Hi I am planning a retrofit of the Direct measurement TPMS system onto my audi a7 / other mini project cars in the near future. i have purchased a new controller 5q0907273b. and yes i know it is the wrong module for the car.
what i have noticed on my setup is. can high / can low seemed to be swapped around compared to what other fourms have stated.
pin1, can low
pin2, 12v
pin3, can high
pin4, gnd
but have managed communication with VCDS on my bench setup.
i am expecting the missing message error codes as i am running this on the bench and not the car and emulating terminal 15 signal but its the invalid data recorded i believe i need sorting.
in adaptation i have found the following options. can someone post there adaption valves im hoping if i set them in the module will stop complaining.
or in the basic setting the three digit number required to complete the static calibration.
any help would be great
pin1, can low
pin2, 12v
pin3, can high
pin4, gnd
Friday,31,May,2019,20:36:52:02338
VCDS Version: 18.9.1.0 (x64) HEX-NET CB: 0.4505.4
VIN: License Plate: TPMS BLANK
Address 65: Tire Pressure
Control Module Part Number: 5Q0 907 273 B
Component and/or Version: RDKBERU30 H04 0009
Software Coding:
Work Shop Code:
VCID: 342411779F324DEA09-8060
Advanced Identification/FAZIT
Serial number: 30000000199536
Identification: BEB-018
Date: 21.06.18
Manufacturer number: 0683
Test stand number: 9536
Flash Status
Programming Attempts(application): 1/0/0
Programming Attempts(data): 0
Successful Attempts(data): 0
Flash Date: 00.00.00
Flash Tool Code(data): 00000 000 00000
Misc.
Hardware number: 5Q0 907 273
Workshop System Name: J502
Equipment/PR Code: 000000000000000000000000
Dataset Number: -----------
Dataset Version: ----
ASAM Dataset: EV_RDKBERU30
ASAM Dataset Revision: 006001
VCDS Info:
Labels: 3AA-907-273.clb
ROD: EV_RDKBERU30_006_VW37.rod
Friday,31,May,2019,20:37:33:02338
VIN: License Plate: TPMS BLANK1
Address 65: Tire Pressure Labels: 3AA-907-273.clb
Control Module Part Number: 5Q0 907 273 B HW: 5Q0 907 273
Software Coding:
Work Shop Code:
ASAM Dataset: EV_RDKBERU30 006001 (VW37)
6 Faults Found:
8390146 - Calibration
C114C F0 [009] - Type Incorrectly Set
Reset counter: 0
Time: 00:00:00
12652550 - invalid data record
B2005 00 [009] - -
Reset counter: 0
Time: 00:00:00
12656647 - No Communication with ABS Brake Control Module
U0121 00 [009] - -
[CAN Bremse keine Kommunikation]
Reset counter: 0
Time: 00:00:00
12656662 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
[Kl15 keine CAN Kommunikation]
Reset counter: 40
Time: 00:00:00
12656664 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
[Kombiinstrument keine CAN Kommunikation]
Reset counter: 0
Time: 00:00:00
12656671 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
[Gateway keine CAN Kommunikation]
Reset counter: 0
Time: 00:00:00
Friday,31,May,2019,20:39:28:02338
VIN: License Plate: TPMS BLANK2
UDS Adaptation Channel (1B): IDE03508-SPECIFIED pressure line selection (end of assembly line)
Stored value 255
Stored value 255
UDS Adaptation Channel (1B): IDE03511-Front-axle SPECIFIED pressure fully loaded
Stored value 255
UDS Adaptation Channel (1B): IDE03512-Rear-axle SPECIFIED pressure fully loaded
Stored value 255
UDS Adaptation Channel (5B): IDE03513-IDE03525-Write sensor identification number-Sensor identification number (sensor ID)
Stored value 0
UDS Adaptation Channel (5B): IDE03513-IDE06104-Write sensor identification number-Wheel position
Stored value Left front
UDS Adaptation Channel (1B): IDE03532-Load status selected
Stored value Unknown (0)
UDS Adaptation Channel (1B): IDE08521-Front-axle SPECIFIED pressure comfort
Stored value 255
UDS Adaptation Channel (1B): IDE08522-Rear-axle SPECIFIED pressure comfort
Stored value 255
UDS Adaptation Channel (1B): IDE08523-Front-axle SPECIFIED pressure standard
Stored value 255
UDS Adaptation Channel (1B): IDE08524-Rear-axle SPECIFIED pressure standard
Stored value 255
UDS Adaptation Channel (1B): MAS02356-Type of calibration
Stored value Menu
