Does VCDS have the ability to operate/test the flaps on a 2006 VW Beetle without actually operating the top?
Tuesday,28,August,2018,15:02:55:63037
VCDS Version: 18.2.1.5 (x64) HEX-V2 CB: 0.4411.4
VIN: 3VWSF31Y06M324226 License Plate:
Mileage: 176680km-109783mi Repair Order:
Chassis Type: 1Y (1Y - VW New Beetle Cab (2003 > 2010))
Scan: 01 02 03 08 15 17 19 25 26 29 35 37 39 46 54 56 65 75
VIN: 3VWSF31Y06M324226 Mileage: 176680km-109783miles
Address 01: Engine Labels: 06A-906-032-BGP.lbl
Part No SW: 07K 906 032 B HW: Hardware No
Component: R5 G 7828
Revision: -------- Serial number: VWZ5Z0F2298336
Coding: 0000003
VCID: 2809FBFC2EEC7897194-513C
Readiness: 0110 1101
Part No SW: 09G 927 750 CG HW: 09G 927 750 CG
Component: AQ 250 6F 0759
Revision: 00H27000 Serial number:
Coding: 0000008
VCID: 78A9EBBCBECC2817494-513C
17105 - Transmission Output Speed Sensor (G195)
P0721 - 008 - Implausible Signal - Intermittent
Address 03: ABS Brakes Labels: 1C0-907-37x-ESP-F.lbl
Part No: 1C0 907 379 Q
Coding: 0019978
VCID: 38292BBCFE4CE817894-5160
Address 15: Airbags Labels: 1T0-909-605.lbl
Part No: 6Q0 909 605 AL
Component: 01 AIRBAG VW71 0811
Coding: 0012337
VCID: 015F8658ED1669DF7EA-513C
Subsystem 1 - Part No: 1C0 959 339 F
Component: BF-Gewichtsens. 006 0007
Address 17: Instruments Labels: None
Part No: 1C0 920 501 T
Component: KOMBI+WEGFAHRS. M73 V01
Coding: 11234
Shop #: WSC 00066
VCID: 290FFEF830E6419F06A-4B00
Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
Part No: 6N0 909 901
Component: Gateway K<->CAN V012
Coding: 00006
Shop #: WSC 00066
VCID: 70B9D39CD3BC7057814-4B00
Address 25: Immobilizer Labels: 1C0-920-xxx-25.clb
Part No SW: 1C0 920 501 T HW: 1C0 920 501 T
Component: IMMO X007
Revision: xxxxxxxx Serial number: VWZ5Z0F2298336
VCID: 290FFEF835E6419F06A-513C
Address 26: Auto Roof Labels: 1Y0-959-255-HYD.lbl
Part No: 1Y0 959 255 C
Component: VSG NBC ¤
VCID: 40D9435CA69CA0D7314-513C
00532 - Supply Voltage B+
Address 46: Central Conv. Labels:
VCID: 55F782084C0E357F722-FFFE
Address 56: Radio Labels: 1J0-035-18x-56.lbl
Part No: 1C0 035 196 BG
Component: RADIO DE2 0006
Coding: 06031
Shop #: WSC 00066
VCID: 6597B2C81C7EA5FFE22-51CE
65535 - Internal Control Module Memory Error
00-10 - - - Intermittent
End----------(Elapsed Time: 04:15, VBatt start/end: 14.0V/13.9V)-----------
I'm not aware of any output test support for this Roof Electronics.
Just what issue are you having with the top other than some voltage issue. Does the Comfort Control Module, address 46, communicate? It isn't there in the Auto-Scan and it needs to talk for the top to operate.
erWin is your friendI'm going to see if I can locate a diagram that shows the location of the fuse for the roof electronics. Unfortunately fuse location card is no longer with the car.
