High Beam Assist Activation
Hbuk24
Spain
C?ID=306940
I have an Audi TT 8S which has the camera installed from factory and im told that you can activate the high beam assist function. Does anyone have steps to do this or experience with it? I followed some instructions previously which created a lot of lighting errors. Thanks
PetrolDave
Westbury, UK
C?ID=1423
Seeing a VCDS Auto-Scan of your TT 8S will help to ensure that you get the correct instructions to enable HBA for your car.
Hbuk24
Spain
C?ID=306940
Sure, please see an original scan below;
Sunday,12,January,2020,16:42:30:30289
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64(Parallels)
VCDS Version 19.6.2.0 (x64)  HEX-V2 CB: 0.4508.4
VIN: TRUZZZFV3F1009952   License Plate:
Chassis Type: FV-AU37 (8S0)
Scan: 01 03 05 08 09 10 15 16 17 19 2B 42 44 52 55 5F A5 A9
VIN: TRUZZZFV3F1009952   Mileage: 91851km-57073miles
Address 01: Engine (J623-CHHC)       Labels:. 06K-907-425-V1.clb
   Part No SW: 8S0 906 259     HW: 06K 907 425 B
   Component: 2.0l R4 TFSI  H13 0003
   Revision: --H13---
   Coding: 0A1900322424050B3002
   Shop #: WSC 06385 790 00016
   ASAM Dataset: EV_ECM20TFS0208S0906259 001004
   ROD: EV_ECM20TFS0208S0906259.rod
   VCID: 7AAEFB5F1C583CC7873-802F
20277 - Terminal 15 Voltage
          P151B 00 [036] - Implausible
                    Mileage: 91851 km
                    Date: 2020.01.12
                    Time: 15:43:43
                    Engine speed: 798.00 /min
                    Normed load value: 3.1 %
                    Coolant temperature: 90 ∞C
                    Intake air temperature: 34 ∞C
                    Voltage terminal 30: 12.050 V
                    Engine: operating status: IS
                    STATE_LS_SAE[1]: OL_CDN
                    T_AST_SAE: 0 s
                    MAP_MES_SAE: 27 kPa
                    Lambda probe voltage: bank 1: probe 1 (broadband probe): 1.987 V
                    FAC_TPS_1_SAE: 11.718750 %
                    FUP_H_SAE: 11000.0 kPa
15057 - Fuel Rail/System Pressure
          P0088 00 [096] - Too High
   Part No SW: 8S0 907 379 B    HW: 8S0 907 379 B
   Component: ESC           H31 0504
   Revision: 00000000    Serial number: 63474000000378
   Coding: 32AA108D1A9915B2409A0069C2939306444C0858A8020043C96022
   ASAM Dataset: EV_Brake1UDSContiMK100IPB 052008
   ROD: EV_Brake1UDSContiMK100IPB_052.rod
   VCID: 40DA49B73A04A617897-8015
   Part No SW: 3Q0 959 435     HW: 3Q0 959 435
   Component: VWKESSYMQB    023 0522
   Revision: 00023000    Serial number: 0356563904
   Coding: 000F0F1620
   ASAM Dataset: EV_KessyHellaMQBAB 004027
   VCID: 77A8E26B2F4A21AFF8D-8023
   Part No SW: 8S0 820 047     HW: 8S0 820 047
   Component: AC Manuell el H05 0030
   Revision: 20009000    Serial number: 14190000009000
   Coding: 410040000011100100
   ASAM Dataset: EV_AirCondiMAPrehAU33x 003011
   ROD: EV_AirCondiMAPrehAU33x.rod
   VCID: 70BAD9774A247697397-8025
   Operating and display unit 1 for air conditioning:
   Subsystem 1 - Part No SW: 8S0 820 374 A    HW: 8S0 820 374 A
   Component: E774 BuA_1  H06 0010
   Serial number: 00000000000000000916
   Operating and display unit 2 for air conditioning:
   Subsystem 2 - Part No SW: 8S0 820 360 D    HW: 8S0 820 360 D
   Component: E775 BuA_2  H06 0010
   Operating and display unit 3 for air conditioning:
   Subsystem 3 - Part No SW: 8S0 820 360 C    HW: 8S0 820 360 C
   Component: E776 BuA_3  H06 0010
   Operating and display unit 4 for air conditioning:
   Subsystem 4 - Part No SW: 8S0 820 360 E    HW: 8S0 820 360 E
   Component: E777 BuA_4  H06 0010
   Operating and display unit 5 for air conditioning:
   Subsystem 5 - Part No SW: 8S0 820 374 B    HW: 8S0 820 374 B
   Component: E778 BuA_5  H06 0010
   Part No SW: 5Q0 937 084 BR    HW: 5Q0 937 084 AJ
   Component: BCM MQBAB H   H18 0136
   Serial number: 01011500600635
   Coding: 07054C46C201067D03044004B31807A80080000000000000000000000000
   ROD: EV_BCMBOSCH_013.rod
   VCID: 094C949349BE275F9E9-805D
   Subsystem 1 - Part No SW: 8S2 955 119 A    HW: 8S2 955 119 A  Labels: 5QX-955-119-V1.CLB
   Component: 43x RL 140703  032 0371
   Serial number: 00000001407010600651
   Coding: 1BC7F7
   Subsystem 2 - Part No SW: 8U0 955 559 A    HW: 8U0 955 559 A  Labels: 8U0-955-559.CLB
   Component: G397_RLS  H06 0002
   Serial number: 20170017
   Coding: 00005D
   Light switch:
   Subsystem 3 - Part No SW: 8V0 941 531 AA    HW: 8V0 941 531 AA
   Serial number: 31 10 2014  00001298
   Subsystem 4 - Part No SW: 5Q0 951 171     HW: 5Q0 951 171
   Serial number: 000000000ZY143210P5Q
   Serial number: 00000000000031477725
204546 - Remote key 2
                    Reset counter: 144
                    Mileage: 91818 km
                    Date: 2019.12.17
                    Time: 09:38:45
262912 - Sensor for Anti-Theft Alarm System
          B1330 F5 [008] - Alert Emergency Activation Stage 1
                    Reset counter: 184
                    Mileage: 91818 km
                    Date: 2019.12.17
                    Time: 09:38:46
   Part No SW: 5Q0 919 283 E    HW: 5Q0 919 283
   Component: PARKHILFE 4K  H10 0051
   Revision: --------    Serial number: 39291435205285
   Coding: 0000050001
   VCID: 3B203E5B53E2C5CFDC5-806F
   Part No SW: 5Q0 959 655 P    HW: 5Q0 959 655 P
   Component: AirbagVW20    009 0870
   Serial number: 003M7R008LLN
   Coding: 88CCF0C00C8000005C5000CFC0C800000065
   ROD: EV_AirbaVW20SMEVW37X.rod
   VCID: 4DC46083FD567B7F721-8019
   Subsystem 1 - Part No SW: -----------    HW: 480 000 701 15
   Serial number: 35700000000B4079621C
   Subsystem 2 - Part No SW: -----------    HW: 480 000 701 15
   Serial number: 358000000007D539621J
   Subsystem 3 - Part No SW: -----------    HW: 480 010 712 14
   Component: SideSensor_Dr  004 0108
   Serial number: 351001A014A5F5C2CECQ
   Subsystem 4 - Part No SW: -----------    HW: 480 400 910 14
   Serial number: 3550002A7175A922917%
   Front Sensor Passenger:
   Subsystem 5 - Part No SW: -----------    HW: 480 400 910 14
   Serial number: 3560002A5175A924114W
   Pedestrian Protection Center:
   Subsystem 6 - Part No SW: -----------    HW: 480 400 812 14
   Serial number: 23000029F1811B91607X
   Subsystem 7 - Part No SW: -----------    HW: 480 000 612 14
   Serial number: I0M000000007C0CC1211
   Subsystem 8 - Part No SW: -----------    HW: 480 000 612 14
   Serial number: I0N00000000C94CC1218
   Part No SW: 8S0 907 129 AL    HW: 8S0 907 129 AL
   Component: Lenks. Modul  H07 0140
   Revision: --------    Serial number: 91335OA800762
   Coding: 280C
   ASAM Dataset: EV_SMLSKLOMQB 019002
   ROD: EV_SMLSKLOMQB_010_VW37.rod
   VCID: 045285A76E9C7A37EDF-8051
Address 17: Instruments (J285)       Labels:* Redir Fail!-SRI2
   Part No SW: 8S0 920 790     HW: 8S0 920 790
   Component: FBenRDW       H32 0221
   Coding: 24250110698006000120A8809000800000000000
   ASAM Dataset: EV_DashBoardBOSCHAU33X 001013
   ROD: EV_DashBoardBOSCHAU33X.rod
   VCID: 76B6EF6F284058A7E3B-8023
   Part No SW: 8S0 907 468 A    HW: 8S0 907 468
   Component: GW MQB TT3    012 0203
   Revision: --------    Serial number: 10121410802670
   Coding: 030100042F025A004B000268080000000000000000000000000000000001
   ASAM Dataset: EV_GatewContiAU33X 011002
   ROD: EV_GatewContiAU33X_011.rod
   VCID: 3E26374F40F0D0E7FBB-806B
   Subsystem 2 - Part No SW: 8S0 951 523 B    HW: 8S0 951 523 B
   Component: J453 MFL  H06 0001
   Serial number: 20141127192416 RD508
   Subsystem 3 - Part No SW: 8S0 915 181 A    HW: 8S0 915 181 A
   Serial number: 1322795203
   Serial number: 14000306508006
   Coding: 0100000000000000
   ROD: EV_ELVMarquMQBB.rod
   VCID: 71BCDC73412E7F9F369-8025
   Part No SW: 5Q0 959 593 D    HW: 5Q0 959 593 B
   Serial number: 060115BLN04479
   Coding: 001146225C01040100001402
   VCID: 42DE43BF3408B4079F3-8017
   Coding: 9103
   VCID: 3728226B6FCAE1AF38D-8063
Address 52: Door Elect, Pass.
   Coding: 03DE00102B200200
   ASAM Dataset: EV_HeadlRegulAUDIMXBAU64X 005010
   VCID: 343215677EBC0AB71DF-8061
   Coding: E01800
   Coding: E01800
   Subsystem 3 - Part No SW: 8S0 941 329     HW: 8S0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo links  H02 S002
   Coding: E01800
   Subsystem 4 - Part No SW: 8S0 941 329     HW: 8S0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H02 S002
   Coding: E01800
Address 5F: Information Electr. (J794)       Labels:* Redir Fail!
   Part No SW: 8S0 035 072 A    HW: 8S0 035 072
   Component: MU-H-ND-ER    041 0139
   Serial number: A587A0FB000508
   Coding: 013304013C00000011111101000800002F0000E3000000001A
   ASAM Dataset: EV_MUHig4CGen2HBAS 001115
   ROD: EV_MUHig4CGen2HBAS_AU37.rod
   VCID: 2D0400039D965B7F521-8079
   Multimedia Operating Unit:
   Subsystem 1 - Part No SW: 8S0 919 614 L    HW: 8S0 919 614 L
   Component: ControlUnit_H  H21 0129
   Serial number: C1000015111400010114
   Subsystem 2 - Part No SW: V03 959 800 EG    HW: -----------
   Component: Gracenote2  --- 1008
Address A5: Frt Sens. Drv. Assist (R242)       Labels:| 5Q0-980-653.clb
   Part No SW: 8S0 980 653     HW: 5Q0 980 653
   Component: MQB_MFK       H06 0002
   Serial number: 00000268359
   Coding: 0100000001010300000501000000010100
   ROD: EV_MFKBoschAU370.rod
   Part No SW: 8S0 907 159     HW: 4H0 907 159 A
   Component: SAS-GEN 2     H07 0004
   Serial number: 141203200313
End----------(Elapsed Time: 01:24, VBatt start/end: 13.2V/13.2V)-----------
Dana
Western PA, USA
Thanks Dave. There's a bit of history in this thread as well but we sorted those main issues and I suggested posting in Retrofits.
Hbuk24
Spain
C?ID=306940
I have found the instructions below online, do they look correct? I have created issues on the car before trying to activate HBA so wanted some advice before I try these. Thanks
 High Beam Assist
Unit 9
security access 31347
adaptions
Unit A5
security access
Module 09
Long coding: No long coding at all needed on this module.. I was really surprised by this!!!!
Adaptations:
Fernlicht_assistent:
* Erweiterte_Fernlichtsteuerung: AFS, FLA, Fernlicht ueber AFS
* Menuesteuerung Fernlichtassistent: Present
* Fernlichtassistent Reset: not active
* Menuesteuerung Fernlichtassistent Werkseinstellung: Not present
* Assistenzfahrlicht, Empfindlichkeit per BAP einstellbar: Present
*** I only needed to change the two that are highlighted but you can also change "Fernlichtassistent Reset" to "not active" and the Auto Assist will be remembered after switching the ignition off.
Module A5:
Long coding: byte 2 value 01 (bit 0 on)
Unit A5
security access 20103
change the speed activation and deactivation of auto full beam
Unit A5
Security Access 20103
Adaption
find in the menu "activation speed for high-beam assistant"
standard value is 57 km/h, set your speed then ok
find in the menu "channel speed threshold for high beam recommendation off"
standard value is 27 km/h, set your speed then ok
find in the menu:
-activation speed for high beam assistant insert 20 on the blank space below then ok
-speed threshold for high beam off
insert 10 on the blank space below then ok
-check if this parameter is on:
main beam assist urban area detection, set on if not
Hbuk24
Spain
C?ID=306940
I could not find the following option available to try it unfortunately;
Hbuk24
Spain
C?ID=306940
Yes I did enter the security code
Dana
Western PA, USA
Posting the Adaptation function map from 09 might be necessary but I'd search for "Fernlicht" the next time you are connected to the BCM. I believe one if the channels named Fernlichtassistent may apply.
DV52
C?ID=194404
^^^Hbuk: Hi.
hmm...... the words bolded in your instruction below may be greatly exaggerated!!! ;)
Module 09
I'm not familiar with Audi TT 8S, but the vehicle appears to have a not uncommon MQB platform BCM. I suspect therefor that the original author of your instructions was "surprised" because the BCM that pertained to the instruction was the newer type which contained no long code. Your BCM does indeed appear to have a live and healthy long code.
Here's the code for the pertinent Byte:
Byte 2, Bits 0-2 (Advanced Highbeam control)
Halogen=hex0
Halogen_main_beam_assist=hex1
Xenon_AFS=hex2,
Xenon_AFS_and_main_beam_assist=hex3
Bi-xenon_AFS=hex4
Bi-xenon_AFS_and_main_beam_assist=hex5
Bi-xenon_AFS_and_MDF_GLW= hex6
Your setting for Byte 2 is Hex4C (or Binary 01001100) - so using my list, your car appears to have HiDs because Bits 0 -2 have a value of hex4. Perhaps you might try changing this to 01001101, which equals Hex 4D).
PS: I'm not sure if making this change also means that you will lose the current headlight calibration - if so, some time spent in Basic Settings for the BCM may be needed
PPS: Has this car been tuned?
Hbuk24
Spain
C?ID=306940
Thanks for your response, I will look in to this shortly. The car is fitted with the standard LED headlights.
Yes the har has been remapped, would this affect anything?
DV52
C?ID=194404
Yes the car has been remapped, would this affect anything?
No -I expect that it will make no difference to the HBA activation exercise - but it might explain the intermittent System Pressure -too high DTC in the hex01 module.
Not sure how the implausible T15 error can be generated - anyone else have a view? In any event, these (and the BCM faults - have you replaced the battery in the key fob yet?) appear to be aberrations - try clearing and re-poll.
Hbuk24
Spain
C?ID=306940
Hi Don, Sorry but I don't understand. I am not aware of any errors. The autoscan comes back with all systems OK and the only morning i get is regarding traffic signs.
PetrolDave
Westbury, UK
C?ID=1423
   Revision: --H13---
:confused::confused::confused:
Hbuk24
Spain
C?ID=306940
Im not when this scan was from, a while ago I have a lot of issues which I had resolved. I can find a recent scan and post it here.
Hbuk24
Spain
C?ID=306940
Please see below the latest scan from yesterday;
Wednesday,29,January,2020,18:57:26:30289
VIN: TRUZZZFV3F1009952   Mileage: 94785km-58896miles
  Component: 2.0l R4 TFSI  H13 0004
  Revision: --H13---
  ASAM Dataset: EV_ECM20TFS0208S0906259 001005
Readiness: 0010 0001
  Coding: 000F0F1620
  Coding: 1BC7F7
  Coding: 00005D
  Light switch:
  Coding: 0000050001
  Coding: 280C
  Coding: 242D0110698406000122F8809000800000000000
  Coding: 001546225C01040100001402
  Coding: 9103
  Part No SW: 5Q0 959 592 D    HW: 5Q0 959 592 B
  Serial number: 100115BA91780A
  Coding: 001546225E01040100001402
  VCID: 41DC4CB3310EAF1F869-8015
  Coding: E01800
  Coding: E01800
  Coding: E01800
  Coding: E01800
  Coding: 013304013C00000011111101000800002F0000E3000000001E
  Subsystem 1 - Part No SW: V03 959 801 ET    HW: -----------
  Component: ECE 2015  --- 0105
  Subsystem 2 - Part No SW: 8S0 919 614 L    HW: 8S0 919 614 L
  Coding: 0101000001010300000501000000010100
End----------(Elapsed Time: 01:25, VBatt start/end: 12.1V/12.1V)-----------
m87a
Bosnia and Herzegovina
C?ID=156900
did you try to change any adaptations channels? do a back up first in case you need to revert to factory
Hbuk24
Spain
C?ID=306940
No, Im not sure what this is?
