A7 Spoiler activation speed settings
Au07
C?ID=231702
hi, just wonder if anyone been able to identify where to change speed at which spoiler comes up and down on A7 (or R8/TT(may be similar))
would like it to come up earlier (50mph) and go down later(30mph)...
Au07
C?ID=231702
anyone? no one know what channels this speed settings can be found at ? ?
Is this the Auto-Scan of your car?
Since it doesn't have a dedicated module for the spoiler, I'm not 100% certain what module actually controls the spoiler. The CCM at address 46 has a coding bit for "Rear Spoiler Installed" but I don't see anything else in there that looks promising.
Dana
Western PA, USA
Yeah Uwe, that's the car we received a scan from via e-mail. I don't know if altering the default speed is possible but the fact that with or without is in 46 coding makes me suspect modifications (if supported) would be in an Adp channel.
The OP may want to run Adaptation function control module maps and compare them. If this was my project I'd run 46 Adp maps:
1) Normal, no SA code.
2) Using SA code 22790
3) Using SA code 16017
4) Using SA code 51894 (mostly because the function of that one is unknown in MLB BCM2 modules)
After gathering a collection of maps they can be used to compare which channels are, and are not, accessible with each SA code. With any luck one corresponding to kilometers per hour opens up so it can be experimented with.
Maps are explained here: https://www.ross-tech.com/vcds/tour/controller-channels-map.php
I use a program called CompareIt! but you can use Excel (or similar) to compare data. If you would like someone here to compare the data please upload the maps to an online host (such as Google Drive) with a link to them -and- paste the contents here in the event someone wants to use the text.
Au07
C?ID=231702
Thanks for valued input!
I did checked all channels with initial code before, the only similar figure i found at that point was channel 13 with figure 87, what roughly corresponds to speed when spoiler goes down.
now after you tipped this SC looks like code 16017 unrevealed channel 203 with figure 133, what is similar to speed when spoiler activated..
played with this figures, changed activate to 100 but no luck, what if same thing need to be done in module 17? as if you want to delete spoiler you have to delete them in both modules not to get any faults?
ups... there's no channels in 17....
Au07
C?ID=231702
also when changing channel 203 below 41 "light malfunction" comes on the screen but the only fault i get is:
Thursday,05,December,2019,20:30:01:31877
VCDS Version: Release 19.6.2 (x64) Running on Windows 7 x64
Address 46: Central Conv. Labels: 4H0-907-064-46.clb
Control Module Part Number: 4H0 907 064 HN HW: 4H0 907 064 HN
Component and/or Version: BCM2 2.0 H61 0825
Software Coding: 013F0622A0B9B884C3200A840E010D470000000000000000000000000000
Work Shop Code: WSC 02391 785 00200
VCID: 7CF7D89BFF97E2AFFB-8028
Fault Codes have been Erased
03389 - Data Set Implausible
Reset counter: 55
Mileage: 52805 km
Date: 2019.12.05
Time: 20:29:50
Dana
Western PA, USA
It sounds like you stumbled into the tail light channels. rlarsen has a bunch of excellent charts in our forum but this is a simple view of the tail light channels in question:
https://forums.ross-tech.com/showth...lamp-euro-coding&p=48947&viewfull=1#post48947
I'd change all channels back to their factory values at this point if you haven't already. The AdpLog.CSV file should be helpful if they weren't all reverted as you went.
https://forums.ross-tech.com/showthread.php?1029-CodingLog-and-AdpLog-little-safety-nets-for-you
If you would prefer to disable the spoiler function entirely then I would look to see which fuse powers it and pull it followed by coding 46 to see what happens in the next complete scan. If a single fuse for that component alone doesn't exist (because the fuse powers several things) then it may be necessary to unplug it directly before removing the coding bit in address 46.
MasterTommy
Amsterdam
C?ID=295586
Unplugging the spoiler will at least give a definitive answer as to which module controls the spoiler by checking which module throws errors... Or is it already known for a fact that its 46?
Au07
C?ID=231702
i have reverted back.
i have previously deleted spoiler in open position from 17 and 46 and it was fine.. but that's not how i want it to be...
;SW:4H0-907-064-HN   HW:4H0-907-064-HN ---  Central Conv. --- SA: 16017
;Component:BCM2 2.0      H61 0825	 Coding:013F0622A0B9B884C3200A840E010D470000000000000000000000000000
;Thursday	5	December	2019	20:06:59:31877
;VCDS Version: Release 19.6.2 (x64)  Data version: 20190930 DS308.0
;VCID: 7CF7D89BFF97E2AFFB-8028
Channel		Field 1	Field 2	Field 3	Field 4
1	57313	N/A	N/A	N/A	N/A
2	57313	N/A	N/A	N/A	N/A
3	36961	N/A	N/A	N/A	N/A
4	36961	N/A	N/A	N/A	N/A
5	0	N/A	N/A	N/A	N/A
6	0	N/A	N/A	N/A	N/A
7	0	N/A	N/A	N/A	N/A
8	0	N/A	N/A	N/A	N/A
9	36961	N/A	N/A	N/A	N/A
10	0	N/A	N/A	N/A	N/A
11		ERROR:	Channel 11	Not	Available
12		ERROR:	Channel 12	Not	Available
13	87	N/A	N/A	N/A	N/A
14	200	N/A	N/A	N/A	N/A
15	200	N/A	N/A	N/A	N/A
16	5	N/A	N/A	N/A	N/A
17		ERROR:	Channel 17	Not	Available
18		ERROR:	Channel 18	Not	Available
19		ERROR:	Channel 19	Not	Available
20		ERROR:	Channel 20	Not	Available
21	21	N/A	N/A	N/A	N/A
22		ERROR:	Channel 22	Not	Available
23		ERROR:	Channel 23	Not	Available
24		ERROR:	Channel 24	Not	Available
25		ERROR:	Channel 25	Not	Available
26		ERROR:	Channel 26	Not	Available
27		ERROR:	Channel 27	Not	Available
28		ERROR:	Channel 28	Not	Available
29		ERROR:	Channel 29	Not	Available
30		ERROR:	Security	access	required
31		ERROR:	Channel 31	Not	Available
32		ERROR:	Channel 32	Not	Available
33		ERROR:	Channel 33	Not	Available
34		ERROR:	Channel 34	Not	Available
35		ERROR:	Channel 35	Not	Available
36		ERROR:	Channel 36	Not	Available
37		ERROR:	Channel 37	Not	Available
38		ERROR:	Channel 38	Not	Available
39		ERROR:	Channel 39	Not	Available
40		ERROR:	Channel 40	Not	Available
41		ERROR:	Channel 41	Not	Available
42		ERROR:	Channel 42	Not	Available
43		ERROR:	Channel 43	Not	Available
44		ERROR:	Channel 44	Not	Available
45		ERROR:	Channel 45	Not	Available
46		ERROR:	Channel 46	Not	Available
47		ERROR:	Channel 47	Not	Available
48		ERROR:	Channel 48	Not	Available
49		ERROR:	Channel 49	Not	Available
50		ERROR:	Channel 50	Not	Available
51		ERROR:	Channel 51	Not	Available
52		ERROR:	Channel 52	Not	Available
53		ERROR:	Channel 53	Not	Available
54		ERROR:	Channel 54	Not	Available
55		ERROR:	Channel 55	Not	Available
56		ERROR:	Channel 56	Not	Available
57		ERROR:	Channel 57	Not	Available
58		ERROR:	Channel 58	Not	Available
59		ERROR:	Channel 59	Not	Available
60	15	N/A	N/A	N/A	N/A
61	12287	N/A	N/A	N/A	N/A
62	65535	N/A	N/A	N/A	N/A
63	168	N/A	N/A	N/A	N/A
64	40	N/A	N/A	N/A	N/A
65	63	N/A	N/A	N/A	N/A
66		ERROR:	Channel 66	Not	Available
67		ERROR:	Channel 67	Not	Available
68		ERROR:	Security	access	required
69	0	N/A	N/A	N/A	N/A
70	0	N/A	N/A	N/A	N/A
71		ERROR:	Channel 71	Not	Available
72	25600	N/A	N/A	N/A	N/A
73	25700	N/A	N/A	N/A	N/A
74	25700	N/A	N/A	N/A	N/A
75	12830	N/A	N/A	N/A	N/A
76	0	N/A	N/A	N/A	N/A
77	50	N/A	N/A	N/A	N/A
78		ERROR:	Channel 78	Not	Available
79		ERROR:	Channel 79	Not	Available
80		ERROR:	Channel 80	Not	Available
81		ERROR:	Channel 81	Not	Available
82		ERROR:	Channel 82	Not	Available
83		ERROR:	Channel 83	Not	Available
84		ERROR:	Channel 84	Not	Available
85	3860	N/A	N/A	N/A	N/A
86	20610	N/A	N/A	N/A	N/A
87	5180	N/A	N/A	N/A	N/A
88	350	N/A	N/A	N/A	N/A
89	780	N/A	N/A	N/A	N/A
90	300	N/A	N/A	N/A	N/A
91	25760	N/A	N/A	N/A	N/A
92	1380	N/A	N/A	N/A	N/A
93		ERROR:	Channel 93	Not	Available
94	0	N/A	N/A	N/A	N/A
95	3	N/A	N/A	N/A	N/A
96	30	N/A	N/A	N/A	N/A
97	50	N/A	N/A	N/A	N/A
98	1	N/A	N/A	N/A	N/A
99		ERROR:	Channel 99	Not	Available
100		ERROR:	Channel 100	Not	Available
101		ERROR:	Channel 101	Not	Available
102		ERROR:	Security	access	required
103	0	N/A	N/A	N/A	N/A
104	190	N/A	N/A	N/A	N/A
105	23	N/A	N/A	N/A	N/A
106		ERROR:	Channel 106	Not	Available
107		ERROR:	Channel 107	Not	Available
108		ERROR:	Channel 108	Not	Available
109		ERROR:	Channel 109	Not	Available
110		ERROR:	Channel 110	Not	Available
111		ERROR:	Channel 111	Not	Available
112		ERROR:	Channel 112	Not	Available
113		ERROR:	Channel 113	Not	Available
114		ERROR:	Channel 114	Not	Available
115		ERROR:	Channel 115	Not	Available
116		ERROR:	Channel 116	Not	Available
117		ERROR:	Channel 117	Not	Available
118		ERROR:	Channel 118	Not	Available
119		ERROR:	Channel 119	Not	Available
120		ERROR:	Channel 120	Not	Available
121		ERROR:	Channel 121	Not	Available
122		ERROR:	Channel 122	Not	Available
123		ERROR:	Channel 123	Not	Available
124		ERROR:	Channel 124	Not	Available
125		ERROR:	Channel 125	Not	Available
126		ERROR:	Channel 126	Not	Available
127		ERROR:	Channel 127	Not	Available
128		ERROR:	Channel 128	Not	Available
129		ERROR:	Channel 129	Not	Available
130		ERROR:	Channel 130	Not	Available
131		ERROR:	Channel 131	Not	Available
132		ERROR:	Channel 132	Not	Available
133		ERROR:	Channel 133	Not	Available
134		ERROR:	Channel 134	Not	Available
135		ERROR:	Channel 135	Not	Available
136		ERROR:	Channel 136	Not	Available
137		ERROR:	Channel 137	Not	Available
138		ERROR:	Channel 138	Not	Available
139		ERROR:	Channel 139	Not	Available
140		ERROR:	Channel 140	Not	Available
141		ERROR:	Channel 141	Not	Available
142		ERROR:	Channel 142	Not	Available
143		ERROR:	Channel 143	Not	Available
144		ERROR:	Channel 144	Not	Available
145		ERROR:	Channel 145	Not	Available
146		ERROR:	Channel 146	Not	Available
147		ERROR:	Channel 147	Not	Available
148		ERROR:	Channel 148	Not	Available
149		ERROR:	Channel 149	Not	Available
150	0	N/A	N/A	N/A	N/A
151		ERROR:	Channel 151	Not	Available
152		ERROR:	Channel 152	Not	Available
153		ERROR:	Channel 153	Not	Available
154		ERROR:	Channel 154	Not	Available
155		ERROR:	Channel 155	Not	Available
156		ERROR:	Channel 156	Not	Available
157		ERROR:	Channel 157	Not	Available
158		ERROR:	Channel 158	Not	Available
159		ERROR:	Channel 159	Not	Available
160		ERROR:	Channel 160	Not	Available
161		ERROR:	Channel 161	Not	Available
162		ERROR:	Channel 162	Not	Available
163		ERROR:	Channel 163	Not	Available
164		ERROR:	Channel 164	Not	Available
165		ERROR:	Channel 165	Not	Available
166		ERROR:	Channel 166	Not	Available
167		ERROR:	Channel 167	Not	Available
168		ERROR:	Channel 168	Not	Available
169		ERROR:	Channel 169	Not	Available
170		ERROR:	Channel 170	Not	Available
171		ERROR:	Channel 171	Not	Available
172		ERROR:	Channel 172	Not	Available
173		ERROR:	Channel 173	Not	Available
174		ERROR:	Channel 174	Not	Available
175		ERROR:	Channel 175	Not	Available
176		ERROR:	Channel 176	Not	Available
177		ERROR:	Channel 177	Not	Available
178		ERROR:	Channel 178	Not	Available
179		ERROR:	Channel 179	Not	Available
180		ERROR:	Channel 180	Not	Available
181	65535	N/A	N/A	N/A	N/A
182	7	N/A	N/A	N/A	N/A
183	65535	N/A	N/A	N/A	N/A
184	3	N/A	N/A	N/A	N/A
185	65535	N/A	N/A	N/A	N/A
186	7	N/A	N/A	N/A	N/A
187	0	N/A	N/A	N/A	N/A
188	0	N/A	N/A	N/A	N/A
189	0	N/A	N/A	N/A	N/A
190	4	N/A	N/A	N/A	N/A
191	65535	N/A	N/A	N/A	N/A
192	255	N/A	N/A	N/A	N/A
193	6	N/A	N/A	N/A	N/A
194	7	N/A	N/A	N/A	N/A
195	20488	N/A	N/A	N/A	N/A
196	20520	N/A	N/A	N/A	N/A
197	20488	N/A	N/A	N/A	N/A
198	20520	N/A	N/A	N/A	N/A
199	20488	N/A	N/A	N/A	N/A
200	20520	N/A	N/A	N/A	N/A
201	20488	N/A	N/A	N/A	N/A
202	20520	N/A	N/A	N/A	N/A
203	133	N/A	N/A	N/A	N/A
204	0	N/A	N/A	N/A	N/A
205	0	N/A	N/A	N/A	N/A
206	0	N/A	N/A	N/A	N/A
207	0	N/A	N/A	N/A	N/A
208	0	N/A	N/A	N/A	N/A
209	0	N/A	N/A	N/A	N/A
210	0	N/A	N/A	N/A	N/A
211	51214	N/A	N/A	N/A	N/A
212	15	N/A	N/A	N/A	N/A
213	12336	N/A	N/A	N/A	N/A
214	1	N/A	N/A	N/A	N/A
215		ERROR:	Channel 215	Not	Available
216		ERROR:	Channel 216	Not	Available
217		ERROR:	Channel 217	Not	Available
218		ERROR:	Channel 218	Not	Available
219		ERROR:	Channel 219	Not	Available
220		ERROR:	Channel 220	Not	Available
221	51400	N/A	N/A	N/A	N/A
222	51400	N/A	N/A	N/A	N/A
223	51400	N/A	N/A	N/A	N/A
224	51400	N/A	N/A	N/A	N/A
225	51400	N/A	N/A	N/A	N/A
226	51400	N/A	N/A	N/A	N/A
227	51400	N/A	N/A	N/A	N/A
228	51400	N/A	N/A	N/A	N/A
229	51400	N/A	N/A	N/A	N/A
230	2771	N/A	N/A	N/A	N/A
231	2772	N/A	N/A	N/A	N/A
232	2901	N/A	N/A	N/A	N/A
233	2902	N/A	N/A	N/A	N/A
234	3532	N/A	N/A	N/A	N/A
235	3533	N/A	N/A	N/A	N/A
236	3554	N/A	N/A	N/A	N/A
237	3555	N/A	N/A	N/A	N/A
238	0	N/A	N/A	N/A	N/A
239	0	N/A	N/A	N/A	N/A
240	0	N/A	N/A	N/A	N/A
241	0	N/A	N/A	N/A	N/A
242	0	N/A	N/A	N/A	N/A
243	0	N/A	N/A	N/A	N/A
244	0	N/A	N/A	N/A	N/A
245	0	N/A	N/A	N/A	N/A
246	1504	N/A	N/A	N/A	N/A
247	1503	N/A	N/A	N/A	N/A
248		ERROR:	Channel 248	Not	Available
249		ERROR:	Channel 249	Not	Available
250		ERROR:	Channel 250	Not	Available
251		ERROR:	Channel 251	Not	Available
252		ERROR:	Channel 252	Not	Available
253		ERROR:	Channel 253	Not	Available
254		ERROR:	Channel 254	Not	Available
255		ERROR:	Channel 255	Not	Available
Au07
C?ID=231702
if you delete it from only one module, other one gives fault, so i think it is on both of them, 17 and 46.
in fact, there is button on the dash to manually operate it, so one of the modules may only control that...
