Friday,07,September,2018,20:23:18:28780
VCDS Version: 18.2.1.5 (x64)
VIN: WAUZZZ4M3HD028651 License Plate: MAGNUS
Mileage: 27655km-17184mi Repair Order:
Chassis Type 4M-AU73 (8W7)
Scan: 01 02 03 06 08 09 13 15 16 17 18 19 23 2B 36 3C 42 44 46 47
51 52 5F 69 6C 6D 74 81 8B 8C A5 AC BA BB BC C5 C6 CA CF
VIN: WAUZZZ4M3HD028651 Mileage: 27655km-17184miles
23-Brake Booster -- Status: Malfunction 0010
46-Central Conv. -- Status: INTERFACE NOT COMPATIBLE
74-Chassis Control -- Status: INTERFACE NOT COMPATIBLE
BA-Motor Mounts -- Status: OK 0000
C5-Therm. mgt. -- Status: Malfunction 0010
C6-Batt. Chrg. -- Status: Malfunction 0010
CA-Sunroof -- Status: INTERFACE NOT COMPATIBLE
CF-Lane Chge Asst 2 -- Status: INTERFACE NOT COMPATIBLE
Address 01: Engine (J623-CVZA) Labels: Redir Fail!
Part No SW: 4M0 907 401 A HW: 059 907 309 F
Component: 3.0TDI MD1 H23 0008
Revision: C7H23---
Coding: 2A2A403A057E050335382B00000000000000000000000000
Shop #: WSC 31414 790 00001
ASAM Dataset: EV_ECM30TDI0114M0907401A 001016
ROD: EV_ECM30TDI0114M0907401A.rod
VCID: 275784455E9D787C45-8072
Active accelerator pedal:
Subsystem 1 - Part No SW: 4M1 723 523 HW: 4M1 723 523
Component: J1115 - FFP H17 0007
Serial number: 123456789ABCDEFGHIJK
Clutch Control Unit Sub:
Subsystem 2 - Part No SW: 0D7 142 057 D HW: 0D7 142 057 D
Component: J1128 CCU H04 0031
17158 - Databus
Mileage: 27424 km
Date: 2018.09.03
Time: 20:52:19
Engine speed: 1782.50 /min
Vehicle speed: 68 km/h
Coolant temperature: 93 °C
Intake air temperature: 22 °C
Voltage terminal 30: 13.200 V
Unlearning counter according OBD: 33
Engine status: COENG_RUNNING
Engine status-Test_Program_Co Eng st COMPU VERB UBYTE: 3
23467 - Brake Booster Control Module
U103F 00 [032] - Implausible signal
Mileage: 27424 km
Date: 2018.09.03
Time: 20:52:17
Coolant temperature: 92 °C
Intake air temperature: 23 °C
Voltage terminal 30: 12.740 V
Com st X Set1 Val1-Bits 0-7: 0
Com st X Set1 Val2-Bits 0-7: 0
Com st X Set1 Val3-Bits 0-7: 0
Com st X Set1 Val4-Bits 0-7: 0
Com st X Set1 Val5-Bits 0-7: 0
Com st X Set1 Val6-Bits 0-7: 0
Com st X Set1 Val7-Bits 0-7: 0
Com st X Set1 Val7-Bits 0-7: 193
Address 02: Auto Trans (J217) Labels:* None
Part No SW: 4M0 927 158 M HW: 0D7 927 156 B
Component: 0D7 30TDIRdW H03 1009
Revision: --H03---
Coding: 100000
ASAM Dataset: EV_TCMALX52011 002011
ROD: EV_TCMALX52011.rod
VCID: 3E794121A107D9B416-806A
Automatic Transmission Fluid Pump:
Subsystem 1 - Part No SW: 4M0 927 154 AA HW: 0D7 321 281 A
Component: V552 ATFP D.4 0000
Serial number: 00001057
Address 03: ABS Brakes (J104) Labels:. 4M0-907-379-PRE-V1.clb
Part No SW: 4M0 907 379 P HW: 4M0 907 379 P
Component: ESP9 Premium H09 0649
Coding: 2C9830B232A40A9ED1A41896187E52AAF6A6DA340C4C508B18184A556F655B
Shop #: WSC 36596 001 1048576
ASAM Dataset: EV_ESP9BOSCHAU536P 011013
ROD: EV_ESP9BOSCHAU536P.rod
VCID: 448D33C9CFEBB36440-8010
6 Faults Found:
12891401 - Unknown Error Code
U04B5 00 [032] - -
Mileage: 27424 km
Date: 2018.09.03
Time: 20:52:17
12891402 - Unknown Error Code
U04B5 00 [032] - -
Mileage: 27424 km
Date: 2018.09.03
Time: 20:52:17
4560900 - Unknown Error Code
C0598 00 [032] - -
Mileage: 27424 km
Date: 2018.09.03
Time: 20:52:20
4560898 - Unknown Error Code
C0598 00 [032] - -
Mileage: 27424 km
Date: 2018.09.03
Time: 20:52:17
4560902 - Unknown Error Code
C0598 00 [032] - -
Mileage: 27424 km
Date: 2018.09.03
Time: 20:52:17
4560896 - Unknown Error Code
C0598 00 [032] - -
Mileage: 27424 km
Date: 2018.09.03
Time: 20:52:17
Address 06: Seat Mem. Pass (J521) Labels:* None
Part No SW: 4M1 959 760 E HW: 4M1 959 760 E
Component: MEM-BFS 008 0031
Serial number: 00000226565779
Coding: 001010000000B0410000010101010000110000313100000000000000000000
ROD: EV_SCMPasseSideCONTIAU736.rod
VCID: 3B7F4835B215CC9C31-806E
Address 08: Auto HVAC (E87) Labels:* None
Part No SW: 4M0 820 043 AD HW: 4M0 820 043 AD
Component: Klima Zone 3 H52 0093
Coding: 661A48094548400D02220280820000000000000000000000000000000000
ASAM Dataset: EV_AirCondiFrontBHTCAU736 001013
ROD: EV_AirCondiFrontBHTCAU736.rod
VCID: 67D7C4459E1DB87C85-8032
Subsystem 1 - Part No SW: 4M1 820 021 HW: 4M1 820 021
Component: J216 FLuftV H05 0001
Serial number: 00000000000001127749
Subsystem 2 - Part No SW: 4H0 907 658 A HW: 4H0 907 658 A
Component: AQ_Hum_Sensor H01 0005
Serial number: B798855800PAG0MUFU02
Subsystem 3 - Part No SW: 8W0 919 158 A HW: 8W0 919 158 A
Component: Klima Heck H40 0073
Address 09: Cent. Elect. (J519) Labels:* None
Part No SW: 8W0 907 063 CG HW: 8W0 907 063 BG
Component: BCM1 MLBevo H13 0266
Coding: 07501943C13900CD4501571958BF88F9130331009000000000000000E00016810A4502AB32B71A
VCID: 0201F5D1957F7D5432-8056
Subsystem 1 - Part No SW: 4M1 955 119 A HW: 4H2 955 119 C Labels: 1KX-955-119.CLB
Component: WWS536 160911 043 0893
Serial number: 89555300401625500689
Coding: 1BC7F7
Component: G397_RLFS H06 0004
Serial number: 62404927
Coding: 0200FF
Light switch:
Subsystem 3 - Part No SW: 4M0 941 531 AA HW: 4M0 941 531 AA
Component: E1 - LDS H06 0008
Serial number: 30 06 2016 00524385
Subsystem 4 - Part No SW: 8W0 857 511 HW: 8W0 857 511
Component: Y7_Innenspieg H09 0002
Serial number: GX1CE101081611521135
Coding: 030000
Interior Light Module:
Subsystem 5 - Part No SW: 4M0 947 135 CK HW: 4M0 947 135
Component: J528-Dachele H14 0130
Serial number: Q00215340
Subsystem 6 - Part No SW: 4M0 925 301 H HW: 4M0 925 301 H
Component: SL-Q7NF/AU736 H10 0013
Serial number: 00000000000000004794
15 Faults Found:
65914 - Databus
Reset counter: 226
Mileage: 26608 km
Date: 2018.08.02
Time: 15:22:37
average_Voltage_terminals: 14.20 V
Outside air temperature sensor-Resistance: 0.00 kOhm
Outside air temperature sensor-Outside air temperature on CAN: 27.50 °C
interior_temperature: 31.00 °C
Vehicle speed: 0.00 km/h
65915 - Databus
Fault Frequency: 7
Reset counter: 226
Mileage: 26608 km
Date: 2018.08.03
Time: 11:39:38
average_Voltage_terminals: 14.80 V
interior_temperature: 28.00 °C
Vehicle speed: 1.78 km/h
65942 - Control Module for Wiper Motor(s)
U113C 00 [008] - Impausible Message
Reset counter: 226
Mileage: 26623 km
Date: 2018.08.13
Time: 08:40:37
average_Voltage_terminals: 11.70 V
Outside air temperature sensor-Outside air temperature on CAN: 16.00 °C
interior_temperature: 18.00 °C
Terminal control-Terminal 75 status: OFF
Terminal control-Terminal 15 status signal: OFF
Terminal control-Terminal 15 via CAN: OFF
66069 - Sensor for Rain and Light Detection
U113B 00 [008] - Impausible Message
Reset counter: 226
Mileage: 26623 km
Date: 2018.08.13
Time: 09:53:06
Outside air temperature sensor-Outside air temperature on CAN: 17.50 °C
interior_temperature: 17.50 °C
Terminal control-Terminal 75 status: Not available
Terminal control-Terminal 15 via CAN: Not available
66937 - Unknown Error Code
B1366 F0 [008] - Unknown Error Elaboration
Reset counter: 226
Mileage: 26623 km
Date: 2018.08.13
Time: 08:45:06
average_Voltage_terminals: 11.80 V
66949 - Databus
Reset counter: 226
Mileage: 26608 km
Date: 2018.08.02
Time: 15:22:39
66950 - Databus
Reset counter: 226
Mileage: 26608 km
Date: 2018.08.02
Time: 15:22:39
66961 - Databus
Reset counter: 226
Mileage: 26608 km
Date: 2018.08.02
Time: 15:22:39
66962 - Databus
Reset counter: 226
Mileage: 26608 km
Date: 2018.08.02
Time: 15:22:39
196720 - Front Parking Aid Sensor(s)
B10FC 13 [008] - Open Circuit
Reset counter: 226
Mileage: 26608 km
Date: 2018.08.02
Time: 15:22:32
average_Voltage_terminals: 12.40 V
196758 - Databus
Reset counter: 238
Mileage: 27424 km
Date: 2018.09.03
Time: 20:52:19
average_Voltage_terminals: 13.30 V
Outside air temperature sensor-Outside air temperature on CAN: 19.00 °C
interior_temperature: 24.50 °C
Vehicle speed: 68.71 km/h
196898 - Databus
Fault Frequency: 15
Reset counter: 238
Mileage: 26608 km
Date: 2018.08.02
Time: 15:22:33
average_Voltage_terminals: 13.40 V
327698 - Databus
Reset counter: 238
Mileage: 27424 km
Date: 2018.09.03
Time: 20:52:19
average_Voltage_terminals: 13.20 V
Vehicle speed: 68.72 km/h
327712 - Databus
Fault Frequency: 10
Reset counter: 238
Mileage: 26608 km
Date: 2018.08.02
Time: 15:22:33
66340 - No Communications with Rain/Light Sensor
U10F6 00 [008] - -
Reset counter: 226
Mileage: 26623 km
Date: 2018.08.13
Time: 08:40:37
Address 13: Auto Dist. Reg (J428) Labels:* None
Part No SW: 4M0 907 561 D HW: 4M0 907 561
Component: LRR4 H10 0220
Coding: 5477FFFB58FFEC0A949C80E0
ASAM Dataset: EV_ACCBOSCHAU736 002018
ROD: EV_ACCBOSCHAU49X_002.rod
VCID: 31636A1D605936CC9B-8064
9 Faults Found:
2172 - Databus
Reset counter: 226
Mileage: 26608 km
Date: 2018.08.07
Time: 15:47:13
Control Module temperature: 28 °C
Voltage terminal 15: 12.0 V
2101 - Databus
Reset counter: 238
Mileage: 27424 km
Date: 2018.09.03
Time: 20:52:17
Control Module temperature: 33 °C
Voltage terminal 15: 12.8 V
Velocity_vehicle_reference: 19.09 m/s
Longitudinal_acceleration_vehicle_reference: -0.17 m/s²
Status_ACC_System: ACC_activ_controlled
2153 - Databus
Reset counter: 238
Mileage: 26608 km
Date: 2018.08.07
Time: 15:47:13
2115 - Databus
Reset counter: 238
Mileage: 27424 km
Date: 2018.09.03
Time: 20:52:17
1134 - Databus
Reset counter: 226
Mileage: 26608 km
Date: 2018.08.07
Time: 15:47:13
1135 - Databus
Reset counter: 226
Mileage: 26608 km
Date: 2018.08.07
Time: 15:47:13
1136 - Databus
Reset counter: 226
Mileage: 26608 km
Date: 2018.08.07
Time: 15:47:13
1137 - Databus
Reset counter: 226
Mileage: 26608 km
Date: 2018.08.07
Time: 15:47:13
2068 - Databus
Reset counter: 238
Mileage: 27424 km
Date: 2018.09.03
Time: 20:52:19
Voltage terminal 15: 13.1 V
Velocity_vehicle_reference: 19.23 m/s
Longitudinal_acceleration_vehicle_reference: -0.07 m/s²
Address 15: Airbags (J234) Labels:* None
Part No SW: 4M0 959 655 HW: 4M0 959 655
Component: Airbag10.44 H70 0086
Serial number: 003L10031H8B
Coding: AAFCF0C00CA0000098F600F3C04C00000000
ASAM Dataset: EV_AirbaAU10BPAAU736 005012
ROD: EV_AirbaAU10BPAAU736_005_AU49.rod
VCID: 78F59739C3A327841C-802C
Belt Pretensioner left:
Subsystem 1 - Part No SW: 4M0 980 945 HW: 4M0 980 945
Component: BeltPretRevFL 205 2033
Serial number: 4M0857705D0301Q01588
Coding: 88001B
Belt Pretensioner right:
Subsystem 2 - Part No SW: 4M0 980 946 HW: 4M0 980 946
Component: BeltPretRevFR 205 2033
Serial number: 4M0857706J0301Q01213
Coding: 88001B
Subsystem 3 - Part No SW: ----------- HW: 442 061 510 16
Serial number: 3577Y00A51FFD1113293
Subsystem 4 - Part No SW: ----------- HW: 442 061 510 16
Serial number: 3587Y00A31FD753221E4
Subsystem 5 - Part No SW: ----------- HW: 442 0B0 310 16
Component: SideSensor_Dr 1C7 0148
Serial number: 3517700BB21590A1430.
Subsystem 6 - Part No SW: ----------- HW: 442 0B0 310 16
Serial number: 3527700AF2235620A30$
Subsystem 7 - Part No SW: ----------- HW: 442 0C2 109 16
Component: FrontSensor_D 1C5 014A
Serial number: 3557500C321ADC71E34L
Front Sensor Passenger:
Subsystem 8 - Part No SW: ----------- HW: 442 0C2 109 16
Component: FrontSensor_P 1C5 014A
Serial number: 3567500C321ADC70B2BO
Pedestrian Protection Center:
Subsystem 9 - Part No SW: ----------- HW: 442 0C2 109 16
Component: PedP_Sensor_C 1C5 014A
Serial number: 2307500A121F10C161C-
Subsystem 10 - Part No SW: ----------- HW: 442 420 809 16
Component: PedPSensor_D2 21E 0887
Serial number: I0M8U00B71FB75F3F0B7
Subsystem 11 - Part No SW: ----------- HW: 442 420 809 16
Component: PedPSensor_P2 21E 0887
Serial number: I0N8U00991FFD130634T
Central Sensor XY:
Subsystem 12 - Part No SW: ----------- HW: 410 203 110 16
Component: CentrSensorXY 1C8 0108
Serial number: I0O78009D21A82B4611$
1060613 - Databus
Reset counter: 238
Mileage: 27424 km
Date: 2018.09.03
Time: 20:52:18
1060614 - Databus
Reset counter: 238
Mileage: 27424 km
Date: 2018.09.03
Time: 20:52:18
1060615 - Databus
Reset counter: 238
Mileage: 27424 km
Date: 2018.09.03
Time: 20:52:18
1060617 - Databus
Reset counter: 238
Mileage: 27424 km
Date: 2018.09.03
Time: 20:52:18
Address 16: Steering wheel (J527) Labels: 4M0-907-129.clb
Part No SW: 4M0 907 129 JE HW: 4M0 907 129 JE
Component: Lenks.Modul H11 0009
ROD: EV_SMLSKLOAU736_006.rod
VCID: 7CFD8B29F79B0BA478-8028
Address 17: Instruments (J285) Labels:* Redir Fail!-SRI2
Part No SW: 4M0 920 794 B HW: 4M0 920 794 B
Component: FHybRDW H15 0302
Coding: 040401D07C9800080BA669703204600000000000
ASAM Dataset: EV_DashBoardAU736 001022
VCID: 32616511655F0DD4E2-8066
16777046 - Charger for HV Battery
U1139 00 [008] - No Communications
Fault Frequency: 9
Reset counter: 245
Mileage: 26623 km
Date: 2018.08.15
Time: 15:13:35
16776982 - Databus
Reset counter: 226
Mileage: 26608 km
Date: 2018.08.03
Time: 11:39:35
16777089 - Databus
Reset counter: 226
Mileage: 26608 km
Date: 2018.08.02
Time: 15:22:31
Address 18: Aux. Heat (J364) Labels:* None
Part No SW: 4M0 265 105 E HW: 4M0 265 105 E
Component: HSG H10 0080
Coding: 0D0803
ASAM Dataset: EV_AuxilParkHeateEBEAU736 001016
ROD: EV_AuxilParkHeateEBEAU736.rod
VCID: 2953827D48894E0C53-807C
Part No SW: 8W7 907 468 D HW: 8W7 907 468 C
Component: Gateway H30 0309
Revision: 5C000001 Serial number: 0185C285716A26
Coding: 02010101000206C08C82010000590032DC520007180000000175079E10000000
ASAM Dataset: EV_CGateCONTIAU491 002040
ROD: EV_CGateCONTIAU491_002_AU49.rod
VCID: 4C9D1BE9E7BB7B2488-8018
Subsystem 1 - Part No SW: 4M0 951 523 A HW: 4M0 951 523 A
Component: J453 MFL H06 0002
Serial number: 20161025030053 00411
Subsystem 2 - Part No SW: 8S0 915 181 C HW: 8S0 915 181 C
Serial number: 2222561904
131662 - Lane change assistant control module
U1045 00 [008] - No communication
Reset counter: 226
Mileage: 26608 km
Date: 2018.08.02
Time: 15:43:14
131670 - Automatic distance regulation 2
U1071 00 [008] - No communication
Reset counter: 226
Mileage: 26608 km
Date: 2018.08.02
Time: 15:22:36
131671 - No Communications with Cruise Control (Front) Distance Sensor
U0235 00 [008] - -
Reset counter: 226
Mileage: 26608 km
Date: 2018.08.02
Time: 15:22:36
131722 - Control Module 2 for Lane Change Assistance
U10A5 00 [008] - No Communications
Reset counter: 226
Mileage: 26608 km
Date: 2018.08.02
Time: 15:43:14
Address 23: Brake Booster (J539) Labels: None
Part No SW: 4M0 909 059 C HW: 4M0 909 059
Component: J539 EBKV H11 0194
Serial number: 085430010692
ASAM Dataset: EV_BrakeBoostBOSCHAU736 001001
ROD: EV_BrakeBoostBOSCHAU736.rod
VCID: 346D63099F4B03E4F0-8060
Brake Assistance Sub:
Subsystem 1 - Part No SW: 4M0 909 057 A HW: 4M0 909 057
Component: VX70BrakeAssi H04 0153
Serial number: 05802861260916081834
208896 - FlexRay Databus Defective
U0080 00 [096] - -
Mileage: 27477 km
Date: 2018.09.04
Time: 12:34:14
216064 - Brake Pedal Position Sensor 1/2
P05E0 00 [032] - Correlation
Mileage: 27424 km
Date: 2018.09.03
Time: 20:52:17
Address 2B: Steer. Col. Lock (J764) Labels:| 5Q0-905-861.clb
Part No SW: 3Q0 905 861 A HW: 3Q0 905 861 A
Component: ELV-MLBevo H05 0032
Serial number: 16000250107011
Coding: 8800000000000000
ROD: EV_ELVMarquMQBB.rod
Address 36: Seat Mem. Drvr (J136) Labels:* None
Component: MEM-FS 008 0031
Serial number: 00000226565538
Coding: 00181B000000B0410000010101010000110000313100000000000000000000
ROD: EV_SCMDriveSideCONTIAU736.rod
Address 3C: Lane Change (J769) Labels:* None
Part No SW: 4M0 907 566 B HW: 4M0 907 566
Component: MRR1Rear H13 0230
Revision: --------
Coding: 1EC002
ASAM Dataset: EV_RearRadarS1BoschAU736 001015
ROD: EV_RearRadarS1BoschAU736.rod
1192210 - Databus
Reset counter: 238
Mileage: 27424 km
Date: 2018.09.03
Time: 20:52:19
Control Module temperature: 38 °C
Voltage terminal 30: 13.20 V
Vehicle speed: 49.18 km/h
Terminal 15 status: OFF
Voltage terminal 15: Measured value not available
Address 42: Door Elect, Driver (J386) Labels:* None
Part No SW: 4M0 959 793 E HW: 4M0 959 793 C
Component: TSG FS 009 0055
Serial number: 0000224201871
Coding: 005D9A015E000080000130B2
ROD: EV_DCU2DriveSideMAXHCONT.rod
VCID: 40853FD9DBF3AF4464-8014
524420 - Databus
Reset counter: 226
Mileage: 26608 km
Date: 2018.08.03
Time: 11:39:40
Address 44: Steering Assist (J500) Labels:* None
Part No SW: 4M0 909 144 H HW: 4M0 909 144 B
Component: EPS_MLBEVO1BS H20 0005
Serial number: 0000387818
Coding: B0150101010001
ASAM Dataset: EV_EPSVWBSAU736 009023
ROD: EV_EPSVWBSAU736_009.rod
3149825 - Databus
Reset counter: 226
Mileage: 26608 km
Date: 2018.08.02
Time: 15:22:31
FreezeFrame_mw_120C_Timeout-Engine speed: 0 /min
FreezeFrame_mw_120C_Timeout-System status: Reset
FreezeFrame_mw_120C_Timeout-Supply voltage: Terminal 30: 11.75 V
FreezeFrame_mw_120C_Timeout-Terminal 15 status measured: On
FreezeFrame_mw_120C_Timeout-Engine steering torque sensor: average value: 0.00 Nm
FreezeFrame_mw_120C_Timeout-Terminal 15 resulting: On
FreezeFrame_mw_120C_Timeout-Terminal 15 status signal: On
FreezeFrame_mw_120C_Timeout-Steering pinion angle: offset corrected: 459.45 °
FreezeFrame_mw_120C_Timeout-ARA signal red cyclic: 00
FreezeFrame_mw_120C_Timeout-PLA signal red cyclic: 00
FreezeFrame_mw_120C_Timeout-SCU state: System OK
FreezeFrame_mw_120C_Timeout-Steering_angle_sender_status: System OK
3148801 - Databus
Reset counter: 226
Mileage: 26608 km
Date: 2018.08.02
Time: 15:22:31
FreezeFrame_mw_120C_Timeout-Supply voltage: Terminal 30: 11.76 V
Address 46: Central Conv.
Interface not compatible.
Address 47: Sound System (J525) Labels:* None
Part No SW: 4M0 035 223 C HW: 4M0 035 223
Component: MIB2_amp_PD H03 0440
Serial number: 00000000000591
Coding: 0135960B008AF53AAF0000010001
ASAM Dataset: EV_AMPMst16C4Gen2BOSE 001001
ROD: EV_AMPMst16C4Gen2BOSE_AU57.rod
VCID: 234F90552AA5945C19-8076
Address 51: Electric Drive (J841) Labels: None
Part No SW: 4M1 907 080 B HW: 4M1 907 080 B
Component: A73P7828S1000 H02 0018
Revision: --H02---
Coding: 01000000000000000000
ASAM Dataset: EV_DMCM08530214M1907080B 001002
ROD: EV_DMCM08530214M2907080.rod
VCID: 2C5D7B69477B5B24A8-8078
Part No SW: 4M0 959 792 E HW: 4M0 959 792 C
Component: TSG BFS 009 0055
Serial number: 0000224890618
Coding: 005D9A015E000080000130B0
ROD: EV_DCU2PasseSideMAXHCONT.rod
VCID: 3F873C25A60DD0BC1D-806A
524420 - Databus
Reset counter: 226
Mileage: 26608 km
Date: 2018.08.03
Time: 11:39:40
Part No SW: 4M1 035 036 HW: 4M1 035 036
Component: MU-P-LN-EU 033 0917
Serial number: A805K0GB001145
Coding: 013796010000000053110002000A00332F001DE5017001009E
ROD: EV_MUHig6C3Gen2HBAS_AU49.rod
VCID: 63CFD0556A25D45C59-8036
Subsystem 1 - Part No SW: V03 959 802 DD HW: -----------
Component: ECE 2018/2019 --- 0169
Subsystem 2 - Part No SW: 4M1 919 605 HW: 4M1 919 605
Component: AU536_DU_HIGH H44 0008
Serial number: AUZ8Z9GJM007BD
Multimedia Operating Unit:
Subsystem 3 - Part No SW: 4M0 919 615 H HW: 4M0 919 615 H
Component: ControlUnit_P H15 0209
Serial number: 27101600000000000446
Component: Gracenote2 --- 1015
U1111 00 [008] - -
Reset counter: 226
Mileage: 26608 km
Date: 2018.08.02
Time: 15:22:56
Voltage terminal 30: 14.2 V
BAP-BAP_Function_ID: 02
7194 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Reset counter: 226
Mileage: 26608 km
Date: 2018.08.06
Time: 07:25:25
Voltage terminal 30: 14.9 V
7205 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Reset counter: 235
Mileage: 26623 km
Date: 2018.08.15
Time: 15:13:35
Voltage terminal 30: 15.1 V
Address 69: Trailer (J345) Labels:| 5Q0-907-383.clb
Part No SW: 4M0 907 383 D HW: 4M0 907 383 B
Component: Anhaenger H20 0214
Revision: 9A001003 Serial number: 0420863037
Coding: 0110000202010000
VCID: 336F60159A4504DCE9-8066
Trailer Articulation Angle Sensor:
Subsystem 1 - Part No SW: 4M0 907 811 HW: 4M0 907 811
Component: G820 KNWINSEN H18 0019
Serial number: 35022
Address 6C: Back-up Cam. (J928) Labels:* None
Part No SW: 4M0 907 428 E HW: 4M0 907 428
Component: Areaview 2 H13 0315
Serial number: C854607JG005175
Coding: 02350601BF0FA10008404500
ASAM Dataset: EV_CamSysRVAV2CE2MLBEv 004015
ROD: EV_CamSysRVAV2CE2MLBEv_004.rod
9598995 - Video Signal Line for Front Surroundings Camera
B1278 01 [008] - Electrical Failure
Reset counter: 226
Mileage: 26608 km
Date: 2018.08.02
Time: 15:22:37
13706029 - Voltage Supply for Camera; Front
B1862 01 [008] - Electrical Failure
Reset counter: 226
Mileage: 26608 km
Date: 2018.08.02
Time: 15:22:30
Address 6D: Trunk Elect. (J605) Labels:| 5Q0-959-107.clb
Part No SW: 4M0 959 107 B HW: 4M0 959 107 A
Component: HDSG-Modul H13 0161
Revision: -------- Serial number: 31022578700000
Coding: 00F0
ROD: EV_DeckLidCONTIAU736_VW27.rod
Address 74: Chassis Control
Address 81: Gear Shift (J587) Labels: 4MX-713-041-81.clb
Part No SW: 4M1 713 041 F HW: 4M1 713 041 F
Component: GSM-LL H09 0073
Revision: 0L0D5012 Serial number: 20161020001950
ROD: EV_GSMWaehlZFAU736_AU49.rod
VCID: 28558779538377044C-807C
Address 8B: Adaptive Cruise 2 (J850) Labels: 4M0-907-541.clb
Part No SW: 4M0 907 541 D HW: 4M0 907 541
ASAM Dataset: EV_ACC2BOSCHAU736 002018
ROD: EV_ACC2BOSCHAU736_002_AU73.rod
VCID: 2F676C65766D203C8D-807A
Address 8C: Hybrid Battery
Address A5: Frt Sens. Drv. Assist (R242) Labels:* None
Part No SW: 4M0 907 217 D HW: 4M0 907 217 A
Component: BVS H14 0042
Coding: 040703060000040202202387CD0000B4B0F0C020E280
ROD: EV_BVSMLBevKOSTAAU736.rod
6 Faults Found:
1122561 - Databus
Fault Frequency: 11
Reset counter: 226
Mileage: 26608 km
Date: 2018.08.02
Time: 15:22:31
Control Module temperature: 32 °C
Voltage terminal 15: 11.50 V
1122656 - Databus
Fault Frequency: 12
Mileage: 26608 km
Date: 2018.08.03
Time: 11:39:33
Control Module temperature: 30 °C
Voltage terminal 15: 11.10 V
1123714 - Databus
Reset counter: 226
Mileage: 26608 km
Date: 2018.08.02
Time: 15:22:38
Voltage terminal 15: 14.30 V
1123173 - Databus
Reset counter: 238
Mileage: 27424 km
Date: 2018.09.03
Time: 20:52:19
Voltage terminal 15: 13.30 V
1123735 - Databus
Reset counter: 226
Mileage: 26608 km
Date: 2018.08.02
Time: 15:22:34
Voltage terminal 15: 13.50 V
1123600 - predictive route data
B1630 02 [008] - Signal Failure
Reset counter: 240
Mileage: 27546 km
Date: 2018.09.05
Time: 11:34:16
Control Module temperature: 35 °C
Voltage terminal 15: 12.10 V
Address AC: Reductant Control (J880) Labels: 4M0-907-355.clb
Part No SW: 4M0 907 355 B HW: 4M0 907 355 B
Component: SCR-Stg-G3H04 0005
ASAM Dataset: EV_RDCMINERGAU736 005009
ROD: EV_RDCMINERGAU736.rod
VCID: 30656F196B533FC494-8064
Address BA: Motor Mounts (J931) Labels: None
Part No SW: 4M0 907 145 D HW: 4M0 907 145 B
Component: AEMevo H09 0111
ASAM Dataset: EV_AEMZFAU736 006012
ROD: EV_AEMZFAU736_006_AU73.rod
Part No SW: 4M0 959 795 E HW: 4M0 959 795 C
Component: TSG HFS 009 0055
Serial number: 0000226381029
Coding: 004D980000000080000030A0
ROD: EV_DCU2RearDriveMAXHCONT.rod
VCID: 428135D1D5FFBD5472-8016
Component: TSG HBFS 009 0055
Serial number: 0000226358179
ROD: EV_DCU2RearPasseMAXHCONT.rod
Address C5: Therm. mgt. (J1024) Labels:* None
Part No SW: 4M0 965 429 D HW: 4M0 965 429 B
Component: TME-Max H04 0021
Serial number: 0027434
Coding: 01
ASAM Dataset: EV_ThermContrVISAU49X 001023
ROD: EV_ThermContrVISAU49X_VW37.rod
VCID: 387557398323E784DC-806C
Subsystem 1 - Part No SW: 4M0 959 603 B HW: 4M0 959 603 B
Component: G395 pT-Sens1 H10 0009
Subsystem 2 - Part No SW: 12E 963 231 G HW: 12E 963 231 G
Component: J848 HV-PTC H09 0208
Serial number: LM163023003810000310
Subsystem 3 - Part No SW: 4M0 816 797 A HW: 4M0 816 797 A
Component: J842 EKK es33 H02 0012
Serial number: 00000000016102600214
Refrigerant Pressure And Temperature Sender 2:
Subsystem 4 - Part No SW: 4M0 959 603 B HW: 4M0 959 603 B
Component: G826 pT-Sens2 H10 0009
Refrigerant Pressure And Temperature Sender 3:
Subsystem 5 - Part No SW: 4M0 959 603 B HW: 4M0 959 603 B
Component: G827 pT-Sens3 H10 0009
Refrigerant Expansion Valve 1:
Subsystem 6 - Part No SW: 4M0 816 682 E HW: 4M0 816 682 E
Component: N636 EV1_KaMi H12 0102
Serial number: 00000000000150148272
Refrigerant Shut Off Valve 2:
Subsystem 7 - Part No SW: 4M0 816 702 A HW: 4M0 816 702 A
Component: N640 AV2_KaMi H12 0102
Serial number: 00000000000130149739
Refrigerant Shut Off Valve 3:
Subsystem 8 - Part No SW: 4M0 816 702 A HW: 4M0 816 702 A
Component: N641 AV3_KaMi H12 0102
Serial number: 00000000000130149732
Refrigerant Shut Off Valve 4:
Subsystem 9 - Part No SW: 4M0 816 702 A HW: 4M0 816 702 A
Component: N642 AV4_KaMi H12 0102
Serial number: 00000000000130149532
Refrigerant Shut Off Valve 5:
Subsystem 10 - Part No SW: 4M0 816 702 A HW: 4M0 816 702 A
Component: N643 AV5_KaMi H12 0102
Serial number: 00000000000130149508
37116 - Implausible Data Received from Battery Energy Control Module 2
U0413 00 [040] - -
Mileage: 27433 km
Date: 2018.09.04
Time: 07:43:52
Expanded ambient data 1-Voltage terminal 30: 0.000 V
Expanded ambient data 1-Vehicle speed: 0 km/h
Expanded ambient data 1-System status: Control operation: ignition on
Expanded ambient data 1-Power quota setting by energy management: 00
Expanded ambient data 1-Status of drive readiness hybrid: Engine start
Expanded ambient data 1-Ambient temperature: 14.50 °C
Expanded ambient data 1-current state of low temp.circ.: 00
Expanded ambient data 1-previous state low-temp.circ.: 00
Expanded ambient data 1-Operating time in the current state of the low temp.circ.: 00
Expanded ambient data 1-current state of high-temp.circ.: 00
Expanded ambient data 1-previous state of high-temp.circ.: 00
Expanded ambient data 1-Operating time in the current state of the high temp.circ.: 00
Expanded ambient data 1-current state of battery low temp.circ.: 00
Expanded ambient data 1-previous state of battery low temp.circ.: 00
Expanded ambient data 1-Operating time in current state of the battery low temp.circ.: 01
Expanded ambient data 1-current state of battery cold circuit: 00
Expanded ambient data 1-previous state of battery cold circuit: 00
Expanded ambient data 1-Operating time in the current state of the cold circuit: 01
37134 - Implausible Data Received from Battery Energy Control Module 2
U0413 00 [040] - -
Mileage: 27433 km
Date: 2018.09.04
Time: 07:43:52
60016 - Unknown Error Code
P13F1 00 [047] - -
Fault Frequency: 146
Mileage: 26608 km
Date: 2018.08.08
Time: 10:13:22
Expanded ambient data 1-Power quota setting by energy management: 15
Expanded ambient data 1-Ambient temperature: 27.00 °C
Expanded ambient data 1-current state of battery low temp.circ.: 07
Expanded ambient data 1-Operating time in current state of the battery low temp.circ.: 21
Expanded ambient data 1-Operating time in the current state of the cold circuit: 23
Address C6: Batt. Chrg. (AX4) Labels:* 5QE-915-681.clb
Part No SW: 5QE 915 681 G HW: 5QE 915 681 G
Component: OBC Delta-ES H55 0721
Coding: 11508B207004
ASAM Dataset: EV_OBCTwoPhaseDT2AU736 006011
ROD: EV_OBCTwoPhaseDT2AU736_006_AU73.rod
VCID: 50A50F990B935FC4F4-8004
13705528 - Databus
Reset counter: 226
Mileage: 26623 km
Date: 2018.08.13
Time: 08:23:37
Address CA: Sunroof
Address CF: Lane Chge Asst 2
End-------------------------(Elapsed Time: 07:53)--------------------------
Gateway Installation List: 8W7 907 468 D
C6-Batt. Chrg. -- Status: OK 0000
