Hi there, I have just had my brake pads changed on my Audi A6 2014, 2.0, TDI, (UK vehicle). The brake pad warning light keeps illuminating on the dash, so having done some reading, it is likely to be a broken connection to a sensor. The obvious question, yes, the pads have definitely been changed and are new, so comfortable its the sensor/connection.
How do I disable the Brake Pad Warning Light using the VCDS software?
I have tried to find an exact answer on the forum but no luck unfortunately.
I am very knew to the VCDS software so please feel free to use "Idiots guide" language.....I can see coding strings is going to be part of the answer but am confused how that works.
Any help would be gratefully appreciated
Thanks!
Thanks!
Tuesday,03,March,2020,15:14:27:46541
VCDS Version: 19.6.2.0 (x64) HEX-V2 CB: 0.4508.4
VIN: WAUZZZ4G3EN182843 License Plate:
Chassis Type: 4G-AU57 (4G0)
Scan: 01 03 05 08 09 10 15 16 17 19 3B 42 44 46 47 52 53 55 5F 62
72 AC
VIN: WAUZZZ4G3EN182843 Mileage: 73894km-45915miles
Address 01: Engine (J623-CNHA) Labels:. 04L-907-309-V1.clb
Part No SW: 04L 906 021 FE HW: 04L 907 309
Component: R4 2,0L EDC H23 8243
Revision: 85H23---
Coding: 0A194012242401080000
Shop #: WSC 56882 001 1048576
ASAM Dataset: EV_ECM20TDI01104L906021FE 002007
ROD: EV_ECM20TDI01104L906021FE_002.rod
VCID: 6D87C9623D1AA2BF121-8038
19226 - Particulate Trap Bank 1
P2002 00 [101] - Efficiency Below Threshold
Mileage: 73888 km
Date: 2020.03.03
Time: 13:50:10
Engine speed: 1818.50 /min
Normed load value: 56.9 %
Vehicle speed: 107 km/h
Coolant temperature: 86 °C
Intake air temperature: 83 °C
Voltage terminal 30: 14.580 V
Exhaust mass flow of low-pressure EGR: calculated: 3.012
Differential pressure ratio: low-pressure EGR: 31.5 kg/h
Exh.recircul. 2: differential pres.sensor 1 bank 1: adap. value: 38.5 hPa
Exhaust recirculat.2: different.press.sens.1 bank 1: raw value: 38.2 hPa
Exh.recircul.valve 1 bank 1: pos.feedback - Act.value: 64.39 %
Exhaust recirc.valve 2 bank 1: posit.feedback - Act.value: 51.17 %
Exh. gas recirc. 2: diff. press. sensor 1 bank 1: dyn. value: 38.5 hPa
Address 03: ABS Brakes (J104) Labels:. 4G0-907-379-V1.clb
Part No SW: 4G0 907 379 L HW: 4G0 907 379 L
Component: ESP PREMIUM H09 0450
Coding: 06A09F016005F9809B00
VCID: 3A2D323E3CD4C507C73-806E
Part No SW: 4H0 907 064 FN HW: 4H0 907 064 EN
Component: BCM2 2.0 H36 0551
Coding: 03B83046000000000000
VCID: 7AADF23E7CD40507873-802E
Serial number: 0214000122868001
Address 08: Auto HVAC (J255) Labels:| 4G0-820-043-2Z.clb
Part No SW: 4G0 820 043 BA HW: 4G0 820 043 BA
Component: KLIMA 2 ZONEN H14 0096
Serial number: 01071400111268
Coding: 3421090821
ASAM Dataset: EV_AirCondiBasisUDS 004002
ROD: EV_AirCondiBasisUDS_004.rod
VCID: 5F9BA3AAC7B6C02F90D-800A
Address 09: Cent. Elect. (J519) Labels:. 4H0-907-063-V1.clb
Part No SW: 4H0 907 063 CE HW: 4H0 907 063 E
Component: BCM1 2.0 H12 0130
Revision: 19012002 Serial number: 00000001555361
Coding: 2600201040349F600481008000001D0C0F9D830827090201000004606100
VCID: 6D87C9623D9AA2BF121-8038
Component: WWS57X 140621 H37 0080
Serial number: 140630055157
Coding: 0045F7
Component: G397_RLFS H06 0002
Serial number: 22844189
Coding: 02006D
Subsystem 3 - Part No SW: 4G0 941 531 BE HW: 4G0 941 531 BE
Component: E1 - LDS H07 0044
Serial number: 23 06 2014 00001518
Subsystem 4 - Part No SW: 4G0 907 658 A HW: 4G0 907 658 A
Component: Humidity_Sens H03 0002
Serial number: 3828C637000000000001
Address 10: Park/Steer Assist (J446) Labels:| 4H0-919-475-7X2.clb
Part No SW: 4H0 919 475 AA HW: 4H0 919 475 AG
Revision: 11001001 Serial number: 61061419000341
Coding: 08C206
VCID: 71BFD5122122465F369-8024
Part No SW: 4H0 959 655 C HW: 4H0 959 655 C
Component: Airbag10.43 H43 0040
Revision: -------- Serial number: 003JG00JL4UQ
Coding: 3032343631324E303235554A305234473053
VCID: 3635260E08CC216723B-8062
Serial number: 3575HRB405F2M4PG0P3O
Serial number: 3585HRB40632M4PG408+
Serial number: 3515JRB405J2SIIA21EK
Serial number: 3525JRB405L2SIIAA83R
Serial number: 3554VRB401A52MDSOH85
Serial number: 3564VRB401A52MDSQ8PG
Part No SW: 4G0 953 568 A HW: 4G0 953 568 A
Component: Lenks.Modul H05 0201
Revision: 00000000 Serial number: 20140707000312
Coding: 000014
VCID: 30391016EA280F57797-8064
Subsystem 1 - Part No SW: 4G0 951 528 C HW: 4G0 951 528 C
Address 17: Instruments (J285) Labels:| 4H0-920-xxx-17.clb-SRI1
Part No SW: 4G8 920 950 S HW: 4G8 920 950 S
Component: MDieGb H43 0411
Revision: 27450259 Serial number: 658020714592022
Coding: 33A40A000B412600010000
ASAM Dataset: EV_RBC7KMID 004048
ROD: EV_RBC7KMID.rod
VCID: 3FDB432A27F6E02FF0D-806A
1048578 - No Basic Setting
B2010 00 [009] - -
[Steuergerät keine oder falsche Grundeinstellung / Adaption]
Reset counter: 40
Mileage: 73880 km
Date: 2020.03.03
Time: 13:37:23
Part No SW: 4G0 907 468 AD HW: 4G0 907 468 AC
Revision: -------- Serial number: 00000001466281
Coding: 00CD074400
VCID: 72BDDA1E24247D47CF3-8026
Serial number: 9617223703
Voltage stabilizer:
Subsystem 2 - Part No SW: 8K0 959 663 F HW: 8K0 959 663
Component: J532_DCDCStab H23 0021
Serial number: 140208000000000006FB
Part No SW: 4G0 907 637 H HW: 4G0 907 637 D
Component: SARA 3D H03 0056
Revision: -------- Serial number: EJ1BPA720AY5GP
ASAM Dataset: EV_SARA2 005012
ROD: EV_SARA2.rod
VCID: 33331F1A1BBE344F045-8066
Component: TSG FA H03 0507
Coding: 011C16004001620002080002
VCID: 47CB5BCA7FA6A8EF48D-8012
Part No SW: 4G0 909 144 M HW: 4G0 909 144 G
Component: RCEPS H41 0011
Revision: 00001000 Serial number: 0025714666
Coding: 101000010000
ASAM Dataset: EV_RCEPS 009010
ROD: EV_RCEPS_009.rod
Revision: 00002001 Serial number: 0339889791
Coding: 011B062280B900408320080400010E470000000000000000000000000000
Component: DWA-Sensor H01 0010
Part No SW: 4G0 035 223 C HW: 4G0 035 223 A
Component: BOSE-G3-C7 H07 0160
Revision: CJ007001 Serial number: 00000000120361
VCID: 1D67D9A28DBA923FC21-8048
Component: TSG BF H03 0507
VCID: 46D556CE78ACB1E7B3B-8012
Part No SW: 4H0 907 801 H HW: 4H0 907 801 A
Component: EPB-4 H04 0015
Revision: -------- Serial number: 00000001123019
ROD: EV_ParkiBrake_VW51.rod
VCID: 2D070962FD9A62BF521-8078
Address 55: Headlight Range (J431) Labels:| 8X0-907-357.clb
Part No SW: 4H0 907 357 B HW: 4H0 907 357 B
Serial number: 140707-0002-088
Coding: 112196101000A300
ROD: EV_HeadlRegulBasic.rod
Part No SW: 4G0 035 192 H HW: 4G0 035 192 F
Component: RMC Nav Plus H55 0801
Coding: 0101000101415B47082B060301020100000000
VCID: 270BFB4ADFE648EFA8D-8072
Subsystem 1 - Part No: 8X0 919 884 G
Component: P24-50-13.06 0001
Subsystem 2 - Part No SW: 4G0 919 603 B HW: 4G0 919 603 B
Component: DU6 Basic H43 0084
Serial number: 9464F30E2668186
Subsystem 3 - Part No SW: 4G2 919 710 B HW: 4G2 919 710 B
Component: E380 BDT C7 H11 0204
Serial number: 90349NG9000AH
Address 62: Door, Rear Left (J388) Labels:. 4H0-959-795.clb
Component: TSG HL H03 0507
VCID: 49CF5DF269B25E9F5E9-801C
Address 72: Door, Rear Right (J389) Labels:. 4H0-959-795.clb
Component: TSG HR H03 0507
Part No SW: 4G0 907 355 C HW: 4G0 907 355 B
Component: SCR-Stg-G2 H10 0010
Revision: 00000000 Serial number: 141681459
ROD: EV_RDCMA00100_008.rod
VCID: 2B03077AC38E6C8F4C5-807E
End----------(Elapsed Time: 01:40, VBatt start/end: 12.1V/12.0V)-----------
