Fitting Adaptive Cruise Control to a 2008 Touareg V6TDI
hedditch
Australia
C?ID=131483
I an currently in the process of Retrofitting Adaptive Cruise Control
(ACC) into my 2008 V6 3.0 TDI (CASA) Touareg. This is exactly the
same as has been done by two other members on the Club Touareg Forum,
however one had a V10 TDI and the other had a V8 Gas engine. I
currently have all the coding information I require with the exception
of the Engine Codes, which I am a little uncertain about.
On the V10 the code changes have been determined to be as follows...
1. Go into the gateway module #19 I believe.
enable the #13 module for acc
2. Code the ABS unit #03 I believe
go to coding, whatever # is there add +2048 to it. For example mine was
008578 + 2048 = 10626
3. Activate the acc in the ENGINE #01 module
first deactivate the CCS. Go to "coding II" - type 16167 to deactivate.
Then type in 13377 to activate acc . If you somehow need to revert to regular ccs
the activation code is 11463
4. Under the steering wheel # 16 you will need to select the correct
switch coding. Mine is 0010222
My only area of concern is point #3 - Engine #01 -
Can anybody tell me what changes, if any need to be done to the engine coding the support the ACC fitment?
Kind regards
Stuart.
Please post up some real scan data so people can see exactly what ECU you have.
hedditch
Australia
C?ID=131483
Saturday,24,November,2012,10:49:39:04442
VCDS Version: Release 11.11.4 (x64)
Data version: 20120807
Stuart
Chassis Type: 7L - VW Touareg
Scan: 01 02 03 05 06 08 09 11 13 15 16 17 18 19 1C 22 29 32 34 36
          37 39 3C 46 47 55 56 57 64 65 68 69 6C 6D 6E 75 76 77
VIN: WVGZZZ7LZ8D046567   Mileage: 127160km/79013miles
Address 01: Engine (CAS)       Labels: 059-907-401-CAT1.clb
   Part No SW: 7L0 907 401 N    HW: 7L0 907 401 H
   Component: 3.0TDI EDC17G104AG  0060
   Revision: --H02---    Serial number: VWX3Z0G1687973
   Coding: 04210023590F0D68
   Shop #: WSC 12345 123 54321
   VCID: 36693693425627A8CB9
   Part No SW: 09D 927 750 FT    HW: 09D 927 750 FT
   Component: AL 750 6A           1168
   Revision: 00H75000    Serial number:
   Coding: 0012392
   VCID: 850B015FCF30FC30923
Address 03: ABS Brakes        Labels: 7L0-907-379-MK25E1.clb
   Part No SW: 7L0 907 379 L    HW: 7L0 907 379 L
   Component: ESP ALLRAD MK25E1   0303
   Revision: 00H53001
   Coding: 0004482
   Shop #: WSC 31414 790 00001
   VCID: 42815A43199E8B08771
   Part No SW: 3D0 909 139 B    HW: 5WK 485 04
   Component:    Kessy            6840
   Revision: 68406620    Serial number: VWX3Z0G1687973
   Coding: 0000232
   VCID: 2855E8EB9FE24158495
   Part No: XXXXXXXXXXX
Address 08: Auto HVAC        Labels: 7L6-907-044.clb
   Part No: 7L6 907 044 AF
   Component: CLIMAtronic 2+2     4331
   Coding: 0020020
   VCID: 78F5F8AB0FC211D8195
   Part No: 7L6 907 049 F
   Component: CLIMAtronic FOND    0503
Address 09: Cent. Elect.        Labels: 7Lx-937-049-V2.clb
   Part No SW: 7L6 937 049 AF    HW: 7L6 937 049 AF
   Component: J519                2000
   Revision: -0004---    Serial number: --------------
   Coding: 600004003B221C000000000000000000
   VCID: 8005104BD712D918A15
Address 15: Airbags        Labels: 7L0-959-655.lbl
   Part No SW: 7L0 959 655     HW: 7L0 959 655
   Component: J234  39 VW8T       0250
   Revision: 92011025    Serial number: 0039P003JRFF
   Coding: 0013113
   VCID: FAF162A3B1CE83C8EF1
   Part No: 7L6 953 549 F
   Component: J527                3601
   Coding: 0010011
Address 17: Instruments        Labels: 7L6-920-xxx-7L6.lbl
   Part No SW: 7L6 920 890 K    HW: 7L6 920 890 K
   Component: J285 KOMBI-INST.    9733
   Revision: KHH06V02
   Coding: 0005701
   Shop #: WSC 30021 000 1048576
   VCID: 4085504B13929918615
Address 19: CAN Gateway        Labels: 6N0-909-901-7L.clb
   Part No SW: 6N0 909 901     HW: 7L6 920 890 K
   Component: J533  GW-K-CAN TP20 9733
   Coding: 7FE2E7EBC8046003
   VCID: F0E5408BE3B2C998515
   Part No: 0AD 927 755 BG
   Component: TRANSFERCASE        0126
   VCID: 8103154FDB18D010AEB
Address 34: Level Control        Labels: None
   Part No: 7L0 907 553 J
   Component: LUFTFDR.-CDC- 3C3P1 3125
   Coding: 0015521
   VCID: 3A7122A3714EC3C82F1
Address 37: Navigation (J0506)       Labels: 1T0-035-680.clb
   Part No SW: 7L6 035 680 C    HW: 7L6 035 680 A
   Component: RNS-MID       H04 3810
   Revision: AB001001    Serial number: VWZ6Z7G7272099
   Coding: 06010402040000210000
   ASAM Dataset: ------------------------- ------
   VCID: 32610A836D3E3B88E71
   Part No: 7L6 959 933 A
   Component: 1A HSG              0600
   Coding: 0000081
   VCID: 4085504B10929918615
   Part No: 7L0 959 701 R
   Component: Tuersteuergeraet FS 6302
   Part No: 7L0 959 702 R
   Component: Tuersteuergeraet BF 6302
   Part No: 7L6 959 703
   Component: Tuersteuergeraet HL 0202
   Part No: 7L6 959 704
   Component: Tuersteuergeraet HR 0202
   Part No: 7L0 907 719 A
   Component:    Neigungssensor   0020
   Part No: 7L6 951 171 B
   Component:    Innenraumsensor  0020
Address 55: Xenon Range        Labels: 7L6-907-357-A.lbl
   Part No SW: 7L6 907 357 A    HW: 7L6 907 357 A
   Component: AFS-Steuergeraet    0001
   Revision:   H02       Serial number:
   Coding: 1288579
   VCID: 39733DAF7448C8D026B
   Subsystem 1 - Part No: 7L6 941 329 B
   Component: AFS-Lst.-Modul l    X008
   Coding: 00000019
   Subsystem 2 - Part No: 7L6 941 329 B
   Component: AFS-Lst.-Modul r    X008
   Coding: 00000019
Address 56: Radio (J0506)       Labels: 1T0-035-680.clb
Address 68: Wiper Electr.        Labels: 7L0-955-119-V2.clb
   Part No: 7L6 955 119 C
   Component: J400__ Front Wiper  5301
   Coding: 0001397
   VCID: 3A7122A3754EC3C82F1
   Subsystem 2 - Part No: 1K0 955 559 AF  Labels: 1K0-955-559-AF.CLB
   Component: RLS     271107 046  0204
   Coding: 00208933
   Shop #: WSC 31414
Address 69: Trailer        Labels: 7L0-907-383-1D2.lbl
   Part No SW: 7L0 907 383 G    HW: 7L0 907 383 G
   Component: ANHAENGERELEKTRONIK 8854
   VCID: 387538AB4F42D1D8D95
   Part No SW: 7L6 907 441 B    HW: 7L6 907 441 B
   Component: J772__Rearview      0033
   Revision: 00H13000    Serial number:    PA8 J860593
   Coding: 0010001
   VCID: 346D0C9B572A35B8F5D
Address 76: Park Assist        Labels: 3D0-919-283.lbl
   Part No: 7L0 919 283 F
   Component: 0E Einparkhilfe     1107
Address 77: Telephone        Labels: RETROFIT77.lbl
   Part No SW: KTC 364 96P     HW: KTC 364 96P
   Component: SWP:3.24.7      H24 0212
   Shop #: WSC 21977 142 74100
   VCID: 3E792EB36966EFE8139
NEtech
C?ID=56995
For #3 coding should be:
04210023590F0E68
You can see that, if you press [Long Coding Helper].
PS. update your VCDS.
hedditch
Australia
C?ID=131483
ACC Installed and working
Just thought I should close out this thread..
I have now installed ACC in my 2008 Touareg V6TDI and it works perfectly...My Modified Scan Log is attached for information.. (Address 13 Auto Distance Regulation)
 Tuesday,30,June,2015,13:10:23:04442
VCDS Version: 14.10.2.0 (x64)
Data version: 20150311
Dealer/Shop Name: Hedditch
Workshop Code: 123 12345 054321
VIN: WVGZZZ7LZ8D046567   License Plate: XVG493
Mileage: 196240km-121937mi   Repair Order:
Chassis Type: 7L (6N0)
Scan: 01 02 03 05 08 09 13 15 16 17 19 22 28 34 37 46 55 56 68 69
          6C 76 77
VIN: WVGZZZ7LZ8D046567   Mileage: 196240km-121937miles
68-Wiper Electr. -- Status: OK 0000
 Touarge
   Component: 3.0TDI EDC17A104AG  0060
   Coding: 04210023590F0E68
   VCID: 3669369342562791843-508E
   Coding: 0012392
   VCID: 050B815F4F307C095D9-50C8
   Revision: 00H53001
   Coding: 0014722
   VCID: 42815A43199E8B3138B-8017
   Coding: 0000232
   VCID: 2855E8EB9FE2416106F-807D
   Coding: 0020020
   VCID: 78F5F8AB0FC211E156F-802D
   Subsystem 1 - Part No: 7L6 907 049 F
   Coding: 600004002B221C000000000000000000
   VCID: 0005904B571259216EF-8055
Address 13: Auto Dist. Reg        Labels: None
   Part No SW: 7L6 907 567     HW: 7L6 907 567
   Component: AC201  RDW 1    030 0363
   Revision: 00030000    Serial number: 00000000003464
   Coding: 0010000
   Shop #: WSC 98765 666 38533
   VCID: 7BFFE7A73EF43AF93BD-802E
   Coding: 0013113
   VCID: 7AF1E2A331CE03F120B-802F
   Coding: 0010021
   Revision: KHH06V02
   Coding: 0005701
   VCID: 4085504B139299212EF-8015
   Coding: FFE2E7EBC8046003
   VCID: 70E5C08B63B249A19EF-8025
   VCID: 0103954F5B185029611-50E6
Address 28: HVAC, Rear
Address 34: Level Control        Labels: 7Lx-907-553-34.clb
   Coding: 0015521
   VCID: 3A7122A3714EC3F160B-806F
   Component: RNS-MID       H04 5238
   Coding: 0E0004020400002100
   VCID: 32610A836D3E3BB1A8B-8067
   Coding: 0000081
   VCID: 4085504B109299212EF-4A9C
   Subsystem 1 - Part No: 7L0 959 701 R
   Subsystem 2 - Part No: 7L0 959 702 R
   Subsystem 3 - Part No: 7L6 959 703
   Subsystem 4 - Part No: 7L6 959 704
   Subsystem 5 - Part No: 7L0 907 719 A
   Subsystem 6 - Part No: 7L6 951 171 B
Address 55: Headlight Range        Labels: 7L6-907-357-A.lbl
   Coding: 1288579
   VCID: 39733DAF7448C8E9691-806C
   Coding: 00000019
   Coding: 00000019
   Coding: 0001397
   VCID: 3A7122A3754EC3F160B-806F
   Coding: 00208933
   Shop #: WSC 31414
   Coding: 0000003
   VCID: 387538AB4F42D1E196F-806D
   Revision: 00H13000    Serial number:    PA8 J790212
   Coding: 0010001
   VCID: 346D0C9B572A3581BA7-8061
   VCID: 3E792EB36966EFD15C3-806B
End-------------------------(Elapsed Time: 03:36)--------------------------
Kind regards and many thanks....
Stuart........
Spacewalker
Poland
C?ID=159607
Well done !!!!
I also retrofited ACC in Touareg V10 BLE engine , but 7LA model.
Possible, but not easy.
Mattmeurer
C?ID=86950
I’m looking into putting acc on my 2010 Touareg, thanks for the scan info but what sensors did you use? The dual newer ones or were you able to track down the emblem one. I know vw made very few that weren’t even sold in the states with adaptive cruise (the only one I know of was a vw training center Touareg)
