Error 00149 - End of Line Programming not Completed - DCC Suspension
m87a
Bosnia and Herzegovina
C?ID=156900
For everyone with error 00149 - End of Line Programming not Completed, I have found a way to finally clear it. You will have this error if you bought a used unit (replaced) or flashed yours to newer version.
To fix this you need to save your VIN in adaptation channel 30 by saving value 1
Address 14: Susp. Elect. (J250), Login: 06865 Adaptation channell 30 save 1.
After this I had to cycle key two times,or if this doesn't work remove power to electronic fuse 35 and error is gone after that automatically or clear faults.
For basic setting you need to lift your car so that wheel are hung and sensors are reading values,
Address 14: Susp. Elect. (J250) Login: 31564, Basic Settings: channell: 1 Go ON/OFF.
I have flashed my unit from version 69 to 70 and finally to 71. I think that handling is better but could be just my imagination.
hope this will help somebody :)
Jef
HQ
m87a
C?ID=156900
Tuesday,25,August,2015,18:46:04:03082
VCDS Version: 15.7.0.1 (x64)
Data version: 20150729
VIN: WVWZZZ1KZBW145982   License Plate: GTD
Mileage: 60110km-37350mi   Repair Order:
Chassis Type: 1K (7N0)
Scan: 01 02 03 08 09 14 15 16 17 19 25 37 42 44 46 52 55 56 77
VIN: WVWZZZ1KZBW145982   Mileage: 60110km-37350miles
Address 01: Engine (J623-CFGB)       Labels: 03L-906-018-CFF.clb
   Part No SW: 03L 906 018 BC    HW: 03L 907 309 R
   Component: R4 2,0L EDC   X22 7819
   Revision: 42X22---    Serial number: 00000000000000
   Coding: 001D0012040400080000
   Shop #: WSC 92521 052 00000
   ASAM Dataset: EV_ECM20TDI01103L906018BC 003005
   ROD: EV_ECM20TDI01103L906018BC_VW36.rod
   VCID: 6CDD86F58787FD5E9A-8038
   Part No SW: 02E 300 054 H    HW: 02E 927 770 AL
   Component: GSG DSG AG6     511 2601
   Revision: 05351113    Serial number: 00001010130182
   VCID: 1B3F9529DAA9CAE6A3-804E
   Part No SW: 1K0 907 379 BE    HW: 1K0 907 379 BE
   Component: ESP MK60EC1   H31 0108
   Revision: 00H31001
   Coding: 143B600D092600FF281406EC901B0042310800
   VCID: 76E9A49DC1CB378E7C-8022
   Part No SW: 5K0 907 044 EA    HW: 5K0 907 044 EA
   Component: Climatronic   H17 1010
   Revision: 00003001
   Coding: 0000000002
   Shop #: WSC 00015 115 12345
   VCID: 6ED98CFDB19B0F4EB4-803A
   Part No SW: 1K0 937 087 J    HW: 1K0 937 087 J
   Component: BCM PQ35  H   103 0615
   Revision: 00103 AD
   Coding: 66180A3AE8251A0000C80080300089EC47FD0088733D8520E48840240040
   VCID: 38756AA58B5F81FEAE-806C
   Component: Wischer 30101  26  0512
   Coding: 009F95
   Component: RLS 161010 05  54  0403
   Coding: 0730AD
Address 14: Susp. Elect. (J250)       Labels: None
   Component: DAEMPFUNGS-SG H07 0070
   Revision: 00000000    Serial number: 27101007080002
   Coding: 000180
   VCID: 2757B9D956E11E0637-8072
   Part No SW: 5K0 959 655 D    HW: 5K0 959 655 D
   Component: AirbagVW10    037 0606
   Serial number: 003FKRAEYNHY
   Coding: 00003132
   ROD: EV_AirbaVW10SMEVW360_SE36.rod
   VCID: 3B7F75A9B269AAE643-806E
   Serial number: 3572MSME0527135AZZZQ
   Serial number: 3582MSME5F671057ZZZ/
   Serial number: 3512QSME18247539ZZZU
   Serial number: 3522QSME2C527547ZZZ-
   Part No SW: 5K0 953 507 AG    HW: 5K0 953 549 A
   Component: Lenks.Modul   007 0080
   Revision: --------    Serial number:  90422JHO0019J
   Coding: 589A040000
   ROD: EV_SMLSNGKUDS_SE36.rod
   VCID: 75EBA391D4CD3C9675-8020
   Serial number: 0005278
   Coding: 830000
   Part No SW: 5K6 920 871 A    HW: 5K6 920 871 A
   Component: KOMBI         H20 0420
   Coding: 170D00
   VCID: 3261588D65236BAE90-8066
   Part No SW: 7N0 907 530 C    HW: 1K0 907 951
   Component: J533  Gateway H37 0614
   Revision:   H37       Serial number: 061110F2000242
   Coding: 350000
   VCID: 30655285632F59BEE6-8064
   Component: IMMO          H20 0420
   VCID: 6AD180ED8D73E36EE8-803E
Address 37: Navigation (J0506)       Labels: 1T0-035-680.clb
   Part No SW: 1T0 035 680 L    HW: 1T0 035 680 C
   Component: RNS-MID       H42 5238
   Revision: AB001001    Serial number: VWZ6Z7K4333018
   Coding: 04000002040000A00000
   Shop #: WSC 05314 123 12345
   VCID: 3777699986418E86A7-8062
   Subsystem 1 - Part No: 1T0 919 859 C
   Component: EU East V12  8196
00862 - Antenna for GPS Navigation (R50/R52)
                    Fault Frequency: 78
                    Reset counter: 240
                    Mileage: 59748 km
                    Date: 2015.08.17
                    Time: 22:01:04
Address 42: Door Elect, Driver        Labels: 1K0-959-701-MAX3.lbl
   Part No SW: 5K0 959 701 C    HW: 5K0 959 701 C
   Component: Tuer-SG         009 2117
   Coding: 0004214
   VCID: 3261588DAD236BAE90-8066
   Part No: 1K0 909 144 J
   Component: EPS_ZFLS Kl. 179    3001
   Revision: 00H17000
   VCID: 31635781A82550B6E9-8064
Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MAX3.lbl
   Part No SW: 5K0 959 702 C    HW: 5K0 959 702 C
   Coding: 0004470
   VCID: 336F5D89523962A69B-8066
   Coding: 1444956
   VCID: 346D5E955737659E82-8060
   Component: AFS-Lst.-Modul l    0004
   Coding: 00000022
   Coding: 00000022
Address 56: Radio (J0506)       Labels: 1T0-035-680.clb
                    Fault Frequency: 78
                    Reset counter: 240
                    Mileage: 59748 km
                    Date: 2015.08.17
                    Time: 22:01:04
Address 77: Telephone (J738)       Labels: 1K8-035-730.clb
   Part No SW: 1K8 035 730 D    HW: 1K8 035 730 D
   Component: Telefon       H08 6900
   Revision: 00008000    Serial number: 00000A07957277
   Coding: 410120
   Shop #: WSC 00028 028 00001
   VCID: 2A5140ED45F3236E28-807E
End-------------------------(Elapsed Time: 02:28)--------------------------
Dana
Western PA, USA
This is long overdue but I just linked this from the 00149 DTC page.
I believe this has also fixed Golf 5/6 platform Audi Magnetic Ride modules as well (perhaps 8P A3, 8J TT and 42 R8) but I wasn't confident enough to list those chassis types. If that sounds correct we can expand on the Wiki notes in the future.
