Faulty coil or fuel injektor 2.0 tfsi
snowmad
Sweden
C?ID=335258
Hi!
Our 2010 A5 888 2.0 tfsi engine just lost power, ESP is on mil on and off.
Vcds says misfire on cylinder 3 P0303 Misfire Detected
Engine got no power and got a bad smell and smoke of fuel from the exhaust
Engine does not start up easy, shakes/does not run smooth, and feels and sounds like one cylinder is dead.
Strange thing, I cleared the codes just to confirm fault in no 3.
Now there no codes at all but engine still hard to start, shakes/vibrates, sounds like it’s only on 3 and there that massive smoke smelling fuel from the exhaust.
I’m thinking more and more in faulty / stuck open injector, but how to confirm if and which one(s)?
or am i lost/wrong as usual?
this is Engine scan first time, when there were codes precent
                Address 01: Engine       Labels: 06H-907-115-CAB.clb
Control Module Part Number: 8K2 907 115 AJ    HW: 8K2 907 115 D
  Component and/or Version: 2.0l R4/4V TF H15 0002
           Software Coding: 0114000C240F0160
            Work Shop Code: WSC 52341 002 1048576
              ASAM Dataset: EV_ECM20TFS0118K2907115AJ 001002 (AU48)
                       ROD: EV_ECM20AVS.rod
                      VCID: 77F9D27DCE9910F2EC-8022
4060 - Cylinder 3
          P0303 00 [101] - Misfire Detected
                    Mileage: 129246 km
                    Date: 2019.03.08
                    Time: 17:52:39
                     Engine speed: 1390.00 /min
                    Normed load value: 42.0 %
                    Vehicle speed: 26 km/h
                    Coolant temperature: 61 °C
                    Intake air temperature: 7 °C
                    Ambient air pressure: 940 mbar
                    Voltage terminal 30: 13.169 V
                    Unlearning counter according OBD: 77
 7960 - Cylinder Disabling
          P130A 00 [032] - -
                    Mileage: 129247 km
                    Date: 2019.03.08
                    Time: 17:53:46
                     Engine speed: 797.00 /min
                    Normed load value: 23.9 %
                    Vehicle speed: 5 km/h
                    Coolant temperature: 64 °C
                    Intake air temperature: 10 °C
                    Voltage terminal 30: 13.334 V
 4051 - Random/Multiple Cylinder Misfire Detected
          P0300 00 [101] - -
                    Mileage: 129246 km
                    Date: 2019.03.08
                    Time: 17:52:35
                     Engine speed: 1982.50 /min
                    Normed load value: 45.5 %
                    Vehicle speed: 25 km/h
                    Intake air temperature: 8 °C
                    Voltage terminal 30: 13.264 V
snowmad
Sweden
C?ID=335258
Will do that!
Is there supposed to be pressure left in the fuel rail some hours after shut down?
will vcds be able to show me what rail pressure is, and what it's suposed to be?
I’m thinking “if no pressure until just before engine starts (have to crank it lots of turns now) then I concentrate on injector(s)
Hopefully I find one cylinder flooded, if I got spark and compression then it must be the injector right?
I’ve never seen this kind of fuel fog from any exhaust before.
I and my clothes smelled like I’ve been swimming in fuel!
Pistons, rods, bearings, chains, tensioners and so only got 1600km (2500miles) on them sins dealer rebuilt engine to cure oil consumption.
Will do that!
It is seriously advised you get an RTFB and in addition to the aforementioned VCDS video Uwe pointed you too, that actual mechanical tests be done to correlate consistency of OBD tests and for FOD.
JPPSG
https://forums.ross-tech.com/showth...essional-Problem-Solver-Guide-quot-JPPSG-quot
snowmad
Sweden
C?ID=335258
Thanks Uwe and european Jack.
Now I have a game plan.
Remove all coils and sparkplugs and inspect.
Also inspect inside of cylinders (and top of pistons) using my small USB camera.
If there’s any of what you call FOD inside, or markings, pitching from sutch passing the combustion chamber, I might call it a day and my be trade it as is!
BUT if nothing is pounded, pitched, lose or otherwise bad inside I will go on checking rail pressure.
I now know that’s supposed to be done with a “warm” engine, but I don’t think I can stand that much fuel fog fumes 
Fredrick Awuor
Kenya
C?ID=309834
Hi!
4060 - Cylinder 3
                    Mileage: 129246 km
                    Date: 2019.03.08
                    Time: 17:52:39
          P130A 00 [032] - -
                    Mileage: 129247 km
                    Date: 2019.03.08
                    Time: 17:53:46
          P0300 00 [101] - -
                    Mileage: 129246 km
                    Date: 2019.03.08
                    Time: 17:52:35
hello,i could bet that you have a bad fuel injector valve.....and bad coilpacks as well,VW has really struggled with these injector valves that you will be surprised if you were to key your VIN into ETKA,almost 5 revisions.....it could get worse and dump fuel into combustion chamber thereby causing hydrolock,as some seep into oil pan,try swapping coilpacks to see if misfire vacates.....
+50 for Fred.......indeed!
The HPP can also leak raw fuel in sump too causing #3 failure or ultimate engine destruction.
snowmad
Sweden
C?ID=335258
fuel pressure ok.
Jack and Fredrik u scare me a bit :-) !
I looked inside all 4 cylinders, nothing bad.
Got hands on a used 07K905115F coilpack (same as the others)
Also changed oil and oilfilter (no fuel smell from old fuel)
Started engine, little ruff at first (but not as bad as before) after 45-60sek I went normal!
I have ordered 4 brand new coils.
QUESTION: can the ignition fault counter be reset?
Cyl #1&2 has 200 #3 750 #4 500 (not the exact numbers)
I think: starting from zero (0) is a good idea with the new coilpacks.
More misfire at #3 after new coilpaks = injector problem
fuel pressure ok.
Coil pack & plugs failure are a result of secondary ignition failure during continued use & while in ultimate misfire & that still is not corrected now huh?
Symphony of Destruction?
Please post a new auto-scan........
https://www.youtube.com/watch?v=K5jvUXij7nU
snowmad
Sweden
C?ID=335258
Jack, I’m sorry for not being able to express myself in English.
No fault codes present as of now (only got the fault codes from first post who I erased back then)
The misfire counter number must be from cars birth and that’s why I would like to reset the counter.
The “750” number can be read just with key on (engine NOT running).
Wife have driven car +60km on one used and 3 original to the car coilpack with no fault code
The 4 new coilpacs is to arrive monday or tuesday.
After installing them I would like to reset the counter..
//Lars
snowmad
Sweden
C?ID=335258
This is the counter numbers which i wonder if they can be reset?
Saturday,16,March,2019,13:04:21:21588
VCDS Version: 18.9.1.0
VIN: WAUZZZ8T7AAxxxxxx   License Plate:
                Address 01: Engine  (8K2 907 115 AJ)
13:03:53
  IDE00604   Short term adaptation of mixture formation bank 1 -1.6 %
  IDE01975   Numb.of misfir.: cylinder 1 205
  IDE01976   Numb.of misfir.: cylinder 2 214
  IDE01977   Numb.of misfir.: cylinder 3 774
  IDE01978   Numb.of misfir.: cylinder 4 496
and hers a autoscan now after about 120km
 Sunday,17,March,2019,10:05:32:21588
VIN: WAUZZZ8T7AAzzzzzz   License Plate: ORD666
Mileage: 129380km-80393mi   Repair Order:
Chassis Type: 8T-AU48 (8T0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 42 46 47 52 53 55 56 62 72
VIN: WAUZZZ8T7AA017306   Mileage: 129380km-80393miles
Address 01: Engine (CL0MA-CDNC)       Labels:| 06H-907-115-CAB.clb
   Part No SW: 8K2 907 115 AJ    HW: 8K2 907 115 D
   Component: 2.0l R4/4V TF H15 0002
   Revision: E1H15---
   Shop #: WSC 52341 002 1048576
Readiness: 0000 0100
   Part No SW: 8K0 927 156 F    HW: 0B5 927 156 E
   Component: 0B5 20TFSIRdW H03 0011
   Revision: --H03---    Serial number: 0000000066
   Coding: 000001
   Shop #: WSC 06325 000 00000
   ASAM Dataset: EV_TCMDL501 A02044
   ROD: EV_TCMDL501.rod
   VCID: 3779127D8E19D0F22C-8062
   Part No SW: 8K0 907 379 CA    HW: 8K0 907 379 CA
   Component: ESP8 quattro  H04 0010
   Coding: 090D08
   VCID: 7AFFCB49F58B0D9A93-802E
   Part No SW: 8K0 907 064 DP    HW: 8K0 907 064 DP
   Component: BCM2 1.1      H02 0324
   Coding: 010400
   VCID: 010DBCA5985D5E42D2-8054
   Subsystem 1 - Part No SW: 8T0 959 754 D    HW: 8T0 959 754 D
   Serial number: 0509000046228012
   Serial number: 0209000059431008
   Part No SW: 8T1 820 043 AN    HW: 8T1 820 043 AN
   Component: KLIMA 1 ZONE  H08 0171
   Revision: A1000000    Serial number: 01290820091718
   Coding: 64000000
   VCID: 7DF5C055E4A53AA2B6-8028
   Part No SW: 8K0 907 063 P    HW: 8K0 907 063 P
   Component: BCM1 1.0      H25 0380
   Revision: 10025001    Serial number: 00000000452480
   Coding: 2600D0914034AF010009000300005D5D0F1C430800010101000000
   VCID: 3C730D51BF3FF3AAC1-8068
   Subsystem 1 - Part No SW: 8T1 955 119 D    HW: 8J1 955 119   Labels: 1KX-955-119.CLB
   Component: WWS 030909  H14 0070
   Serial number: SWF09090035175
   Coding: 00FD11
   Component: RLS  H04 0003
   Serial number: 10579268
   Coding: 02532C
   Subsystem 3 - Part No SW: 8K0 941 531 AL    HW: 8K0 941 531 AL
   Component: E1 - LDS  H08 0090
   Serial number: 00000000001708090723
   Part No SW: 8K0 919 475 J    HW: 8K0 919 475 A
   Component: PARKHILFE 8K  H06 0050
   Revision: 11001001    Serial number: 39840923802476
   Coding: 100107
   VCID: 408B79A1D3D7974A9D-8014
   Part No SW: 8K0 959 655 G    HW: 8K0 959 655 G
   Component: AirbagVW-AU10 H39 0560
   Serial number: 003EFD057NUO
   Coding: 30343438363030303030554A304C38543053
   VCID: 418D7CA5D0DD9E4292-8014
   Serial number: 6334MSME4A012A000
   Serial number: 6344MSME4A633A37K
   Serial number: 6352QSME25394E2CS
   Serial number: 6362QSME52394E2CT
   Serial number: 63732SME5A384424$
   Serial number: 63832SME69384B10%
   Revision: --------    Serial number: 90304IHR0005U
   Coding: 000016
   VCID: 3D750055A425FAA2F6-8068
   Part No SW: 8T0 920 900 N    HW: 8T0 920 900 N
   Component: KOMBIINSTR.   H33 0253
   Revision: 00000000    Serial number: BX420Z589
   Coding: 0F07310003000008010000
   VCID: 3E770759A923E1BAEF-806A
   Part No SW: 8T0 907 468 R    HW: 8T0 907 468 H
   Component: GW-BEM 5CAN   H06 0105
   Revision: GB600050    Serial number: 5000G098168146
   Coding: 00C303
   VCID: 50AB49E103B767CA0D-8004
   Subsystem 1 - Part No SW: 8K0 915 181 E    HW: 8K0 915 181 E
   Component: J367-BDM  H06 0170
   Serial number: 1908A6D7050809
            000 -  -  - Intermittent
                    Fault Frequency: 70
                    Reset counter: 28
                    Mileage: 121634 km
                    Date: 2018.08.29
                    Time: 07:53:57
                    Bin. Bits:    10111
                    Voltage: 11.30 V
                    Count: 6
   Part No SW: 8T0 959 793 D    HW: 8T0 959 793 A
   Component: TSG FA        H07 1101
   Coding: 011C02624000450005
   VCID: 4A9F5B89E5EB5D1A43-801E
   Revision: 00002001    Serial number: 0121095385
   Coding: 011A0620203900000030040000000000
   Shop #: WSC 06342 000 00000
02616 - Fuel Tank Cap; Unlock
            009 - Open or Short to Ground
                    Fault Status: 01101001
                    Fault Frequency: 52
                    Reset counter: 245
                    Mileage: 117004 km
                    Date: 2018.04.18
                    Time: 14:10:19
02615 - Fuel Tank Cap; Lock
                    Fault Frequency: 46
                    Reset counter: 245
                    Mileage: 117008 km
                    Date: 2018.04.19
                    Time: 08:46:55
Address 47: Sound System (J525)       Labels:. 8T0-035-223-BOC.clb
   Part No SW: 8T0 035 223 AR    HW: 8T0 035 223 AJ
   Component: DSP Prem      H17 0320
   Revision: 00017001    Serial number: 34834004452502
   Coding: 0203010301
   Shop #: WSC 40970 222 96083
   VCID: 7EF7C759E9A321BAAF-802A
   Part No SW: 8T0 959 792 D    HW: 8T0 959 792 A
   Component: TSG BF        H07 1101
   Coding: 011C02224000450005
   VCID: 499D6485E0ED56024A-801C
                    Fault Frequency: 60
                    Reset counter: 27
                    Mileage: 122881 km
                    Date: 2018.09.21
                    Time: 08:39:20
   Revision: 00000003    Serial number: 00000000434661
   VCID: 34632571976F3BEA09-8060
   Part No: 8K5 907 357
   Shop #: WSC 06324 000 00000
   VCID: 77F9D27D069910F2EC-8022
   Part No SW: 8T1 035 186 P    HW: 8T1 035 186 P
   Component: Concert3      H04 0310
   Revision: 00000007    Serial number: AUZ5Z6I1262726
   Coding: 0503008001040500415B070000
   VCID: 448375B1C7CF8B6AB9-8010
   Subsystem 1 - Part No SW: 8T0 919 603 E    HW: 8T0 919 603 E
   Component: Display
   Part No SW: 8T0 959 795 E    HW: 8T0 959 795 B
   Component: TSG HL        H05 1101
   Coding: 010C02224000450005
   VCID: 4D95509514854A2266-8018
                    Fault Frequency: 41
                    Reset counter: 32
                    Mileage: 121231 km
                    Date: 2018.08.06
                    Time: 08:33:46
   Component: TSG HR        H05 1101
End-------------------------(Elapsed Time: 03:38)--------------------------
Reset the fault memory 3-5 times fast and without an engine restart It should reset I believe when checking after a verified key cycle and being re-coded.
Then cold reboot the car battery with bridge.
snowmad
Sweden
C?ID=335258
Jack thank you very much.
I understand the procedure until here.
Caldstart (disconnect battery wait a bit than reconnect the battery) but what is the bridge??
….. discharge positive cable while disconnected???
Please have patience with me I’m just a dumbas and not in my native language...
Lars
Did you when battery is disconnected, connect a bridge wire from one side to other of terminals in car & "NOT the Battery"!, than turn ignition ON during wait time than turn key off, remove bridge and reconnect battery?
snowmad
Sweden
C?ID=335258
No, done nothing yet. Still waiting for the colipacks to arive. But now i understand the bridge and why to do it. I'l be back reporting the outcom as son as i installed new coilpacks and executed your counter clearing instruction.
Lars
snowmad
Sweden
C?ID=335258
I replaced the coilpacks some 2 weeks ago and tried only half the reset advice
“Reset the fault memory 3-5 times fast and without an engine restart it should reset I believe”
-no misfire counter reset.
I now need to know if I need a code to reactivate the “Bang & Olufssen” system if I disconnect the battery.
I bought a new battery that I will replace it as soon as I know that I will be able to play music afterwards (the old battery is just that, old and a litle weak)
-and then I will perform the entire procedure including drain all current from system (the bridge thing) before reconnecting the new battery.
I will report when I know the result.
