Audi a6 Allroad problem coding
p.yotov
Bulgaria
C?ID=239054
hi, i have here audi a6 2006 allroad. In the menu for Level Control is only 4 options not like allroad suspension with 5 position. I cant find what is changed to miss the 5 position in the menu. any ideas will be great
Thursday,03,October,2019,16:32:20:55583
VCDS Version: 19.6.1.0  HEX-NET CB: 0.4513.4
VIN: WAUZZZ4F96N111106   License Plate:
Mileage: 212330km-131935mi   Repair Order:
Gateway Installation List:  4F0 910 468 A
55-Headlight Range -- Status: Not registered 0001
Thursday,03,October,2019,16:53:48:55583
Chassis Type: 4F (4F0)
Scan: 01 02 03 05 07 08 09 0E 15 16 17 19 34 37 42 46 47 4F 52 53
          55 56 61 62 69 6D 72 77
VIN: WAUZZZ4F96N111106   Mileage: 212330km-131935miles
Address 01: Engine        Labels: 059-907-401-ASB.clb
   Part No SW: 4F0 910 402 N    HW: 4F0 907 401 B
   Component: 3.0L V6TDI  G000AG  0020
   Revision: --H01---    Serial number:
   Coding: 0011372
   Shop #: WSC 66565 257 00032
   VCID: 281C01969B2A040FF1-807C
005715 - Please check DTC Memory of ABS Controller
               P1653 - 002 -
                    Fault Status: 01100010
                    Mileage: 211914 km
                    Date: 2020.01.15
                    Time: 14:00:03
                    RPM: 756 /min
                    Torque: 66.3 Nm
                    Duty Cycle: 1.0 %
                    Voltage: 13.98 V
                    Bin. Bits: 00001100
                    Torque: 179.4 Nm
006217 - Please check DTC Memory of Transmission Controller
               P1849 - 008 -  - Intermittent
                    RPM: 63 /min
                    Torque: 226.2 Nm
                    (no units): 0.0
                    Voltage: 5.93 V
                    Torque: 581.4 Nm
   Part No SW: 4F1 910 156 B    HW: 09L 927 156 A
   Component: AG6 09L 3,0 TDI RdW 0050
   Revision: --H01---    Serial number:        4110781
   Shop #: WSC 19460 666 12345
   VCID: 230616BAE20CE757A4-8076
Address 03: ABS Brakes        Labels: 4F0-910-517.clb
   Part No SW: 4F0 910 517 L    HW: 4F0 614 517 L
   Component: ESP 8.0 quattro H04 0090
   Coding: 0000396
   Shop #: WSC 02325 785 00200
   VCID: 2D12F082B4C8212702-8078
                    Reset counter: 3
                    Mileage: 212332 km
                    Date: 2020.01.22
                    Time: 14:50:08
                    Hex Value: 0x0000
                    Hex Value: 0x4282
                    Hex Value: 0x0024
                    Hex Value: 0x01AD
                    Hex Value: 0x00FF
   Part No SW: 4F0 910 852 B    HW: 4F0 905 852 E
   Component: FBSAUDIC6 ELV   H08 0210
   Revision: 00H08000    Serial number: 10604102225377
   Coding: 0000131
   Shop #: WSC 01114 002 1048576
   VCID: 250208A2EC381967CA-8070
   Subsystem 1 - Part No: 4F0 910 131 E
   Component: FBSAUDIC6 EZS   H45 0070
   Component: FBSAUDIC6 IDG   H39 0040
   Part No SW: 4F0 910 730 F    HW: 4E0 035 729
   Component: Interfacebox    H43 2120
   Revision: 00000000    Serial number: 350K-057617955
   Coding: 0012002
   Shop #: WSC 95417 954 999999
   VCID: 240415A6E702E06FDD-8070
   Component: Bedienteil MMIC6H08 0050
   Subsystem 2 - Serial number: 00000000273784
   Subsystem 3 - Serial number: 0109.11.050000000100010659ÿ
   Subsystem 4 - Serial number: 010659ÿ
   Part No SW: 4F0 910 043     HW: 4F1 820 043 S
   Component: KLIMABETAETIGUNGH12 0160
   Revision: 00000027    Serial number: 00000000204048
   Coding: 0000374
   VCID: 5BF66E5A9AFC9F97AC-800E
   Part No SW: 4F0 910 279 D    HW: 4F0 907 279
   Component: ILM Fahrer      H15 0190
   Coding: 0012121
   Shop #: WSC 02335 785 00200
   VCID: 2A18FB9E8526361FE7-807E
   Subsystem 1 - Part No: 4F1 910 113   Labels: 1KX-955-119.CLB
   Component: Wischer AudiC6  H05 0150
   Coding: 00062736
   Shop #: WSC 02335
   Coding: 00141886
   Shop #: WSC 02335
   Part No SW: 4E0 910 111 F    HW: 4E0 035 111 A
   Component: CD-Changer      H44 0470
   Revision: 00000000    Serial number: AUZ5ZBE8015649
   VCID: 1C742D46DF72D8AF65-8048
   Part No SW: 4F0 910 655 E    HW: 4F0 959 655 B
   Component: 43 AIRBAG AUDI8RH29 0260
   Revision: 07H29000    Serial number: 0037LD0B0E3T
   Coding: 0013363
   VCID: 291A049280203D07EE-807C
   Subsystem 1 - Serial number: 6332CSME0C6464575
   Subsystem 2 - Serial number: 6342CSME0C644D2DG
   Subsystem 3 - Serial number: 6352QSME0250161F7
   Subsystem 4 - Serial number: 6362QSME06371D0BJ
   Subsystem 5 - Serial number: 63734SME024E0729$
   Subsystem 6 - Serial number: 63834SME024E77171
   Component: Lenksäulenmodul H07 0230
   Revision: 00H07000    Serial number: 90026053090227
   Coding: 0002142
   Shop #: WSC 02323 785 00200
   VCID: 66804FAE51BED27F03-8032
   Part No SW: 4F0 910 930 A    HW: 4F0 920 931 F
   Component: KOMBIINSTR. M73 H16 0670
   Revision: 00200000    Serial number: 4PV7149C5
   Coding: 2081003
   VCID: 210A1CB2F810F547B6-8074
Address 19: CAN Gateway        Labels:. 4F0-910-468.clb
   Component: Gateway         H11 0070
   Revision: 11          Serial number: 1300805B13012F
   Coding: 6DFE5BC41B3106
   VCID: 271E02AA96340B77F8-8072
                    Reset counter: 3
                    Mileage: 212332 km
                    Date: 2020.01.22
                    Time: 14:35:16
Address 34: Level Control        Labels: 4F0-910-553.clb
   Part No SW: 4F0 910 553     HW: 4F0 907 553
   Component: J197 LUFTFEDER  H15 0040
   Serial number: 006280018540
   Coding: 0000220
   VCID: 618A5CB2B890B547F6-8034
                    Fault Status: 11101101
                    Reset counter: 3
                    Mileage: 212332 km
                    Date: 2020.01.22
                    Time: 14:35:11
   Part No SW: 4E0 910 888 P    HW: 4E0 919 887 D
   Component: MNS ECE         H48 1060
   Revision: 00000000    Serial number: 364GT067576303
   Shop #: WSC 08744 264 88789
   VCID: 3B36CEDA7ABCBF978C-806E
02927 - DVD Read Error
                    Reset counter: 42
                    Mileage: 212319 km
                    Date: 2020.01.21
                    Time: 11:12:51
                    Hex Value: 0x5E26
                    Hex Value: 0xDCEE
                    Hex Value: 0x0401
                    Hex Value: 0x0000
   Component: TSG FA          H12 0080
   Revision: 00-00000
   Coding: 0001642
   Shop #: WSC 02327 785 00200
   VCID: 2C14FD868FD2282F15-8078
   Part No SW: 4F0 910 289 B    HW: 4F0 907 289 B
   Component: Komfortgeraet   H18 0130
   Revision: 01300018    Serial number: 01007823600000
   Coding: 3285637
            009 - Open or Short to Ground
                    Fault Status: 01101001
                    Reset counter: 2
                    Mileage: 212120 km
Address 47: Sound System        Labels: 4F0-910-223-AS.lbl
   Part No SW: 4F0 910 223 C    HW: 4F0 035 223
   Component: Amp.-ASK        H10 0320
   Revision: 34S00001    Serial number: 00404060251551
   Coding: 0000102
   Shop #: WSC 20995 000 1048576
   VCID: 1E70274EC96ECABF8B-804A
   Part No SW: 4F0 910 280     HW: 4F0 907 280
   Revision:             Serial number: 00000000099314
   Coding: 0001003
   VCID: 5EF0674E89EE8ABFCB-800A
   Component: TSG BF          H12 0080
   Revision: 00-00000
   Coding: 0001642
   Part No SW: 4F0 910 801     HW: 4F0 907 801
   Component: EPB  C63C0030   H03 0030
   Revision: C63C0030
   Coding: 0000321
   Shop #: WSC 02334 785 00200
   VCID: 5DF2604284E891A7D2-8008
   Part No: 8P0 907 357 F
   Coding: 0000004
   VCID: 3D32C0C264A8B1A7B2-8068
01535 - Control Circuit for Right Headlight Range Adjusting Motor (V49)
                    Fault Status: 11101010
                    Reset counter: 3
                    Mileage: 212328 km
                    Date: 2020.01.22
                    Time: 14:35:12
01534 - Control Circuit for Left Headlight Range Adjusting Motor (V48)
                    Reset counter: 3
                    Mileage: 212328 km
                    Date: 2020.01.22
                    Time: 14:35:12
   Part No SW: 4E0 910 541 L    HW: 4F0 035 541 E
   Component: TUNER EU/US/RDW H42 0560
   Revision: 00000000    Serial number: 352K 057596931
   Revision: 00000000    Serial number: 00000000153713
   Shop #: WSC 06348 116 57033
   Component: von TU3  2511070827
   Coding: 344630393135313035442054553332353131303730383237
   Shop #: WSC 12345 384 00290
   Coding: 0001066
   VCID: 2E10F78EB9CE5A3F3B-807A
Address 69: Trailer        Labels: 4F0-910-383.lbl
   Part No SW: 4F0 910 383     HW: 4F0 907 383
   Component: ANHAENGERELEKTR H02 0020
   Coding: 0000331
   VCID: 628853BEBD96AE5FEF-8036
Address 6D: Trunk Elect.        Labels: Redir Fail!
   Part No SW: 4F9 910 591     HW: 4F9 827 851 F
   Component: ValeoHeckdeckel H25 0290
   Revision: --H25001    Serial number: E5030000B
   VCID: 6C943D864F52E82F55-8038
   Subsystem 1 - Part No: 4F9 910 592
   Component: ValeoHeckdeckel H18 0280
   Subsystem 3 - Serial number: RD08.11.05--H18001001A0043ÿ
   Subsystem 4 - Serial number: 1A0043ÿ
00317 - Rear Lid Control Module (J605)
                    Reset counter: 23
                    Mileage: 207396 km
   Part No SW: 4F0 910 795 E    HW: 4F0 959 794 E
   Coding: 0001066
   Part No SW: 4E0 910 336 L    HW: 4E0 862 335
   Component: Handyvorb2      H20 1120
   Revision: 00000000    Serial number: 00000005194401
   Coding: 0010930
   Shop #: WSC 00316 223 90254
   VCID: 2B16FE9A8ADC2F171C-807E
End----------(Elapsed Time: 01:49, VBatt start/end: 14.0V/14.0V)-----------
Moving to Tweaks.
TBAx
C?ID=287144
Does the car have the Allroad parameters? If not, there is no way to enable the Allroad suspension mode.
You can test incrementing apk 66 in module 09 by 32 and see if this changes anything.
p.yotov
Bulgaria
C?ID=239054
All is ok the car is like s6 with air suspension, it move up and down ok. But the highest position is missing from the menu
