Change behavior of ASC/ESP button?
MasterTommy
Amsterdam
C?ID=295586
I'm usually in the habit of asking stuff that results in a 'not possible' answer, but here it goes;
On certain golf 7's (pre-facelift), it seems to be possible to change the ASR/ESP button behavior through changing a bit in the ABS module. Stock seems to be ASR off (short press) and ESP sport (long press). It can be recoded to ASR off/ESP off (which seems to be stock on a Golf R?), ESP sport/ESP off and probably a dozen other styles.
Anyway, this involves changing Byte 29 in de ABS controller (last byte). I was having a look at my ABS controller as I'm getting pretty fed up with the overactive ESP (as inn: I'd like to turn it off and have some fun every now and then. I've got the power to match anyway). Unfortunately, the ABS controller in my car seems to have 46 bytes, and byte 29 has hex value 'AA' (where golf 7’s have 09). Not something I'm going to touch.
Does anyone have an idea if this is possible, more in-depth knowledge of the coding of these modules and/or a Golf 7 R facelift autoscan? :)
ABS module:
Address 03: ABS Brakes (J104) Labels:. 5Q0-907-379-IPB-V1.clb
Part No SW: 5Q0 614 517 CF HW: 5Q0 614 517 AD
Component: ESC H25 0513
Revision: 00000000 Serial number: 62057000001070
Coding: 0AEE6B9A54220B744779070762C66950D62AD0E2E046967DB8625088C2AA4200002F641A1B13111435351919323200
ROD: EV_Brake1UDSContiMK100IPB_036.rod
VCID: 77BE26B1CE6DD1FD84-8022
Autoscan:
Sunday,04,February,2018,03:55:42:41109
VCDS Version: 18.1.0.2 (x64)  HEX-NET CB: 0.4411.4
VIN: WVGZZZ5NZJW123456   License Plate:
Mileage: 17976km-11169mi   Repair Order:
Chassis Type: 5N-VW37 (3Q0)
Scan: 01 02 03 05 06 08 09 10 13 14 15 16 17 19 22 29 2B 36 39 3C
          42 44 47 4B 52 5F 65 69 6C 6D 75 82 A5 BB BC CA CF D6 D7
VIN: WVGZZZ5NZJW123456   Mileage: 17976km-11169miles
CA-Sunroof -- Status: OK 0000
Address 01: Engine (J623-CUAA)       Labels:. 03N-906-026-CUA.clb
   Part No SW: 03N 906 026 D    HW: 03N 907 309
   Component: R4 2.0l BTD   X24 3680
   Revision: A1X24---
   Coding: 01250032047605083000
   Shop #: WSC 92521 052 00000
   ASAM Dataset: EV_ECM20BTD01103N906026D 004005
   ROD: EV_ECM20BTD011.rod
   VCID: 2C14C9DD47ABA22539-8078
Readiness: 1110 1011
   Part No SW: 0DL 300 011 M    HW: 0GC 927 711 G
   Component: GSG DQ500     H06 2001
   Revision: 00H06V07
   VCID: 3228D7A5658FF4D573-8066
   Component: VWKESSYMQB    037 0906
   Revision: 00037000    Serial number: 0451329535
   Coding: 132C2C0723
   ROD: EV_KessyHellaMQBAB.rod
   VCID: 3E30F395A1D720B587-806A
   Subsystem 1 - Part No SW: 3G0 962 243 A    HW: 3G0 962 243 A
   Component: GEB.F.Heckoef  H17 0903
   Serial number: 98226912
   Component: Sitzmemory    H08 0022
   Serial number: Y0006QGM20164
   Coding: 001000020000050081C281808181000000008181000000F400
   ASAM Dataset: EV_SeatMemorPasseSide 002022
   ROD: EV_SeatMemorPasseSide_VW37.rod
   VCID: 3C34F99DB7CB32A5A9-8068
   Part No SW: 5NA 907 044 N    HW: 5NA 907 044 N
   Component: AC Automat    H35 4301
   Revision: 20K08000    Serial number: 00000B00605887
   Coding: 0002012420241001110510420010112A
   ASAM Dataset: EV_ACClimaPrehVW37X 002023
   ROD: EV_ACClimaPrehVW37X_002_VW37.rod
   VCID: 4AD8AF45ED1F9C152B-801E
   Subsystem 2 - Part No SW: 3G0 907 049 E    HW: 3G0 907 049 E
   Component: E265KlimaHeck  H02 0201
   Serial number:       04031501850571
          P1719 00 [008] - -
          [PTC-Reduzierung durch MSG]
                    Reset counter: 200
                    Mileage: 17976 km
                    Date: 2018.02.04
                    Time: 03:53:28
                    Voltage terminal 30: 14.2 V
                    Auxiliary heater: in stages-Act.val.: 2
   Part No SW: 5Q0 937 084 CQ    HW: 5Q0 937 084 CG
   Component: BCM MQBAB H   H36 0253
   Serial number: 01001721700533
   ROD: EV_BCMBOSCH_018.rod
   VCID: 095A5049A899D70DE2-805C
   Subsystem 1 - Part No SW: 5NB 955 119     HW: 5NB 955 119   Labels: 1KX-955-119.CLB
   Component: 326 LL 170630  033 0372
   Serial number: 00000001706280300593
   Component: RLHS  042 0105
   Serial number: S8Y17M08D14H01M31S46
   Coding: 00A8EE
   Serial number: 000000000ZY1718333XN
   Subsystem 4 - Part No SW: 5QD 951 605     HW: 5QD 951 605
   Serial number: 00002856223971734394
   Part No SW: 3Q0 919 298 B    HW: 3Q0 919 298
   Component: PLA 3.0 12K   H09 0029
   Serial number: 001607177478001
   Coding: 0A31667A51
   ASAM Dataset: EV_EPHBO2CVW3260000 010016
   ROD: EV_EPHBO2CVW3260000.rod
   Part No SW: 2Q0 907 572 M    HW: 2Q0 907 572 B
   Component: ACCCONTIMQB   H02 0233
   Coding: 320167CB5CFF8728749C8145804087
   Serial number: 12071741350391
   ROD: EV_DRCONTITEMIC_VW27.rod
   VCID: 383CE58D83F31E854D-806C
   Part No SW: 5Q0 959 655 BK    HW: 5Q0 959 655 BK
   Serial number: 003VXR33ZYC9
   Coding: 98FCC0C00C8000005C5400CF004800000065
   VCID: 0A586F45AD9FDC15EB-805E
   Belt Pretensioner left:
   Component: BeltPretRevFL  106 1032
   Serial number: 5NB857705C0216R00777
   Coding: 80000D
   Belt Pretensioner right:
   Component: BeltPretRevFR  106 1032
   Serial number: 5NB857706C0217R00515
   Coding: 80000D
   Subsystem 3 - Part No SW: -----------    HW: 480 000 808 17
   Serial number: 35700000000B2B19A62O
   Subsystem 4 - Part No SW: -----------    HW: 480 000 808 17
   Serial number: 35800000000156842728
   Subsystem 5 - Part No SW: -----------    HW: 480 400 208 17
   Serial number: 3510001BB260B4F1B4BB
   Subsystem 6 - Part No SW: -----------    HW: 480 402 807 17
   Serial number: 3520001A524CDB11F48B
   Subsystem 7 - Part No SW: -----------    HW: 480 402 907 17
   Serial number: 3550001C322EA2B5730%
   Pedestrian Protection Driver:
   Subsystem 8 - Part No SW: -----------    HW: 480 402 907 17
   Component: PedP_Sensor_D  000 6149
   Serial number: 2280001B526D7C0386BB
   Subsystem 9 - Part No SW: -----------    HW: 480 402 907 17
   Component: PedP_Sensor_P  000 6149
   Serial number: 2290001B526D7C0475EE
   Pedestrian Protection Center:
   Subsystem 10 - Part No SW: -----------    HW: 480 402 907 17
   Component: PedP_Sensor_C  000 6149
   Serial number: 2300001B526D7C04615Z
   Subsystem 11 - Part No SW: -----------    HW: 480 002 707 17
   Serial number: I0M00000000D91C0252+
   Subsystem 12 - Part No SW: -----------    HW: 480 002 707 17
   Serial number: I0N000000002A1C0252W
   Part No SW: 5Q0 953 521 BB    HW: 5Q0 953 569 A
   Revision: FF034034    Serial number: 20170802501343
   Coding: 0C10
   ROD: EV_SMLSVALEOMQB.rod
   VCID: 73A612A1DA15BDDDB8-8026
   Part No SW: 5NA 920 791 B    HW: 5NA 920 791 B
   Component: KOMBI         407 3193
   Coding: 07A400987E8C000801887B0F3401000880000000
   VCID: 42C88765D52F4455E3-8016
   Part No SW: 3Q0 907 530 G    HW: 3Q0 907 530 C
   Component: GW MQB High   518 5304
   Serial number: 23071710800155
   Coding: 0B0500344F017300FB07225E9E0F00010001070000000000000000000000
   ROD: EV_GatewNF_VW27.rod
   VCID: 3326D2A19A95FDDD78-8066
   Serial number: 29170001574160027313
   Coding: 2DFFFF
   Subsystem 3 - Part No SW: 5QA 915 181 E    HW: 5QA 915 181 E
   Serial number: 4480423804
   Power Converter DC AC:
   Subsystem 4 - Part No SW: 5Q0 907 155 F    HW: 5Q0 907 155 F
   Component: U13DCAC  H25 0780
   Serial number: 0024537
   Serial number: HA1-00020.06.17
   Coding: 0101
   Part No SW: 8V0 907 399 B    HW: 8V0 907 399 B
   Component: LCM_MLBevoH08 0014
   VCID: 45C29C79C401736DC6-8010
   Serial number: 17000199457001
   Coding: 0800000000000000
   ROD: EV_ELVMarquMQBB.rod
   VCID: 71AA18A9A0098FCD4A-8024
   Serial number: Y0006QGM20144
   Coding: 001000020000150001C281808181000000008181000000F400
   ROD: EV_SeatMemorDriveSide_002_VW48.rod
Address 3C: Lane Change (J769)       Labels:| 3Q0-907-566.clb
   Part No SW: 3Q0 907 566 E    HW: 3Q0 907 566
   Component: MRR1Rear      H20 0510
   Revision: --------
   Coding: 14C002
   VCID: 3A38FF85BDFF0C95BB-806E
   Serial number: 080717EG809145
   Coding: 003F1B20D200048000001000
   VCID: 43C68261CA354D5DE8-8016
   Part No SW: 5QF 909 144     HW: 5QF 909 144 _
   Component: EPS_MQB_ZFLS  506 5572
   Coding: 9307
   ROD: EV_SteerAssisMQB_013.rod
   VCID: 075E5671BE8DA17DF4-8052
Address 47: Sound System (J525)       Labels:| 3Q0-035-466.clb
   Part No SW: 3Q0 035 465     HW: 3Q0 035 465
   Component: MIB2_amp_P_VW H60 0440
   Revision: 00000001    Serial number: VWZ8Z1HJD00TYB7
   Coding: 1223060001A00A2AAA0000000000
   ASAM Dataset: EV_AMPMst16C3Gen2ALPI 001016
   ROD: EV_AMPMst16C3Gen2ALPI_VW37.rod
   VCID: 6B960AC18225651D70-803E
   Serial number: 21071710803739
   Coding: 000000050100085207104F010A0000000000000000000000000000000000
   VCID: 72A817A5A50FB4D5B3-8026
   Serial number: 070717EG609369
   Coding: 003F1120DE00048000001000
Address 5F: Information Electr. (J794)       Labels:| 5G0-035-MIB-HGH2.clb
   Part No SW: 5NA 035 022 A    HW: 5NA 035 022
   Component: MU-H-LND-EU   H54 1121
   Serial number: A846G0HS006021
   Coding: 02730601000000005111010200880A331F0106E401200400DE
   VCID: 312AD8A96089CFCD0A-8064
   Subsystem 1 - Part No SW: 5G6 919 606     HW: 5G6 919 606
   Component: ABT_High-2  H50 9130
   Serial number: VWZ6ZJT2116065
   Subsystem 2 - Part No SW: V03 959 800 QR    HW: -----------
   Component: ECE 2017/2018  --- 0161
   Component: Gracenote2  --- 1016
   Part No SW: 5Q0 907 273 B    HW: 5Q0 907 273
   Component: RDKBERU30     H04 0009
   Serial number: 30000000098730
   ROD: EV_RDKBERU30_006_VW37.rod
   VCID: 3424D1BD9F9BFAE561-8060
   Part No SW: 5Q0 907 383 N    HW: 5Q0 907 383 N
   Component: Anhaenger     H27 0264
   Revision: 8A001003    Serial number: 0449274529
   Coding: 0100000202000000
   Part No SW: 5Q0 907 556 C    HW: 5Q0 907 556
   Component: Areaview 2    H13 0608
   Serial number: C854707JG016316
   Coding: 01230600A30F200000204814
   ASAM Dataset: EV_CamSysRVAV2ARCE2MQBAB 006017
   VCID: 393AE089B8F9078DB2-806C
   Part No SW: 5Q0 959 107 M    HW: 5Q0 959 107 C
   Component: HDSG-Modul    H12 0261
   Revision: --------    Serial number: 31450492700000
   Coding: 0AA8
   Part No SW: 5NA 035 284 B    HW: 5NA 035 284 B
   Component: OCULowMQBLGE  H17 0717
   Revision: --------
   Coding: 02230601EA42380D3F1CBE020045400382E608
   ASAM Dataset: EV_OCULowMQBLGE 004044
   ROD: EV_OCULowMQBLGE_004_VW27.rod
   Part No SW: 5NA 919 608 B    HW: 5NA 919 608 B
   Component: HeadupDisplay 023 0302
   Coding: 574060
   ASAM Dataset: EV_HeadUpDisplContiVW481 001015
   ROD: EV_HeadUpDisplContiVW481.rod
   VCID: 47DE9671FE0D617D34-8012
   Part No SW: 3Q0 980 654 H    HW: 3Q0 980 654 A
   Component: MQB_B_MFK     H08 0272
   Serial number: 29071712K20584
   Coding: 000307060000040100262347C150A90098000E200040
   ROD: EV_MFKBoschMQBB_VW27.rod
   Serial number: 120717EG908013
   Coding: 002A11200101048000001000
   Serial number: 190617EFJ09168
   Coding: 208040732602
   ROD: EV_SunRoofCONTIAU736.rod
   VCID: 3D32F499ACD13BAD9E-8068
Address CF: Lane Chge Asst 2 (J770)       Labels:. 3Q0-907-566.clb
   Part No SW: 3Q0 907 590 E    HW: 3Q0 907 590
   Revision: --------
   Coding: 14C002
   VCID: 373EE6B18EED11FD44-8062
   VCID: 16600B35E92708F57F-8042
   ROD: EV_LEDModLeftMELCOAU736_VW48.rod
End----------(Elapsed Time: 02:37, VBatt start/end: 14.4V/14.4V)-----------
Moving to Tweaks.
golfi_vend
Tartu, Estonia
C?ID=195131
It would become A8 or A6 to have ESP Off in Your options.
PS! Know Your legal requirements before this MOD.
MasterTommy
Amsterdam
C?ID=295586
Thanks! Mind if I ask how you got detailed coding info? It looks to me like you're manually using Lcode with a different label file?
For the record, current coding value results in ESC On/ASR Off/ESC Sport. Same as 09 in your drop-down menu.
They're pretty easy as an end-user here since you have a light-version of rules to conform to as opposed to typerating the manufacturers go through.
MasterTommy
Amsterdam
C?ID=295586
Changed byte 29 to A8, and that worked! Going to try A6 too tomorrow just for posterity.
MasterTommy
Amsterdam
C?ID=295586
So, 'tomorrow' turned into somewhere yesterday. Did want to give this a follow-up though.
#8 and #6 have the same coding description and give the same button set-up. However, #8 seems to be a solution for that one guy who wants his screen to say 'ESP Off' but we all know you don't want to send that guy out with the ESP actually being off. Ergo, yet again ESP gets a little less strict when you supposedly turned it off, but it's not really.
#6, well let's say I havent seen a Tiguan smoke all 4 wheels in the first three gears until yesterday.
I'm going to do some more driving around to verify the differences, since time-for-some-fun-with-nobody-else-around situations don't present themselves every drive, but there definitely is a difference between these two settings.
TBAx
C?ID=287144
Golf 6 and Golf 7 are nothing alike so please don’t use a modified coding from this site on a Golf 7.
MasterTommy
Amsterdam
C?ID=295586
I get that, which is why first thing I tested if those bits affect the button behaviour in my car. They do, and they do exactly like the bit description in the screenshot. Which for me is enough to (very carefully) push the throttle with one eye closed sitting halfway on the seat and halfway out the car in case it explodes changing this completely untested coding change.
TBAx
C?ID=287144
I don‘t understand your sarcasm, sorry.
localstring
C?ID=349217
since I didn't want to start a new topic for this, I will ask my question here really hoping to get an answer from someone familiar with it.
I own a Seat Leon FR 1.8 5F Facelift and I have the same ABS Module (47 Bytes) as MasterTommy:
Adresse 03: Bremsenelektronik (J104)       Labeldatei: 5Q0-907-379-IPB-V1.clb
   Teilenummer SW: 5Q0 614 517 CF    HW: 5Q0 614 517 AD
   Bauteil: ESC           H25 0513
   Revision: 00000000    Seriennummer: 60657000002378
   Codierung: 20EE6A92342521708780060140CC2804562C84E16002147518425074C223430000000012121212B835351919323200
   Betriebsnr.: WSC 00049 770 00102
   ASAM Datensatz: EV_Brake1UDSContiMK100IPB 036010
   VCID: 77AA1D386F4116CFAFF-8022
Even in combination with the corresponding .clb file my Coding looks like this, so I have no clue if I'm in the right place.
I would like to have "ESC Activated / ASR off / ESC Sport" in my options in ESP Multimedia Menu.
I assume that I have to change the value to "29". But I'm not sure, and I really don't want to break anything.
Since it worked on MasterTommy's Golf 7 R with the exact same ABS module, can I assume it's gonna work on my Leon, too? The only difference is that the Golf has a button for the ESP, while on my car the setting is changed on the Multimedia Menu.
I would really really appreciate if someone could help me on this.
Btw: May I ask, golfi_vend where did you get the Label file from?
golfi_vend
Tartu, Estonia
C?ID=195131
This is my custom label file created with info from internet. Value 29 would be correct.
localstring
C?ID=349217
Thanks for your quick reply! I think I'll try that within the next few days, hoping not to break anything :eek:
PetrolDave
Westbury, UK
C?ID=1423
Take a full Auto-Scan first, VCDS will save it as a baseline if you need it.
VCDS also saves a log of every change you make, so you can see what the old and new values were if needed.
localstring
C?ID=349217
Thank you for your advice. I take a full Auto-Scan every time I change something. So I think it would be possible for me to change things back.
What I'm really worried about is the fact that a change could potentially cause irreperable damage if I'm not 100% sure that I'm in the right place with Byte 29, Bit 0-3.
And even if it is the right Byte (it worked on MasterTommy's car with the same ABS module like mine) I believe there are different circumstances on each car and there may be situations where things don't behave as expected.
For example, isn't it fundamentally different when ESP settings are set via the menu than via a button?
Sorry guys, maybe I'm just way too scared :facepalm:
PetrolDave
Westbury, UK
C?ID=1423
I've changed the setting on my Octavia exactly as you are asking and all is working perfectly. No damage :thumbs:
AFAIK the button is just a shortcut to avoid the hassle of having to use the menus - I don't have a button (but intend to retrofit one) so I have to use the menus.
atom
C?ID=321366
Hi! I have 3.0tdi allroad A6 2010 model. ESP button is single step. I would like to change it to two step.
Current coding is 0033164
edit. 4f facelift also has the inner long light disabled with xenon light unless you hold the long light switch. Is it possbile to code these to work as normal long lights? it is possible with relay.
Monday,11,February,2019,18:15:08:35041
VCDS Version: 18.9.1.0 (x64)  HEX-NET CB: 0.4436.4
VIN: WAUZZZ4F8AN075336   License Plate:
Chassis Type: 4F-AU56 (4F0)
Scan: 01 02 03 05 08 09 15 16 17 18 19 34 3C 42 46 47 4C 4F 52 53
          55 56 5F 62 69 72 76
VIN: WAUZZZ4F8AN075336   Mileage: 230390km-143157miles
Address 01: Engine (CDY)       Labels: Redir Fail!
   Part No SW: 4F9 910 402 A    HW: 4F0 907 401 E
   Component: 3.0TDI EDC17G000AG  0080
   Revision: 16H03---    Serial number:
   Coding: 0125002C191F0128
   Shop #: WSC 83968 425 739974
   VCID: 24040495E7531E6A99-8070
001682 - Fan 1 Control Circuit
               P0692 - 000 - Short to Plus
                    Fault Frequency: 16
                    Mileage: 229893 km
                    Date: 2019.02.09
                    Time: 15:36:49
                    Temperature: 18.9°C
                    Mass Air / Rev.: 1192.6 mg/str
                    Duty Cycle: 95.5 %
                    Temperature: 112.1°C
001650 - Cylinder 2 Glow Plug Circuit (Q11)
               P0672 - 000 - Electrical Fault
                    Mileage: 230197 km
                    Date: 2019.02.11
                    Time: 04:36:24
                    RPM: 819 /min
                    Voltage: 12.16 V
                    Temperature: 22.5°C
                    Lambda: 21.1 %
                    Temperature: 8.1°C
001651 - Cylinder 3 Glow Plug Circuit (Q12)
               P0673 - 000 - Electrical Fault
                    Mileage: 230197 km
                    Date: 2019.02.11
                    Time: 04:36:24
                    RPM: 819 /min
                    Voltage: 12.16 V
                    Temperature: 22.5°C
                    Lambda: 21.1 %
                    Temperature: 8.1°C
   Part No SW: 4F2 910 156 R    HW: 09L 927 156 C
   Component: AG6 09L 3,0 TDI RdW 0040
   Revision: --H05---    Serial number:        4562627
   Shop #: WSC 02325 785 00200
   VCID: 3424F4D557B38EEA09-8060
   Part No SW: 4F0 910 517 AM    HW: 4F0 614 517 BD
   Component: ESP8 quattro    H03 0100
   Coding: 0033164
   VCID: 6FAE3BB97E15ED3234-803A
   Part No SW: 4F0 910 852 B    HW: 4F0 905 852 D
   Component: FBSAUDIC6 ELV   H05 0100
   Revision: 00H05000    Serial number: 10602601551044
   Coding: 0000131
   Shop #: WSC 24569 001 1048576
   VCID: 25021991EC69E7628E-8070
   Subsystem 1 - Part No: 4F0 910 132 E
   Subsystem 2 - Part No: 4F0 910 220 K
   Component: FBSAUDIC6 IDG   H01 0053
   Part No SW: 4F0 910 043 B    HW: 4F1 820 043 AL
   Component: KLIMABETAETIGUNGH30 0080
   Revision: 00000076    Serial number: 00000000695480
   Coding: 0006422
   VCID: 1D723171C4392FA2D6-8048
00003 - Control Module
                    Fault Status: 00100011
                    Mileage: 202987 km
                    Date: 2018.02.13
                    Time: 06:47:45
                    Temperature: 8.0°C
                    Fault Status: 00101010
                    Reset counter: 99
                    Mileage: 229717 km
                    Date: 2019.01.22
                    Time: 11:41:58
                    Temperature: 22.0°C
   Part No SW: 4F0 910 279 N    HW: 4F0 907 279
   Component: ILM Fahrer      H22 0320
   Coding: 0013121
   Shop #: WSC 02335 785 00200
   Subsystem 1 - Part No: 4F1 910 113 D  Labels: 1KX-955-119.CLB
   Component: Wischer AudiC6  H10 0040
   Coding: 00056595
   Shop #: WSC 02335
   Coding: 00146221
   Shop #: WSC 02335
Address 15: Airbags (J234)       Labels:* 4F0-910-655-10.clb
   Part No SW: 4F0 910 655 Q    HW: 4F0 959 655 G
   Component: Airbag AU1042 H07 0200
   Revision: --------    Serial number: 003F9002NJE%
   Coding: 30314236303630303032554A304C34463053
   Shop #: WSC 02323 785 00200
   ROD: EV_Airba10AURB4.rod
   VCID: 3522C9D194C997E23E-8060
   Serial number: 3574SRB40000B04C9A7D
   Serial number: 3584SRB40000B0413A2Z
   Serial number: 3516HRB401RCB77N3SO2
   Serial number: 3526HRB402TD0ORB041E
   Serial number: 3554NRB40000573032CS
   Serial number: 3564NRB400005734A51W
   Component: J0527               0530
   Revision: 00H05000    Serial number: 90026100790036
   Coding: 0002042
   VCID: 271E13999665F572BC-8072
   Component: E0221           H02 0100
Address 17: Instruments (J285)       Labels:. 4F0-920-xxx-17.clb
   Part No SW: 4F0 920 933 Q    HW: 4F0 920 933 Q
   Component: KOMBIINSTR.   H08 0147
   Revision: 00300000    Serial number: DHK00DK3A
   Coding: 03566A0303010008000000
   Shop #: WSC 02391 823 56573
   VCID: 3522C9D19CC997E23E-8060
Address 18: Aux. Heat        Labels: None
   Part No SW: 4F0 910 105 A    HW: 4F0 265 081 AA
   Component: Heizgeraet      H08 0100
   Revision:        B    Serial number: 09018641
   Coding: 0000111
   Shop #: WSC 02145 785 00200
   VCID: 1B763F69DA2D219228-804E
01406 - No Flame
            000 -  -  - Intermittent
                    Reset counter: 99
                    Mileage: 229715 km
                    Date: 2019.01.21
                    Time: 11:57:29
                        Start
                    Temperature: 24.0°C
                    Temperature: -48.0°C
   Part No SW: 4F0 907 468 N    HW: 4F0 907 468 G
   Component: GW-BEM 5CAN-M H06 0035
   Revision: MB200030    Serial number: 3000M10311808C
   Coding: 000303
   VCID: 3A38DAEDB5D7789AD3-806E
   Subsystem 1 - Part No SW: 8K0 915 181 C    HW: 8K0 915 181 C
   Component: J367-BDM  H07 0125
   Serial number: 00000000002790146483
                    Fault Frequency: 22
                    Reset counter: 99
                    Mileage: 228102 km
                    Date: 2018.12.13
                    Time: 08:27:32
                    Bin. Bits:    00000
                    Voltage: 11.60 V
                    Count: 11
Address 34: Level Control        Labels: 4F0-910-553.clb
   Part No SW: 4F0 910 553 D    HW: 4F0 907 553 A
   Component: J197 LUFTFEDER  H17 0030
   Serial number: 00872000835600
   Coding: 0000220
   Part No SW: 4L0 910 566 D    HW: 4L0 907 566 B
   Component: J0769_SWA_MasterH01 0020
   Revision: 00H01000    Serial number: 6PZ 009 014-15
   Coding: 0000104
   VCID: 2F2EFBB9BE95AD3274-807A
   Subsystem 1 - Part No: 4L0 910 568 D
   Component: J0770_SWA_Slave_H01 0020
   Subsystem 2 - Serial number: 6PZ 009 014-35
   Subsystem 3 - Serial number: 5F22.03.1000H010003CN12489ÿ
   Subsystem 4 - Serial number: N12489ÿ
   Part No SW: 4F0 959 793 R    HW: 8K0 959 793 D
   Revision:             Serial number: 0000103332440
   Coding: 011F02205040410003
   VCID: 46C0BE1DF12F0C7AA7-8012
02123 - Door Warning Light / Entry Light
                    Fault Status: 00101100
                    Reset counter: 74
                    Mileage: 228757 km
                    Date: 2018.12.29
                    Time: 14:43:38
   Part No SW: 4F0 910 289 N    HW: 4F0 907 289 N
   Component: Komfortgeraet   H29 0250
   Revision: 02500029    Serial number: 01283640830000
   Coding: 0402053
   VCID: 3522C9D15CC997E23E-8060
Address 47: Sound System (J525)       Labels: Redir Fail!
   Part No SW: 4F0 035 223 P    HW: 4F0 035 223 P
   Component: BOSE G3 C6    H01 0100
   Revision: AG001300    Serial number: 00000000075526
   Coding: 0D010000
   VCID: 291A15A14071C302AA-807C
   Part No SW: 4F0 910 274 B    HW: 4F0 907 274
   Component: J793  RKA+      H02 0110
   Revision: 00000815    Serial number: 00008150116855
   Coding: 0623569
   VCID: 23060789E25D1952E0-8076
   Part No SW: 4F0 910 280     HW: 4F0 907 280 C
   Component: ILM Beifahrer   H13 0100
   Revision:             Serial number: 00000000634875
   Coding: 0001013
   VCID: 5EF0767D89BF74BA8F-800A
   Part No SW: 4F0 959 792 R    HW: 8K0 959 792 D
   Revision:             Serial number: 0000103277188
   VCID: 45C2B911CC290762AE-8010
                    Reset counter: 72
                    Mileage: 206635 km
                    Date: 2018.04.08
                    Time: 21:43:42
   Part No SW: 4F0 910 801 D    HW: 4F0 907 801 B
   Component: EPB  CEFC0090   H05 0090
   Revision: --H05---
   Coding: 0000321
   VCID: 210A0D81F8410B42F2-8074
   Part No: 8P0 907 357 H
   Coding: 0000004
   VCID: 3FCEABF96EF55DB2E4-806A
   Part No SW: 4F0 035 053 B    HW: 4F0 035 053
   Component: Radio U Basic H45 0020
   Revision: AB001007    Serial number: 341CQ0A7721265
   Coding: 010003010000000000
   VCID: 1C743C751F2326AA21-8048
   Part No SW: 4E0 035 652 A    HW: 4E0 035 652
   Component: B-BN-EU       H56 0048
   Revision: --------    Serial number: 349C60A7537959
   Coding: 010100050002F3ED11000305EF6300030001
   VCID: 1F0E0B790E353DB2C4-804A
   Subsystem 1 - Part No: 4G0 919 884 F
   Component: EUR 2010  1005
   Subsystem 2 - Part No SW: 4L0 919 604     HW: 4L0 919 604
   Component: DU6 Basic  H43 0306
   Serial number: 9355CK0A1100935
   Subsystem 3 - Part No SW: 4F0 910 609 E    HW: 4F1 919 611 M
   Component: Bedienteil MM  H01 0060
   Serial number: 00000001546455
00862 - Antenna for GPS Navigation (R50/R52)
                    Fault Frequency: 28
                    Reset counter: 99
                    Mileage: 228203 km
                    Date: 2018.12.13
                    Time: 18:08:45
                    Voltage: 14.40 V
03606 - Antenna for Telphone Base-Plate
            009 - Open or Short to Ground
                    Fault Status: 01101001
                    Reset counter: 72
                    Mileage: 230227 km
                    Date: 2019.02.11
                    Time: 05:15:44
                    Voltage: 14.00 V
   Revision:             Serial number: 0000010273387
   Coding: 010E00204040220003
   VCID: 43C6A709C21D395280-8016
Address 69: Trailer        Labels:. 4F0-907-383.clb
   Part No SW: 4F0 907 383 D    HW: 4F0 907 383 D
   Component: ECS - TOWBAR MODULE 0404
   VCID: 2C14ECB58F83D62A51-8078
   Revision:             Serial number: 0000010275467
   Part No SW: 4L0 910 283 C    HW: 4L0 919 283 C
   Component: Parkhilfe 8-Kan H02 0500
   Revision: 00H02000    Serial number: 12621008800451
   Coding: 0201416
   VCID: 2A18EAAD8577C81AA3-807E
01548 - Sensor for Parking Aid; Rear Right (G206)
                    Fault Status: 00101001
                    Reset counter: 99
                    Mileage: 229247 km
                    Date: 2019.01.11
                    Time: 17:16:04
End----------(Elapsed Time: 02:00, VBatt start/end: 12.2V/12.2V)-----------
localstring
C?ID=349217
Ok, first of all I wanna say thank you so much to you guys helping me out :thumbs:
I just tried it a minute ago and it works like a charm! I'm so happy now :)
I just saw that the Front Assist has also been disabled when setting ASR off. I assumed this was only the case with ESP Sport or ESP Off. But it looks like the ASR is behaving the same way.
However, do you think there is a way to have ASR and Front Assist on at the same time? I can't imagine exactly for what the Front Assist needs the ASR.
PetrolDave
Westbury, UK
C?ID=1423
I noticed the same - on asking other owners the conclusion was that with ASR off the calculations used by Front Assist might be invalid so to avoid possible legal issues VAG disable Front Assist when ASR is off.
Personally I've always found Front Assist far to willing to "cry wolf" so having it disabled doesn't bother me - every time it's alarmed I've said "WTF there's no need for that"!!!
MasterTommy
Amsterdam
C?ID=295586
Thats the pre-warning, you can turn that off in the car settings in the infotainment (stays off after a key-cycle). Front assist will still be on but at least you wont get that annoying warning that feels like you just avoided certain death when you just passed too close to a bush.
Tigaun45
Laval, Canada
C?ID=70829
Hello, I have a 2020 Tiguan and I am trying to add an option to be able to completely disable the traction control (ESC) instead having the option ESC sport which doesn't disable it completely. I read many threads that mention to change the byte 29 from 09 to 06. This works on older versions that have 30 bytes, but my tiguan has 46 bytes on the long coding on the ABS module. My byte 29 is 8A. Does anyone know how to code the long coding in order to disable ESC completely? Here is what I get from module 3. As you can see, there is no 09 in byte 29. I have the latest VCDS plug.
Part No SW: 5Q0 614 517 DK HW: 5Q0 614 517 BN
Component: ESC H35 0113
Revision: 00000000 Serial number: 53349000000325
Coding: 0BFA6BA450201B6DC57B0305A2CA49D0D60AD8A3C045927410415058D28A4A0B00402F641A1B13111435351919323200
ASAM Dataset: EV_Brake1UDSContiMK100IPB 049012
ROD: EV_Brake1UDSContiMK100IPB_049.rod
VCID: 7DA7F22F0D7F6253184-8028
