I'm trying to do a tweak provided by DV52 to adjust the curves on the cluster light sensor, which requires Security Access to modify the necessary Adaption channels.
I've tried 20103, which DV52 has provide as working on other MK7 Golf platform cars, but it's not accepted on my car no matter what I try. I've tried it with ignition power only and with engine running, but it always says the code is not accepted.
Here's an AutoScan. Note that the malfunctions listed were caused by me when I disconnected the overhead console to install a homelink module.
Wednesday,09,December,2015,09:06:43:43055
VCDS Version: 15.7.3.0
Data version: 20151124
VIN: WVWLF7AU4GW136712 License Plate: 2016VWGOLFR
Mileage: 2182km-1355mi Repair Order:
Chassis Type: AU (5Q0)
Scan: 01 02 03 05 08 09 14 15 16 17 19 22 2B 42 44 52 55 5F 75 A9
VIN: WVWLF7AU4GW136712 Mileage: 2182km-1355miles
Address 01: Engine (J623-CYFB) Labels: 06K-907-425-V1.clb
Part No SW: 8V0 906 259 H HW: 06K 907 425 E
Component: 2.0l R4 TFSI H13 0002
Revision: --H13---
Coding: 091D00122426000E3004
ASAM Dataset: EV_ECM20TFS0208V0906259H 001003
ROD: EV_ECM20TFS0208V0906259H_VW37.rod
VCID: 458BBB3CC409C91602-8010
Part No SW: 0D9 300 012 HW: 02E 927 770 AQ
Component: DQ250-6A MQB H53 4904
Revision: 06253104 Serial number: TFK01508230699
ROD: EV_TCMDQ250021_AU37.rod
VCID: 53AF95643A5D67A69C-8006
Part No SW: 3Q0 907 379 AA HW: 3Q0 907 379 F
Component: ESC H42 0623
Revision: 00000000 Serial number: 62575000000140
Coding: 01FA6BA154230972057E030141C56980D62A90A0C08296B7004000D8C208
VCID: 79F307CCF8717DF636-802C
Address 05: Acc/Start Auth. (J518) Labels: 5Q0-959-435.clb
Revision: 00021000 Serial number: 0381191442
Coding: 030C0C
ROD: EV_KessyHellaMQBAB_AU37.rod
VCID: 3A71D8C0BDF7B6EE7F-806E
Address 08: Auto HVAC (J255) Labels: 5G0-907-044.clb
Part No SW: 5G0 907 044 BD HW: 5G0 907 044 BD
Component: Climatronic H03 1001
Revision: 00001K08
Coding: 00020004100100000005004012111402
ROD: EV_ACClimaBHBVW37X_SK37.rod
VCID: 6AD128808DD7C66ECF-803E
Address 09: Cent. Elect. (J519) Labels: None
Part No SW: 5Q0 937 085 AJ HW: 5Q0 937 085 AF
Component: BCM MQBAB HNA H24 0175
Serial number: 01061526100485
Coding: 00011A46C041A2E169E44000091C07201800000000000000000000000000
ROD: EV_BCMBOSCH_AU37.rod
VCID: 01036F2C90A125367E-8054
Slave 1:
Subsystem 1 - Part No SW: 5G1 955 119 A HW: 5G1 955 119 A Labels: 5QX-955-119-V1.CLB
Component: WWS 150707 043 0551
Serial number: 150804121608
Slave 2:
Subsystem 2 - Part No SW: 5Q0 955 547 A HW: 5Q0 955 547 A Labels: 5Q0-955-547.CLB
Component: RLHS 037 0059
Serial number: S4Y15M08D20H08M24S55
Coding: 90A8DD
0263 - Supply Voltage for Interior Lights
B1314 11 [008] - Short to Ground
Reset counter: 70
Mileage: 1849 km
Date: 2015.11.21
Time: 16:18:06
Address 14: Susp. Elect. (J250) Labels: 5Q0-907-376.clb
Part No SW: 5Q0 907 376 A HW: 5Q0 907 376 A
Component: DAEMPFUNGS-SG H17 0120
Serial number: 28091541350477
ROD: EV_DRCONTITEMIC.rod
VCID: 3777C1F48EE5AB8680-8062
Component: AirbagVW20 010 0830
Serial number: 003GCR03H5SP
VCID: 4797B134FE05DB06F0-8012
Seat occupant detection; front passenger side:
H11 0021
Serial number: IBH0000000000034ZH8R
Coding: 42462D4765776963687473732E
Subsystem 2 - Part No SW: ----------- HW: 480 001 609 15
Serial number: 35700000000CDC45661V
Subsystem 3 - Part No SW: ----------- HW: 480 001 609 15
Serial number: 358000000009748C561P
Component: ----------- 001 6149
Serial number: 3510002AD1D25F7112D8
Subsystem 5 - Part No SW: ----------- HW: 480 402 109 15
Serial number: 3520002AB1D1B5D160DB
Subsystem 6 - Part No SW: ----------- HW: 480 402 109 15
Serial number: 3550002C11CF2DA4B28K
Subsystem 7 - Part No SW: ----------- HW: 480 402 109 15
Serial number: 3560002C11CF2DA5A22F
Address 16: Steering wheel (J527) Labels: 5Q0-953-549.clb
Part No SW: 5Q0 953 507 HL HW: 5Q0 953 549 E
Component: Lenks. Modul 003 0110
Revision: -------- Serial number: 18091508490846
Coding: 0410
ROD: EV_SMLSKLOMQB_SE37.rod
VCID: 07177134BE851B0630-8052
Part No SW: 5G1 920 858 A HW: 5G1 920 858 A
Component: KOMBI 303 6420
Coding: 0BAD081A3B80CF0502087A001400000000000000
VCID: 2E59E49071BF6A4ED3-807A
Part No SW: 5Q0 907 530 AF HW: 5Q0 907 530 F
Component: GW MQB High 128 1223
Revision: -------- Serial number: 0003980871
Coding: 0101000830085900FB00022A9C0F00000001050000000000000000000000
ROD: EV_GatewLear.rod
VCID: 75EB0BFCD469199652-8020
Subsystem 2 - Part No SW: 5G0 959 442 Q HW: 5G0 959 442 Q
Component: E221__MFL-DC1 H10 0101
Serial number: 29150001812010035385
Coding: 31FFFF
Address 22: AWD (J492) Labels: 0CQ-907-554.clb
Part No SW: 0CQ 907 554 H HW: 0CQ 525 130
Serial number: HA1-00010.08.15
Coding: 0001
ROD: EV_AllWheelContrHA1VW37X_AU21.rod
VCID: 4A918800ED17266EEF-801E
Address 2B: Steer. Col. Lock (J764) Labels: 5Q0-905-861.clb
Component: ELV-MQBA H01 0120
Revision: 00000000 Serial number: 15000214022006
Coding: 5D00000000000000
ROD: EV_ELVMarquMQB_AU37.rod
VCID: 346DF6F89F93409EA5-8060
Component: TSG FS 020 0041
Serial number: 060915BI505416
Coding: 003E13208000040000000000
ROD: EV_DCUDriveSideEWMAXCONT_AU37.rod
VCID: 438FA524CA3DF7262C-8016
Subsystem 1 - Part No SW: 5Q0 959 811 HW: 5Q0 959 811
Serial number: 00000000000007354588
Coding: 111000
Part No SW: 3Q0 909 144 J HW: 3Q0 909 144 H
Component: EPS_MQB_ZFLS 505 5063
Coding: 8102
ROD: EV_SteerAssisMQB.rod
VCID: 3973C7CCB8F1BDF676-806C
Component: TSG BFS 020 0041
Serial number: 100915BI915411
Coding: 003E13208000040000800000
ROD: EV_DCUPasseSideEWMAXCONT_AU37.rod
VCID: 4281A020D527FE2E27-8016
Subsystem 1 - Part No SW: 5Q0 959 812 HW: 5Q0 959 812
Serial number: 00000000000007504944
Coding: 091000
Address 55: Headlight Range (J745) Labels: 7P6-907-357.clb
Part No SW: 7P6 907 357 D HW: 7P6 907 357 A
Component: AFS-ECU H07 0090
Coding: 022202010B000400
ROD: EV_HeadlRegulVWAFS_SE26.rod
VCID: 4085AA28DB2BEC3E31-8014
Subsystem 1 - Part No SW: 3D0 941 329 E HW: 3D0 941 329 E Labels: 3D0-941-329.CLB
Component: LeiMo links H01 0002
Coding: 2E0000
Subsystem 2 - Part No SW: 3D0 941 329 E HW: 3D0 941 329 E Labels: 3D0-941-329.CLB
Component: LeiMo rechts H01 0002
Coding: 2E0000
Part No SW: 3Q0 035 876 HW: 3Q0 035 876
Component: MU-S-NS-US H25 0245
Serial number: VWZAZ2R0415075
Coding: 027300020000000051220002001808001F0207F401200105C6
ROD: EV_MUStd4CTSAT_VW26.rod
VCID: 71E33FECA00135B68E-8024
Media Player Position 1:
Subsystem 1 - Part No SW: 5GM 919 605 HW: 5GM 919 605
Component: ABT_Std-2_Nav H52 1028
Serial number: VWZ8Z9RFC0087X
Engine Control Module 2:
Subsystem 2 - Part No SW: 3G0 919 866 B HW: -----------
Component: NAR 2015/16 --- 0220
Address 75: Telematics (J949) Labels: 5QE-035-285.clb
Part No SW: 5QE 035 285 A HW: 5QE 035 285 A
Component: OCULowMQBUS 007 0568
Coding: 02730002C2821A017F1E06020000
ROD: EV_OCULowMQB.rod
9455635 - Microphone 1
B129B 13 [008] - Open Circuit
Reset counter: 79
Mileage: 1849 km
Date: 2015.11.21
Time: 12:35:41
9458195 - Control Module for Cellular Telephone
B1052 13 [008] - Open Circuit
Reset counter: 79
Mileage: 1849 km
Date: 2015.11.21
Time: 12:35:41
Address A9: Struct. Borne Sound (J869) Labels: 4H0-907-159.clb
Part No SW: 5G0 907 159 D HW: 4H0 907 159 A
Component: SAS-GEN 2 H07 0001
Serial number: 150908201144
VCID: 2F67F99476B56346D8-807A
End-------------------------(Elapsed Time: 04:55)--------------------------
