Hi everyone, I think this may be the incorrect forum as I just noticed it is for UNVERIFIED new users, I am a verified new user. I will post it elsewhere I can work out how to transfer it to the correct forum.
I have had my 2016 Passat Highline TDI 2.0 Diesel for a while and decided I needed to add the KUFATEC PLA3.0 Park Assist to the car, I can talk about that process in the Retrofit Forum if appropriate at a later date. It seems to be coded correctly and works well.
FAULTS:
I have some other funny faults that keep coming back and one in particular with the ACC that is annoying, that is it switches off randomly it seems, you can see the fault codes 0010. There are a few modules with the same fault code but as I am a newbie I am unsure if they are related.
Full Scan of my car is shown below. Any clues and help would be appreciated. Cheers Andrew aka free2beee
FAULTS:
Saturday,28,March,2020,15:39:37:41391
VCDS Version: 19.6.2.2 (x64) HEX-V2 CB: 0.4508.4
VIN: WVWZZZ3CZGE132303 License Plate: DCU64G
Mileage: 83672km-51991mi Repair Order:
Chassis Type: 3C-VW48 (5Q0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 2B 3C 42 44 52 5F 6C A5
CF
VIN: WVWZZZ3CZGE132303 Mileage: 83672km-51991miles
Address 01: Engine (J623-DFCA) Labels:. 04L-907-309-V1.clb
Part No SW: 04L 906 026 FN HW: 04L 907 309 M
Component: R4 2,0L EDC H23 1195
Revision: B4H23---
Coding: 011D0012046505083000
Shop #: WSC 05311 115 00318
ASAM Dataset: EV_ECM20TDI01104L906026FN 002001
ROD: EV_ECM20TDI01104L906026FN_002_VW48.rod
VCID: 7BA3F1D0736F7A2F9C7-802E
Part No SW: 0D9 300 041 J HW: 02E 927 770 AQ
Component: DQ250-6F MQB H53 4906
Revision: 06253104 Serial number: TFK01510270727
Shop #: WSC 05311 115 00089
ROD: EV_TCMDQ250021.rod
VCID: 1F1BE5408737C60FD0F-804A
Part No SW: 3Q0 907 379 AB HW: 3Q0 907 379 G
Component: ESC H42 0723
Revision: 00000000 Serial number: 63185000000703
Coding: 0EEC928F34230B6E077A060041C64970492CD0E0608292F51862F03AC2A9
Shop #: WSC 17873 123 50804
VCID: 7AADF4D47C554327871-802E
8307 - Databus
[FCAN: PLA_Status_PLA_ESP signal is invalid]
Fault Frequency: 19
Reset counter: 36
Mileage: 83408 km
Date: 2020.02.27
Time: 11:34:33
16401 - Tire Pressure Warning
C102D 00 [009] - -
Reset counter: 245
Mileage: 83547 km
Date: 2020.03.12
Time: 05:59:19
Part No SW: 3Q0 959 435 C HW: 3Q0 959 435 C
Component: VWKESSYMQB 036 0710
Revision: 00036000 Serial number: 0385786377
Coding: 0F00100F03
Shop #: WSC 04174 123 61029
ASAM Dataset: EV_KessyHellaMQBAB 004032
VCID: 3A2D34D43CD58327C71-806E
Part No SW: 5G0 907 044 BG HW: 5G0 907 044 BG
Component: Climatronic H04 1202
Revision: 00001K10
Coding: 1112010430210000111550401210180A
ASAM Dataset: EV_ACClimaBHBVW37X 005137
ROD: EV_ACClimaBHBVW37X_005_VW37.rod
VCID: 6D87CF883D1BE49F123-8038
Geber f¸r K‰ltemitteldruck/K‰ltemitteltemperatur:
263682 - Exterior Air Quality/Humidity Sensor
B137A 31 [008] - No Signal
Reset counter: 36
Mileage: 83651 km
Date: 2020.03.24
Time: 15:20:21
Voltage terminal 30: 14.5 V
Outside air temperature: 23.5 ∞C
System run time-Engine running time: 255 s
System run time-Terminal 15 on: 255 s
Address 09: Cent. Elect. (J519) Labels:| 5Q0-937-08X-MV1.clb
Part No SW: 5Q0 937 086 AJ HW: 5Q0 937 086 AJ
Revision: -------- Serial number: 86581111151510
Coding: 03011B46C2C102FF07A04094B11007281880000000000000000000000000
ROD: EV_BCMBOSCH_015.rod
VCID: 025D8C3414850BE7DF1-8056
Subsystem 1 - Part No SW: 3G2 955 119 A HW: 3G1 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS 150801 043 0607
Serial number: 150930150330
Subsystem 2 - Part No SW: 5Q0 955 547 A HW: 5Q0 955 547 A Labels: 5Q0-955-547.CLB
Component: RLHS 037 0059
Serial number: S4Y15M11D19H15M36S17
Coding: 90A8DD
Light switch:
Subsystem 3 - Part No SW: 3G0 941 633 HW: 3G0 941 633
Component: E1 - LDS MQB H01 0032
Serial number: 15 06 2015 10000699
Subsystem 4 - Part No SW: 5Q0 951 172 HW: 5Q0 951 172
Serial number: 000000000ZY1527208K0
Subsystem 5 - Part No SW: 5Q0 951 605 A HW: 5Q0 951 605 A
Component: Sirene, DWA 005 0312
Serial number: 00000000000033891458
534549 - Databus
Reset counter: 23
Mileage: 83408 km
Date: 2020.02.27
Time: 11:33:16
540693 - Databus
Reset counter: 238
Mileage: 83408 km
Date: 2020.02.27
Time: 11:33:16
204546 - Remote key 2
Reset counter: 238
Mileage: 83411 km
Date: 2020.02.27
Time: 11:48:52
Address 10: Park/Steer Assist (J791) Labels:| 5Q0-919-298.clb
Part No SW: 5QA 919 298 C HW: 5QA 919 298 A
Serial number: 000308417618339
Coding: 0371167851
ROD: EV_EPHVA2CAU3700000.rod
VCID: 50F9767C8A692977195-8004
Address 13: Auto Dist. Reg (J428) Labels:| 3Q0-907-572.clb
Part No SW: 3Q0 907 572 B HW: 3Q0 907 572 B
Component: ACC BOSCH MQB H04 0192
Coding: 320467D251FFC428949C804D
Shop #: WSC 00015 115 00001
ASAM Dataset: EV_ACCBOSCHVW48X 001008
ROD: EV_ACCBOSCHVW48X.rod
VCID: 34311AEC1EB175571DD-8060
1538 - Sensor for Automatic Distance Control
[FAULT_SENSOR_BLIND]
Reset counter: 29
Mileage: 83497 km
Date: 2020.03.06
Time: 15:21:06
Control Module temperature: 42 ∞C
Voltage terminal 15: 12.8 V
Velocity_vehicle_reference: 28.51 m/s
Longitudinal_acceleration_vehicle_reference: 0.06 m/s≤
Status_ACC_System: ACC_activ_controlled
1542 - Sensor for Automatic Distance Control
[FAULT_SYSTEM_BLIND]
Reset counter: 29
Mileage: 83498 km
Date: 2020.03.06
Time: 15:21:32
Control Module temperature: 41 ∞C
Voltage terminal 15: 13.0 V
Velocity_vehicle_reference: 29.54 m/s
Longitudinal_acceleration_vehicle_reference: 0.34 m/s≤
Status_ACC_System: ACC_Override
Part No SW: 3Q0 959 655 BB HW: 3Q0 959 655 BB
Component: Airbag VW20 013 0195
Revision: -------- Serial number: 003STPPAKVGF
Coding: 98FCC0C0000000005C540000008800000065
Shop #: WSC 05314 000 00001
ROD: EV_AirbaVW20TS6VW48X.rod
VCID: 7F5B05C06777660FB0F-802A
Subsystem 1 - Part No SW: ----------- HW: 454 000 111 15
Serial number: 3576U00000065689971G
Subsystem 2 - Part No SW: ----------- HW: 454 000 111 15
Serial number: 3586U000000ED489971V
Subsystem 3 - Part No SW: ----------- HW: 454 800 211 15
Component: SideSensor_Dr 301 0148
Serial number: 3516R5962C5080000003
Subsystem 4 - Part No SW: ----------- HW: 454 802 410 15
Component: SideSensor_Pr 301 0148
Serial number: 3526R6E93BC08000000K
Subsystem 5 - Part No SW: ----------- HW: 454 801 610 15
Component: FrontSensor_D 304 0149
Serial number: 3556V18CCC108000000I
Address 16: Steering wheel (J524) Labels:| 5Q0-953-549.clb
Part No SW: 3Q0 953 521 B HW: 5Q0 953 569 A
Component: Lenks.Modul 075 0195
Revision: FF033033 Serial number: 20151021400459
Coding: 0810
ROD: EV_SMLSVALEOMQB.rod
VCID: 2F3B1580F797568F60F-807A
Part No SW: 3G0 920 751 A HW: 3G0 920 751 A
Component: KOMBI 301 6421
Coding: 27A401186798000801887B0B1000000000000000
VCID: 2313E9B0AB5FE2EFF47-8076
U1014 00 [009] - -
Fault Frequency: 34
Reset counter: 251
Mileage: 83408 km
Date: 2020.02.27
Time: 11:31:28
16776980 - Databus
[PLA_Status_01 keine Kommunikation]
Reset counter: 238
Mileage: 83408 km
Date: 2020.02.27
Time: 11:31:29
Part No SW: 5Q0 907 530 AJ HW: 5Q0 907 530 M
Component: GW MQB High 212 2246
Revision: -------- Serial number: 09111510800334
Coding: 030300345F087300FB0002581C0F00010001070000000000000000000000
ROD: EV_GatewConti_013.rod
VCID: 79AFEBD87953483F8EB-802C
Subsystem 2 - Part No SW: 5G0 959 442 K HW: 5G0 959 442 K Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H17 0040
Serial number: 29150002186110075451
Coding: 2CFFFF
Subsystem 3 - Part No SW: 5Q0 915 181 G HW: 5Q0 915 181 G
Component: J367-BDMHella H04 8050
Serial number: 1488858203
Analog clock:
Subsystem 4 - Part No SW: 3G0 919 204 C HW: 3G0 919 204 C
Component: Analoguhr 209 2002
Part No SW: 3Q0 905 861 HW: 3Q0 905 861
Component: ELV-MQBB H05 0032
Serial number: 15000154107005
Coding: 0800000000000000
ROD: EV_ELVMarquMQBB.rod
VCID: 71BFD3F82123007F36B-8024
Address 3C: Lane Change (J769) Labels:| 3Q0-907-566.clb
Part No SW: 3Q0 907 566 B HW: 3Q0 907 566
Component: MRR1Rear H16 0230
Revision: --------
Coding: 44C002
ASAM Dataset: EV_RearRadarS1BoschVW48X 001002
VCID: 372B2DE00FC79E4F38F-8062
Component: TSG FS 020 0041
Serial number: 220815BHM11588
Coding: 00351A208001020000000000
VCID: 43D349304B1FC2EF947-8016
Subsystem 1 - Part No SW: 5Q4 959 811 E HW: 5Q4 959 811 E Labels: 5QX-959-81X-V1.CLB
Serial number: 00000000000002557486
Coding: 0D0000
Part No SW: 5Q0 909 144 S HW: 5Q0 909 144 R
Component: EPS_MQB_ZFLS 125 1063
Coding: 9303
VCID: 44D14A2C4E11C5D7ADD-8010
Component: TSG BFS 020 0041
Serial number: 011015BIU19426
Coding: 003510208001020000000000
VCID: 42DD4C345405CBE79F1-8016
Subsystem 1 - Part No SW: 5Q4 959 812 E HW: 5Q4 959 812 E Labels: 5QX-959-81X-V1.CLB
Serial number: 00000000000002560819
Coding: 050000
Part No SW: 3G0 035 045 G HW: 3G0 035 045
Component: MU-H-N-RW H50 0343
Serial number: A688J0FB000689
Coding: 02840108FF00000051510001000828001F0204C601200102DF
VCID: 221DECB4B445EBE7FF1-8076
Subsystem 1 - Part No SW: 5G0 919 606 HW: 5G0 919 606
Component: ABT_High H62 0031
Serial number: VWZ8Z9RU30423C
Subsystem 2 - Part No SW: V03 959 806 FQ HW: -----------
Component: ROW 2019/2020 --- 0079
Subsystem 3 - Part No SW: V03 959 800 EG HW: -----------
Component: Gracenote2 --- 4008
Address 6C: Back-up Cam. (J772) Labels:| 5Q0-980-556.clb
Part No SW: 5Q0 980 556 HW: 5Q0 980 556
Component: RVC Compact H07 0100
Coding: 0184010162002017000040
Shop #: WSC 05311 000 00197
ROD: EV_CamSysRVRVCPANAMQBAB_005_VW48.rod
VCID: 77ABEDE04F475E4FF8F-8022
Address A5: Frt Sens. Drv. Assist (R242) Labels:| 3Q0-980-65X-A5.clb
Part No SW: 3Q0 980 654 C HW: 3Q0 980 654
Component: MQB_B_MFK H04 0023
Serial number: 12111511K20116
Coding: 000408010000010100022346C050410084000E000020
Address CF: Lane Chge Asst 2 (J770) Labels:. 3Q0-907-566.clb
Part No SW: 3Q0 907 590 B HW: 3Q0 907 590
Revision: --------
Coding: 44C002
ASAM Dataset: EV_RearRadarS2BoschVW48X 001002
End----------(Elapsed Time: 02:07, VBatt start/end: 12.0V/12.0V)-----------
