Hi
I've just picked up this car and had a week of trouble free motoring. Then, coming home from work I put the gear selector in S and accelerated hard. When the RPM rose above 3000 I got the flashing glow plug coil and a message to restrict RPM to 2500 Max and the car went in to limp mode. Turning the car off and back on again cleared the restriction and limp mode was disabled. I tried a hard acceleration in D and the same thing happened when the revs got above 3000 RPM. When I got home VCDS gave me the following.
Under the Fuel and Oil Px Sw faults above, why is the Engine Speed and Crankshaft Speed different and also the Vehicle Speeds?
The day after, I tried a hard acceleration again in S mode and only the Oil Px Sw showed up as a fault.
Could the glow plug faults be causing the oil and fuel switch problems?
A friend who used to have a similar year A6 said that the instrument pod can also cause ECM faults. Would this show up on a different address as well though if the pod was at fault?
Any help/knowledge greatly received.
Jase
Monday,25,March,2019,20:54:56:35452
VCDS Version: 18.9.1.0 (x64)
VIN: WAUZZZ8T59A007207 License Plate:
Chassis Type: 8T-AU48 (8T0)
Scan: 01 02 03 05 06 07 08 09 0E 10 15 16 17 19 1E 36 37 42 46 47
52 53 55 56 77
VIN: WAUZZZ8T59A007207 Mileage: 238620km-148271miles
Address 01: Engine (J623-CCWA) Labels:| 059-907-401-V1.clb
Part No SW: 8K2 907 401 HW: 8K1 907 401 A
Component: 3.0TDI EDC17 X01 0006
Revision: 15X01---
Coding: 0114002C190F0120
Shop #: WSC 92521 052 00000
ASAM Dataset: EV_ECM30TDI0118K2907401 001006
ROD: EV_ECM30TDI0118K2907401.rod
VCID: 6ADDBF518DF5951A63-803E
6 Faults Found:
7144 - Please Check DTC Memory in CAN Gateway (J533)
U1008 00 [040] - -
Mileage: 237405 km
Date: 2018.12.02
Time: 14:33:42
Engine speed: 657.00 /min
Normed load value: 11.8 %
Coolant temperature: 81 °C
Intake air temperature: 18 °C
Voltage terminal 30: 11.300 V
Unlearning counter according OBD: 5
Crankshaft speed (RPM): 657.0 /min
Vehicle speed: 0.00 km/h
Accelerator position: 0.00 %
Vehicle voltage terminal 30: 11300 mV
Bus Diag st Node 0-Bits 0-7: 00000000
Com ct Rx TO BEM-Bits 0-7: 00000000
Cr C st Key 0-Bits 0-7: 00000000
5211 - Fuel Rail/System Pressure
P0087 00 [096] - Too Low
5212 - Fuel Rail/System Pressure
5580 - Oil Pressure Switch
P164B 00 [032] - Malfunction
Mileage: 238594 km
Date: 2019.03.24
Time: 20:15:07
Engine speed: 2703.50 /min
Normed load value: 12.5 %
Vehicle speed: 99 km/h
Coolant temperature: 77 °C
Intake air temperature: 24 °C
Voltage terminal 30: 14.200 V
Crankshaft speed (RPM): 2274.0 /min
Vehicle speed: 139.07 km/h
Vehicle voltage terminal 30: 14120 mV
C Eng Ds T u Raw: 745.0 mV
Co Eng st: COENG_RUNNING
Engine oil temperature: 80.1 °C
5417 - Cylinder 5 Glow Plug Circuit (Q14)
P0675 00 [047] - Electrical Fault
Mileage: 223341 km
Date: 2017.06.29
Time: 17:43:24
Engine speed: 878.00 /min
Normed load value: 29.4 %
Coolant temperature: 12 °C
Intake air temperature: 13 °C
Voltage terminal 30: 13.500 V
Crankshaft speed (RPM): 878.0 /min
Vehicle voltage terminal 30: 13540 mV
Coolant temperature: 12.8 °C
Glow status-Bits 0-7: 00000000
Glow status-Bits 0-7: 10110000
Glw Plg r LVS Ps: 22.70 %
Intake air temperature: 13.8 °C
5418 - Cylinder 6 Glow Plug Circuit (Q15)
P0676 00 [047] - Electrical Fault
Mileage: 237284 km
Date: 2018.12.01
Time: 07:10:07
Engine speed: 947.50 /min
Normed load value: 32.9 %
Coolant temperature: 6 °C
Intake air temperature: 6 °C
Voltage terminal 30: 13.340 V
Crankshaft speed (RPM): 947.5 /min
Vehicle voltage terminal 30: 13200 mV
Coolant temperature: 6.0 °C
Glw Plg r LVS Ps: 23.18 %
Intake air temperature: 6.4 °C
Address 02: Auto Trans (J217) Labels:| 0B6-927-156.clb
Part No SW: 8K0 927 158 A HW: 0B6 927 156
Component: 0B6 30 TDIRdW H04 0030
Revision: --H04---
Coding: 001001
Shop #: WSC 06325 000 00000
ASAM Dataset: EV_TCMAL651 A01004
ROD: EV_TCMAL651.rod
VCID: 346161299FB113EA09-8060
4765 - Functionality limited due to Engine Control Module
P1719 00 [040] - -
Mileage: 237883 km
Date: 2019.01.13
Time: 09:52:32
Engine speed: 2217.00 /min
Transmission input speed: 2235 /min
Transmission output speed: 3238 /min
Engine torque: -60 Nm
Transmission fluid temperature: 41 °C
Accelerator position: 0.0 %
Clutch status: 1
Part No SW: 8K0 907 379 AB HW: 8K0 907 379 AB
Component: ESP8 quattro H04 0060
Coding: 140500
VCID: 79FF901DF0532E829A-802C
Part No SW: 8K0 907 289 C HW: 8K0 907 289 C
Component: BCM2.01 H38 0253
Revision: 00003002
Coding: 011000
VCID: 397F501DB0D3EE82DA-806C
Subsystem 1 - Part No SW: 8T0 959 754 D HW: 8T0 959 754 D
Component: FBSAUDIB8 IDG H37 0060
Serial number: 0508000028732018
Component: ELVAUDIB8 H35 0039
Serial number: 0208000010999012
Address 06: Seat Mem. Pass (J521) Labels:. 8T0-959-760.clb
Part No SW: 8T0 959 760 B HW: 8T0 959 760 B
Component: MEM-BFS H09 0043
Revision: AA000000 Serial number: 00001001106448
Coding: 08217025002400001000
VCID: 428D37F1DD05AD5A8B-8016
Address 07: Control Head Labels: 8T0-035-7xx-07-H.clb
Part No SW: 8T0 035 729 T HW: 4E0 035 729
Component: Interfacebox H43 5570
Revision: 00000000 Serial number: 329G 087583491
Coding: 0005002
VCID: 4A9D1FD12535751A43-801E
Subsystem 1 - Part No: 8T0 919 609
Component: E0380 BedienteilH08 0100
Subsystem 2 - Serial number: 00000000107313
Subsystem 3 - Serial number: 0128.06.080000000100010323ÿ
Subsystem 4 - Serial number: 010323ÿ
Reset counter: 237
Mileage: 237200 km
Date: 2018.11.09
Time: 17:02:50
Bin. Bits: 00000001 00000000
Bin. Bits: 00000000 00000001
Bin. Bits: 00000000 00000000
Address 08: Auto HVAC (J255) Labels:. 8Tx-820-043-3Z.clb
Part No SW: 8T2 820 043 T HW: 8T2 820 043 T
Component: KLIMA 3 ZONEN H06 0140
Revision: D1000000 Serial number: 0117.06.080535
Coding: 36060000
VCID: 438332F5C21FA45280-8016
Part No SW: 8K0 907 063 D HW: 8K0 907 063 D
Component: BCM1 1.0 H22 0253
Revision: 05022001 Serial number: 00000000168198
Coding: 260050914034AF010009000300005D5D001D438800010141000000
Shop #: WSC 06325 123 12345
VCID: 30696D3963A92FCA6D-8064
Subsystem 1 - Part No SW: 8T2 955 119 C HW: 8J2 955 119 Labels: 1KX-955-119.CLB
Component: WWS 010708 H11 0040
Serial number: SWFBIE 0000014
Coding: 00FD11
Component: RLS H04 0003
Serial number: 10171545
Coding: 02532C
Subsystem 3 - Part No SW: 8K0 941 531 G HW: 8K0 941 531 G
Component: E1 - LDS H07 0070
Serial number: 00000000000207081306
Part No SW: 8T2 035 110 C HW: 8T2 035 110 C
Component: MP3-Changer H43 0390
Revision: 00043002 Serial number: AUZ5ZBH8473823
VCID: 2B537A558A8F4C1258-807E
Address 10: Park/Steer Assist (J446) Labels:. 8K0-919-475.clb
Part No SW: 8K0 919 475 E HW: 8K0 919 475 A
Component: PARKHILFE 8K H06 0020
Revision: 11001001 Serial number: 52840818202417
Coding: 100101
VCID: 3B734A15BAEFDC92C8-806E
Address 15: Airbags (J234) Labels:* 8K0-959-655.clb
Part No SW: 8K0 959 655 B HW: 8K0 959 655 B
Component: AirbagVW-AU10 H26 0410
Serial number: 0038JD170HZH
Coding: 30323433363030303030554A305238543053
VCID: 3C714909B7E1DBAAC1-8068
Serial number: 6334MSME3B0530465
Serial number: 6344MSME316063722
Serial number: 6352QSME6C471F31Q
Serial number: 6362QSME7324307DH
Serial number: 63732SME770E467FG
Serial number: 63832SME6C2477274
Component: Lenks.Modul H12 0013
Revision: -------- Serial number: 90315HFU00005
Coding: 000036
VCID: 3D77440DA4FBD2A2F6-8068
Component: E221 - MFL H02 0003
Part No SW: 8T0 920 981 B HW: 8T0 920 981 B
Component: KOMBIINSTR. H30 0221
Revision: 00000000 Serial number: 97M70D178
Coding: 2F1F010002002600010000
Part No SW: 8T0 907 468 K HW: 8T0 907 468 K
Component: GW-BEM 4CAN-M H09 0092
Revision: EB302042 Serial number: 4200E0862382EE
Coding: 000303
VCID: 499F20DDE0337E024A-801C
Subsystem 1 - Part No SW: 8K0 915 181 B HW: 8K0 915 181 B
Component: J367-BDM H04 0150
Serial number: 18028343110608
Address 1E: Media Player 2 (R199) Labels:. 4E0-035-785.lbl
Part No SW: 4E0 035 785 F HW: 4E0 035 785 C
Component: SG ext.Player H15 0850
Revision: 00000000
VCID: 2B537A554A8F4C1258-807E
Address 36: Seat Mem. Drvr (J136) Labels:. 8T0-959-760.clb
Component: MEM-FS H09 0043
Revision: AA000000 Serial number: 00001001106574
Coding: 08397325002400001000
Part No SW: 4E0 910 888 P HW: 4E0 919 887 M
Component: MNS ECE H51 1060
Revision: 00000000 Serial number: 333GX087588117
Shop #: WSC 00976 210 89512
VCID: 3B734A157AEFDC92C8-806E
Part No SW: 8K0 959 793 HW: 8K0 959 793
Component: TSG FA H09 0149
Revision: Serial number: 8
Coding: 011002225E012201
VCID: 7DF7840DE47B12A2B6-8028
Revision: 00003002 Serial number: 0111877938
Coding: 011B068200390480002000
Component: LIN BACKUP HO H03 1301
02615 - Fuel Tank Cap; Lock
009 - Open or Short to Ground
Fault Status: 01101001
Reset counter: 241
Mileage: 238220 km
Date: 2019.02.25
Time: 14:05:29
02616 - Fuel Tank Cap; Unlock
Fault Frequency: 9
Reset counter: 241
Mileage: 238220 km
Date: 2019.02.27
Time: 09:54:37
Address 47: Sound System (J525) Labels:. 8T0-035-223-BOM.clb
Part No SW: 8T0 035 223 T HW: 8T0 035 223 F
Component: DSP Prem H14 0400
Revision: 00H14003 Serial number: 34814002043001
Coding: 020101
Shop #: WSC 12336 024 394758
VCID: 3F8B3E05AEF7C0B2E4-806A
Part No SW: 8K0 959 792 HW: 8K0 959 792
Component: TSG BF H09 0149
Revision: Serial number: 47
VCID: 7CF18909FF611BAA81-8028
Fault Frequency: 93
Reset counter: 242
Mileage: 237935 km
Date: 2019.01.26
Time: 12:59:25
Part No SW: 8K0 907 801 E HW: 8K0 907 801 E
Component: EPB Audi B8 H05 0060
Revision: 00000003 Serial number: 00000000162928
VCID: 316F683D68A326C262-8064
Part No: 8K0 907 357 B
Component: Dynamische LWR H01 0030
Shop #: WSC 06324 000 00000
VCID: 3461612957B113EA09-8060
Part No SW: 4E0 910 541 T HW: 4F0 035 541 L
Revision: 00000000 Serial number: 336G-087574932
VCID: 316F683DA8A326C262-8064
Part No SW: 4E0 910 336 M HW: 4E0 862 335
Component: Handyvorb2 H20 1130
Revision: 00000000 Serial number: 00000005191442
Coding: 0010920
VCID: 2C5179498F814B2A51-8078
End-------------------------(Elapsed Time: 03:30)--------------------------
Tuesday,26,March,2019,21:12:59:35452
52 53 55 56 77
VIN: WAUZZZ8T59A007207 Mileage: 238740km-148346miles
Revision: 15X01---
Mileage: 238706 km
Date: 2019.03.26
Time: 20:12:48
Engine speed: 2221.50 /min
Normed load value: 72.9 %
Vehicle speed: 104 km/h
Coolant temperature: 82 °C
Intake air temperature: 16 °C
Voltage terminal 30: 14.180 V
Crankshaft speed (RPM): 2221.5 /min
Vehicle speed: 102.54 km/h
Vehicle voltage terminal 30: 14180 mV
Accelerator position: 52.42 %
C Eng Ds T u Raw: 780.4 mV
Engine oil temperature: 84.7 °C
P0675 00 [109] - Electrical Fault
Mileage: 238628 km
Date: 2019.03.25
Time: 21:02:46
Engine speed: 804.00 /min
Normed load value: 27.8 %
Coolant temperature: 16 °C
Intake air temperature: 7 °C
Ambient air pressure: 1030 mbar
Voltage terminal 30: 13.780 V
Crankshaft speed (RPM): 804.0 /min
Vehicle voltage terminal 30: 13920 mV
Coolant temperature: 16.5 °C
Glw Plg r LVS Ps: 21.15 %
Intake air temperature: 7.7 °C
P0676 00 [109] - Electrical Fault
Mileage: 238628 km
Date: 2019.03.25
Time: 21:02:46
Revision: --H04---
Coding: 001001
P1719 00 [040] - -
Mileage: 238706 km
Date: 2019.03.26
Time: 20:12:49
Engine speed: 2290.00 /min
Transmission input speed: 2267 /min
Transmission output speed: 2616 /min
Engine torque: 376 Nm
Transmission fluid temperature: 45 °C
Accelerator position: 48.8 %
Clutch status: 2
Coding: 140500
Revision: 00003002
Coding: 011000
Coding: 0005002
Reset counter: 243
Mileage: 238628 km
Date: 2019.03.25
Time: 21:19:17
Coding: 36060000
Coding: 00FD11
Coding: 02532C
Coding: 100101
Coding: 000036
Coding: 000303
Revision: 00000000
Reset counter: 243
Mileage: 238628 km
Date: 2019.03.25
Time: 21:20:52
Reset counter: 243
Mileage: 238628 km
Date: 2019.03.25
Time: 21:21:47
Coding: 020101
Reset counter: 244
Mileage: 238628 km
Date: 2019.03.25
Time: 21:01:46
Coding: 0010920
End-------------------------(Elapsed Time: 03:29)--------------------------
Jase
