Saturday,05,January,2019,21:32:39:18214
VCDS Version: 18.9.0.4 (x64) HEX-V2 CB: 0.4437.4
VIN: WAUZZZ8V6KA004422 License Plate: AS
Mileage: 13908km-8642mi Repair Order:
Chassis Type: 8V-AU37 (3Q0)
Scan: 01 02 03 08 09 10 15 17 19 29 39 42 44 4B 52 5F BB BC D6 D7
VIN: WAUZZZ8V6KA004422 Mileage: 13908km-8642miles
Address 01: Engine (J623-DKRF) Labels: None
Part No SW: 04C 906 025 AD HW: 04C 907 309 BB
Component: R3 1.0l TFS H20 6194
Revision: D7H20000
Coding: 02250032232401082000
Shop #: WSC 06314 790 00021
ASAM Dataset: EV_ECM10TFS01104C906025AD 003005
ROD: EV_ECM10TFS011_AU37.rod
VCID: 629DA96234CBC377E8F-8036
CAN Converter 01:
17165 - Databus
Part No SW: 0CW 300 042 D HW: 0AM 927 769 E
Component: GSG DQ200G2_M H05 1609
Revision: 00005008 Serial number: CU501807167140
Shop #: WSC 17734 418 534600
ROD: EV_TCMDQ200021_VW31.rod
VCID: 372B2836CFC9F6DF6F1-8062
Part No SW: 5Q0 614 517 DG HW: 5Q0 614 517 AG
Component: ESC H62 0654
Revision: 00000000 Serial number: 62038000001048
Coding: 12F18AA2242022708B7B0E0260C52448512444D1700624730221F0748208420B00000012121212B835351919323200
VCID: 79AFEE0EB95D20AFD95-802C
Part No SW: 8V0 820 043 AE HW: 8V0 820 043 AE
Component: AC Automat H03 0150
Revision: 20003000 Serial number: 00000001619313
Coding: 03100003000000001000000000001000
ASAM Dataset: EV_AirCondiFrontVaAU37X 008025
VCID: 75B7E23E954544CFBDD-8020
Subsystem 1 - Part No SW: 4H0 907 658 B HW: 4H0 907 658 B
Component: AQ_Hum_Sensor H02 0007
Serial number: 3A029E3900PAG0MUFU03
Address 09: Cent. Elect. (J519) Labels: None
Part No SW: 5Q0 937 084 DC HW: 5Q0 937 084 CF
Component: BCM MQBAB M+ H38 0273
Serial number: 00001819801330
ASAM Dataset: EV_BCMMQB 019001
ROD: EV_BCMBOSCH_019_VW37.rod
VCID: 7CA1F71AB66F1587C23-8028
Subsystem 1 - Part No SW: 8V2 955 119 A HW: 8V2 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS370 180615 043 0580
Serial number: 180629123450
Coding: 0A47F7
Subsystem 2 - Part No SW: 81A 955 547 A HW: 81A 955 547
Component: G397_RLFS H06 0002
Serial number: 21533757X81A955547A0
Coding: 00006C
Light switch:
Subsystem 3 - Part No SW: 8V0 941 531 AR HW: 8V0 941 531 AR
Component: E1 - LDS MQB H06 0032
Serial number: 28 05 2018 20000477
Subsystem 4 - Part No SW: 8V0 951 177 HW: 5Q0 951 172
Serial number: 000000000ZY181500W94
Subsystem 5 - Part No SW: 5Q0 951 605 A HW: 5Q0 951 605 A
Serial number: 00000000000030423467
Steering Column Switch:
Subsystem 6 - Part No SW: 82A 953 521 A HW: 5Q1 953 549
Component: J527 SMLS MQB 004 0060
Serial number: 00000003081820240486
Address 10: Park/Steer Assist (J446) Labels:| 5Q0-919-283.clb
Part No SW: 5QA 919 283 C HW: 5QA 919 283
Component: PDC 4 KanalH07 0050
Serial number: 000308419618202
Coding: 0600040011
ASAM Dataset: EV_EPHVA14AU3700000 009037
ROD: EV_EPHVA14AU3700000.rod
VCID: 4ACD61C2AC3B7B3700F-801E
Part No SW: 5Q0 959 655 BJ HW: 5Q0 959 655 BJ
Component: AirbagVW21 006 0339
Serial number: 003VWR4EBYRB
Coding: 98CCC0000C0000005C5400CA00C8000000C5
ASAM Dataset: EV_AirbaVW20SMEVW37X 002160
ROD: EV_AirbaVW20SMEVW37X.rod
VCID: 094F9ECEE9BD302FC95-805C
Subsystem 1 - Part No SW: ----------- HW: 480 000 108 18
Serial number: 35700000000756741338
Subsystem 2 - Part No SW: ----------- HW: 480 000 108 18
Serial number: 3580000000058674133A
Subsystem 3 - Part No SW: ----------- HW: 480 400 108 18
Component: SideSensor_Dr 003 6149
Serial number: 3510001B929F2612148.
Subsystem 4 - Part No SW: ----------- HW: 480 400 108 18
Component: SideSensor_Pr 003 6149
Serial number: 3520001B529F2613651Y
Subsystem 5 - Part No SW: ----------- HW: 480 401 307 18
Component: FrontSensor_D 004 6149
Serial number: 3550001182B6D2E2F2EI
Pedestrian Protection Driver:
Subsystem 6 - Part No SW: ----------- HW: 480 401 407 18
Component: PedP_Sensor_D 004 6149
Serial number: 22800010A2B7F1A5B425
Subsystem 7 - Part No SW: ----------- HW: 480 401 407 18
Component: PedP_Sensor_P 004 6149
Serial number: 22900011C2B6D2E35142
Subsystem 8 - Part No SW: ----------- HW: 480 002 807 18
Component: PedPSensor_D2 001 0887
Serial number: I0M000000008D168233+
Subsystem 9 - Part No SW: ----------- HW: 480 002 807 18
Component: PedPSensor_P2 001 0887
Serial number: I0N000000000F168233-
Part No SW: 8V0 920 950 HW: 8V0 920 950
Component: KOMBI H20 2601
Coding: 27AD0A082B8006000104FA001000000000000000
ASAM Dataset: EV_DashBoardVDDMQBAB 009065
VCID: 77ABE8368F4936DFAF1-8022
16777018 - Function Restricted due to Interrupted Communications
U1110 00 [008] - -
[BAP_Audio_0x31 keine Kommunikation]
Fault Frequency: 9
Reset counter: 59
Mileage: 10734 km
Date: 2018.12.22
Time: 20:23:11
Part No SW: 3Q0 907 530 Q HW: 3Q0 907 530 C
Component: GW MQB High 439 4344
Revision: -------- Serial number: 0008237786
Coding: 030100043F0857005B00004A100B00000001010000000000000000000000
ASAM Dataset: EV_GatewNF 013044
ROD: EV_GatewNF_VW37.rod
VCID: 3D273A1EEDF5DC8FB5D-8068
Subsystem 2 - Part No SW: 81A 951 523 A HW: 81A 951 523 A
Component: J453 MFL H04 0004
Serial number: 20180625173551 22127
Subsystem 3 - Part No SW: 5Q0 915 181 J HW: 5Q0 915 181 J
Component: J367-BDMConti H03 1050
Serial number: 758860019118072308A0
Address 29: Left Light (J1018) Labels: 8S0-907-397.clb
Part No SW: 8S0 907 397 D HW: 8S0 907 397 D
Component: LCM_MQB H07 0022
ASAM Dataset: EV_LCMLeftCONTIAU426 001009
ROD: EV_LCMLeftCONTIAU426_VW41.rod
VCID: 42DD49E2940BA377C8F-8016
Address 39: Right Light (J1023) Labels: 8S0-907-397.clb
ASAM Dataset: EV_LCMRightCONTIAU426 001009
Part No SW: 5Q0 959 593 F HW: 5Q0 959 593 F
Component: TSG FS001 0287
Serial number: YE007RGL2342D
Coding: 001C8A205001000000001002
VCID: 44D14FFA8E1FAD47FA3-8010
Part No SW: 5Q0 909 144 AA HW: 5Q0 909 144 AA
Component: EPS_MQB_ZFLS 130 1081
Coding: 81170000
ROD: EV_SteerAssisMQB_015.rod
VCID: 73B3DC269B315AFF939-8026
Address 4B: Multifunc. Module (J745) Labels:* None
Part No SW: 3Q0 907 338 C HW: 3Q0 907 338 C
Component: FCM MQB Low 002 0342
Serial number: 19071810800959
Coding: 000000050900146600102B03020000000000000000000000000000000000
ASAM Dataset: EV_MultiModulContiVW48X 002004
ROD: EV_MultiModulContiVW48X_002_VW37.rod
VCID: 3537223ED5C504CF7DD-8060
Part No SW: 5Q0 959 592 F HW: 5Q0 959 592 F
Component: TSG BFS001 0287
Serial number: YE007RGH1028A
Coding: 001C82205C01000000001002
VCID: 43D34CE68B11AA7FC39-8016
Part No SW: 81A 035 192 E HW: 81A 035 192
Component: MU-HS-LND-EU 050 0235
Coding: 01730301FF0A000011111101000A00102F002CC601F00100CE
ASAM Dataset: EV_MUHigScl6C3DELP 001011
ROD: EV_MUHigScl6C3DELP_AU37.rod
VCID: 2313EC666B518A7FA39-8076
Subsystem 1 - Part No SW: 8W0 919 866 AF HW: -----------
Component: ECE 2018/2019 --- 0035
Subsystem 2 - Part No SW: 8V0 919 604 C HW: 8V0 919 604 C
Component: DU High H49 0014
Serial number: AUZ8Z9J1Y0CP5V
Multimedia Operating Unit:
Subsystem 3 - Part No SW: 8V0 919 614 BE HW: 8V0 919 614 BE
Component: ControlUnit_B H50 0103
Serial number: ALJAL131051800050127
Part No SW: 8W1 959 595 D HW: 8W1 959 595 D
Component: TSG HFS003 0187
Serial number: YE007RGE25444
Coding: 000C82204001000000001002
ROD: EV_DCU2RearDriveMAXHCONT.rod
VCID: 4EC56DD2505357175C7-801A
Component: TSG HBFS003 0187
Serial number: YE007RGE25531
ROD: EV_DCU2RearPasseMAXHCONT.rod
Address D6: Light Ctrl Left 2 (A31) Labels: 7PP-941-572.clb
Part No SW: 7PP 941 572 AC HW: 7PP 941 572 A
Component: LED1L H09 0008
VCID: 176BC8B6AF09D6DF4F1-8042
Address D7: Light Ctrl Right 2 (A27) Labels: 7PP-941-572.clb
Component: LED1R H09 0008
End----------(Elapsed Time: 01:32, VBatt start/end: 12.1V/12.0V)-----------
