8J TT convertible flap output test not working
mgjohn
C?ID=221666
Hi
I have vcds 14.10.2 running and wish to Adapt Flap Motors on my 8J Audi tt convertible roof (26)
With the roof stowed when I attempt to run flap Output Tests they don’t move but test just reports 'ON'
I have cleared all dtc’s, power cycled ignition and laptop, even tried a different pc – all to no avail.
The indicator lamp test work as does other controller tests eg windows
The roof itself is working ok too so you could say I don't need to run Adaption but why won't it work?
Do i need a different lbl file or security code perchance
Cheers, John
Measuring block data
Address 26: Auto Roof (8J7 959 255 B)
> 15:11:27 Group 001: Convertible Top Status (Actual)
> 11010 Convertible Top Status
> 1010 Convertible Top Flap Status
> 39.0 Conv. Top Flap Sensor Left (G596)
> 43.0 Conv. Top Flap Sensor Right (G597)
> 15:11:27 Group 007: Convertible Top Flap Sensors (Status: Closed)
> 164.0 Sw. Thresh. (closed) Flap Left (G596)
> 167.0 Sw. Thresh. (closed) Flap Right (G597)
> 15:11:27 Group 008: Convertible Top Flap Sensor (Status: Open)
> 46.0 Sw. Thresh. (open) Flap Left (G596)
> 53.0 Sw. Thresh. (open) Flap Right (G597)
> 15:11:43 Group 001: Convertible Top Status (Actual)
> 01001 Convertible Top Status
> 0101 Convertible Top Flap Status
> 177.0 Conv. Top Flap Sensor Left (G596)
> 177.0 Conv. Top Flap Sensor Right (G597)
> 15:11:43 Group 007: Convertible Top Flap Sensors (Status: Closed)
> 165.0 Sw. Thresh. (closed) Flap Left (G596)
> 15:11:43 Group 008: Convertible Top Flap Sensor (Status: Open)
Bruce
Near Philadelphia, PA, USA
Please post a full autoscan from the vehicle so we can begin to look at the components in the vehicle. If you do not know how to do so, please see this thread:
[h=3]How to post an Auto-Scan[/h]
mgjohn
C?ID=221666
Arrgh - I now realise that was what I should have done first - doh!
Ok - see scan results below - including intermittent errors from flaps ??!
Not worried about other codes for now.
So I tried left and right Flap output tests with fault codes as listed, then I cleared fault codes and retried - both times with same results
Flaps failed to shift and simply report ON - (with engine running or off)
I note that amongst other issues wolfmanjack couldn't get his flaps to move either
http://forums.ross-tech.com/showthread.php?1057-Audi-TT-(8J)-Error-Auto-Roof
I am using Micro-CAN and aiming to follow http://wiki.ross-tech.com/wiki/index.php/Audi_TT_(8J)Automatic_Roof
What does the 'Convertible Top Flap Initialisation' Output Test do? Or do I have to subscribe to erWin for that?
I'm wondering if the only control module 26 output test I can get to run is the indication lamp?
Cheers, John
PS Roof still operating fine - touch wood
Tuesday,28,July,2015,10:40:59:19372
VCDS Version: 14.10.2.0
Data version: 20150311
VIN: TRUZZZ8J891013414   License Plate: A10JST
Mileage: 53690km-33361mi   Repair Order: jly28
Chassis Type: 8J (1K0)
Scan: 01 03 08 09 15 16 17 19 22 25 26 42 44 46 47 52 56 77
VIN: TRUZZZ8J891013414   Mileage: 53690km-33361miles
26-Auto Roof -- Status: Malfunction 0010
Address 01: Engine (CBB)       Labels: 03L-906-022-CBA.clb
   Part No SW: 03L 906 022 DH    HW: 03L 906 022 BQ
   Component: R4 2,0L EDC 0000SG  3133
   Revision: 13H01---    Serial number: AUX7Z0H6FNL07T
   Coding: 0000172
   Shop #: WSC 01236 785 00200
   VCID: 6EFD20F679DCA9518C3-803B
Address 03: ABS Brakes        Labels: 8J0-614-517.clb
   Part No SW: 8J0 614 517 A    HW: 8J0 614 517 A
   Component: ESP MK60E1          0010
   Revision: 00H60001
   Coding: 0083827
   VCID: 2B7BE9E28A4E9C79EBD-807E
                    Reset counter: 228
                    Mileage: 53534 km
                    Date: 2015.07.22
                    Time: 15:16:58
                    Count: 128
                    Count: 773
                    Count: 8212
                    Count: 46336
   Part No SW: 8J0 820 043 AG    HW: 8J0 820 043 AG
   Component: J255  Klima 1 Zone  0080
   Revision: 00H08006    Serial number: 00000001104173
   Coding: 1049876
   VCID: 6BFB29E24ACE5C79ABD-803E
Address 09: Cent. Elect.        Labels: 8P0-907-279-30-H.lbl
   Part No SW: 8P0 907 279 N    HW: 8P0 907 279 N
   Component: Bordnetz-SG     H54 2801
   Revision: 00H54000    Serial number: 00000008796698
   Coding: 01000E8280141C804F1800001800000000085E075C210802000000000000
   VCID: 48B1B66E3BF85761E6F-801D
   Subsystem 1 - Part No: 8J2 955 119 A  Labels: 1KX-955-119.CLB
   Component: Wischer AU354   H08 0070
   Coding: 00064784
   Shop #: WSC 01236
Address 15: Airbags        Labels: 8J0-959-655.lbl
   Part No SW: 8J0 959 655     HW: 8J0 959 655
   Component: -t Airbag 9.43  H02 0020
   Revision: 93H02002    Serial number: 0036K0031V7S
   Coding: 0011636
   VCID: 79D703AA3092FEE9291-802C
   Subsystem 1 - Serial number: 6332DRB40781D3A1Q
   Subsystem 2 - Serial number: 6342DRB407A4051FQ
   Subsystem 3 - Serial number: 63747RB403F61E2BZ
Address 16: Steering wheel        Labels: 8P0-953-549-F.lbl
   Part No SW: 8P0 953 549 F    HW: 8P0 953 549 F
   Component: J0527           H36 0070
   Coding: 0003011
   VCID: 41A7AB4A18C26629211-8014
   Component: E0221           H06 0030
Address 17: Instruments        Labels: 8J0-920-xxx-17-MY8.clb
   Part No SW: 8J0 920 980 B    HW: 8J0 920 980 B
   Component: KOMBIINSTR. VDO H13 0330
   Revision: D0H13005    Serial number: 2246H005001212
   Coding: 0005428
   Shop #: WSC 05842 002 1048576
   VCID: 3041FE8EA368FFA1DEF-8065
Address 19: CAN Gateway        Labels: 1K0-907-530-V3.clb
   Component: J533__Gateway   H16 0202
   Revision:   H16       Serial number: 2700K086268624
   Coding: E9821F261006025101
   VCID: 354FCF9A5C0ADA898D9-8060
   Part No SW: 0BR 907 554 A    HW: 0BR 907 554 A
   Component: Haldex 4Motion      3016
   Coding: 0000005
   VCID: 43ABA14202DE743933D-8016
   Revision: D0H13005    Serial number: AUX7Z0H6FNL07T
Address 26: Auto Roof        Labels: 8J7-959-255.lbl
   Part No: 8J7 959 255 B
   Component: 256 VSG TT      H14 0110
   VCID: 3E5DD0B6693C19D15C3-806B
03246 - Sensor for Canopy Flap; Left (G596)
                    Reset counter: 3
                    Mileage: 53503 km
                    Date: 2015.07.21
                    Time: 15:02:52
03247 - Sensor for Canopy Flap; Right (G597)
                    Reset counter: 3
                    Mileage: 53503 km
                    Date: 2015.07.21
                    Time: 15:02:51
Address 42: Door Elect, Driver        Labels: 8P0-959-801-MIN3.lbl
   Part No SW: 8J7 959 801 E    HW: 8J7 959 801 E
   Component: Tuer-SG         H02 0060
   Coding: 0000565
01034 - Electric Window Thermal Protection Active; Driver
            000 -  -  - Intermittent
   Part No: 8J0 909 144 C
   Component: EPS_ZFLS Kl. 236    2302
   Revision: 00H15000
16347 - Control Module - EEPROM Error
                    Fault Status: 00100101
                    Reset counter: 50
                    Voltage: 8.50 V
                        PD
                    Temperature: 31.0°C
                    Speed: 50.0 km/h
                    Torque: 0.0 Nm
                    Torque: 0.000 Nm
Address 46: Central Conv.        Labels: 8J0-959-433.lbl
   Part No: 8J0 959 433 B
   Component:    KSG          H11 0080
   Coding: 1890300241182D098505489AD633
   Subsystem 2 - Part No: 8J0 951 177
   Component: DWA-Sensor      H03 0020
Address 47: Sound System        Labels: 8J0-035-223.lbl
   Part No SW: 8J0 035 223 D    HW: 8J0 035 223 D
   Component: J525 Amp High   H04 0150
   Revision: PROD_01     Serial number: 00000000103096
   Coding: 0136133
   VCID: 256F1FDAECAAAA093D9-8070
   Part No SW: 8J7 959 802 E    HW: 8J7 959 802 E
   Coding: 0000564
   VCID: 3FA3ADB26E3610D9575-806A
   Part No SW: 8J0 035 195 G    HW: 8J0 035 195 G
   Component: R Symphony2+    H07 0270
   Revision: 00H07000    Serial number: AUZ1Z4H7169788
   Coding: 0730301
   Part No SW: 8P0 862 335 N    HW: 8P0 862 335 N
   Component: FSE_256x BT     H34 0520
   Revision: 00000000    Serial number: 00000005024601
   Coding: 0001202
End-------------------------(Elapsed Time: 01:29)--------------------------
Address 26: DTCs cleared
   Coding: 0000172
   Revision: 00H60001
   Coding: 0083827
                    Reset counter: 228
                    Mileage: 53534 km
                    Date: 2015.07.22
                    Time: 15:16:58
                    Count: 128
                    Count: 773
                    Count: 8212
                    Count: 46336
   Coding: 1049876
   Coding: 00064784
   Shop #: WSC 01236
   Coding: 0011636
   Coding: 0003011
   Coding: 0005428
   Coding: 0000005
   Coding: 0000565
   Revision: 00H15000
                    Reset counter: 50
                    Voltage: 8.50 V
                        PD
                    Temperature: 31.0°C
                    Speed: 50.0 km/h
                    Torque: 0.0 Nm
                    Torque: 0.000 Nm
   Coding: 0136133
   Coding: 0000564
   Coding: 0730301
   Coding: 0001202
End-------------------------(Elapsed Time: 01:27)--------------------------
Address 03: DTCs cleared
Address 44: DTCs cleared
Control Module Part Number: 8J7 959 801 E    HW: 8J7 959 801 E
  Component and/or Version: Tuer-SG         H02 0060
           Software Coding: 0000565
            Work Shop Code: WSC 01236 785 00200
Address 42: DTCs cleared
mgjohn
C?ID=221666
Latest state of play is that today I was unable to raise the roof.
Turned out there had been a problem with left flap
Saturday,01,August,2015,13:19:03:19372
VCDS Version: 15.7.0.1
Data version: 20150729
Mileage: 53730km-33386mi   Repair Order:
VIN: TRUZZZ8J891013414   Mileage: 53730km-33386miles
   VCID: 3E5DD0B6693C19CE64-806A
                    Reset counter: 3
                    Mileage: 53730 km
                    Date: 2015.08.01
                    Time: 12:52:08
I accept that I may reach the point where I need to replace the flap motor, they are recognised as troublesome, but I was able to get things working again as follows:
First I cleared the Module 26 DTC
Next I ran left and right flap output tests (but the flaps never moved)
Lastly I ran 'Convertible Top Flap Initialisation' - this was greyed out before I tried the flap tests and isn't mentioned in your Adaption guidelines.
It all seemed to recover the situation and the roof is working again.
I'm now wondering if your Adaption guidelines work for non North American cars?
Dana
Western PA, USA
Those control modules aren't significantly different so I don't believe the Wiki procedure or Output test function would vary from market to market. I don't have any first hand experience with this roof system but I dug up NAR TPI 2018777/7 to refresh my memory:
It points to TPI 2015779/7 (Convertible top adjustment options) to diagnose/repair mechanical adjustment issues followed by the VAS test plan (Output Test sequence) and notes the complete convertible top run must be completed before exiting the Output Test sequence.​
The only thing I'm not entirely sure about is the VCDS operation "Convertible Top Flap Initialisation" because that's the one I have had success with based on the phone support ticket feedback. If you haven't used that function alone please do at some point followed by the roof cycle to see if the DTC clears at that point.
Either way, this may happen after low battery voltage alone in some cases but the latest/greatest revised parts couldn't hurt at some point to avoid reoccurring problems.
mgjohn
C?ID=221666
Thanks Dana, I noted your changes to the Auto Roof page and followed
[Select]
[26 - Auto Roof]
[Output Tests - 03]
[Select] Selective Output Tests
[Choose]Convertible Top Flap Initialisation
[Start]
Operate the Convertible Top throughout a complete Open/Close sequence BEFORE exiting the Output Test function.
[Done, Go Back]
[Close Controller, Go Back - 06]
The bad news is that you cannot operate the roof with Top Flap Initialisation Test Started, it seems to lock it out.
Repeated fast operation of the switch gets it to stutter into life as if it's controller is busy occupied running .
Stopping the test allows one to open/close the roof ok.
However from looking at the measuring block data taken before running 'initialisation and later afterwards it seems it may have had some effect as the 'open flap' voltage threshold has changed and, after all, setting the threshold voltages that signal flaps open/closed is I guess what the initialisation/adaption is all about.
Tuesday,11,August,2015,18:36:31:19372
Dealer/Shop Name: Fairfield
VIN:    License Plate: A10JST
Mileage:    Repair Order: 11
Measuring blocks taken with roof closed/up and flaps open
motors signal voltage 41/45 - below 50/55v 'open' threshold
18:35:55 Group 007: Convertible Top Flap Sensors (Status: Closed)
  41.0  Conv. Top Flap Sensor Left (G596)
  45.0  Conv. Top Flap Sensor Right (G597)
18:35:55 Group 008: Convertible Top Flap Sensor (Status: Open)
  50.0  Sw. Thresh. (open) Flap Left (G596)
  55.0  Sw. Thresh. (open) Flap Right (G597)
Measuring blocks taken with roof open/down and flaps closed
motors signal voltage 174/175 above 162/165v 'closed' threshold
18:36:59 Group 007: Convertible Top Flap Sensors (Status: Closed)
  162.0  Sw. Thresh. (closed) Flap Left (G596)
  174.0  Conv. Top Flap Sensor Left (G596)
  165.0  Sw. Thresh. (closed) Flap Right (G597)
  175.0  Conv. Top Flap Sensor Right (G597)
18:36:59 Group 008: Convertible Top Flap Sensor (Status: Open)
later after running 'flap initialisation' 'open flap' voltage threshold has changed
motors signal voltage 42/47 below 70/70v (was 42/47v) 'open' threshold
18:45:52 Group 007: Convertible Top Flap Sensors (Status: Closed)
  160.0  Sw. Thresh. (closed) Flap Left (G596)
  42.0  Conv. Top Flap Sensor Left (G596)
  160.0  Sw. Thresh. (closed) Flap Right (G597)
  47.0  Conv. Top Flap Sensor Right (G597)
18:45:52 Group 008: Convertible Top Flap Sensor (Status: Open)
  70.0  Sw. Thresh. (open) Flap Left (G596)
  70.0  Sw. Thresh. (open) Flap Right (G597)
motors signal voltage 174/177 above 162/165v 'closed' threshold
18:46:10 Group 007: Convertible Top Flap Sensors (Status: Closed)
18:46:10 Group 008: Convertible Top Flap Sensor (Status: Open)
  175.0  Conv. Top Flap Sensor Left (G596)
Oh, running the 'Testing Motors for Convertible Flaps' Output Test still has no effect.
So, to summarise, the original adaptation guide doesn't work as flap test doesn't move flaps and the amended Flap Initialisation instructions don't work either - at least for me.
Hey it would be great if I had another TT convertible to run VCDS on eh.
Cheers, John
Dana
Western PA, USA
Yeah :) Another 8J TT without any DTCs would be ideal to baseline but I don't know anyone with one of those vehicles.
The TPI explicitly says not to exit Output tests prior to operating the roof but based on your detailed feedback ... I have to wonder at this point if the guided test plan deactivates the function and you only need to leave the diagnostic session with address 26 open?
mgjohn
C?ID=221666
Maybe but leaving aside the Re-initialisation for a moment to reflect on inoperable flap output tests;
[26 - Auto Roof]
[Output Tests - 03]
[Choose] - Motor for Convertible Top Flap Left (V383)
[Start]
Wait until the Flap has open and closed,
Flaps don't move for me, neither did they for WolfmanJack who wrote:
>Any idea why the flaps do not move at all during the output test for flap motors, but the roof and flaps operate normal when leaving the test -> I was running the test while engine was running -> Should the engine be off ?
and
>What could be an explanation why the flaps do not move at all during the output test for flap motors, but the roof and flaps operate normal when leaving the test ?
I suppose its conceivable that we both have some kind of scrambled controller that allows the roof and flaps to work but doesn't respond to an output test but what about the possibility that vcds might be at fault?
It sounds like you may not have been able to test them on an 8J TT?
As I said upstream the only output test that seems to work is the one that lights the roof open warning indicator.
John - here to help find a solution
Dana
Western PA, USA
Yeah, that wasn't my work so I didn't delete it from the Wiki. Having it there however will generate feedback .. although now that I think about it that may be limited to broken vehicles rather than fully functional baseline roof systems.
WolfmanJack is from the US so that should rule out market specific diagnostic functions discrepancies. RoW repair info on the other hand is market specific so you may need to search erWin Audi by VIN to see if anything is available for this specific vehicle.
I doubt this is a scrambled controller problem because both vehicles have fault codes stored in the 26 controller. We haven't received negative feedback on the Convertible Top Flap Initialisation Output test function but .. our phone support tickets are mainly repair shops with vehicles that just had the latest flap motors installed. WolfmanJack mentioned the VW dealer replaced his motors but I wonder if they were the latest/greatest from the Audi dealer parts department or not?
No, I dug to confirm the label file information matched the test plan and transferred it into the Wiki but I do not have any personal experience with that roof system.
I don't think VCDS is at fault here but you can do the following with a fault free controller and email the resulting files in the Debug folder:
[Options]
Change the Debug level from 0 -to- 1024
[Apply]
At that point you can connect to the #26 roof controller and select Convertible Top Flap Initialisation. Please use your best judgement at this point but I would leave that test active/enabled for at least 10 seconds.
[Done, Go Back]
After exiting VCDS you can check this location C:\Ross-Tech\VCDS\Debug for a file named DEBUG26.DLM. Eric may be able to determine if VCDS receives feedback from the controller when attempting to run the Convertible Top Flap Initialisation reset based on that information.
mgjohn
C?ID=221666
Thanks Dana, your help is much appreciated.
I have just emailed you two debug files, one when trying Convertible Top Flap Initialisation test and one for Motor for Convertible Top Flap Left (V383)
John
mgjohn
C?ID=221666
Oh, I forgot to add - I dug out a handful of euro's and scoured Erwin
The roof operation mechanism is described in detail in A075S00332V-Nr_391__AUDI_TT_Roadster.pdf but as regards initialisation it simply says
"After repair work on the convertible top covers, convertible top cover senders G596 and G597 must
be adapted to the convertible top operation control unit J256. This can only be accomplished using
a VAS tester and the Guided Fault Finding or Guided Functions option."
jt
mgjohn
C?ID=221666
John
Did the debug files get to you ok Dana?
Having experimented some more I reckon the Reinitialisation Test resets the flap motors open/closed threshold voltages to 70 and 160
Having exited the reinit test and operating the roof a few times allows the controller to adjust the thresholds to be within 10v of the readings it's actually seeing from the flap motors.
I guess it would store the settings when you close the controller (?)imho
If this theory is correct then new flap motor adaption process would be:-
Run (and stop) Reinitialisation and then run open/close flap tests a few times - but the open/close flap tests don't work for me - doh!
Where did your wiki info originate?
btw I have opened up and inspected a flap motor and they are not very complex.
About the only thing that could go wrong is for a variable resistance track or contact to develop a fault and send a rogue voltage reading causing the controller to have a fit. I'll post photo's elsewhere.
John
mgjohn
C?ID=221666
John
Have now used VCDS built-in upload facility to transfer debug files after repeated attempts to email attachments to support were bounced.
John
Can you please Forward the bounced mails to us in their entirety so we can have a look at the headers to see why they bounced?
Andy
Sector 7G
HC424490
The debug files appear to show nothing out of the ordinary. The unit is simply saying "running". I'm not sure what else to suggest other then the factory test plan may be using some additional steps that aren't documented for some reason.
Dana
Western PA, USA
This
sounds a lot like what I located in NAR TPI 2018777/7 and the mechanical redirection to TPI 2015779/7.
I didn't originally create that page but the new info was based on the TPIs in addition to locating which Outputs should be supported by the 26 module. After doing so I dug to see what the factory scan tool test plan would do. All of it matched the notes in our label file so someone else had already been there and done that :) I didn't think the label file instructions were incorrect based on personal success working with repair shops over the phone .. but double checking never hurts. At the least we have the Wiki page discrepancy partially sorted.
I agree and suspect it is a potentiometer reading the 26 module isn't happy with but pics would be great!
We just received a NAR scan from a 2008 TT with new flap motor(s) installed and 02000 - Switch Position - Implausible Signal - Intermittent stored. I'll keep an eye on that conversation if I'm unable to reply directly.
mgjohn
C?ID=221666
Done - emailed to support, here's a summary
First one sent Aug 20th bounced back on 25th with a 451
Next sent 27th Aug bounced back 1 Sept same result
<support@ross-tech.com>: host ross-tech.com[207.58.189.11] said: 451
Temporarily unable to process your email. Please try again later. (in reply
to RCPT TO command)
jt
mgjohn
C?ID=221666
Hmm - so anyone got any good theories as to why, when vcds asks the controller to move the flaps it just carries on running, nothing moves and it doesn't report 'end'? And the same thing happens when asked to 'reinitialise'
The good news is that flaps (and roof) are currently all working fine and when controller is asked to cycle the dash roof indicator light it manages that just fine!!
If I were to unplug and reconnect the controller in an attempt to 'reset' it might I be 'lifting up a stone'?
jt
Dana
Western PA, USA
Internal, I replied to E?ID=269727 asking him to try the V383 and V381 Output Tests after the new flap motors are calibrated using the Convertible Top Flap Initialisation procedure.
