100526558
   Coding: 0000147
   VCID: 6393A8FFA75DF53FB45-8036
   Subsystem 1 - Part No: 4F0 910 131 E
   Component: FBSAUDIC6 IDG   H01 0040
00532 - Supply Voltage B+
                    Reset counter: 83
                    Mileage: 225779 km
                    Date: 2019.12.13
                    Time: 12:59:54
                    Fault Frequency: 10
                    Reset counter: 83
                    Mileage: 225779 km
                    Date: 2019.12.13
                    Time: 12:58:51
Address 07: Control Head        Labels: 4L0-910-7xx-07-H.clb
   Part No SW: 4L1 910 732 H    HW: 4E0 035 729 A
   Component: Interfacebox    H43 5570
   Revision: 00000000    Serial number: 387IX067522606
   Coding: 0002002
   VCID: 2F3B14CFBB15015F60D-807A
   Component: E0380 BedienteilH02 0060
   Subsystem 2 - Serial number: 00000000515490
   Subsystem 3 - Serial number: 0105.09.060000000100010435ÿ
   Subsystem 4 - Serial number: 010435ÿ
                    Reset counter: 83
                    Time Indication: 15
   Part No SW: 4L0 910 043     HW: 4L0 820 043 F
   Revision: 00---009    Serial number: 00000000064048
   Coding: 0525320
   VCID: 619FA2F7BD41E72FA69-8034
                    Fault Status: 00101110
                    Reset counter: 82
                    Mileage: 225779 km
                    Date: 2019.12.13
                    Time: 12:51:11
                    Temperature: 23.0°C
                    Reset counter: 80
                    Mileage: 225779 km
                    Date: 2019.12.13
                    Time: 12:58:30
                    Voltage: 9.60 V
                    Reset counter: 83
                    Mileage: 225792 km
                    Date: 2020.01.01
                    Time: 03:57:34
                    Temperature: 3.0°C
                    Temperature: 3.0°C
                    Load: 28.8 %
                    Temperature: -4.0°C
                    RPM: 1240 /min
                    Absolute Pres.: 1.0 bar
                    Current: 0.000 A
                    Temperature: 3.0°C
   Part No SW: 4F0 910 279 J    HW: 4F0 907 279 A
   Coding: 0013121
   VCID: 303917B3A62B1EA7797-8064
   Subsystem 1 - Part No: 4L2 910 113   Labels: 1KX-955-119.CLB
   Component: Wischer AU716   H08 0080
   Coding: 00064792
   Shop #: WSC 31414
   Component: REGENLICHTSENSORH12 0090
   Coding: 00150059
   Shop #: WSC 31414
02385 - Rain / Light Recognition Sensor Function Restricted due to Under-Voltage
                    Reset counter: 82
                    Mileage: 225784 km
                    Date: 2019.12.30
                    Time: 12:49:00
                    Reset counter: 81
                    Mileage: 225776 km
                    Date: 2019.12.13
                    Time: 12:59:00
                    Reset counter: 81
                    Mileage: 225776 km
                    Date: 2019.12.13
                    Time: 12:59:00
   Part No SW: 4L0 910 111 A    HW: 4L0 035 111
   Component: CD-Changer      H41 0100
   Revision: 00000000    Serial number: AUZ5ZBF3041880
   VCID: 1E65D90BCCBF98D7DBB-804A
                    Reset counter: 40
                    Mileage: 225779 km
                    Date: 2019.12.13
                    Time: 13:15:41
02261 - Data Medium
                    Reset counter: 82
                    Mileage: 225792 km
                    Date: 2020.01.01
                    Time: 03:39:45
                    Text: 00000000
                    Reset counter: 80
                    Mileage: 225779 km
                    Date: 2019.12.13
                    Time: 13:00:03
   Part No SW: 4L0 910 655 B    HW: 4L0 959 655
   Component: 31 AIRBAG AUDI8RH38 0120
   Revision: 05H38000    Serial number: 0037GD06M2N6
   Coding: 0013105
   VCID: 2C0103C38A037A4745F-8078
   Subsystem 1 - Serial number: 6332QSME114F2219A
   Subsystem 2 - Serial number: 6342QSME140D1B29H
   Subsystem 3 - Serial number: 6352QSME13613E7FR
   Subsystem 4 - Serial number: 6362QSME126C4459L
   Subsystem 5 - Serial number: 63734SME1532085B-
   Subsystem 6 - Serial number: 63834SME152C1865%
   Revision: 00H08000    Serial number: 90025062340199
   Coding: 0112142
   VCID: 6695B1EB546F801753B-8032
                    Fault Frequency: 7
                    Reset counter: 83
                    Reset counter: 83
                    Mileage: 225779 km
                    Date: 2019.12.13
                    Time: 13:01:55
Address 17: Instruments        Labels: 4L0-910-xxx-17.lbl
   Part No SW: 4F0 910 930 C    HW: 4L0 920 980 F
   Component: KOMBIINSTR. M73 H17 0110
   Revision: 00400000    Serial number: 5HI56YZ76
   Coding: 2673443
   Shop #: WSC 40568 067 57207
   VCID: 2313E8FFE7DDB53FF45-8076
   Part No SW: 4L0 910 468     HW: 4L0 907 468 A
   Component: J533__Gateway   H06 0040
   Revision: 00H06000    Serial number: 0800D0682281BD
   Coding: F557FE7F343602
   Shop #: WSC 00583 210 88973
   VCID: 6C81C3C34A83BA4705F-8038
                    Reset counter: 83
                    Mileage: 225779 km
                    Date: 2019.12.13
                    Time: 13:15:43
Address 34: Level Control        Labels: 4L0-910-553.lbl
   Part No SW: 4L0 910 553 B    HW: 4L0 907 553
   Component: LUFTFDR.-CDC    H03 7550
   Revision: --H03001    Serial number: 15.1528-0095.2
   Coding: 0015510
   Shop #: WSC 00583 210 64613
   VCID: 290FFAD785F16F6FBE9-807C
                    Fault Frequency: 7
                    Reset counter: 168
                    Mileage: 225779 km
                    Date: 2019.12.13
                    Time: 12:59:03
                    Error Code: 13
                    Reset counter: 80
                    Mileage: 225779 km
                    Date: 2019.12.13
                    Time: 13:00:03
                    Error Code: 64
01577 - Turn-Off due to Over-Temp
                    Fault Status: 00100001
                    Reset counter: 83
                    Mileage: 225781 km
                    Date: 2019.12.13
                    Time: 13:36:35
                    Error Code: 68
   Part No SW: 4E0 910 887 Q    HW: 4E0 919 887 D
   Component: MNS ECE         H48 0850
   Revision: 00000000    Serial number: 399H1067535890
   VCID: 3B23309F7F6DEDFFDC5-806E
                    Reset counter: 83
                    Mileage: 225779 km
                    Date: 2019.12.13
                    Time: 13:00:31
02261 - Data Medium
                    Reset counter: 83
                    Mileage: 225792 km
                    Date: 2020.01.01
                    Time: 03:56:47
                    Hex Value: 0x0000
                    Raw, Form. N/A: 000 045 048
                    Fault Frequency: 13
                    Reset counter: 82
                    Mileage: 225779 km
                    Date: 2019.12.13
                    Time: 13:13:36
                    Reset counter: 80
                    Mileage: 225779 km
                    Date: 2019.12.13
                    Time: 13:00:10
   Part No SW: 4L0 910 566 A    HW: 4L0 907 566 A
   Component: J0769_SWA_MasterH06 0060
   Revision: 00H06000    Serial number: 6PZ 009 014-00
   Coding: 0001101
   Subsystem 1 - Part No: 4L0 910 568 A
   Component: J0770_SWA_Slave_H05 0060
   Subsystem 2 - Serial number: 6PZ 009 014-20
   Subsystem 3 - Serial number: 3F30.08.0600H0500000010219ÿ
   Subsystem 4 - Serial number: 010219ÿ
Address 42: Door Elect, Driver        Labels: 4L0-910-793-42.lbl
   Part No SW: 4L0 910 793 B    HW: 4L0 959 793 B
   Component: TSG FA          H12 0130
   Revision: 00-00000
   Coding: 0002651
                    Reset counter: 80
                    Mileage: 225779 km
                    Date: 2019.12.13
                    Time: 13:15:43
   Part No SW: 4L0 910 289 D    HW: 4L0 907 289 A
   Component: Komfortgeraet   H05 0020
   Revision: 0020 ---    Serial number: 01018817190000
   Coding: 7610619
   VCID: 313F12B7AD2117AF769-8064
01699 - Motor for Central Locking; Hatch/Trunk (V53)
            009 - Open or Short to Ground
                    Fault Status: 01101001
                    Reset counter: 42
                    Mileage: 203836 km
                    Date: 2018.03.19
                    Time: 12:38:12
                    Reset counter: 80
                    Mileage: 225779 km
                    Date: 2019.12.13
                    Time: 13:03:58
Address 47: Sound System        Labels: 4L0-910-223-BO.lbl
   Part No SW: 4L0 910 223 G    HW: 4L0 035 223 D
   Component: DSP-High AU716  H02 0150
   Revision: PROD_01     Serial number: 00000000015745
   Coding: 0000017
                    Reset counter: 83
                    Voltage: 8.00 V
                    Reset counter: 83
                    Mileage: 225787 km
                    Date: 2019.12.30
                    Time: 12:49:57
                    Voltage: 8.30 V
   Part No SW: 4F0 910 280     HW: 4F0 907 280 E
   Revision:             Serial number: 00000000008708
   Coding: 0011101
   VCID: 5EE5990B8C3FD8D79BB-800A
                    Reset counter: 83
                    Mileage: 225776 km
                    Date: 2019.12.13
                    Time: 13:00:00
                    Voltage: 6.700 V
                    Temperature: 23.0°C
                    Reset counter: 83
                    Mileage: 225776 km
                    Date: 2019.12.13
                    Time: 12:59:00
                    Voltage: 8.000 V
                    Temperature: 22.0°C
Address 52: Door Elect, Pass.        Labels: 4L0-910-793-52.lbl
   Part No SW: 4L0 910 793 B    HW: 4L0 959 792 B
   Component: TSG BF          H12 0130
   Revision: 00-00000
   Coding: 0002651
                    Reset counter: 80
                    Mileage: 225779 km
                    Date: 2019.12.13
                    Time: 13:15:43
   Coding: 0000022
                    Reset counter: 40
                    Mileage: 225784 km
                    Date: 2019.12.13
                    Time: 12:59:53
   Part No SW: 4E0 910 541 T    HW: 4E0 035 541 P
   Revision: 00000000    Serial number: 388H$067550845
                    Reset counter: 83
                    Mileage: 225779 km
                    Date: 2019.12.13
                    Time: 13:15:43
                    Fault Frequency: 229
                    Reset counter: 83
                    Mileage: 225779 km
                    Date: 2019.12.13
                    Time: 12:58:50
Address 57: TV Tuner        Labels: None
   Part No SW: 4E0 910 148 E    HW: 4E0 919 148
   Component: R0078 TVhybridT     0470
   Revision: R0H05000    Serial number: 76300700558602
   Coding: 0000303
   VCID: 2517F6E7E9E94B0F9A1-8070
                    Reset counter: 83
                    Mileage: 225779 km
                    Date: 2019.12.13
                    Time: 12:59:34
00863 - Antenna 1 for TV (R55)
            010 - Open or Short to Plus
                    Fault Status: 01101010
                    Reset counter: 40
                    Mileage: 225779 km
                    Date: 2019.12.13
                    Time: 12:50:50
   Part No SW: 4L0 910 181     HW: 4L0 915 181
   Component: J0644 BEM       H12 0530
   Revision: --------    Serial number: 00000000040765
   Shop #: WSC 00426 210 85279
   VCID: 6491ABE3A253F2074DF-8030
   Component: von VA0  2609010410
   Coding: 344630393135313035442056413032363039303130343130
                    Reset counter: 83
                    Mileage: 225779 km
                    Date: 2019.12.13
                    Time: 13:00:31
                    Fault Frequency: 16
                    Date: 2019.12.13
                    Time: 13:11:34
Address 62: Door, Rear Left        Labels: 4L0-910-795.lbl
   Part No SW: 4L0 910 795 B    HW: 4L0 959 795 B
   Coding: 0002058
                    Reset counter: 80
                    Mileage: 225779 km
                    Date: 2019.12.13
                    Time: 13:15:43
Address 65: Tire Pressure        Labels: 4F0-910-273-HI.lbl
   Part No SW: 4F0 910 273 C    HW: 4F0 907 273 A
   Revision: 00050100    Serial number: 00000700017713
   Coding: 0222424
                    Fault Status: 10100010
                    Reset counter: 80
                    Mileage: 225779 km
                    Date: 2019.12.13
                    Time: 13:00:31
                    (no units): 255.0
                    Voltage: 6.60 V
                    (no units): 42.0
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
01467 - Front Left Tire Pressure Sensor (G222)
                    Fault Status: 11100100
                    Reset counter: 43
                    Mileage: 225798 km
                    Date: 2020.01.01
                    Time: 04:38:01
                    (no units): 21.0
                    Voltage: 13.70 V
                    (no units): 46.0
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
01468 - Front Right Tire Pressure Sensor (G223)
                    Reset counter: 43
                    Mileage: 225798 km
                    Date: 2020.01.01
                    Time: 04:38:01
                    (no units): 21.0
                    Voltage: 13.70 V
                    (no units): 49.0
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
01469 - Rear Left Tire Pressure Sensor (G224)
                    Reset counter: 43
                    Mileage: 225798 km
                    Date: 2020.01.01
                    Time: 04:38:01
                    (no units): 21.0
                    Voltage: 13.70 V
                    (no units): 52.0
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
01470 - Rear Right Tire Pressure Sensor (G225)
                    Reset counter: 43
                    Mileage: 225798 km
                    Date: 2020.01.01
                    Time: 04:38:01
                    (no units): 21.0
                    Voltage: 13.70 V
                    (no units): 55.0
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
   Part No SW: 4L0 910 441 A    HW: 4L0 907 441 A
   Component: J772__Rearview      0050
   Revision: --H12---    Serial number: 525PA8-J6840ZY
   Coding: 1021001
   VCID: 2411EBE3E2D3B2078DF-8070
                    Fault Frequency: 7
                    Reset counter: 83
                    Mileage: 225779 km
                    Date: 2019.12.13
                    Time: 12:58:51
                        Reverse OFF
                    Count: 3
                    Reset counter: 43
                    Mileage: 225779 km
                    Date: 2019.12.13
                    Time: 12:59:04
                        Reverse OFF
                    Count: 3
            013 - Check DTC Memory
                    Fault Status: 01101101
                    Reset counter: 43
                    Mileage: 225828 km
                    Date: 2006.03.15
                    Time: 12:07:48
                        Reverse OFF
                    Count: 3
   Part No SW: 4L0 910 945     HW: 4L0 827 851 B
   Component: ValeoHeckdeckel H21 0280
   Revision: --H21001    Serial number: E5030000B
   Shop #: WSC 98765 666 38354
   Subsystem 3 - Serial number: RD09.09.06--H21001000A0050ÿ
   Subsystem 4 - Serial number: 0A0050ÿ
   Revision: AAH05061    Serial number: 001951261-----
   Coding: 0003587
   VCID: 2615F1EB94EF401793B-8072
   Component: J_245_EE15_SKB09H10 0180
   Component: J_394_EE15_SKB09H10 0180
   Component: J_392_EE15_SKB09H10 0180
                    Fault Frequency: 11
                    Reset counter: 83
                    Mileage: 225779 km
                    Date: 2019.12.13
                    Time: 12:59:54
Address 72: Door, Rear Right        Labels: 4L0-910-795.lbl
   Part No SW: 4L0 910 795 B    HW: 4L0 959 794 B
   Coding: 0002058
                    Reset counter: 80
                    Mileage: 225779 km
                    Date: 2019.12.13
                    Time: 13:15:43
   Part No SW: 4F0 910 283 G    HW: 4F0 919 283 G
   Component: Parkhilfe 8-Kan H12 0060
   Revision: 00H12000    Serial number: 06330624005744
   Coding: 0221146
                    Reset counter: 80
                    Mileage: 225779 km
                    Date: 2019.12.13
                    Time: 13:00:04
                    Reset counter: 80
                    Mileage: 225779 km
                    Date: 2019.12.13
                    Time: 12:59:06
   Part No SW: 4E0 910 336 M    HW: 4E0 862 335
   Component: Handyvorb2      H18 1130
   Revision: 00000000    Serial number: 00000005101268
   Coding: 0010920
   Shop #: WSC 00583 210 82263
                    Reset counter: 83
                    Mileage: 225779 km
                    Date: 2019.12.13
                    Time: 12:59:56
End----(Elapsed Time: 02:29, VBatt start/end: 11.8V/11.9V. VIgn 11.9V)-----
                Address 19: CAN Gateway       Labels: 4L0-910-468.clb
Control Module Part Number: 4L0 910 468     HW: 4L0 907 468 A
  Component and/or Version: J533__Gateway   H06 0040
           Software Coding: F557FE7F343602
            Work Shop Code: WSC 00583 210 88973
                    Reset counter: 83
                    Mileage: 225779 km
                    Date: 2019.12.13
                    Time: 13:15:43
Nic_V8
C?ID=385619
Thanks Uwe.
OK, that's what I thought. It's got the old-school, 4F-style battery manager. I'm pretty sure it expects a flooded battery. That said, I've had nothing but positive experiences with installing AGM batteries in cars that don't have a battery manager at all, so if you've already got the new AGM and can't return it for the "right" battery, I'd go ahead and install it and just change the serial number of the battery in the battery manager. Doing so tells it you've installed a new battery.
PetrolDave
Westbury, UK
C?ID=1423
+1
When the battery died on my B7 RS4 (no battery manager on the 8E platform!) I replaced it with an AGM battery of the same physical size with no issues, in fact it made starting much easier because of the higher CCA rating.
Nic_V8
C?ID=385619
Hi Uwe should i be using CAN 19 then coding 07 or 61 Battery Regulator? These are the numbers i have in each:
CAN 19, Coding 07 - F557FE7F343602
61 Battery Regulator - 344630393135313035442056413032363039303130343130
Sorry for the silly questions it's my first time using VCDS. Thanks for your help.
Nic_V8
C?ID=385619
Which one contains the serial number?
61-Battery Regulation. In coding, there should be drop-down, the first is for the module itself, and the second is for a virtual sub-system, the battery. Then you can use the battery coding assistant to change the serial number:
Neither of those looks like a serial number to me. Just change the existing serial number. Change the last digit by one.
Nic_V8
C?ID=385619
Will it not matter that the battery spec is different to the previous battery?
Like I said easlier, there's not really any explicit way to change the battery spec on that first-gen battery management system. All you really need you need to do here is tell it it's got a new battery, and changing the serial number accomplishes that.
Nic_V8
C?ID=385619
Perfect thank you very much for your help. Now got to figure out if i can turn off the TPMS as keep getting the error on the dash each time i start the vehicle. No sensors installed when i purchased the vehicle.
MartinsX
Riga, Latvia
C?ID=268515
Uwe and Dave, are You sure that installing AGM battery in a place of a regular one will not shorten it's life?
I have no data from practical experiments, but according theory AGM requires a bit different charging voltage.
From another point of view, a lot of modern cars with start-stop feature (mainly equipped with AGM batteries) use charging voltage 15V and higher to get battery recharged ASAP and keep start-stop system functional even in city traffic with a lot of stopping/starting cycles and short distances between them, and don't care about battery lifetime...
Sure? No. Confident? Yes. Back in the day when we were contemplating doing BMW software as well, we got a 2002 BMW 325i brand-new. The original (conventional) battery died quite suddenly at about 2 years. I replaced it with an AGM. It stayed in there for somewhere between 7 and 8 more years, at which time we parked had parked the car an extended period of time, and it wouldn't start when we returned to it. We jump-started it, drove it some, charged put it on a charger, and it seemed OK, but at 7-8 years of age, and knowing the battery had been in a state of substantial discharge for some time, I didn't trust it, so I replaced it. Anyway, if a car battery lasts 7-8 years, I don't think its life has been shortened.
AGM batteries will tolerate higher charge voltages (and currents) because they have very low internal resistance, but I don't think they require higher charge voltages to love a long, happy life. That said, I think it would be a terrible idea to install a conventional (wet) battery in place of an AGM in a car that's got a charging system designed for an AGM. Those higher voltages likely will shorten a wet battery's life.
The good news is that most modern VAG cars with start/stop systems do let you specify the type of battery. The bad news is I'm not sure I understand the difference between the "Fleece" and "AGM" choices available in that Adaptation channel in some Gateways. It seems to me those should be synonyms for the same type of battery.
PetrolDave
Westbury, UK
C?ID=1423
The AGM battery was still going strong when I sold my RS4 after having been in place for more years than the original wet battery - so on that (limited) experience I would say the AGM battery didn't have its life shortened.
Similarly I fitted an AGM battery to my other car (a Citroen C1) when the OE wet battery expired after 3 years, the AGM battery was in place for 7 years and I only replaced it (with an identical AGM battery) when the workshop advised that's its capacity was down to 70% and I didn't want to risk Winter starting problems as the car is only used once a week. So that experience also suggests that fitting an AGM battery in place of a wet one does not reduce its life.
MartinsX
Riga, Latvia
C?ID=268515
Sounds good! Then I have only one possibility left - to agree with You.
That was confusing me too, when I look in parts catalog. And in first gen BEM's only different battery partnumbers can be selected, without description of battery type and capacity. So I have to use some reverse investigation by comparing available partnumbers in BEM selection with the ones in parts catalog, and they did not match, because are changed from time BEM was designed... So I need to trace supersession chain, too.
Actually could bee nice to have any data do, and if yes, then how, the charging voltage/current curve really changes if selecting one of battery partnumbers marked "Fleece" in catalog.
Boki Ar
Arandjelovac, Serbia
C?ID=57300
Uwe,
what do You mean "Fleece" battery? Is a enhanced flooded battery (EFB) in question, please.
For example, if we are charging a Fleece battery, what parameters should be set? Is the rule 10% of capacity valid? (75Ah = 7.5A) and how much V? 14,8 or more...
PetrolDave
Westbury, UK
C?ID=1423
This page on the Varta website suggests that EFB batteries also use a fleece, so maybe an EFB battery is what is being referred to as "fleece"?
https://www.varta-automotive.com/en-gb/technology/efb-battery-technology
EFB batteries support applications that operate at a partial state of charge and don’t require the deep-cycling characteristics of an AGM battery. A polyfleece scrim material, added to the positive plate surface, makes this possible. This helps to stabilise the active material of the plates, which increases the endurance.
A random current GW (GatewNF) has the following choices for battery type:
  • Wet
  • Fleece
  • Wind6V
  • Wind12V
  • Ultracap
  • Gel
  • Lithium ions
  • EFB
  • Binary - AGM
  • EFB+
So it seems that there is a distinction between "Fleece", "EFB", "EFB+", and "Binary - AGM", and there is still no clarity here.
The other thing I find interesting about this list is that there's only one entry for "Lithium Ion" when it's well know that there are two quite different chemistries:
There are the 3.6-3.7V (nominal) traditional Li-ion cells; these are the type used in virtually all modern EV traction batteries (and cell phones and laptops) due to their high energy density. The can be charged to 4.2V per cell, so battery with 3 cells in series should never see more than 12.6V, but one with 4 cells in series would need a over 16V to be charged fully.
Then there is the 3.3V (nominal) LiFePo type cell, popularized by A123 Systems, that can be charged to 3.6V. They are much less volatile than traditional Li-ion cells, but also have considerably less energy density. If you buy a "Li-Ion" starter battery for a car or motorcycle (they save a lot of weight compared to a lead-acid battery), it will almost certainly have four LiFePo cells in series. That makes it compatible with most existing charging systems (but the charge voltage should not exceed 14.4V).
So which kind of "Lithium ions" battery is that entry for?
