Audi A4 2013 volume currently unavailable
purebmw
Guatemala
C?ID=346307
Hello everyone. First time posting. was wondering if you guys could help me. so here is what happened mmi died and another shop changed it. so mmi started working but no sound. Fuses checked, optical bus diagnostics done and everythig seems OK. Autoscan down below
thanks for your help :)
 Thursday,21,March,2019,09:08:26:24100
VCDS Version: 18.9.1.0 (x64)  HEX-NET CB: 0.4436.4
VIN: WAUEFAFL3DA148538   License Plate:
Chassis Type: FL-AU48 (8R0)
Scan: 01 02 03 05 08 09 15 16 17 19 36 42 44 46 52 53 56 5F 62 6C
          72
VIN: WAUEFAFL3DA148538   Mileage: 65450km-40668miles
09-Cent. Elect. -- Status: Sporadic communication error 1000
Address 01: Engine (0-----CAEB)       Labels:. 06H-907-115-CDN.clb
   Part No SW: 8K5 907 115 C    HW: 8K2 907 115 L
   Component: 2.0l R4/4V TF H09 0005
   Revision: ECH09---
   Coding: 4A030013242400062000
   Shop #: WSC 04039 001 1048576
   ASAM Dataset: EV_ECM20TFS0118K5907115C 001006
   ROD: EV_ECM20TFS0118K5907115C.rod
   VCID: 3228E235657145DA1B-8066
Readiness: 1110 0101
Address 02: Auto Trans (J217)       Labels:| 0AW-927-156.clb
   Part No SW: 8K2 927 155 E    HW: 0AW 927 156 K
   Component: 0AW 20TAVSUSA H05 0003
   Revision: --H05---    Serial number: 0000000974
   Coding: 000001
   Shop #: WSC 06325 000 00000
   ASAM Dataset: EV_TCMVL381 A02431
   ROD: EV_TCMVL381.rod
   VCID: 373ED3218E13A0F22C-8062
   Part No SW: 8K0 907 379 CH    HW: 8K0 907 379 CH
   Component: ESP8 front    H09 0100
   Coding: 081D18
   VCID: 014A7DF998572E42D2-8054
02214 - Tire Pressure Warning
                    Reset counter: 41
                    Mileage: 65452 km
                    Date: 2018.11.13
                    Time: 01:35:52
                    Hex Value: 0x0000
                    Hex Value: 0x0702
                    Hex Value: 0x0021
                    Hex Value: 0x1BA9
                    Hex Value: 0x0000
   Part No SW: 8K0 907 064 GM    HW: 8K0 907 064 FM
   Component: BCM2 2.0      H11 0621
   Coding: 0D814000000000000000
   Subsystem 1 - Part No SW: 8K0 959 754 B    HW: 8K0 959 754 B
   Serial number: 0812000166707014
   Subsystem 2 - Part No SW: 8K0 905 852 E    HW: 8K0 905 852 E
   Serial number: 2312000222218016
                    Fault Status: 00101101
                    Reset counter: 81
                    Mileage: 65452 km
                    Date: 2018.11.13
                    Time: 00:00:01
   Part No SW: 8K1 820 043 T    HW: 8K1 820 043 T
   Revision: C1000000    Serial number: 01101020120303
   Coding: 6400208000
   VCID: 393AD519B007B682DA-806C
   Revision: 08016001    Serial number: 00000489663702
   Coding: 26000091863CAFC00000480300003D0D0F1C5208A2090221000008004000020100000030000000
   VCID: 78BC101DCB8D6F8AE5-802C
   Component: WWS 091012  H07 0080
   Serial number: SWF12100096167
   Coding: 00FD11
   Serial number: 20631161
   Coding: 02005D
   Component: E1 - LDS  H03 0031
   Serial number: 00000000000210120112
   Component: USHL4.2  H30 0030
   Serial number: 0000002274555R38T602
   Subsystem 5 - Part No SW: 4H0 907 658     HW: 4H0 907 658
   Serial number: 6E384F46000000000001
   Part No SW: 8K0 959 655 P    HW: 8K0 959 655 P
   Serial number: 003KJD90V48L
   Coding: 303844354730303030304A55304C384B3053
   Shop #: WSC 09805 002 1048576
   VCID: 4AD89AD5EDE12D1A43-801E
   Subsystem 1 - Part No SW: 8K0 959 339 C    HW: 8K0 959 339 C
   Serial number: 5810000R120000AGFL
   Serial number: 6334MSME7166053DE
   Serial number: 6344MSME7165532FI
   Serial number: 6352QSME2125287AE
   Serial number: 6362QSME4C242C70L
   Serial number: 63732SME49241658
   Serial number: 63832SME4924244A$
   Part No SW: 8R0 953 568 Q    HW: 8R0 953 568 Q
   Component: Lenks.Modul   H02 0171
   Revision: 00000000    Serial number: 20121011000234
   Coding: 000036
   VCID: 4FEE8BC11E83083214-801A
   Part No SW: 8K0 920 982 D    HW: 8K0 920 982 D
   Component: KOMBIINSTR.   H35 0553
   Revision: 00000000    Serial number: RBI36LK9D
   Coding: 8BB609000301D705020000
   VCID: 3522D9299C1F52E23E-8060
   Part No SW: 8R0 907 468 H    HW: 8R0 907 468 C
   Component: GW-BEM 4CAN-M H11 0051
   Revision: 1Y050025    Serial number: 2541Y129280141
   Coding: 80C303FF00
   VCID: 44C4B4EDC7C5FB6AB9-8010
   Serial number: 5180858101
                    Reset counter: 81
                    Mileage: 65452 km
                    Date: 2018.11.13
                    Time: 00:00:01
                    Bin. Bits:    00000
                    Voltage: 12.00 V
                    Count: 7
                    Bin. Bits:    10000
                    Time: 0.90 s
   Part No SW: 8K0 959 760 D    HW: 8K0 959 760 D
   Component: MEM-FS        H06 0076
   Revision: AA000000    Serial number: 00000039539758
   Coding: 00581B00000000000000
   VCID: 3B36CF11BA3B8492C8-806E
   Part No SW: 8T0 959 793 P    HW: 8T0 959 793 G
   Component: TSG FA        H09 0304
   Coding: 011C13204E00410001
   VCID: 56E07EA5215979FAD7-8002
   Revision: 00001000    Serial number: 0021900568
   Coding: 100000000001
   Shop #: WSC 06324 000 00000
   ROD: EV_RCEPSAU48X_008.rod
   VCID: 3424E42D9F654BEA09-8060
18689 - Terminal 30
          U140A 00 [009] - Open Circuit
          [Ausfall der Versorgungsspannung (Kl30 oder Kl31) im Stillstand (unkritisch)]
                    Reset counter: 41
                    Mileage: 65452 km
                    Date: 2018.11.13
                    Time: 00:06:39
                    Write only channel
   Revision: 00002001    Serial number: 0184829737
   Coding: 0106023A00FA400580B0013200000000
   Component: GTO BF  H01 0080
   Serial number: 00000000000000583166
   Subsystem 3 - Part No SW: 8K0 959 591 B    HW: 8K0 959 591
   Component: J245 PS050  H08 0043
                    Reset counter: 81
                    Mileage: 65452 km
                    Date: 2018.11.13
                    Time: 00:00:01
   Part No SW: 8T0 959 792 P    HW: 8T0 959 792 G
   Component: TSG BF        H09 0304
   VCID: 55E279A93C5F72E2DE-8000
   Part No SW: 8K0 907 801 L    HW: 8K0 907 801 J
   Component: EPB-4         H01 0003
   Revision: --------    Serial number: 00000001186863
   ROD: EV_ParkiBrake_AU48.rod
   VCID: 383CD01D830DAF8A25-806C
   Part No SW: 4G0 035 082 D    HW: 4G0 035 082
   Component: Radio U SIRIU H60 0112
   Revision: AB001007    Serial number: 156H-0C7621138
   Coding: 020007010000000000
   Shop #: WSC 31414 790 00001
   VCID: 210A1D793897CE42F2-8074
   Part No SW: 8R1 035 746 C    HW: 8R1 035 746 B
   Component: H-BNT-NA      H43 0624
   Revision: --------    Serial number: 204JY0C7535433
   Coding: 0F0200000006A1EF41028B4E00000403140000000000000000
   VCID: 373ED3218613A0F22C-8062
   Subsystem 1 - Part No: 8R0 060 884 AM
   Component: NAR 2012  0605
   Component: DU7 High  H41 0104
   Serial number: A130JQ0C2552604
   Serial number: 00000001297653
   Subsystem 4 - Part No: 8R0 060 961 D
   Component: CD-Database  4353
01524 - Antenna for Telephone
                    Fault Status: 00101011
                    Reset counter: 41
                    Mileage: 65452 km
                    Date: 2018.11.13
                    Time: 01:58:02
                    Voltage: 12.40 V
00822 - Connection DSP to Radio
                    Reset counter: 41
                    Mileage: 65452 km
                    Date: 2018.11.13
                    Time: 01:41:05
                    Voltage: 13.40 V
   Part No SW: 8T0 959 795 Q    HW: 8T0 959 795 H
   Component: TSG HL        H07 0304
   Coding: 010C13204000210001
   VCID: 59FA759950475682FA-800C
   Revision: --H07---    Serial number: 525PA8-J2791UV
   Coding: 1000006
   VCID: 383CD01D4B0DAF8A25-806C
   Component: TSG HR        H07 0304
End----------(Elapsed Time: 02:01, VBatt start/end: 13.8V/13.7V)-----------
MasterTommy
Amsterdam
C?ID=295586
Well, if I remember correctly, DSP = amplifier. If the infotainment unit complains about not being connected to the amp, i’d say theres your problem. If the car doesnt have an amp, the new unit is coded incorrectly and/or has the wrong dataset.
I've looked at what coding info we have for that 5F / J794 and I don't see anything pertaining to sound system, amp, or speaker configuration.
purebmw
Guatemala
C?ID=346307
so what you're saying is that the mmi unit doesnt need coding? the mmi unit is used... any ideas if that could be the problem?
Could be the wrong MMI unit or the wrong data/parameter set in it?
I don't suppose you have a scan from before it was swapped out?
purebmw
Guatemala
C?ID=346307
no i dont, it was changed in another shop :( same mmi unit . same part no. but its an ebay unit
