Hi!
I was changing my oil here the other day, and some time ago my radio went dead, i was about to finish up, when i thought i just should check my fuses to see if i had missed one blown one for the radio.
But, there was one thing i did wrong, my ignition was on!
I was checking the fuses, and i checked them all, both in the enginebay and under the dash.
When i got in to the car after, almost every warning light lighted up my car on the inside.
I connected the car, and here is what i found out.
Address 01: DTCs cleared
This was the first one. And when i tried a second time, i got this.
As you can se on the 03 ABS, one the first log it can not be reached, on the second one, it is sporadic comm.
Does anyone have a hint or clur where i should begin?
It looks like everything ends up with the ABS unit?!
HELP ME PLEASE!!
Saturday,26,August,2017,13:00:06:18381
VCDS Version: 17.8.0.1 (x64)
VIN: WVGZZZ1TZ6W001897 License Plate:
Mileage: 265610km-165042mi Repair Order:
Chassis Type: 1T (1K0)
Scan: 01 03 08 09 15 16 17 18 19 25 42 44 46 52 56 62 69 72
VIN: WVGZZZ1TZ6W001897 Mileage: 265610km-165042miles
03-ABS Brakes -- Status: Cannot be reached 1100
Address 01: Engine Labels: 03G-906-016-BKC.clb
Part No SW: 03G 906 016 CD HW: 028 101 194 5
Component: R4 1,9L EDC G000SG 6246
Revision: 12345678 Serial number: VWZ7Z0E2162445
Coding: 0000072
Shop #: WSC 01324 785 00200
VCID: 67DDDCB5562A197E2B-8032
18057 - Powertrain Data Bus
P1649 - 000 - Missing Message from ABS Controller
Torque: 46.0 Nm
Speed: 4.0 km/h
Voltage: 12.01 V
Bin. Bits: 00001000
Torque: 0.0 Nm
Bin. Bits: 00000000
Readiness: 0 0 1 1 1
Address 03: ABS Brakes
Part No: 1K0 907 044 BA
Component: ClimatronicPQ35 066 0606
Address 09: Cent. Elect. Labels:. 3C0-937-049-23-H.lbl
Part No SW: 3C0 937 049 E HW: 3C0 937 049 E
Component: Bordnetz-SG H37 1002
Revision: 00H37000 Serial number: 00000001916004
Coding: 098B8F210004100000120C000000000000087F075C
VCID: 2B5560858A42FD1E0F-807E
Subsystem 1 - Component: Fehler Lin-Slave 01
02071 - Local Databus
Reset counter: 95
Mileage: 265611 km
Voltage: 12.30 V
00153 - Windshield Wiper Motor; Driver Side (V216)
Reset counter: 95
Mileage: 265611 km
Voltage: 12.30 V
Address 15: Airbags Labels: 1T0-909-605.lbl
Part No SW: 1T0 909 605 C HW: 1T0 909 605 C
Component: 02 AIRBAG VW62 0506 1500
Revision: 09025000 Serial number: 0038BD0DBRZZ
Coding: 0012338
VCID: 356146FD5C06BBEE69-8060
Part No SW: 1K0 953 549 F HW: 1K0 953 549 F
Component: Lenks‰ulenmodul 021 0050
Coding: 0000042
Part No: 1T0 920 872 A
Component: KOMBIINSTRUMENT VDD 1112
Coding: 0007101
Shop #: WSC 44402 001 1048576
VCID: 326B7DE1AD68ACD64C-8066
Address 18: Aux. Heat Labels: 1K0-815-071.clb
Part No: 1K0 815 071 H
Component: Zuheizer 031 1312
Revision: A Serial number: 09010046
Coding: 0000011
VCID: 2A5B658185B8E416F4-807E
Address 19: CAN Gateway Labels:. 1K0-907-530-V1.clb
Part No SW: 1K0 907 530 F HW: 1K0 907 951
Component: Gateway H10 0120
Revision: H10 Serial number: 28001055180419
Coding: 3D3F5340078002
Reset counter: 95
Mileage: 265611 km
Time: 11:19:36
01304 - Radio
Reset counter: 95
Mileage: 265611 km
Time: 11:19:40
Component: IMMO VDD 1112
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN1.lbl
Part No: 1T0 959 701
Component: Tuersteuergeraet 09 0157
Coding: 0000116
VCID: 74E7BBF917FCE2E69E-8020
Part No: 1K1 909 144 J
Component: EPS_ZFLS Kl.5 D04 1606
00625 - Vehicle Speed Signal
Mileage: 5600 km
Temperature: 16.0∞C
Voltage: 12.20 V
Voltage: 11.90 V
Part No SW: 1K0 959 433 AR HW: 1K0 959 433 AR
Component: 01 KSG PQ35 G2 010 0101
Revision: 00010000 Serial number: 00000000000000
Coding: 009002085103087F2D06840560084F01E0A500
VCID: 000FE7295344CE468A-8054
01312 - Powertrain Data Bus
013 - Check DTC Memory
Fault Status: 01101101
Reset counter: 95
Mileage: 265611 km
Time: 11:46:17
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN1.lbl
Part No: 1T0 959 702
Coding: 0000116
VCID: 75E186FD1C86FBEEA9-8020
Address 56: Radio
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN1.lbl
Part No: 1K0 959 703 B
Component: Tuersteuergeraet 06 0214
Coding: 0000048
VCID: 2F6D7495BE5A813E23-807A
Address 69: Trailer
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN1.lbl
Part No: 1K0 959 704 B
Coding: 0000048
VCID: 306F77E9A3649EC63A-8064
End-------------------------(Elapsed Time: 01:48)--------------------------
Saturday,26,August,2017,12:24:21:18381
VIN: WVGZZZ1TZ6W001897 License Plate: AR96294
Mileage: 265610km-165042mi Repair Order: anette
03-ABS Brakes -- Status: Sporadic communication error 1000
Coding: 0000072
RPM: 798 /min
Torque: 34.0 Nm
Speed: 4.0 km/h
Voltage: 14.14 V
Bin. Bits: 00001000
Torque: 156.0 Nm
Bin. Bits: 00000000
Readiness: 1 1 0 0 0
Subsystem 1 - Part No: 1T0 955 119 C Labels: 1KX-955-119.CLB
Component: Wischer VW358 012 0401
Coding: 00065493
Shop #: WSC 01324
Coding: 0012338
Coding: 0000042
Coding: 0007101
Coding: 0000011
Reset counter: 135
Mileage: 265611 km
Time: 00:15:58
01304 - Radio
Fault Frequency: 17
Reset counter: 95
Mileage: 265611 km
Time: 00:16:03
Coding: 0000116
Mileage: 5600 km
Temperature: 24.0∞C
Voltage: 14.20 V
Voltage: 14.00 V
Reset counter: 95
Mileage: 265611 km
Time: 11:06:44
Coding: 0000116
Address 56: Radio
Coding: 0000048
Address 69: Trailer
Coding: 0000048
End-------------------------(Elapsed Time: 01:45)--------------------------
HELP ME PLEASE!!
