2010 A3 auto open/close and rain closing not working properly
AngryGiraffe
C?ID=304578
I am fairly new at using VagCom so it is very possible that I have something coded wrong, but I have enabled the auto open/close features with the fob/remote. All of the windows work, but the sunroof will not open or close. Also the rain sensor will not auto close any of the windows or roof. Sensor is turned on at the stalk and the sensitivity is set to high. Here are a few screen shots of how I currently have things set up.
I can also provide an auto-scan if that helps. Any help fixing this would be greatly appreciated.
AngryGiraffe
C?ID=304578
Ok. Here is the auto scan.
Sunday,16,April,2017,16:55:04:00109
VIN: WAUMFAFM4AA174615   License Plate:
VCDS Release 17.1.3:  SRI Reset
Control Module Part Number: 8P0 920 982 N       Labels:  8P0-920-xxx-17-MY8.clb
Component:KOMBIINSTR. VDO H03 0990, Coding:0017288
Channel  	Description                                       	Unit      	Current val.  	New val.
02       	Service Reminder Status                           	          	1             	---
40       	Distance since Service                            	km x100   	38            	---
41       	Time since Service                                	Days      	150           	---
42       	Minimum Distance to Service                       	km x100   	150           	---
43       	Maximum Distance to Service                       	km x100   	150           	---
44       	Maximum Time to Service                           	Days      	365           	---
45       	Oil Quality                                       	          	1             	---
47       	Soot Quantity                                     	km x100   	0             	---
48       	Thermal Load                                      	km x100   	110           	---
49       	Minimum Time to Service                           	Days      	365           	---
50       	Basic Distance Value for Oil Change               	km x100   	160           	---
51       	Basic Time Value for Oil Change                   	Days      	365           	---
52       	Basic Distance Value for Inspection               	km x100   	160           	---
53       	Distance since Inspection                         	km x100   	38            	---
54       	Basic Time Value for Inspection                   	Days      	365           	---
55       	Time since Inspection                             	Days      	150           	---
56       	Day Counter                                       	Days      	2525          	---
Address 09-02,8K0 910 557 ,recoded (Long Coding),from,064C2D,to,024C2D,(06314/123/12345),
Chassis Type: FM (1K0)
Scan: 01 02 03 08 09 0F 15 16 17 19 22 25 42 44 46 52 55 56 62 65
          72 77
VIN: WAUMFAFM4AA174615   Mileage: 99110km-61584miles
65-Tire Pressure -- Status: Not registered 0011
Address 01: Engine (CCT)       Labels: 06J-906-026-CCT.clb
   Part No SW: 8P0 907 115 AM    HW: 8P0 907 115 Q
   Revision: AAH17---    Serial number: AUX7Z0J4FN50U1
   Coding: 0103010A1C0F0160
   Shop #: WSC 06314 000 00000
   VCID: 7DA4F06491F1683F46F-8028
Readiness: 0010 0001
   Part No SW: 02E 300 012 K    HW: 02E 927 770 AM
   Component: GSG DSG AG6     511 2111
   Revision:    51112    Serial number: 00001008261452
   Shop #: WSC 04940 001 00001
   VCID: 186AC1F09E93AD17F59-804C
   Part No SW: 1K0 907 379 AJ    HW: 1K0 907 379 AJ
   Revision: 00H30001
   Coding: 1150600F492900FE881106E5921E0041390000
   VCID: 7AAEFB788CDF5F0763D-802E
   Part No SW: 8P0 820 043 BN    HW: 8P0 820 043 BN
   Component: KlimavollautomatH09 0150
   Revision: 000028      Serial number: 8P0820043BN
   VCID: 79ACE47485D9541F6A7-802C
Address 09: Cent. Elect. (J519)       Labels: 8P0-907-063.clb
   Part No SW: 8P0 907 063 D    HW: 8P0 907 063 D
   Component: BCM PQ35  M   105 0575
   Revision: 00105 AK
   Coding: 6E00083F703336E4A87241E1211089CC477E2BAA117DD929E40808840040
   Shop #: WSC 06314 123 12345
   VCID: 35342844E541707FCEF-8060
   Subsystem 1 - Part No SW: 8P1 955 119 F    HW: 8P1 955 119 F  Labels: 1KX-955-119.CLB
   Component: Wischer AU350  H10 0040
   Coding: 00DD13
   Subsystem 2 - Part No SW: 8K0 910 557     HW: 8K0 955 559 A  Labels: 8K0-955-559.CLB
   Component: REGENLICHTSEN  H04 0003
   Coding: 024C2D
13 Faults Found:
00061 - Footwell Lights
                    Fault Status: 00101010
                    Reset counter: 248
                    Mileage: 98753 km
                    Date: 2017.04.08
                    Time: 17:22:46
                        Term 15 Off
                    Voltage: 12.20 V
                        Term 50 Off
02195 - Dimmer Switch Instrument Panel & Switch Lighting (E20)
                    Reset counter: 248
                    Mileage: 98753 km
                    Date: 2017.04.08
                    Time: 17:40:43
                        Term 15 Off
                    Voltage: 12.35 V
                        Term 50 Off
01800 - Light Switch (E1)
                    Reset counter: 248
                    Mileage: 98753 km
                        Term 15 Off
                    Voltage: 12.35 V
                        Term 50 Off
00834 - Signal for Activation of Heated Rear Window
                    Fault Status: 00101001
                    Fault Frequency: 15
                    Reset counter: 248
                    Mileage: 98753 km
                        Term 15 Off
                    Voltage: 12.40 V
                        Term 50 Off
01259 - Fuel Pump Relay (J17)
                    Fault Frequency: 14
                    Reset counter: 248
                    Mileage: 98753 km
                        Term 15 Off
                    Voltage: 12.40 V
                        Term 50 Off
03266 - Control Circuit for Signal Horn
                    Fault Frequency: 13
                    Reset counter: 248
                    Mileage: 98753 km
                        Term 15 Off
                    Voltage: 12.40 V
                        Term 50 Off
03396 - Supply voltage terminal 30 for central locking
                    Fault Status: 00101011
                    Fault Frequency: 11
                    Reset counter: 248
                    Mileage: 98753 km
                        Term 15 Off
                    Voltage: 12.40 V
                        Term 50 Off
00927 - Terminal 30 (Right)
                    Reset counter: 248
                    Mileage: 98753 km
                        Term 15 Off
                    Voltage: 12.40 V
                        Term 50 Off
00153 - Windshield Wiper Motor;  Driver Side (V216)
                    Reset counter: 248
                    Mileage: 98753 km
                        Term 15 Off
                    Voltage: 12.40 V
                        Term 50 Off
                    Reset counter: 248
                    Mileage: 98753 km
                        Term 15 Off
                    Voltage: 12.40 V
                        Term 50 Off
00059 - Terminal 30 for Interior Lighting
                    Fault Frequency: 9
                    Reset counter: 248
                    Mileage: 98753 km
                        Term 15 Off
                    Voltage: 12.40 V
                        Term 50 Off
00185 - Control Circuit; Relay for Supply Voltage Terminal 15
                    Fault Status: 00101100
                    Reset counter: 248
                    Mileage: 98753 km
                    Voltage: 12.05 V
                        Term 50 Off
01134 - Alarm Horn (H12)
                    Reset counter: 248
                    Mileage: 98753 km
                    Date: 2017.04.08
                    Time: 21:07:28
                    Voltage: 12.00 V
                        Term 50 Off
Address 0F: Digital Radio
Address 15: Airbags (J234)       Labels: 8P0-959-655-10.clb
   Part No SW: 8P0 959 655 Q    HW: 8P0 959 655 Q
   Component: Airbag AU1042 H07 0200
   Revision: --------    Serial number: 003FC0016DU.
   Coding: 303142393041303030374A55304C38503053
   ROD: EV_Airba10AURB4.rod
   VCID: 50FA79D07A633557FD9-8004
   Subsystem 1 - Part No SW: 8P0 910 339 C    HW: 8P0 959 339 C
   Component: BF-Gewichtss.  H02 0030
   Serial number: 5810000R0000004E0W
   Serial number: 3572DRB40000B3E4D1E3
   Serial number: 3582DRB40000B3A12A5T
   Serial number: 35128RB400005822BFCU
   Serial number: 35228RB400005822BC5L
   Serial number: 35547RB4000058B96FB2
   Serial number: 35647RB4000058B969F1
   Part No SW: 8P0 953 549 K    HW: 8P0 953 549 K
   Coding: 0014142
   VCID: 46D65F8884A7EBE7575-8012
   Component: E0221           H02 0100
Address 17: Instruments        Labels: 8P0-920-xxx-17-MY8.clb
   Part No SW: 8P0 920 982 N    HW: 8P0 920 982 N
   Component: KOMBIINSTR. VDO H03 0990
   Revision: D0H03005    Serial number: 2244J005002555
   Coding: 0017288
   Shop #: WSC 24103 067 57207
   VCID: 44D24580B29BD9F7491-8010
Address 19: CAN Gateway        Labels: 1K0-907-530-V4.clb
   Part No SW: 1K0 907 530 AD    HW: 1K0 907 951
   Component: J533  Gateway   H16 0233
   Revision:   H16       Serial number: 4520K105060023
   Coding: ED837F06000702002102
   VCID: 698CB434F579E49F9A7-803C
                    Reset counter: 208
                    Mileage: 98366 km
   Part No SW: 0BR 907 554 B    HW: 0BR 907 554 B
   Component: Haldex 4Motion      3017
   Coding: 0000005
   Revision: D0H03005    Serial number: AUX7Z0J4FN50U1
Address 42: Door Elect, Driver        Labels: 8P0-959-801-MIN3.lbl
   Part No SW: 8P0 959 801 N    HW: 8P0 959 801 N
   Component: Tuer-SG         H04 0100
   Coding: 0001213
   Part No: 1K0 909 144 J
   Component: EPS_ZFLS Kl. 233    3001
   Revision: 00H17000
   VCID: 313C1C541D295C5F927-8064
Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MIN3.clb
   Part No SW: 8P0 959 802 N    HW: 8P0 959 802 N
   Coding: 0001213
   VCID: 47C8528C83ADF2EFAC3-8012
   Part No: 8P3 907 357
   Coding: 0000013
   VCID: 7AAEFB7880DF5F0763D-802E
   Part No SW: 8P0 035 186 T    HW: 8P0 035 186 T
   Component: R Concert2+     H03 0280
   Revision: 00H03000    Serial number: AUZ1Z3K6175936
   Coding: 0750102
   VCID: 43D0469CB795DECF70B-8016
Address 62: Door, Rear Left        Labels: 8P4-959-801.lbl
   Part No SW: 8P4 959 801 F    HW: 8P4 959 801 F
   Component: Tuer-SG         H04 0050
   Coding: 0001176
   Shop #: WSC 06314 000 1012544
   VCID: 42DE4398A88FD7C77BD-8016
Address 65: Tire Pressure        Labels: 8J0-907-273.lbl
   Part No SW: 8J0 907 273 A    HW: 8J0 907 273 A
   Component: J502-RDK        H03 0370
   Revision: --H03-H0    Serial number: 13373700532320
   Coding: 0860021
   Shop #: WSC 06435 000 00000
   VCID: 2F381A2C0B1D4AAF843-807A
03224 - Play Protection Active
            000 -  -  - Intermittent
                    Reset counter: 233
                    Mileage: 98437 km
                    Date: 2017.04.02
                    Time: 11:05:41
                    Bin. Bits: 00011000 11000101
                    Voltage: 13.80 V
                    Text:  13,0°C;n.erkannt;     n.erkannt
02214 - Tire Pressure Warning
                    Fault Frequency: 7
                    Reset counter: 236
                    Mileage: 98435 km
                    Date: 2017.04.02
                    Time: 11:05:12
                    Bin. Bits: 00001000 11000101
                    Voltage: 14.00 V
                    Text:  13,0°C; -1,85bar;3452935102;C0h; 30°C
Address 72: Door, Rear Right        Labels: 8P4-959-802.lbl
   Part No SW: 8P4 959 802 F    HW: 8P4 959 802 F
   Coding: 0001176
   Part No SW: 8P0 862 335 AB    HW: 8P0 862 335 T
   Component: FSE_256x BT     H38 0600
   Revision: 00000000    Serial number: 00000005033792
   Coding: 0001277
   VCID: 76B6EF48B4C73B67075-8022
End----------(Elapsed Time: 01:23, VBatt start/end: 11.9V/11.9V)-----------
