Upgrading 2012 USA Passat SE to highline BCM - central locking remote matching
compu_85
Springfield, VA
C?ID=152533
I am attempting to install a used highline BCM so I can run factory style foglights on our 2012 NMS Passat SE, replacing the 5K0 937 085 S BCM with a highline edit 5K0 937 087 Q. The highline module is from a wreck, but seems to work fine except for one issue - I can't get the central locking remotes to pair.
I've tried the procedure here, but adaptation channel 1 is not available. Is there something basic I'm overlooking? I did check that there are no fault codes in the BCM.
The SEL which the control module came from had Kessy, which I assume has a different procedure than the non Kessy cars. I recall that you could get a SE trim passat with foglights but not Kessy so I would think I should be able to get this working.
Thanks!
-Jason
Spacewalker
Poland
C?ID=159607
Thanks!
-Jason
You will not fix it via VCDS :(
We already spoke with Rosstech about that ,
I also had few of this BCM from Skoda with Kessy
One parameter is locked in a EEprom memory that is why channel 1 is Not available and there is nothing which can be fix via cooding
VCDS must do some huuuuuge update in a future, make software much much stronger, anyway will not be a Number 1 on the market.
compu_85
Springfield, VA
C?ID=152533
You mean other than posting an Auto-Scan? ;)
Here's the AS with the stock control unit. If it will help I can post an AS with the control unit I'm trying to get working.
Wednesday,16,January,2013,09:34:22:37565
VCDS Version: Beta 12.10.2 (x64)
Data version: 20121222
Chassis Type: 7N0
Scan: 01 02 03 08 09 15 16 17 19 1C 25 42 44 46 4F 52 56 62 72 77
VIN: 1VWBN7A32CC0XXXXX
Address 01: Engine (J623-CKRA)       Labels: 03L-906-012-CKR.clb
   Part No SW: 03L 906 012 BP    HW: 03L 907 309 S
   Component: R4 2,0L EDC   H21 2158
   Revision: 71H21---    Serial number:
   Coding: 001D0012042400000000
   Shop #: WSC 09003 957 00200
   ASAM Dataset: EV_ECM20TDI01103L906012BP 004004
   ROD: EV_ECM20TDI01103L906012BP.rod
   VCID: 73CB1363DA27958685F
Address 02: Auto Trans        Labels: 02E-300-0xx.lbl
   Part No SW: 02E 300 057 P    HW: 02E 927 770 AL
   Component: GSG DSG AG6     512 3113
   Revision: 05551213    Serial number: 00001201202009
   VCID: 266D3A379175B02ED21
   Revision: 00H31001
   Coding: C54BC0F549290000A31003E5921A0042A71000
   VCID: 7DDF355BE463D3F6E3B
02214 - Tire Pressure Warning
                    Reset counter: 108
                    Mileage: 32014 km
                    Date: 2008.14.25
                    Time: 11:33:04
                    Count: 32768
                    Count: 4608
                    Count: 16401
                    Count: 51712
                    Count: 1
                    Count: 1278
   Part No SW: 561 907 044 H    HW: 561 907 044 H
   Component: Climatronic   043 0202
   Revision: 00001001
   Coding: 0010001002
   ROD: EV_ACClimaBHBVW411_VW41.rod
   VCID: 1C1918DF17397AFE745
   Part No SW: 5K0 937 085 S    HW: 5K0 937 085 S
   Component: BCM PQ35 B+   021 0064
   Revision: BH021001
   Coding: 6F200EBBFC2B28D408080001160008C80271A09040A00560648060040C70
   VCID: 43AB83A3C2076506D5F
   Component: RLS 160312 05  54  0403
   Coding: 06300A
   Part No SW: 5C0 959 655     HW: 5C0 959 655
   Component: AirbagVW10G   013 0809
   Serial number: 003ENM01ZYWZ
   Coding: 00003548
   ASAM Dataset: EV_AirbaVW10SMEVW360 A01024
   ROD: EV_AirbaVW10SMEVW360.rod
   VCID: EFC39F13360F3166E17
   Subsystem 1 - Part No SW: 5C6 959 339 A    HW: 5C6 959 339 A
   Component: BF-Gewichtss.  H10 0045
   Serial number: 6940000Y120000D1RS0$
   Coding: 303044
   Serial number: 3572MSME6D616569ZZZ2
   Serial number: 3582MSME5B20146AZZZX
   Serial number: 3516KSME73062B17ZZZQ
   Serial number: 3526KSME77183A17ZZZY
   Serial number: 3556LSME3C097C15ZZZ0
   Crash sensor for front airbag; passenger side:
   Serial number: 3566LSME29157C15ZZZ.
   Part No SW: 1K5 953 521 AK    HW: 5K0 953 569 B
   Revision: FF010040    Serial number: 20120124100193
   Coding: 088A160000
   ROD: EV_SMLSNGVOLWS.rod
   VCID: 76CD2A77C95580AEA21
   Subsystem 1 - Part No SW: 3C8 959 537 D    HW: 3C8 959 537 D
   Component: E221__MFL-YVJ  H06 0022
   Coding: E20000
   Part No SW: 561 920 970 C    HW: 561 920 970 C
   Component: KOMBI         H07 0507
   Coding: 631E01
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04093
   ROD: EV_Kombi_UDS_VDD_RM09_SK25.rod
   VCID: 1A151EC71D0D04CE669
   Part No SW: 7N0 907 530 P    HW: 1K0 907 951
   Component: J533  Gateway H40 1623
   Revision:   H40       Serial number: 24031201290535
   Coding: 461000
   VCID: 3D5FF55BA4E313F6A3B
   Part No SW: 561 919 965     HW: 561 919 965
   Component: Kompass         002 0001
   Revision: 00002000    Serial number: 1829227R1E0906
   VCID: E3EBE32322C7850675F
   Component: IMMO          H07 0507
   VCID: EAF58E070DEDD44EB69
   Component: TUER-SG FT    002 0525
   Revision: 13110009    Serial number: 0004242632
   Coding: 0404F5
   ASAM Dataset: EV_TSGFPQ25BRFVW46X A04001
   ROD: EV_TSGFPQ25BRFVW46X.rod
   VCID: DB9BDBC3D2B7BDC63DF
   Slave Driver:
   Subsystem 1 - Part No SW: 561 959 811     HW: 561 959 811   Labels: 3C0-959-70X-GEN4.CLB
   Component: J388__TSG_HL  004 4472
   Coding: 800000
   Part No: 1K0 909 144 N
   Component: EPS_ZFLS Kl. 290    3301
   Revision: 00H22000
   VCID: 354FED7B5CD3CBB66BB
   Component: EZE_2         H40 1623
   Coding: 01030108
   VCID: EFC39F133E0F3166E17
   Subsystem 1 - Part No SW: 561 959 591     HW: 561 959 591
   Component: J245 P05 FFD7  H07 0004
   Coding: 181100
   Subsystem 2 - Part No SW: 561 919 204 B    HW: 561 919 204 B
   Component: Analoguhr  008 0004
   Component: TUER-SG BT    002 0525
   Revision: 15110009    Serial number: 0004254922
   Coding: 0404F4
   ASAM Dataset: EV_TSGBPQ25BRFVW46X A04001
   ROD: EV_TSGBPQ25BRFVW46X.rod
   VCID: DC99D8DFD7B9BAFE345
   Slave Passenger:
   Subsystem 1 - Part No SW: 561 959 812     HW: 561 959 812   Labels: 3C0-959-70X-GEN4.CLB
   Component: J389__TSG_HR  004 4472
   Coding: 800000
Address 56: Radio (J503)       Labels: 5M0-035-1xx-56.clb
   Part No SW: 1K0 035 180 AE    HW: 1K0 035 180 AE
   Component: Radio Prem-8  H02 0016
   Revision: -----16S    Serial number: VWZ4Z7M3271340
   Coding: 0500040004000B
   VCID: 63EB632362C70506F5F
03138 - Input AUX IN
                    Reset counter: 66
                    Mileage: 31998 km
                    Date: 2008.14.24
                    Time: 15:40:34
Address 77: Telephone (J412)       Labels: 7P6-035-730.clb
   Part No SW: 5K0 035 730 E    HW: 5K0 035 730 E
   Component: TELEFON       H09 2902
   Revision: 1B001001    Serial number: 00007661964486
   Coding: 0A10040000010110
   ASAM Dataset: EV_UHVNA A01719
   ROD: EV_UHVNA.rod
   VCID: 277337335E7FA926E97
-J
compu_85
Springfield, VA
C?ID=152533
So it seems like I can add keys to the lowline module:
And with the highline - note I had the wrong part number in the OP:
Here's an autoscan with the highline BCM:
Friday,11,July,2014,08:05:00:37565
VCDS Version: 14.7.0.0 (x64)
Data version: 20140601
VIN: 1VWBN7A32CC0XXXXX   License Plate: COMPU
Mileage: 96090km-59707mi   Repair Order:
Chassis Type: A3 (7N0)
VIN: 1VWBN7A32CC076511   Mileage: 96090km-59707miles
   VCID: 73CB1363DA2795A262-8026
18648 - NOx Sensor 1 Bank 1
          P2201 00 [096] - Implausible Signal
   Coding: 0000024
   VCID: 266D3A379175B00A35-8073
   Revision: 00H31001
   VCID: 7DDF355BE463D3D204-8028
   Revision: 00001001
   Coding: 0010001002
   ROD: EV_ACClimaBHBVW411.rod
   VCID: 1C1918DF17397ADA93-8049
   Part No SW: 5K0 937 087 Q    HW: 5K0 937 087 Q
   Component: BCM PQ35 H+   111 0147
   Revision: BL111001
   Coding: 6F200EBFDC2B28D448080001360000C807F1A00041A005205A8860000C70
   VCID: 43AB83A3C207652232-8016
   Coding: 03300A
   Coding: 00003548
   VCID: 6FC31F13B60FB14286-803A
   Coding: 303044
   Coding: 088A160000
   VCID: 76CD2A77C955808A45-8023
   Coding: E20000
   Coding: 631E01
   ROD: EV_Kombi_UDS_VDD_RM09_SE35.rod
   VCID: 1A151EC71D0D04EA81-804F
   Coding: 461000
   VCID: 3D5FF55BA4E313D244-8068
   VCID: 63EB6323A2C7052212-8036
   ROD: EV_Immo_UDS_VDD_RM09_SE36.rod
   VCID: 6AF50E078DED546AD1-803F
   Coding: 0404F5
   VCID: 5B9B5BC352B73DE25A-800E
   Slave Driver:
   Subsystem 1 - Part No SW: 561 959 811     HW: 561 959 811   Labels: 1K0-959-70X-GEN4.CLB
   Coding: 800000
   Revision: 00H22000
   VCID: 354FED7B5CD3CB928C-8060
   Coding: 01030108
   VCID: 6FC31F13BE0FB14286-803A
   Coding: 181100
   Coding: 0404F4
   VCID: 5C9958DF57B93ADA53-8009
   Slave Passenger:
   Subsystem 1 - Part No SW: 561 959 812     HW: 561 959 812   Labels: 1K0-959-70X-GEN4.CLB
   Coding: 800000
   Component: Radio Prem-8  H02 0008
   Coding: 05000400040024
   Shop #: WSC 40945 444 66060
   VCID: 63EB632362C7052212-8036
   ROD: EV_UHVNA.rod
   VCID: 277337335E7FA9020E-8072
End-------------------------(Elapsed Time: 02:06)--------------------------
Thanks,
-J
compu_85
Springfield, VA
C?ID=152533
FWIW here's the adaptation map for the highline bcm:\
;SW:5K0-937-087-Q   HW:5K0-937-087-Q ---  Cent. Elect.
;Component:BCM PQ35 H+   111 0147, Coding:6F200EBFDC2B28D448080001360000C807F1A00041A005205A8860000C70
;Friday,11,July,2014,08:18:25:37565
;VCDS Version: Beta 14.7.0 (x64)  Data version: 20140601
;VCID: 43AB83A3C207652232-8016
Channel,,Field 1,Field 2,Field 3,Field 4,
01,,ERROR:,Channel 01,Not,Available,
02,,ERROR:,Channel 02,Not,Available,
03,1,OPEN,Single Door,1,-,
04,,ERROR:,Channel 04,Not,Available,
05,1,Auto Unlock, ,ON,-,
06,1,Comfort,Remote Ctrl.,ON,-,
07,,ERROR:,Channel 07,Not,Available,
08,,ERROR:,Channel 08,Not,Available,
09,,ERROR:,Channel 09,Not,Available,
10,0,Unlocked,Beep,OFF,-,
11,1,Locked,Beep,ON,-,
12,1,safe,Blink,Delay,-,
13,,ERROR:,Channel 13,Not,Available,
14,,ERROR:,Channel 14,Not,Available,
15,,ERROR:,Channel 15,Not,Available,
16,,ERROR:,Channel 16,Not,Available,
17,1,Comfort,CLOSE,ON,-,
18,0,Alarm delay,Door Open,OFF,-,
19,0,Locked,Inactive,OFF,-,
20,1,Beep,Inactive,20.0 ms,-,
21,,ERROR:,Channel 21,Not,Available,
22,0,Adapt Value,Erase, ,-,
23,255,Coming Home, ,255.00 s,-,
24,255,Leaving Home, ,255.00 s,-,
25,15,Timer Rear,Window Htr.,15,-,
26,,ERROR:,Channel 26,Not,Available,
27,200,Pas.Door 1-W,Footwell light.,100.00 %,-,
28,,ERROR:,Channel 28,Not,Available,
29,0,10.00 V,Status,Erase,-,
30,60,AFL,Delay,-68.0 ms,-,
31,4,Comfort,Blink,4,-,
32,0,Start,Function,0,-,
33,4,wiper,After-Run,4.00 s,-,
34,,ERROR:,Channel 34,Not,Available,
35,,ERROR:,Channel 35,Not,Available,
36,,ERROR:,Channel 36,Not,Available,
37,,ERROR:,Channel 37,Not,Available,
38,,ERROR:,Channel 38,Not,Available,
39,,ERROR:,Channel 39,Not,Available,
40,,ERROR:,Channel 40,Not,Available,
41,,ERROR:,Channel 41,Not,Available,
42,,ERROR:,Channel 42,Not,Available,
43,,ERROR:,Channel 43,Not,Available,
44,,ERROR:,Channel 44,Not,Available,
45,,ERROR:,Channel 45,Not,Available,
46,,ERROR:,Channel 46,Not,Available,
47,,ERROR:,Channel 47,Not,Available,
48,,ERROR:,Channel 48,Not,Available,
49,,ERROR:,Channel 49,Not,Available,
50,,ERROR:,Channel 50,Not,Available,
51,,ERROR:,Channel 51,Not,Available,
52,,ERROR:,Channel 52,Not,Available,
53,,ERROR:,Channel 53,Not,Available,
54,,ERROR:,Channel 54,Not,Available,
55,,ERROR:,Channel 55,Not,Available,
56,,ERROR:,Channel 56,Not,Available,
57,,ERROR:,Channel 57,Not,Available,
58,,ERROR:,Channel 58,Not,Available,
59,,ERROR:,Channel 59,Not,Available,
60,,ERROR:,Channel 60,Not,Available,
61,,ERROR:,Channel 61,Not,Available,
62,,ERROR:,Channel 62,Not,Available,
63,,ERROR:,Channel 63,Not,Available,
64,,ERROR:,Channel 64,Not,Available,
65,,ERROR:,Channel 65,Not,Available,
66,,ERROR:,Channel 66,Not,Available,
67,,ERROR:,Channel 67,Not,Available,
68,,ERROR:,Channel 68,Not,Available,
69,,ERROR:,Channel 69,Not,Available,
70,,ERROR:,Channel 70,Not,Available,
71,,ERROR:,Channel 71,Not,Available,
72,,ERROR:,Channel 72,Not,Available,
73,,ERROR:,Channel 73,Not,Available,
74,,ERROR:,Channel 74,Not,Available,
75,,ERROR:,Channel 75,Not,Available,
76,,ERROR:,Channel 76,Not,Available,
77,,ERROR:,Channel 77,Not,Available,
78,,ERROR:,Channel 78,Not,Available,
79,,ERROR:,Channel 79,Not,Available,
80,,ERROR:,Channel 80,Not,Available,
81,,ERROR:,Channel 81,Not,Available,
82,,ERROR:,Channel 82,Not,Available,
83,,ERROR:,Channel 83,Not,Available,
84,,ERROR:,Channel 84,Not,Available,
85,,ERROR:,Channel 85,Not,Available,
86,,ERROR:,Channel 86,Not,Available,
87,,ERROR:,Channel 87,Not,Available,
88,,ERROR:,Channel 88,Not,Available,
89,,ERROR:,Channel 89,Not,Available,
90,,ERROR:,Channel 90,Not,Available,
91,,ERROR:,Channel 91,Not,Available,
92,,ERROR:,Channel 92,Not,Available,
93,,ERROR:,Channel 93,Not,Available,
94,,ERROR:,Channel 94,Not,Available,
95,,ERROR:,Channel 95,Not,Available,
96,,ERROR:,Channel 96,Not,Available,
97,,ERROR:,Channel 97,Not,Available,
98,,ERROR:,Channel 98,Not,Available,
99,,ERROR:,Channel 99,Not,Available,
100,,ERROR:,Channel 100,Not,Available,
101,,ERROR:,Channel 101,Not,Available,
102,,ERROR:,Channel 102,Not,Available,
103,,ERROR:,Channel 103,Not,Available,
104,,ERROR:,Channel 104,Not,Available,
105,,ERROR:,Channel 105,Not,Available,
106,,ERROR:,Channel 106,Not,Available,
107,,ERROR:,Channel 107,Not,Available,
108,,ERROR:,Channel 108,Not,Available,
109,,ERROR:,Channel 109,Not,Available,
110,,ERROR:,Channel 110,Not,Available,
111,,ERROR:,Channel 111,Not,Available,
112,,ERROR:,Channel 112,Not,Available,
113,,ERROR:,Channel 113,Not,Available,
114,,ERROR:,Channel 114,Not,Available,
115,,ERROR:,Channel 115,Not,Available,
116,,ERROR:,Channel 116,Not,Available,
117,,ERROR:,Channel 117,Not,Available,
118,,ERROR:,Channel 118,Not,Available,
119,,ERROR:,Channel 119,Not,Available,
120,,ERROR:,Channel 120,Not,Available,
121,,ERROR:,Channel 121,Not,Available,
122,,ERROR:,Channel 122,Not,Available,
123,,ERROR:,Channel 123,Not,Available,
124,,ERROR:,Channel 124,Not,Available,
125,,ERROR:,Channel 125,Not,Available,
126,,ERROR:,Channel 126,Not,Available,
127,,ERROR:,Channel 127,Not,Available,
128,,ERROR:,Channel 128,Not,Available,
129,,ERROR:,Channel 129,Not,Available,
130,,ERROR:,Channel 130,Not,Available,
131,,ERROR:,Channel 131,Not,Available,
132,,ERROR:,Channel 132,Not,Available,
133,,ERROR:,Channel 133,Not,Available,
134,,ERROR:,Channel 134,Not,Available,
135,,ERROR:,Channel 135,Not,Available,
136,,ERROR:,Channel 136,Not,Available,
137,,ERROR:,Channel 137,Not,Available,
138,,ERROR:,Channel 138,Not,Available,
139,,ERROR:,Channel 139,Not,Available,
140,,ERROR:,Channel 140,Not,Available,
141,,ERROR:,Channel 141,Not,Available,
142,,ERROR:,Channel 142,Not,Available,
143,,ERROR:,Channel 143,Not,Available,
144,,ERROR:,Channel 144,Not,Available,
145,,ERROR:,Channel 145,Not,Available,
146,,ERROR:,Channel 146,Not,Available,
147,,ERROR:,Channel 147,Not,Available,
148,,ERROR:,Channel 148,Not,Available,
149,,ERROR:,Channel 149,Not,Available,
150,,ERROR:,Channel 150,Not,Available,
151,,ERROR:,Channel 151,Not,Available,
152,,ERROR:,Channel 152,Not,Available,
153,,ERROR:,Channel 153,Not,Available,
154,,ERROR:,Channel 154,Not,Available,
155,,ERROR:,Channel 155,Not,Available,
156,,ERROR:,Channel 156,Not,Available,
157,,ERROR:,Channel 157,Not,Available,
158,,ERROR:,Channel 158,Not,Available,
159,,ERROR:,Channel 159,Not,Available,
160,,ERROR:,Channel 160,Not,Available,
161,,ERROR:,Channel 161,Not,Available,
162,,ERROR:,Channel 162,Not,Available,
163,,ERROR:,Channel 163,Not,Available,
164,,ERROR:,Channel 164,Not,Available,
165,,ERROR:,Channel 165,Not,Available,
166,,ERROR:,Channel 166,Not,Available,
167,,ERROR:,Channel 167,Not,Available,
168,,ERROR:,Channel 168,Not,Available,
169,,ERROR:,Channel 169,Not,Available,
170,,ERROR:,Channel 170,Not,Available,
171,,ERROR:,Channel 171,Not,Available,
172,,ERROR:,Channel 172,Not,Available,
173,,ERROR:,Channel 173,Not,Available,
174,,ERROR:,Channel 174,Not,Available,
175,,ERROR:,Channel 175,Not,Available,
176,,ERROR:,Channel 176,Not,Available,
177,,ERROR:,Channel 177,Not,Available,
178,,ERROR:,Channel 178,Not,Available,
179,,ERROR:,Channel 179,Not,Available,
180,,ERROR:,Channel 180,Not,Available,
181,,ERROR:,Channel 181,Not,Available,
182,,ERROR:,Channel 182,Not,Available,
183,,ERROR:,Channel 183,Not,Available,
184,,ERROR:,Channel 184,Not,Available,
185,,ERROR:,Channel 185,Not,Available,
186,,ERROR:,Channel 186,Not,Available,
187,,ERROR:,Channel 187,Not,Available,
188,,ERROR:,Channel 188,Not,Available,
189,,ERROR:,Channel 189,Not,Available,
190,,ERROR:,Channel 190,Not,Available,
191,,ERROR:,Channel 191,Not,Available,
192,,ERROR:,Channel 192,Not,Available,
193,,ERROR:,Channel 193,Not,Available,
194,,ERROR:,Channel 194,Not,Available,
195,,ERROR:,Channel 195,Not,Available,
196,,ERROR:,Channel 196,Not,Available,
197,,ERROR:,Channel 197,Not,Available,
198,,ERROR:,Channel 198,Not,Available,
199,,ERROR:,Channel 199,Not,Available,
200,,ERROR:,Channel 200,Not,Available,
201,,ERROR:,Channel 201,Not,Available,
202,,ERROR:,Channel 202,Not,Available,
203,,ERROR:,Channel 203,Not,Available,
204,,ERROR:,Channel 204,Not,Available,
205,,ERROR:,Channel 205,Not,Available,
206,,ERROR:,Channel 206,Not,Available,
207,,ERROR:,Channel 207,Not,Available,
208,,ERROR:,Channel 208,Not,Available,
209,,ERROR:,Channel 209,Not,Available,
210,,ERROR:,Channel 210,Not,Available,
211,,ERROR:,Channel 211,Not,Available,
212,,ERROR:,Channel 212,Not,Available,
213,,ERROR:,Channel 213,Not,Available,
214,,ERROR:,Channel 214,Not,Available,
215,,ERROR:,Channel 215,Not,Available,
216,,ERROR:,Channel 216,Not,Available,
217,,ERROR:,Channel 217,Not,Available,
218,,ERROR:,Channel 218,Not,Available,
219,,ERROR:,Channel 219,Not,Available,
220,,ERROR:,Channel 220,Not,Available,
221,,ERROR:,Channel 221,Not,Available,
222,,ERROR:,Channel 222,Not,Available,
223,,ERROR:,Channel 223,Not,Available,
224,,ERROR:,Channel 224,Not,Available,
225,,ERROR:,Channel 225,Not,Available,
;Friday,11,July,2014,08:21:34:37565
226,,ERROR:,Channel 226,Not,Available,
227,,ERROR:,Channel 227,Not,Available,
228,,ERROR:,Channel 228,Not,Available,
229,,ERROR:,Channel 229,Not,Available,
230,,ERROR:,Channel 230,Not,Available,
231,,ERROR:,Channel 231,Not,Available,
232,,ERROR:,Channel 232,Not,Available,
233,,ERROR:,Channel 233,Not,Available,
234,,ERROR:,Channel 234,Not,Available,
235,,ERROR:,Channel 235,Not,Available,
236,,ERROR:,Channel 236,Not,Available,
237,,ERROR:,Channel 237,Not,Available,
238,,ERROR:,Channel 238,Not,Available,
239,,ERROR:,Channel 239,Not,Available,
240,,ERROR:,Channel 240,Not,Available,
241,,ERROR:,Channel 241,Not,Available,
242,,ERROR:,Channel 242,Not,Available,
243,,ERROR:,Channel 243,Not,Available,
244,,ERROR:,Channel 244,Not,Available,
245,,ERROR:,Channel 245,Not,Available,
246,,ERROR:,Channel 246,Not,Available,
247,,ERROR:,Channel 247,Not,Available,
248,,ERROR:,Channel 248,Not,Available,
249,,ERROR:,Channel 249,Not,Available,
250,,ERROR:,Channel 250,Not,Available,
251,,ERROR:,Channel 251,Not,Available,
252,,ERROR:,Channel 252,Not,Available,
253,,ERROR:,Channel 253,Not,Available,
254,,ERROR:,Channel 254,Not,Available,
255,,ERROR:,Channel 255,Not,Available,
compu_85
Springfield, VA
C?ID=152533
So no ideas? Does the remote central locking work the same on Kessy and non Kessy cars? I did confirm the BCM I got was from a 2012 Passat TDI SEL (a very early car).
Thanks,
-J
Andy
Sector 7G
HC424490
It occurs to me that the KESSY cars have remotes that support remote start as well. It's possible that only those flavor of remotes are compatible with that flavor of BCM? Just a guess.
Spacewalker
Poland
C?ID=159607
No. BCM with "unable to adapt remote" was removed from Kessy cars and also from non kessy cars. Hard to say why that issure happen
compu_85
Springfield, VA
C?ID=152533
Bumping this up....
So I played around with this some tonight. When I check block 091 it shows that 2 remotes are paired. In block 092 the values respond when I press remote buttons (With the fixed code "Not OK" and variable code "OK".
Any hints why the BCM might be blocking adaptation block 1?
Thanks,
-J
compu_85
Springfield, VA
C?ID=152533
FWIW, here's the adaptation map:
;Component:BCM PQ35 H+   111 0147	 Coding:6F200EBFEC2B28D448080001360000C807F1A00041A005205A8868000C70
;Friday	7	July	2017	21:12:41:04834
;VCDS Version: Beta 17.6.0 (x64)  Data version: 20170602 DS274
;VCID: 43C68F21C2873A5F9C-8016
Channel		Field 1	Field 2	Field 3	Field 4
1		ERROR:	Channel 01	Not	Available
2		ERROR:	Channel 02	Not	Available
3	1	OPEN	Single Door	1	 -
4		ERROR:	Channel 04	Not	Available
5	1	Auto Unlock	 	ON	 -
6	1	Comfort	Remote Ctrl.	ON	 -
7		ERROR:	Channel 07	Not	Available
8		ERROR:	Channel 08	Not	Available
9		ERROR:	Channel 09	Not	Available
10	0	Unlocked	Beep	OFF	 -
11	1	Locked	Beep	ON	 -
12	1	safe	Blink	Delay	 -
13		ERROR:	Channel 13	Not	Available
14		ERROR:	Channel 14	Not	Available
15		ERROR:	Channel 15	Not	Available
16		ERROR:	Channel 16	Not	Available
17	1	Comfort	CLOSE	ON	 -
18	0	Alarm delay	Door Open	OFF	 -
19	0	Locked	Inactive	OFF	 -
20	1	Beep	Inactive	20.0 ms	 -
21		ERROR:	Channel 21	Not	Available
22	0	Adapt Value	Erase	 	 -
23	255	Coming Home	 	255.00 s	 -
24	255	Leaving Home	 	255.00 s	 -
25	15	Timer Rear	Window Htr.	15	 -
26		ERROR:	Channel 26	Not	Available
27	200	Pas.Door 1W	Footwell light.	100.00%	 -
28		ERROR:	Channel 28	Not	Available
29	0	10.00 V	Status	Erase	 -
30	60	AFL	Delay	-68.0 ms	 -
31	4	Comfort	Blink	4	 -
32	0	Start	Function	0	 -
33	4	wiper	After-Run	4.00 s	 -
34		ERROR:	Channel 34	Not	Available
35		ERROR:	Channel 35	Not	Available
There was nothing after #33.
I tried adding the start access module to the gateway list and removing it, no change.
Jetta 97
Dallas (McKinney) ,TX ,USA
C?ID=81680
The problem is that Kessy cars adopt remote to BCM when you adopt key to immobilizer. It is like older Vw Touareq, AUDI A8 , and etc.
There is not separate procedure for remote and immobilizer like on none Kessy cars.
So it is not VCDS problem , Even if you have legit ODIS online connection, you will not be able to do this.
compu_85
Springfield, VA
C?ID=152533
So the BCM is different on Kessy and non-Kessy cars? I have a non-Kessy car. I can tell the high BCM has the radio receiver since it can see the keys.
That does seem to be the problem here, I need the BCM to see that it's in a non-Kessy car now.
-J
Jetta 97
C?ID=81680
Yes , of course.
You need to find none kessy BCM that support fog light, if they ever mad it , I am not familiar with this, as I never done this retrofit.
compu_85
Springfield, VA
C?ID=152533
Ok, thanks for the info.
