EOS 3.2 6 speed swap attempt
Craz1000
C?ID=307117
I am attempting this swap and I am currently at the phase of poking at the modules to see if it will allow me to do the swap. When I try to recode the ECU from 0000078 to 0000072 it rejects it and i get "Error 31: Value out of range."
It is my understanding this ECU will need to be reflashed. How may I go about doing this.
Wednesday,18,March,2020,17:04:08:37334
VCDS Version: 19.6.2.2 (x64)  HEX-NET CB: 0.4508.4
VIN: WVWFB71F07V044237   License Plate:
Mileage: 241820km-150259mi   Repair Order:
Chassis Type: 1F (1K0)
Scan: 01 03 08 09 0F 15 16 17 19 1C 25 26 37 42 44 46 52 56 62 63
          65 72 73
VIN: WVWFB71F07V044237   Mileage: 241820km-150259miles
26-Auto Roof -- Status: Malfunction 0010
63-Entry Assist,D -- Status: OK 0000
73-Entry Assist, P -- Status: OK 0000
Address 01: Engine        Labels: 022-906-032-BDB.lbl
   Part No SW: 022 906 032 CF    HW: 022 906 032 GP
   Component: MOTRONIC ME7.1.1G   9378
   Revision: --H02---    Serial number: VWX7Z0G23N98C6
   Coding: 0000078
   Shop #: WSC 00020 000 00000
   VCID: D1EA23AE48786CC7FA-8084
001072 - Catalyst System; Bank 2
               P0430 - 002 - Efficiency Below Threshold - MIL ON
                    Fault Status: 11100010
                    Mileage: 235838 km
                    RPM: 1470 /min
                    Load: 46.6 %
                    Speed: 66.0 km/h
                    Temperature: 85.0°C
                    Temperature: 40.0°C
                    Absolute Pres.: 1020.0 mbar
                    Voltage: 13.843 V
001056 - Catalyst System; Bank 1
               P0420 - 002 - Efficiency Below Threshold - MIL ON
                    Mileage: 235838 km
                    RPM: 1511 /min
                    Load: 24.7 %
                    Speed: 67.0 km/h
                    Temperature: 85.0°C
                    Temperature: 40.0°C
                    Voltage: 13.843 V
008344 - Post-Catalyst Oxygen (Lambda) Sensor Correction; Bank 2
               P2098 - 002 - Too Lean - Intermittent
                    Mileage: 238970 km
                    RPM: 661 /min
                    Load: 36.8 %
                    Speed: 1.0 km/h
                    Temperature: 89.0°C
                    Temperature: 50.0°C
                    Absolute Pres.: 1000.0 mbar
                    Voltage: 13.335 V
000275 - Intake Air Temp. Sensor (G42)
               P0113 - 002 - Signal too High
                    Fault Status: 01100010
                    Mileage: 241822 km
                    Temperature: 72.0°C
                    Temperature: -40.0°C
                    Absolute Pres.: 1010.0 mbar
                    Voltage: 11.303 V
049409 - No Communication with Transmission Control Module
               U0101 - 008 -
                    Mileage: 241822 km
                    Temperature: 72.0°C
                    Voltage: 11.303 V
   Revision: 00H11001
   Coding: 0021218
   VCID: F3A6892692247ED728-80A6
   Part No SW: 1Q0 907 044 E    HW: 1Q0 907 044 E
   Component: ClimatronicPQ35 111 0202
   Revision: 00111021    Serial number: 00000000000000
   VCID: AF2E45563E8C1A378C-80FA
01809 - Actuating Motor for Temperature Flap; Left (V158)
01810 - Actuating Motor for Temperature Flap; Right (V159)
   Part No SW: 3C0 937 049 AE    HW: 3C0 937 049 AE
   Component: Bordnetz-SG     H52 2002
   Revision: 00H52000    Serial number: 00000006781724
   Coding: E58C8F0340041500470000000F00000000285D035C0001
   Shop #: WSC 00020 123 12345
   VCID: EC94925ACF1AA12FE9-80B8
   Component: Wischer 140307 020  0501
   Coding: 00038805
   Shop #: WSC 00020
   Component: RLS     201212 054  0403
   Coding: 00209069
   Shop #: WSC 00020
Address 0F: Digital Radio        Labels: None
   Part No SW: 8E0 035 593 Q    HW: 8E0 035 593 Q
   Component: SDAR SIRIUS     H08 0160
   Revision: 00000000    Serial number: AUZ4Z7L0607781
   Coding: 0000000
   VCID: B73E7D36C6DCD2F7D4-80E2
                    Reset counter: 53
                    Mileage: 241742 km
                    Time: 17:05:32
Address 15: Airbags        Labels: 1Q0-959-655.lbl
   Part No SW: 1Q0 959 655 A    HW: 1Q0 959 655 A
   Component: 14 Airbag VW8C      0180
   Revision: 92009018    Serial number: 003B3001NU1T
   Coding: 0012596
   VCID: BA386402F5CECF9F2B-80EE
   Subsystem 1 - Part No: 1Q0 959 339 A
   Component: BF-Gewichtsens. 007 0003
   Subsystem 2 - Serial number: 3L8HV
   Subsystem 3 - Serial number: 0001.01.000000700000000000ÿ†63
   Subsystem 4 - Serial number: 000000ÿ†6332SRB404C1C8967ÿ†63
   Subsystem 5 - Serial number: 1C8967ÿ†6342SRB40481882C%ÿ†63
   Subsystem 6 - Serial number: 1882C%ÿ†6372URB4021BAF28Aÿ†63
   Subsystem 7 - Serial number: BAF28Aÿ†6382URB4021BAEFAPÿ
   Subsystem 8 - Serial number: BAEFAPÿ
   Part No SW: 1K0 953 549 AQ    HW: 1K0 953 549 AQ
   Component: J0527           036 0070
   Coding: 0012021
   VCID: 814AD3EED8985C472A-80D4
00002 - Transmission Control Unit
   Part No SW: 1Q0 920 973 B    HW: 1Q0 920 973 B
   Component: KOMBIINSTRUMENT VDD 1610
   Revision: V0003000    Serial number: VWX7Z0G23N98C6
   Coding: 0023207
   VCID: B2284C222DBE37DFE3-80E6
   Part No SW: 1K0 907 530 K    HW: 1K0 907 951
   Component: J533__Gateway   H12 0170
   Revision:   H12       Serial number: 33001072270E53
   Coding: 3DBF23680F065000
   Shop #: WSC 00020 999 12345
                    Reset counter: 63
                    Mileage: 241822 km
                    Time: 03:31:05
   Part No SW: 1Q0 919 965     HW: 1Q0 919 965
   Component: Kompass         002 0001
   Revision: 00002000    Serial number: 1350208TKAEC02
   VCID: F9BABB0EB048048762-80AC
   Component: IMMO            VDD 1610
   Shop #: WSC 05666 444 124037
Address 26: Auto Roof        Labels: 1Q0-959-255.clb
   Part No SW: 1Q0 959 255 B    HW: 1Q0 959 255 B
   Component: Verdecksteuergeraet 0622
   Revision: 0032000K    Serial number: 070610430
   Coding: 0655360
                    Reset counter: 103
                    Mileage: 241822 km
                    Time: 02:55:13
                    Voltage: 11.80 V
                    Voltage: 11.90 V
                    Voltage: 4.90 V
                    Error Code: 0
Address 37: Navigation
   Part No SW: 1Q0 959 701 E    HW: 1Q0 959 701 E
   Component: Tuer-SG         006 1209
   Coding: 0001207
   VCID: B6207032C1D62BFFCF-80E2
00131 - Outside Door Handle Illumination/mirror Light Driver Side
   Part No: 1K1 909 144 L
   Component: EPS_ZFLS Kl.071 H07 1806
   VCID: B4244A3AD7AA39EFF1-80E0
   Component:    KSG PQ35 RDK 052 0218
   Coding: 1B908A800186083F28020C0FB0080E0488DC00
   VCID: 8444DAFAC78A496F01-80D0
   Part No SW: 1Q0 959 702 E    HW: 1Q0 959 702 E
   Coding: 0001206
Address 56: Radio
   Part No SW: 1Q0 959 703 A    HW: 1Q0 959 703 A
   Component: Tuer-SG         006 1203
   Coding: 0000128
   Shop #: WSC 00020 000 1012544
Address 63: Entry Assist,D        Labels: 1Q0-959-790.lbl
   Part No SW: 1Q0 959 790 A    HW: 1Q0 959 790 A
   Component: J572  EASYENTRY FS  0603
   Revision: 00H02000    Serial number: 5DS008646-01--
   Component:    RDK              0440
   Coding: 0100101
00625 - Vehicle Speed Signal
                    Reset counter: 83
                    Mileage: 241674 km
                    Time: 20:57:11
   Part No SW: 1Q0 959 704 A    HW: 1Q0 959 704 A
   Coding: 0000128
   VCID: B522773EDCD020E7C6-80E0
Address 73: Entry Assist, P        Labels: 1Q0-959-790.lbl
   Component: J573  EASYENTRY BFS 0603
End----(Elapsed Time: 01:42, VBatt start/end: 11.3V/11.3V. VIgn 11.2V)-----
You will need someone who does "ECU Tuning" or similar to flash MT software into it for you. That assumes that there is MT software available for this engine.
Craz1000
C?ID=307117
I am told there are someone(s) lurking on these forums that can do and have done such things, but I was not provided with names.
NZDubNurd
New Zealand
C?ID=230482
I tried flashing manual R32 software (022 906 032 CD) onto a DSG R32 ecu (022 906 032 CE), and it wasn't sucessful. I flashed it back to DSG and it still worked, so I suspect the hardware is different, though you may have different results. My manual flash file may have had an issue or similar.
Mine was a 2006 Immo 4A ECU - yours is 4C, so even with a brand new ECU, you'll need some additional help with immo coding.
If you want to try manual software, you'll need a flash file from a Euro mk5 R32 with manual trans and IMMO4C (2007 onwards). Then it will only work if the ECU doesn't mind having no 4WD. Idon' think that would be an issue, but you never know! The EOS ECU part number is EOS specific.
I'm not an expert at it, but I did do some other EEPROM changes that worked.
I ended up buying a manual R32 ECU new from ECS for the R32 conversion in my Touran.
I had the same fault code in the ABS, and it DID clear after installing the manual ECU.
Spacewalker
Poland
C?ID=159607
HW could be ok, but "conditions" to update not match between , so this is why failed
99% upload BDM backup directly to CPU should work
so the best way is do manual changes in ECU software
or write whole dump via BDM directly to CPU from proper ECU
NZDubNurd
New Zealand
C?ID=230482
I was in boot mode, but was using someone elses file, not one I'd read myself. so possible the file was corrupt.
Craz1000
C?ID=307117
I got the car to turn on and idle fine with the key in the ignition and running a wire from the starter solenoid to a 12v source. It looks like I will have to wire up my own starter relay from the ignition switch directly to bypass the lockout from the transmission not being there. Which is easy. The issue I am running into now is finding a VR6 tranny. The one that was given to me was off a 2.5 and I was hoping it would work but I also knew that was wishful thinking.
NZDubNurd
New Zealand
C?ID=230482
No, no half-assing the wiring ;): you need to rewire the pin from the J519 that usually goes to from the J519 to the DSG trans, and earth it, and code the J519 for manual trans (I think?). I can't recall the pin number (I'm part way through a bottle of Jim Beam Double Oak :D). You will NEED wiring diagrams, because you are going to have to wire in a clutch switch too.
You can't use a inline (4 cylinder, and US 5cyl) trans, because the bellhousing angle is different. The pattern is the same, but the VR6 is leaned forward, where the inline type is leant backwards. In the US, the MK4 had an option with 2.8 VR6 and FWD, right? One of those trans, with driveshafts that have the MK5 outer CVs fitted should work. The trans WILL, but I'm unsure which driveshaft will be the correct length. Left side MK4 should be fine with the outer swapped. RHS, I'm not 100% on. I have a 02M (MK4) trans in my Touran (MK5) conversion, but it's 4motion, so I have the angle drive and shorter RHS driveshaft - I had some dramas getting the correct shaft and ended up using a TT one with the MK5 outer CVs.
You CAN use a 4motion trans, and leave the angle drive spinning in mid air... even cooler, building the worlds first 4motion EOS??? Mine wasn't the first 4motion Touran (I think it was the 3rd!) but it WAS the worlds first FULLY functional 4motion R32 Touran though :thumbs:
