2003 A6 Quattro Central locking unit flooded.
tultalk
Leak in sun roof seal flooding driver footwell.
Runs. Windows will not work. Sun rood will not open. Flashers/Tuens not working NO sound from radio etc. etc
Pulled control unit. +12 v lead to connector burned off. Inside controller, strap connecting +12 v to PCB burned off.
20 amp fuse not blown.
Changed unit (used on eBay). Hooked it up.
Flashers and turns now working. No sound from radio (on). Interior courtesy lights not workling
Catch 22. Can't open sun roof to stop leaks.
Are all thise things related to some coding with Central Locking Unit?
Have VCDS
Don't see anything under select control module that relates to Central Locking Unit
Need a little insight about where to go with this?
2003 A6 should still be 35-Central Locks -- I think -- as opposed to 46-Cent. Conv.
tultalk
Hi:
Thanks for response. Let me first say that I have never used the VCDS as I bought it just for an "in case" which has not occurred until now. So here I am.
I have looked at the following but don't know where to start. Like I said my existing key start and run vehicle both with damaged controller and with the new one.
Am I required to code my existing keys to this "new" controller (as if coding to a new key?) to get all the functions back or is this indicative of a bigger problem?
Seems strange that the turn signals/flasher would return to correct function but not other items.
Audi A6 (4B) Central Locking
Contents
1 Coding
2 Adaptation
2.1 Channel 021: Remote Control Matching
2.2 Special Notes
Coding
VCDS will display a coding chart a pop-up balloon while connected to the vehicle.
Add the sum of the options to configure the correct coding.
Adaptation
[Select]
[35 - Centr. Locks]
[Adaptation - 10]
Channel 021.
[Read]
Choose the memory position you want the new key be matched on by entering it's number (e.g. "3" for memory position 3). Make sure to TYPE IN the number instead of scrolling up to it, otherwise you will not be able to click [Test].
[Test]
Now press any button on the remote you want to match.
The meas. block field above will change from Not Recogn. to Recognized.
[Save]
[Done, Go Back]
[Close Controller, Go Back - 06]
Note: You can check the current memory positions using Meas. Block 007.
Special Notes
The 4B platform comfort system module has assigned positions, like parking spots 1, 2, 3 and 4, for each remote. This is critical when matching new remotes.
If you are having problems with the Remote Control Matching, please pay special attention to the instructions above:
If Adaptation Channel 21 is not available the control module does NOT support matching remotes with VCDS (or any scan tool). In those cases the remote matching procedure as per the Repair Manual and/or vehicle Owner's Manual will need to be completed.
In those cases, Measuring Block group 007 can still be used to verify the positions.
tultalk
Ran auto scan (attached pdf) and also for controller etc
oops. Don't see how to attach pdf file?? Nor jpg File
oops. Don't seevhow to attach file??
We do not allow attachments here. Please see the link I posted above for instructions how to post a scan.
tultalk
Central Locking flooded
Windows Based VAGN AS Emulator Running on Windows 10 x64
VCDS Version: Release 19.6.1 (x64) Data version: 20190529 DS308.0
Dealer/Shop Name:
Workshop Code: 000 00000 000000
Self-Diagnosis Log
Thursday,04,July,2019, 14:32:42:29746
~ VIN: WAUML64B43N104356 License Plate:
Mileage: Repair Order:
Chassis Type: 4B (4B - Audi A6/S6/RS6/allroad C5 (1998> 2005»
Scan: 01 02030608151617182234353637455556576567
757677
	Address 01: Engine 	Labels: None
Part No: 400 907 560 CL
	Component: 4.2L V8/5V 	G 0001
Coding: 07752
Shop #: WSC 02325
VCID: 72EBF47B3EDB13DF9F-5140
WAUML64B43N 1 04356 AUZ7Z0C2386232
7 Faults Found:
17831 - Secondary Air Injection System; Bank 1
P1423 - 35-00 - Insufficient Flow
17819 - Secondary Air Injection System; Bank 2
P1411 - 35-00 -Insufficient Flow
17983 - Right Engine Mount Solenoid Valve (N145)
P1575 - 35-10 - Short to Plus - Intermittent
17931 - Crash Signal from Airbag Controller
P1523 - 35-10 - Implausible Signal- Intermittent
P0300 - 35-00 -
16688 - Cylinder 4
P0304 - 35-00 - Misfire Detected
16686 - Cylinder 2
P0302 - 35-00 - Misfire Detected
	Address 02: Auto Trans 	Labels: 01L-927-156.lbl
Part No: 4BO 927 156 FG
Component: AG5 01L 4.215V USA 1014
Coding: 01002
Shop #: WSC 02325
VCID: 71E9FB773BDD28C766-5140
Self-Diagnosis Log
Thursday,04,July,2019,14:32:42:29746
Page 2
	Address 03: ABS Brakes 	Labels: 4BO-614-517.lbl
Part No: 4BO 614 517 H
	Component: ABS/ESP allrad 	3428
Coding: 06397
Shop #: WSC 02325
VCID: 2643D82BC2933F7FC3-5124
	Address 08: Auto HVAC 	Labels: 4BO-820-043-MY2.lbl
Part No: 4BO 820 043 AM
Component: A6-Klimavollautomat 0105
Coding: 00010
Shop #: WSC 02325
VCID:65C19F27FF15F4670A-2580
	Address 15: Airbags 	Labels: 4BO-959-655-AI84.1bl
Part No: 4BO 959 655 Q
	Component: Airbag 8.4EP 	2001
Coding: 0000607
Shop #: WSC 02325 785 00200
VCID: 3E73104B6A0387BFAB-5140
	Address 16: Steering wheel 	Labels: 4BO-907-487.lbl
Part No: 4BO 907 487 F
Component: Lenkradelektronik D01
Coding: 01005
Shop #: WSC 02325
VCID: 2F6D3DOFED697E3730-5140
00480 - Control Module in Instruments for Infotainment CAN (J285)
27-10 - Implausible Signal- Intermittent
01304 - Radio
49-10 - No Communications -Intermittent
Self-Diagnosis Log
ThursdaY,04,July,2019,14:32:42:29746
Page 3
VIN: WAUML64843N104356 License Plate:
	Address 17: Instruments 	Labels: 480-920-xxx-17.1bl
Part No: 480 920 981 P
Component: KOM81+WEGFAHRS. VDO D12
Coding: 03283
Shop #: WSC 02805
VCID: 3365317F01415AD754-5140
WAUML64843N104356 AUZ7Z0C2386232
01304 - Radio
	Address 35: Centro Locks 	Labels:. 480-962-258.clb
Part No: 480 962 258 M
Component: Central Lock/Alarm D38
Coding: 15885
Shop #: WSC 02116
VCID: 3365317F01415AD754-4F22
12 Faults Found:
35-00 --
35-00 --
35-00 --
35-00 --
01373 - Alarm triggered by Radio Ground Contact
35-00 --
01570 - Turn-Off Delay; Terminal 15
29-00 - Short to Ground
01561 - Rear left door
59-00 - Can't Unlock
01562 - Rear right door
01574 - Alarm triggered by Door Contact Switch; Rear Right
35-10 - - - Intermittent
01573 - Alarm triggered by Door Contact Switch; Rear Left
01482 - Motors for Central Locking
29-10 - Short to Ground -Intermittent
Self-Diagnosis Log
Page 4
	Address 36: Seat Mem. Drvr 	Labels: None
Part No: 4BO 959 760 B
	Component: Sitzmemory R1 F 	0102
Coding: 00001
VCID: 2C572A03DC7F052F15-4AES
	Address 55: Headlight Range 	Labels: 427-907-357.1bl
Part No: 427 907 357
	Component: dynamische LWR 	009
Coding: 00050
Shop #: WSC 02325
VCID: 0407 A2A3146F2D6FBD-4B 1A
00774 - Level Control System Sensor; Rear Left (G76)
2S-10 - Short to Plus - Intermittent
00776 - Level Control System Sensor; Left Front (G7S)
	Address 56: Radio 	Labels: SEO-035-1xx-56.lbl
Part No: 4BO 035 195 S
Component: symphony II NP2 0011
Coding: 00225
Shop #: WSC 02101
VCID: 306F3E73F05761 CF29-4E96
00S56 - Radio Antenna
36-00 - Open Circuit
	Address 75: Telematics 	Labels: SEO-035-616.lbl
Part No SW: SEO 035 616A HW: SEO 035 616A1
Component: Telematik USA 1
	Coding: 0002303 	.
Shop #: WSC 02325 7S5 00200
VCID: 2345C13FE1A1CA57A4-5140
01656 - Crash Signal
01304 - Radio
E nd-----------------------fElaosed Ti me: 05: 29)--------------------------
Dealer/Shop Name:
Diagnostic Trouble Code Report
ThursdaY,04,JulY,2019, 14:58:46:29746
Control Module Part Number: 4BO 035 195 S
Component and/or Version: symphony II NP2 0011
Software Coding: 00225
Work Shop Code: WSC 02101
VCID: 306F3E73F05761CF29-4E96
00856 - Radio Antenna
www.Ross~Tech.com
Dealer/Shop Name:
Workshop Code: 00000000
Thursday,04,July,2019,14:55:03:29746
Control Module Part Number: 4BO 962 258 M
Component and/or Version: Central Lock/Alarm D38
Software Coding: 15885
Work Shop Code: WSC 02116
12 Faults Found:
35-00 --
35-00 --
35-00 --
35-00 --
35-00 --
29-10 - Short to Ground - Intermittent
OK, this car is so full of fault codes that there's a very low signal-to-noise ratio in what you've posted.
Please clear all fault codes from modules that have fault codes, then do a new scan, and please post the native scan text, not something that's been run through the [Print] function in VCDS. That function is optimized for a sheet-fed printer, but makes things much harder to read here than the original text would be.
tultalk
Save instead of print? Going to Holland MI so won't be back until Sunday. Not aure I understand stored faults.
Would the used controller have faults from the previous installed car?
Is the format just the txt in the log dir which I assume the "save" button refers to?
Maybe I will rerun tonight.
Things like no radio antenna threw me back. Radio turns on but no sound. Wirring diagrams indicate no connection of antenna with replaced controller.
Are any of my problems related to key matching to the "new" controller?
Correct. [Save] or even just [Copy]
Yes, that's entirely possible. Fault codes are stored in non-volatile memory.
Like I said, please clear all the fault codes out of this car and then let's see what comes back.
tultalk
My DSL wen t out for the 50th time. Really bad company. In restaurant right now.
Will clar and rerun. Thanks
tultalk
Did not realize hex key would open. Mia culpa.
Thx
tultalk
Cleared and reran auto can three time as I did not trust. It showed no errors in engine while my small little read out tool showed leaks in air injection
Any way, this no longer appear and only one fault in headlight leveling transmitter. So what is next: Audi A6 (4B) Central Locking Remote Control Matching?
Wednesday,10,July,2019,20:22:34:29746
VCDS Version: 19.6.1.0 (x64)
          75 76 77
   Part No: 4D0 907 560 CL
   Coding: 07752
   Shop #: WSC 02325
   VCID: 72EBF47B3EDB13DF9F-5124
   WAUML64B43N104356     AUZ7Z0C2386232
Readiness: 0110 1101
   Part No: 4B0 927 156 FG
   Component: AG5 01L 4.2l5V  USA 1014
   Coding: 01002
   Shop #: WSC 02325
Address 03: ABS Brakes        Labels: 4B0-614-517.lbl
   Part No: 4B0 614 517 H
   Coding: 06397
   Shop #: WSC 02325
Address 08: Auto HVAC        Labels: 4B0-820-043-MY2.lbl
   Part No: 4B0 820 043 AM
   Coding: 00010
   Shop #: WSC 02325
   VCID: 65C19F27FF15F4670A-257A
            27-00 - Implausible Signal
Address 15: Airbags        Labels: 4B0-959-655-AI84.lbl
   Part No: 4B0 959 655 Q
   Coding: 0000607
Address 16: Steering wheel        Labels: 4B0-907-487.lbl
   Part No: 4B0 907 487 F
   Coding: 01005
   Shop #: WSC 02325
   VCID: 2F6D3D0FED697E3730-5140
Address 17: Instruments        Labels: 4B0-920-xxx-17.lbl
   Part No: 4B0 920 981 P
   Component: KOMBI+WEGFAHRS. VDO D12
   Coding: 03283
   Shop #: WSC 02805
Address 35: Centr. Locks        Labels: 4B0-962-258.clb
   Part No: 4B0 962 258 M
   Coding: 15885
   Shop #: WSC 02116
   Part No: 4B0 959 760 B
   Coding: 00001
   VCID: 2C572A03DC7F052F15-4AE8
   Part No: 4Z7 907 357
   Coding: 00050
   Shop #: WSC 02325
   VCID: 0407A2A3146F2D6FBD-4B1A
   Part No: 4B0 035 195 S
   Coding: 00225
   Shop #: WSC 02101
Address 75: Telematics        Labels: 8E0-035-616.lbl
   Part No SW: 8E0 035 616 A    HW: 8E0 035 616 A
   Component: Telematik USA1
   Coding: 0002303
End-------------------------(Elapsed Time: 05:47)--------------------------
tultalk
Another quetion. I thought 2003 A6 quatttro used CAN bus? Inquiry says not available???
It uses CAN buses internally for communications between modules, but external diagnostic communications are all via K-Lines, so "CAN Not Ready" from VCDS is normal on that car.
tultalk
Have you looked at my auto-scan after clearing codes?
tultalk
I did and evidently posted response in another thread. Here it i0s again
          75 76 77
   Coding: 07752
   Shop #: WSC 02325
   Coding: 01002
   Shop #: WSC 02325
   Coding: 06397
   Shop #: WSC 02325
   Coding: 00010
   Shop #: WSC 02325
   Coding: 0000607
   Coding: 01005
   Shop #: WSC 02325
   Coding: 03283
   Shop #: WSC 02805
   Coding: 15885
   Shop #: WSC 02116
   Coding: 00001
   Coding: 00050
   Shop #: WSC 02325
   Coding: 00225
   Shop #: WSC 02101
   Coding: 0002303
          75 76 77
   Coding: 07752
   Shop #: WSC 02325
Readiness: 0010 1101
   Coding: 01002
   Shop #: WSC 02325
   Coding: 06397
   Shop #: WSC 02325
   Coding: 0000607
   Coding: 01005
   Shop #: WSC 02325
   VCID: 2F6D3D0FED697E3730-5124
   Coding: 03283
   Shop #: WSC 02805
Address 35: Centr. Locks        Labels:. 4B0-962-258.clb
   Coding: 15885
   Shop #: WSC 02116
   Coding: 00001
   VCID: 2C572A03DC7F052F15-4B00
   Coding: 00050
   Shop #: WSC 02325
   VCID: 0407A2A3146F2D6FBD-4B00
   Coding: 00225
   Shop #: WSC 02101
   Coding: 0002303
End-------------------------(Elapsed Time: 05:22)--------------------------
tultalk
tultalk
I have been posting in wrong thread I think since no response to rerun of Auto Scan
          75 76 77
   Coding: 07752
   Shop #: WSC 02325
   Coding: 01002
   Shop #: WSC 02325
   Coding: 06397
   Shop #: WSC 02325
   Coding: 00010
   Shop #: WSC 02325
   Coding: 0000607
   Coding: 01005
   Shop #: WSC 02325
   Coding: 03283
   Shop #: WSC 02805
   Coding: 15885
   Shop #: WSC 02116
   Coding: 00001
   Coding: 00050
   Shop #: WSC 02325
   Coding: 00225
   Shop #: WSC 02101
   Coding: 0002303
          75 76 77
   Coding: 07752
   Shop #: WSC 02325
   Coding: 01002
   Shop #: WSC 02325
   Coding: 06397
   Shop #: WSC 02325
   Coding: 0000607
   Coding: 01005
   Shop #: WSC 02325
   Coding: 03283
   Shop #: WSC 02805
   Coding: 15885
   Shop #: WSC 02116
   Coding: 00001
   Coding: 00050
   Shop #: WSC 02325
   Coding: 00225
   Shop #: WSC 02101
   Coding: 0002303
