Model | Audi S4 qu. 3.0
Date of production | 08.08.2011
Model year | 2012
Sales type | 8K254Y
Engine Code | CCBA
Transmission Code | NGY
Axle drive | 7A
Equipment | ZM
Roof color | L8
Exterior color / Paint Code | L8 / Z9Y
Saturday,07,March,2020,16:42:26:58782
VCDS Version: 19.6.2.2 (x64) HEX-NET CB: 0.4513.4
Dealer/Shop Name: Somnus
VIN: WAUKGAFL5CA037004 License Plate:
Mileage: 91600km-56917mi Repair Order:
Chassis Type: FL-AU48 (8T0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 22 36 3C 42 46 47 52 53
55 56 5F 62 6C 72
VIN: WAUKGAFL5CA037004 Mileage: 91600km-56917miles
Address 01: Engine (J623-CCBA) Labels:. 06E-907-551-CAK.clb
Part No SW: 8K0 907 551 D HW: 8K0 907 551 A
Component: 3.0T SIMOS84 H08 0003
Revision: --H08---
Coding: 0104000A240F0228
Shop #: WSC 06324 000 00000
ASAM Dataset: EV_ECM30TFS0218K0907551D 001003
ROD: EV_ECM30TFS0218K0907551D.rod
VCID: B22876D3E5CA7FDFE3-80E6
Address 02: Auto Trans (J217) Labels:| 0B5-927-156.clb
Part No SW: 8K2 927 156 S HW: 0B5 927 156 F
Component: 0B5 30TFSINAR H10 0001
Revision: --H10--- Serial number: 0000000815
Coding: 000001
Shop #: WSC 06325 000 00000
ROD: EV_TCMDL501.rod
VCID: C6C03A037942F37F5F-8092
9473 - Sensor for Gear Actuator 2
P17E1 00 [096] - Mechanical Malfunction
Part No SW: 8K0 907 379 BJ HW: 8K0 907 379 BJ
Component: ESP8 quattro H04 0060
Coding: 290D1A
VCID: 8248E6131DEA0F5F33-80D6
Part No SW: 8K0 907 064 CG HW: 8K0 907 064 CG
Component: BCM2 2.0 H05 0435
Coding: 0D0100
VCID: F7BE87C746285AF714-80A2
Subsystem 1 - Part No SW: 8K0 905 852 D HW: 8K0 905 852 D
Component: J764 ELV MLB H37 0042
Serial number: 2311000157621013
Address 08: Auto HVAC (J255) Labels:. 8Tx-820-043-3Z.clb
Part No SW: 8T1 820 043 AQ HW: 8T1 820 043 AQ
Component: KLIMA 3 ZONEN H08 0180
Revision: C1000000 Serial number: 01300720110524
Coding: 66102000
Shop #: WSC 06342 000 00000
VCID: 804CEC1B13E61D4F25-80D4
00714 - Centre Right Vent Positioning Motor (V111)
001 - Upper Limit Exceeded
Fault Status: 01100001
Fault Frequency: 40
Reset counter: 32
Mileage: 70913 km
Date: 2016.11.04
Time: 13:08:25
Voltage: 14.20 V
Temperature: 21.0°C
Temperature: 15.0°C
Count: 14299
Count: 25000
Bin. Bits: 00000000
Bin. Bits: 00000000
Time: 255.00 s
00710 - Defroster Flap Positioning Motor (V107)
Fault Frequency: 31
Reset counter: 28
Mileage: 80972 km
Date: 2019.09.20
Time: 23:07:56
Voltage: 13.10 V
Temperature: 15.0°C
Temperature: 10.0°C
Count: 11288
Count: 14918
Bin. Bits: 01000000
Bin. Bits: 10000011
Time: 20.00 s
00712 - Right Footwell Flap Positioning Motor (V109)
Fault Frequency: 15
Reset counter: 61
Mileage: 72598 km
Date: 2019.02.02
Time: 12:10:13
Voltage: 14.60 V
Temperature: 18.0°C
Temperature: 11.0°C
Count: 10000
Bin. Bits: 00000000
Bin. Bits: 10001001
Time: 255.00 s
Part No SW: 8K0 907 063 P HW: 8K0 907 063 P
Component: BCM1 1.0 H30 0392
Revision: 10030001 Serial number: 00000000994991
Coding: 26001091063CAF212700080300003D0D0F9CD24802010161000000
VCID: BC3458EB3F8EB9AF39-80E8
Subsystem 1 - Part No SW: 8K1 955 119 A HW: 8T1 955 119 Labels: 1KX-955-119.CLB
Component: WWS 250711 H07 0070
Serial number: SWF11070250102
Coding: 00FD11
Component: RLS H04 0003
Serial number: 11573496
Coding: 025028
Subsystem 3 - Part No SW: 8K0 941 531 AS HW: 8K0 941 531 AS
Component: E1 - LDS H03 0031
Serial number: 00000000001607110226
Subsystem 4 - Part No SW: 8K0 907 410 C HW: 8K0 907 410 C
Component: HOMELINK H01 0010
Address 10: Park/Steer Assist (J446) Labels:. 8K0-919-475.clb
Part No SW: 8K0 919 475 T HW: 8P0 919 475 M
Component: PARKHILFE 4K H01 0081
Revision: 11001001 Serial number: 36891120882785
Coding: 20010D
Shop #: WSC 19506 444 83994
VCID: CAD80E33655A171FBB-809E
Address 13: Auto Dist. Reg (J428) Labels: None
Part No SW: 8K0 907 561 HW: 8K0 907 561
Component: ACC2 H09 0080
Coding: 002B6E
VCID: EFAEBFA73E781237CC-80BA
Address 15: Airbags (J234) Labels:| 8K0-959-655.clb
Part No SW: 8K0 959 655 K HW: 8K0 959 655 K
Component: AirbagVW-AU10 H44 0610
Serial number: 003GLD0NV6WG
Coding: 303837354230303030304A55304C384B3053
VCID: C5C23D0F4444F86756-8090
Subsystem 1 - Part No SW: 8K0 959 339 C HW: 8K0 959 339 C
Component: BF-Gewichtss. H02 0040
Serial number: 5810000R110000601S
Serial number: 6334MSME420619443
Serial number: 6344MSME61745818E
Serial number: 6352QSME0F5D3456S
Serial number: 6362QSME385C2358O
Serial number: 63732SME1E5E536EI
Serial number: 63832SME3F5E3F62K
Part No SW: 8K0 953 568 G HW: 8K0 953 568 G
Component: Lenks.Modul H17 0014
Revision: -------- Serial number: 90372KGP0002Y
Coding: 00003E
VCID: BE3052E32992ABBF17-80EA
Component: E221 - MFL H02 0010
Part No SW: 8K0 920 981 T HW: 8K0 920 981 T
Component: KOMBIINSTR. H10 0258
Revision: 00000000 Serial number: EJP762V7C
Coding: 8B1709008F00D705020000
VCID: C4C4200B477EC16F41-8090
Part No SW: 8T0 907 468 AE HW: 8T0 907 468 L
Component: GW-BEM 5CAN-M H10 0117
Revision: FC100058 Serial number: 5800F117070317
Coding: 00C303
VCID: 8444E00B07FE016F01-80D0
Subsystem 1 - Part No SW: 8K0 915 181 E HW: 8K0 915 181 E
Component: J367-BDM H07 0170
Serial number: 1102B9FA210711
Address 22: AWD (J492) Labels: 8K0-907-163.clb
Part No SW: 8K0 907 163 A HW: 8K0 907 163 A
Component: 4 Wheel Drive H12 0025
Serial number: 001407110001030
ASAM Dataset: EV_AllWheelDiffeQSPCAN 003016
VCID: AE1062A3F1F25B3F87-80FA
Address 36: Seat Mem. Drvr (J136) Labels:. 8T0-959-760.clb
Part No SW: 8K0 959 760 D HW: 8K0 959 760 D
Component: MEM-FS H06 0074
Revision: AA000000 Serial number: 00000011205547
Coding: 00581B00000000000000
VCID: BB365BF73A80BE9730-80EE
Part No SW: 8K0 907 566 H HW: 4L0 907 566 B
Component: J0769_SWA_MasterH01 0030
Revision: 00H01000 Serial number: 6PZ 009 014-82
VCID: BC3458EBFF8EB9AF39-80E8
Subsystem 1 - Part No: 8K0 907 568 H
Component: J0770_SWA_Slave_H01 0030
Subsystem 2 - Serial number: 6PZ 009 014-92
Subsystem 3 - Serial number: 5F21.07.1100H010003C321064ÿ
Subsystem 4 - Serial number: 321064ÿ
Part No SW: 8T0 959 793 M HW: 8T0 959 793 D
Component: TSG FA H08 1501
Coding: 011C13204E00410001
VCID: D3E61357B21056D7C8-8086
Revision: 00002001 Serial number: 0154975047
Coding: 0106023A00FA440580B0013200000000
Subsystem 1 - Part No SW: 8K0 959 719 B HW: 8K0 959 719
Component: GTO BF H01 0070
Serial number: 00000000000000420143
Subsystem 3 - Part No SW: 8K0 959 591 A HW: 8K0 959 591
Component: J245 PS045 H07 0041
Address 47: Sound System (J525) Labels:. 8T0-035-223-BOM.clb
Part No SW: 8T0 035 223 AN HW: 8T0 035 223 AK
Component: DSP Prem H10 0190
Revision: 00010001 Serial number: 34804008262602
VCID: FAB89EF3753A479F6B-80AE
Part No SW: 8T0 959 792 M HW: 8T0 959 792 D
Component: TSG BF H08 1501
VCID: D2E816538D0A5FDFC3-8086
Part No SW: 8K0 907 801 H HW: 8K0 907 801 H
Component: EPB Audi B8 H09 0100
Revision: 00000003 Serial number: 00000000989836
VCID: B42470CB17DE71EFF1-80E0
Address 55: Headlight Range Labels: 8T0-907-357.clb
Part No SW: 8H0 907 357 C HW: 8H0 907 357 C
Component: AFS 1 H01 0040
Revision: 00H01001 Serial number:
Coding: 0000019
VCID: B22876D32DCA7FDFE3-80E6
Subsystem 1 - Part No: 8K0 941 329
Component: AFS-Modul links H02 S001
Subsystem 2 - Part No: 8K0 941 329
Component: AFS-Modul rechtsH02 S001
Part No SW: 4G0 035 082 B HW: 4G0 035 082
Component: Radio U SIRIU H52 0076
Revision: AB001007 Serial number: 156G90B7538896
Coding: 020007010000000001
VCID: 9F0E8F678E58C2B73C-80CA
Part No SW: 8T1 035 664 D HW: 8T1 035 664 B
Component: H-BN-NA H52 0165
Revision: -------- Serial number: 490G$0B7630368
Coding: 010200000206A9EF75000B0E000000030000
VCID: B93A41FF30BC8C8722-80EC
Component: NAR 2011 0505
Subsystem 2 - Part No SW: 8F0 919 604 HW: 8F0 919 604
Component: DU7 High H43 0084
Serial number: 9466GX0B0629142
Subsystem 3 - Part No SW: 8T0 919 609 G HW: 8T0 919 609 G
Component: E0380 Bedient H08 0100
Serial number: 00000000888620
Component: CD-Database 2712
Part No SW: 8T0 959 795 N HW: 8T0 959 795 B
Component: TSG HL H06 1501
Coding: 010C13204000210001
VCID: D6E0EA43A1E243FF2F-8082
Address 6C: Back-up Cam. Labels: 8T0-907-441.clb
Part No SW: 8T0 907 441 C HW: 4L0 907 441 B
Component: J772__Rearview 0040
Revision: --H05--- Serial number: 525PA8-J1X914W
Coding: 1000006
VCID: B83C44FBCBB6958FDD-80EC
03006 - Back-up Camera System not calibrated
Reset counter: 104
Address 72: Door, Rear Right (J389) Labels:. 8K0-959-794.clb
Component: TSG HR H06 1501
End----(Elapsed Time: 02:10, VBatt start/end: 11.9V/11.9V. VIgn 12.0V)-----
