MK7 GTI and R DSG Reset of Adaption procedure
George Smooth
New Member
South Africa
Is there a specific procedure to follow when resetting the DSG adaptions on the GTI and R.
Thanks,
Please post Auto-Scan(s) from the cars in question so we can see what they're made of.
George Smooth
New Member
South Africa
There are no faults present. I do tuning for Burger Motorsport and we have had a few 7 R's that shudder. Some can go to the dealer for reset but it would help if I knew the VCDS procedure.
Thanks.
I didn't ask for an Auto-Scan to see if faults are present. ;)
George Smooth
New Member
South Africa
Golf 7 R
VCDS Version: Release 15.7.0 (x64) Running on Windows 7 x64
Data version: 20150820
Sunday,20,September,2015,16:21:52:30230
Chassis Type: AU (5Q0)
Scan: 01 02 03 05 08 09 10 14 15 16 17 19 22 2B 42 44 52 55 5F A9
VIN: WVWZZZAUZEW243160   Mileage: 8382km-5208miles
Address 01: Engine (J623-CJXB)       Labels: 06K-907-425-V1.clb
   Part No SW: 5G0 906 259 B    HW: 06K 907 425 B
   Revision: --H13---
   Coding: 091D00322426050B3004
   ASAM Dataset: EV_ECM20TFS0205G0906259B 001003
   ROD: EV_ECM20TFS0205G0906259B_VW37.rod
   VCID: 2D57B12B7C672856CE-8078
Readiness: 1110 0001
   Part No SW: 0D9 300 011 R    HW: 02E 927 770 AQ
   Component: DQ250-6A MQB  H52 4311
   Revision: 05852204    Serial number: TFK01312021995
   ROD: EV_TCMDQ250021_AU37.rod
   VCID: 2441540F2FADE91E11-8070
   Revision: 00000000    Serial number: 63403000000709
   Coding: 01FA93A15424296F0378070641C36980C92A94C0E08296F7004200B8C208
   VCID: 7BF34F73F29376E600-802E
   Revision: 00021000    Serial number: 0322002274
   Coding: 030C0C
   ROD: EV_KessyHellaMQBAB_AU37.rod
   VCID: 3A7D8A77BD298FEE5B-806E
   Part No SW: 5G0 907 044 AA    HW: 5G0 907 044 AA
   Component: Climatronic   H02 0805
   Revision: 00001K06
   Coding: 00120014200100001005000012101800
   ROD: EV_ACClimaBHBVW37X_SK37.rod
   VCID: 66C50E079911DB0ECF-8032
   Part No SW: 5Q0 937 084 AE    HW: 5Q0 937 084 AE
   Component: BCM MQBAB H   H16 0124
   Serial number: 00011334600228
   Coding: 03111A46C24122F30BA44080B10C07281800000000000000000000000000
   ROD: EV_BCMBOSCH_AU37.rod
   Slave 1:
   Component: WWS    131207  042 0551
   Serial number:         131210024235
   Slave 2:
   Component: RLFS  024 0042
   Serial number: Y13M12D13H21M39S56S8
   Coding: 00A8DD
   Serial number: 000000000ZY1331021VZ
   Serial number: 00000000000058181145
   Subsystem 5 - Part No SW: 8V3 959 591     HW: 8V3 959 591
   Component: J245 PS73.013  H02 0007
   Serial number:     WOO2598516A
   Coding: 181801
Address 10: Park/Steer Assist (J791)       Labels: 5Q0-919-294.clb
   Part No SW: 5Q0 919 294 F    HW: 5Q0 919 294 A
   Component: PARKHILFE 8K  H03 0142
   Revision: --------    Serial number: 39331335100849
   Coding: 0031151011
   ROD: EV_EPHVA18AU3700000_SK48.rod
   VCID: 3E758667A101A3CE67-806A
   Part No SW: 5Q0 907 376     HW: 5Q0 907 376
   Component: DAEMPFUNGS-SG H15 0115
   Serial number: 27111341350254
   ROD: EV_DRCONTITEMIC.rod
   VCID: 76E55E47C9B12B8E7F-8022
   Component: AirbagVW20    014 0385
   Serial number: 003F6R039PVX
   VCID: 418FFD9BD0FFDC361A-8014
   Subsystem 1 - Part No SW: -----------    HW: 480 000 712 13
   Serial number: 35767000000173156E0M
   Subsystem 2 - Part No SW: -----------    HW: 480 000 712 13
   Serial number: 3586700000047335BD0W
   Subsystem 3 - Part No SW: -----------    HW: 480 400 712 13
   Serial number: 3516502C91220565934.
   Subsystem 4 - Part No SW: -----------    HW: 480 400 712 13
   Serial number: 3526502C51220765D21-
   Subsystem 5 - Part No SW: -----------    HW: 480 400 612 13
   Serial number: 3556502A51220565711S
   Part No SW: 5Q0 953 507 EA    HW: 5Q0 953 549 C
   Revision: --------    Serial number: 10121304221556
   Coding: 0410
   ROD: EV_SMLSKLOMQB_SE37.rod
   VCID: 79FF557BF8AF44F612-802C
   Part No SW: 5G6 920 870 B    HW: 5G6 920 870 B
   Component: KOMBI         314 2210
   Coding: 27AD0818BB80000800086A00040000
   VCID: 2E55B6277161534EF7-807A
   Revision: --------    Serial number: 0001363722
   Coding: 030100042B085900EF00026A9C0F00010001000000000000000000000000
   ROD: EV_GatewLear.rod
   VCID: 3F8BFB63A60BAAC66C-806A
   Subsystem 2 - Part No SW: 5G0 959 442 M    HW: 5G0 959 442 M
   Component: E221__MFL-DC1  H06 0101
   Serial number: 27130001947850093491
   Coding: 29FFFF
   Serial number: 9262102103
Address 22: AWD (J492)       Labels: 0CQ-907-554.clb
   Part No SW: 0CQ 907 554 D    HW: 0CQ 907 554 D
   Component: Haldex4Motion H52 7076
   Serial number: HA1-00021.10.13
   Coding: 0001
   ROD: EV_AllWheelContrHA1VW37X_AU21.rod
   VCID: 4685EE87F9D1FB0E2F-8012
   Revision: 00000000    Serial number: 13000278102005
   Coding: DD00000000000000
   ROD: EV_ELVMarquMQB_AU37.rod
   VCID: 3461A44F9F4D799E81-8060
   Serial number: 07121302090870
   Coding: 003E12208001040000001000
   ROD: EV_DCUDriveSideEWMAXCONT_AU37.rod
   VCID: 4089F89FDBF5D53E15-8014
   Subsystem 1 - Part No SW: 5Q0 959 812 A    HW: 5Q0 959 812 A
   Serial number: 00000000000001339837
   Coding: 1D0000
   Coding: 8103
   ROD: EV_SteerAssisMQB.rod
   VCID: 3567994B94376096B6-8060
   Serial number: 08121304081303
   Coding: 003E10208E01040000801000
   ROD: EV_DCUPasseSideEWMAXCONT_AU37.rod
   Subsystem 1 - Part No SW: 5Q0 959 811 A    HW: 5Q0 959 811 A
   Serial number: 00000000000001329009
   Coding: 050000
   Part No SW: 7P6 907 357 A    HW: 7P6 907 357 A
   Coding: 02A602000B010200
   ROD: EV_HeadlRegulVWAFS_SE26.rod
   VCID: 3D77816BAC07B8D67E-8068
   Subsystem 1 - Part No SW: 3D0 941 329     HW: 3D0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo links  H05 0012
   Coding: 2E0000
   Subsystem 2 - Part No SW: 3D0 941 329     HW: 3D0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H05 0012
   Coding: 2E0000
   Part No SW: 5G0 035 045 B    HW: 5G0 035 045
   Component: MU-H-N-RW     H42 0291
   Serial number: A311K0D7502804
   Coding: 02730009FF00000011110001000900001F0207D60100010057
   ASAM Dataset: EV_MUHig4CHBAS 001040
   ROD: EV_MUHig4CHBAS_VW37.rod
   VCID: 1F4B5BE306CBCAC64C-804A
   Media Player Position 1:
   Component: ABT_High  H51 0022
   Serial number: VWZ8Z9NJ6006Z4
   Engine Control Module 2:
   Subsystem 2 - Part No SW: V03 959 800 TJ    HW: -----------
   Component: ROW 2014  --- 0030
   Door Electronics Rear Left:
   Component: Gracenote  --- 4005
   Part No SW: 5G0 907 159 B    HW: 4H0 907 159 A
   Component: SAS-GEN 2     H07 0006
   Serial number: 131113201745
End-------------------------(Elapsed Time: 04:16)--------------------------
OK, 09D / DQ250. My understanding is we do not currently have a calibration procedure for that transmission. However, we did recently get regular access to a car that has such a transmission, and will hopefully be able to develop a procedure for it.
PS: Please register your system for support by filling out this form so we can make you a Verified User here.
DV52
C?ID=194404
Uwe: I'm always ecstatic when I hear about RT's developments for the mk7 (purely and unashamedly for self serving reasons)! Will the calibration procedure that you mention above extend generally to the DQ200 series transmissions, or do you anticipate that it will apply solely to the DQ250 box?
Don, to be honest, at this point, I do not know.
Jetta 97
Dallas (McKinney) ,TX ,USA
C?ID=81680
Thanks.
Of topic.
I do not think shuddering will go away with adaptation.
You need to tune DGS, Shuddering /hard shift comes when Torque limit in DSG vs ECU is pass.
Same thing with TDI when you tune them.
Anyway if you think this will go away let customer drive 500-700miles and transmission will adopt it self.
BJAsayHEY
C?ID=185589
Uwe,
Any update on availability of 0D9 adaptation procedure?
Bryan
Dana
Western PA, USA
Bryan,
We are looking into that procedure. Does your vehicle have any functionality issues or fault codes? Either way, posting the Auto-Scan from it couldn't hurt.
MN6845
C?ID=81942
First time poster, long time basic user.
I am also having DSG Shutter, here is a scan of my transmission if it helps.
Part No SW: 0D9 300 041 T HW: 02E 927 770 AQ
Component: DQ250-6F MQB H53 4511
Revision: 05853104 Serial number: TFK01412290295
Shop #: WSC 00066 790 00221
VCID: 2977331948B098762A-807C
I am trying to avoid a DSG flash, with light acceleration the transmission shifts smoothly. With aggressive acceleration it shutters during shifts in full automatic. If in manual mode with aggressive acceleration it shifts like it should without a shutter.
Thanks for the help
MN6845
C?ID=81942
I did find my problem, channel 02:Auto Trans had a few fault codes that needed cleared, cleared the fault codes, and everything returned to normal.
Dana
Western PA, USA
7/28/2016 in ref to FS#1085 | E?ID=313560 | E?ID=310418
I'm bumping this back up from the dead. As of our latest Beta 16 series it should be possible to run Basic Settings on the 09D / DQ250 transmission. If the a Beta version is not available using the above link in the future simply download the latest Release instead.
Because the actual procedure has not been thoroughly tested we would prefer registered users to contact us directly via email. After sending the complete Auto-Scan with the vehicle repair history in addition to any vehicle functionality concerns directly to Support we will pass along the procedure on a case by case basis to receive feedback. When the procedure is confirmed we will post it openly online, most likely in this thread initially and moved to a Wiki page after it is bug free.
10/6/2016 edit. I'm updating this so I can locate it later. This thread contains discussion about about some of the additional BS groups. http://forums.ross-tech.com/showthread.php?7860-DSG-VW-Golf-GTI-MK7-Grateful-for-some-help
Dana
Western PA, USA
I have an update. We were able to test this on a 2015 A3 convertible with Engine Code CNTC and Transmission Code QSN :
Prerequisites:
Transmission fluid temperature between 30°C - 100°C confirmed using Advanced Measuring Values:
** IDE00102 Control Module temperature
** IDE00024 Transmission fluid temperature
Selector lever in Park
Engine idle speed, do not press accelerator pedal
Parking brake and foot brake applied during the entire procedure. This can be confirmed using Advanced Measuring Values:
* IDE02713 Brake Light Switch
* IDE02714 Brake test switch
0D9 - DQ250 MQB - Basic Settings Procedure:
[Select]
[02- Auto Trans]
[Basic Settings-04]
Select [Basic settings of transmission]
[Show Measuring Data] and select:
* IDE00021 Engine speed
* IDE00322 Status of basic setting
[Go!]
- During the basic setting procedure, there may be some loud gear shifting noises from the transmission, this is normal.
Basic settings may not complete successfully if:
- The fluid temperature gets too hot.
- Brake is released
- Engine RPM is increased
Once complete, there should be an indication of this in the [Status of Basic Settings] Advanced Measuring Value group and Basic Settings should report Finished Correctly..
[Done, Go Back] and Check for fault codes. If you have several Intermittent fault codes stored please [Save] them before clearing so the text can be pasted here with any feedback you happen to have.
The IDE numbers in the above procedure may need to be revised due to the recent VCDS dataset revisions but the text descriptions should be identical. Based on my personal experience I would consider this Basic Setting procedure successful but there are a number of additional Basic Setting groups that need to be tested.
This vehicle was not broken but it had fault codes stored in the Auto Transmission before Basic Settings. For that reason I ran control module maps before and after clearing codes:
;SW:0D9-300-012-K   HW:02E-927-770-AQ ---  Auto Trans
;Component:DQ250-6A MQB  H53 4515     Coding:0014
;EV_TCMDQ250021    1001    EV_TCMDQ250021.rod
;Thursday    20    October    2016
;VCDS Version: Release 16.8.3 (x64)  Data version: 20161010 DS267.0
;VCID: 1E7F5DDD019534B2AE-804A
Group    Description    Actual
IDE00018    Voltage terminal 15    13.5     V
IDE00019    Voltage terminal 30    13.8     V
IDE00021-ENG99543    Engine speed-Engine RPM    695     /min
IDE00022-ENG103074    Transmission input speed-Transmission Input Speed Sensor    698     /min
IDE00024    Transmission fluid temperature    38     °C
IDE00075-ENG99967    Vehicle speed-Vehicle Speed Sensor    0     km/h
IDE00086-ENG98363    Accelerator position-Accelerator pedal position    0     %
IDE00091-ENG101172    Status of starter lock-Status Engine Starter Lock    Activate
IDE00094    Kick-down status    OFF
IDE00095-ENG101643    Status of selector lever lock-Status Shift Lock    active
IDE00096-ENG100569    Selector lever position-Shift Position    Position P Stop
IDE00102-ENG102028    Control Module temperature-Control modul temperature    45     °C
IDE00130-ENG103124    Transmission specified idle RPM-Idle Speed Commanded Value    600     /min
IDE00322-ENG100540    Status of basic setting-Basic Settings Status    0
IDE00323-ENG09093    Security Access: Number of invalid keys-Counter Value    0
IDE00451-ENG103018    Currently running routine-Current Test Routine    0
IDE00872-ENG102188    Current of main pressure valve-Oil Pressure Actual Current    819.5     mA
IDE01588-ENG101855    Driving direction-M015 SvnNAbRichtung    not known
IDE02221    Engine torque: qualification    valid
IDE02713    Brake Light Switch    not activated
IDE02714    Brake test switch    not activated
IDE02717-ENG102076    Tiptronic upshift-Tiptronic Up    OFF
IDE02718-ENG101063    Tiptronic downshift-Tiptronic Down    OFF
IDE02719-ENG99606    Selector lever position made plausible-Shift Position Plausible    P
IDE02720-ENG103810    Transmission input speed (RPM) shaft 1-Transmission Input Speed Shaft 1    0     /min
IDE02721-ENG100916    Transmission input speed (RPM) shaft 2-Transmission Input Speed Shaft 2    0     /min
IDE02722-ENG101964    Transmission output speed (RPM) shaft 1-Transmission Output Speed Shaft 1    0     /min
IDE02723-ENG100382    Transmission output speed (RPM) shaft 2-Transmission Output Speed Shaft 2    0     /min
IDE02735-ENG100209    Display of driving mode in instrument panel-Display Driving Position    P
IDE02736-ENG100252    Display of gear in instrument panel-Display Driving Gear    no gear engaged
IDE02790-ENG104124    Specified torque clutch 1-Clutch 1 Commanded Torque    -600     Nm
IDE02796-ENG103463    Current of valve for clutch 1 specified value-Current Valve Clutch 1 Commanded Value    0     mA
IDE02797-ENG100730    Current of valve for clutch 1 actual value-Current Valve Clutch 1 Actual Value    0.5     mA
IDE02800-ENG100171    Specified torque clutch 2-Clutch 2 Commanded Torque    -600     Nm
IDE02805-ENG99237    Current of valve for clutch 2 specified value-Current Valve Clutch 2 Commanded Value    0     mA
IDE02806-ENG103118    Current of valve for clutch 2 actual value-Current Valve Clutch 2 Actual Value    0.1     mA
IDE02862-ENG103213    Production data transmission-Aggregatekennzeichnung (Getriebe)    6
IDE02862-ENG103083    Production data transmission-Baudatum    150326
IDE02862-ENG104019    Production data transmission-Getriebekennbuchstabe    QSN
IDE02862-ENG99175    Production data transmission-Kassel    K
IDE02862-ENG101707    Production data transmission-Kennung der Montagelinie    0
IDE02862-ENG103830    Production data transmission-Lfd.-Nr    863
IDE02864-ENG99505    Actual position of gear positioner A-Gearpositioner A Actual Position    0.14     mm
IDE02865-ENG104121    AD value 1 of actual position of gear positioner A-Gearpositioner A Actual Position AD Value 1    2088
IDE02870-ENG120871    Duty cycle of gear solenoid valve A-Gearpositioner_A_Valve_Duty_Factor    0     %
IDE02872-ENG102218    Actual position of gear adjuster B-Gearpositioner B Actual Position    -8.1     mm
IDE02873-ENG101728    AD value 1 of actual position of gear positioner B-Gearpositioner B Actual Position AD Value 1    1058
IDE02878-ENG120875    Pulse duty factor of gear solenoid valve B-Gearpositioner_B_Valve_Duty_Factor    0     %
IDE02880-ENG103036    Actual position of gear positioner C-Gearpositioner C Actual Position    -0.14     mm
IDE02881-ENG99453    AD value 1 of actual position of gear positioner C-Gearpositioner C Actual Position AD Value 1    2072
IDE02886-ENG120879    Pulse duty factor of gear solenoid valve C-Gearpositioner_C_Valve_Duty_Factor    0     %
IDE02888-ENG103826    Actual position of gear positioner D-Gearpositioner D Actual Position    -8.21     mm
IDE02889-ENG100525    AD value 1 of actual position of gear positioner D-Gearpositioner D Actual Position AD Value 1    1203
IDE02894-ENG120883    Duty cycle of gear solenoid valve D-Gearpositioner_D_Valve_Duty_Factor    0     %
IDE03008-ENG122550    Stop process prevented-GE_StartStopp_Info    Stop release
IDE03008-ENG122551    Stop process prevented-MO_StartStopp_Status    0
IDE03008-ENG122546    Stop process prevented-Stopp-Verbot-Grund 1    not active
IDE03008-ENG122547    Stop process prevented-Stopp-Verbot-Grund 2    not active
IDE03008-ENG122548    Stop process prevented-Stopp-Verbot-Grund 3    not active
IDE03008-ENG122549    Stop process prevented-Stopp-Verbot-Grund 4    not active
IDE03008-ENG122552    Stop process prevented-Stopp-Verbot-Grund 5    not active
IDE03008-ENG122553    Stop process prevented-Stopp-Verbot-Grund 6    not active
IDE03008-ENG122554    Stop process prevented-Stopp-Verbot-Grund 8    not active
IDE03171-ENG102987    Driving strategy transmission mileage-Q002 Total Driving Time    16679.2     km
IDE03172-ENG100789    Driving strategy driving portions in D or S w/ CCS-Q003 Driving Time Ecological    98     %
IDE03173-ENG103567    Driving strategy driving portions in S w/o CCS-Q004 Driving Time Sporty    0     %
IDE03174-ENG100415    Driving strategy driving portions in Tiptronic-Q005 Driving Time Manual    0     %
IDE03180-ENG103176    Number of standard trips-General Denominator    554
IDE03181-ENG102823    Number of ignition cycles-Ignition Cycle Counter    2420
IDE03182-ENG120927    Lower adapted coupling point K1 from kiss point adaptation-lower_Adapted_Clutchpoint_K1_Of_Kisspoint_Adaption    0.27     A
IDE03183-ENG120930    Lower adapted coupling point K2 from kiss point adaptation-lower_Adapted_Clutchpoint_K2_Of_Kisspoint_Adaption    0.245     A
IDE03184-ENG120928    Upper adapted coupling point K1 from microslip adaptation-Upper_Adapted_Clutchpoint_K1_Of_Microslip_Adaption    0.825     A
IDE03185-ENG120929    Upper adapted coupling point K2 from microslip adaptation-Upper_Adapted_Clutchpoint_K2_Of_Microslip_Adaption    0.75     A
IDE03189-ENG110507    Number of prevented stop processes (statistics)-Anzahl Stoppverbote    0
IDE03189-ENG110509    Number of prevented stop processes (statistics)-Gründe für Stoppverbot    not active
IDE03189-ENG110508    Number of prevented stop processes (statistics)-km-Stand des letzten Stoppverbots    0     km
IDE04612-ENG101246    Clutch temperature air / splash oil-Centrifugal oil temperature    38     °C
IDE04805-ENG98547    Driving profile selection-Driving program    Available
IDE04805-ENG98560    Driving profile selection-Free run    not_available
IDE05987-ENG110507    Engine stop prohibitions-Anzahl Stoppverbote    0
IDE05987-ENG110509    Engine stop prohibitions-Gründe für Stoppverbot    not active
IDE05987-ENG110508    Engine stop prohibitions-km-Stand des letzten Stoppverbots    0     km
IDE05988-ENG110505    Pressure of clutch 2: actual value-Clutch_2_actual_value    0.07     bar
IDE05989-ENG110503    Pressure of clutch 1: actual value-Clutch_1_actual_value    0.11     bar
IDE06425    Roller test bench mode: functional    not activated
IDE80001-ENG100467    Analysis 1-Snapshot 1 Failure ID    65535
IDE80002-ENG102386    Analysis 2-Snapshot 1 Mileage    0     km
IDE80003-ENG101467    Analysis 3-Snapshot 1 Counter    0
IDE80005-ENG103330    Analysis 5-Snapshot 1 Shift Position Plausible    ERROR
IDE80007-ENG101090    Analysis 7-Snapshot 1  Commanded Gear    GANG N
IDE80008-ENG100048    Analysis 8-Snapshot 1 Preselection Gear    GANG N
IDE80009-ENG102100    Analysis 9-Snapshot 1 Transmission Input Speed    0     /min
IDE80010-ENG101565    Analysis 10-Snapshot 1 Transmission Output Speed Shaft 1    0     /min
IDE80011-ENG100379    Analysis 11-Snapshot 1 Transmission Speed Shaft 1    0     /min
IDE80012-ENG103459    Analysis 12-Snapshot 1 Transmission Speed Shaft 2    0     /min
IDE80021-ENG102762    Analysis 21-Snapshot 1 Clutch 1 Actual Pressure    0     bar
IDE80022-ENG100347    Analysis 22-Snapshot 1 Clutch 2 Actual Pressure    0     bar
IDE80023-ENG99119    Analysis 23-Snapshot 1 Current Valve Clutch 1 Actual Value    0     mA
IDE80024-ENG101123    Analysis 24-Snapshot 1 Current Valve Clutch 2 Actual Value    0     mA
IDE80025-ENG103611    Analysis 25-Snapshot 1 Accelerator Pedal Position    0     %
IDE80026-ENG101503    Analysis 26-Snapshot 1 Engine torque    -50     Nm
IDE80029-ENG103070    Analysis 29-Snapshot 1 Voltage Terminal 15    0     V
IDE80031-ENG102899    Analysis 31-Snapshot 1 Transmission Fluid Temperature    -60     °C
IDE80033-ENG103098    Analysis 33-Snapshot 2 Failure ID    65535
IDE80034-ENG101047    Analysis 34-Snapshot 2 Mileage    0     km
IDE80035-ENG99915    Analysis 35-Snapshot 2 Counter    0
IDE80037-ENG99369    Analysis 37-Snapshot 2 Shift Position Plausible    ERROR
IDE80039-ENG101369    Analysis 39-Snapshot 2  Commanded Gear    GANG N
IDE80040-ENG103638    Analysis 40-Snapshot 2 Preselection Gear    GANG N
IDE80041-ENG103367    Analysis 41-Snapshot 2 Transmission Input Speed    0     /min
IDE80042-ENG102476    Analysis 42-Snapshot 2 Transmission Output Speed Shaft 1    0     /min
IDE80043-ENG102699    Analysis 43-Snapshot 2 Transmission Speed Shaft 1    0     /min
IDE80044-ENG101900    Analysis 44-Snapshot 2 Transmission Speed Shaft 2    0     /min
IDE80053-ENG102973    Analysis 53-Snapshot 2 Clutch 1 Actual Pressure    0     bar
IDE80054-ENG100122    Analysis 54-Snapshot 2 Clutch 2 Actual Pressure    0     bar
IDE80055-ENG103189    Analysis 55-Snapshot 2 Current Valve Clutch 1 Actual Value    0     mA
IDE80056-ENG103616    Analysis 56-Snapshot 2 Current Valve Clutch 2 Actual Value    0     mA
IDE80057-ENG102447    Analysis 57-Snapshot 2 Accelerator Pedal Position    0     %
IDE80058-ENG103198    Analysis 58-Snapshot 2 Engine torque    -50     Nm
IDE80061-ENG101449    Analysis 61-Snapshot 2 Voltage Terminal 15    0     V
IDE80063-ENG104157    Analysis 63-Snapshot 2 Transmission Fluid Temperature    -60     °C
IDE80065-ENG122555    Analysis 65-Snapshot 1 Weg Gangsteller 1-3    0
IDE80065-ENG122556    Analysis 65-Snapshot 1 Weg Gangsteller 2-4    0
IDE80065-ENG122557    Analysis 65-Snapshot 1 Weg Gangsteller 5-N    0
IDE80065-ENG122558    Analysis 65-Snapshot 1 Weg Gangsteller 6-R    0
IDE80066-ENG122559    Analysis 66-Snapshot 2 Weg Gangsteller 1-3    0
IDE80066-ENG122560    Analysis 66-Snapshot 2 Weg Gangsteller 2-4    0
IDE80066-ENG122561    Analysis 66-Snapshot 2 Weg Gangsteller 5-N    0
IDE80066-ENG122562    Analysis 66-Snapshot 2 Weg Gangsteller 6-R    0
IDE80071-ENG127839    Analysis 71-FID event memory entry 1    FF FF
IDE80071-ENG127848    Analysis 71-FID event memory entry 10    FF FF
IDE80071-ENG127849    Analysis 71-FID event memory entry 11    FF FF
IDE80071-ENG127850    Analysis 71-FID event memory entry 12    FF FF
IDE80071-ENG127840    Analysis 71-FID event memory entry 2    FF FF
IDE80071-ENG127841    Analysis 71-FID event memory entry 3    FF FF
IDE80071-ENG127842    Analysis 71-FID event memory entry 4    FF FF
IDE80071-ENG127843    Analysis 71-FID event memory entry 5    FF FF
IDE80071-ENG127844    Analysis 71-FID event memory entry 6    FF FF
IDE80071-ENG127845    Analysis 71-FID event memory entry 7    FF FF
IDE80071-ENG127846    Analysis 71-FID event memory entry 8    FF FF
IDE80071-ENG127847    Analysis 71-FID event memory entry 9    FF FF
IDE80296-ENG127853    Clutch 1 adaption kiss point part 1 success counter-Clutch 1 adaption part 1 positive case counter    1583
IDE80298-ENG127880    Clutch 2 adaption kiss point part 1 success counter-Clutch 2 adaption part 1 positive case counter    1306
IDE80302-ENG122492    Selector lever information-Datenstand    17
IDE80302-ENG111628    Selector lever information-Part Number    8V1713023G
IDE80302-ENG98856    Selector lever information-Programmability    0
IDE80302-ENG122491    Selector lever information-Programm-Stand    VL
IDE80303-ENG127833    Overall software description-Software full name    F45M
IDE80304-ENG120779    Mechatronics identification DQ250-Änderungsstand BorgWarner    58
IDE80304-ENG120778    Mechatronics identification DQ250-Mechatronik-Identifikation    R12F2198
IDE80305-ENG125922    Parameter set description-Data set name    0D9300012K_4515_NlJF
IDE80312-ENG122524    CAN bus installation information-ACC_06    Unknown
IDE80312-ENG122528    CAN bus installation information-BEM_05    installed
IDE80312-ENG113024    CAN bus installation information-Charisma_01    installed
IDE80312-ENG122522    CAN bus installation information-EPB_01    installed
IDE80312-ENG122525    CAN bus installation information-GRA_ACC_01    installed
IDE80312-ENG122511    CAN bus installation information-TSK_06    installed
ENG120958    Abbruchcode    GSA_ABBRUCH_CODE_OK
ENG122365-ENG104207    Abschaltpfadtest Fehlerursache aus dem SCM-Bit 0    Abschalten ENA erfolgreich
ENG122365-ENG102209    Abschaltpfadtest Fehlerursache aus dem SCM-Bit 1    Abschalten WDA erfolgreich
ENG122365-ENG99197    Abschaltpfadtest Fehlerursache aus dem SCM-Bit 2    EInschalten Endstufen erfolgreich
ENG122365-ENG102937    Abschaltpfadtest Fehlerursache aus dem SCM-Bit 3    Keine Unterspannung im Abschaltpfadtest
ENG122363    Abschaltpfadtest Maximaler AD-Wert im Off-Fall    304
ENG122364    Abschaltpfadtest Minimaler AD-Wert im On-Fall    580
ENG120920    Abtriebsdrehzahl CAN    0     /min
ENG98625-ENG103724    Accelerator position: qualification-Accelerator pedal position: qualification    OK
ENG100091    Ambient temperature    23     °C
ENG120963    Anzahl der Überschreitungen der zulässigen Schleuderöltemperatur    0
ENG120964    Anzahl der Warnungen aufgrund erhöhter Schleuderöltemperatur    0
ENG122366    Anzahl der wegen Unterspannung abgebrochenen Abschaltpfadtests    5817
ENG120970    Anzahl Ereignisse auf K1    0
ENG120972    Anzahl Ereignisse auf K2    0
ENG98482-ENG99180    Checksum of flash-Calibration Checksumme    A5 ED D5 3A
ENG98482-ENG100495    Checksum of flash-Cboot Checksumme    31 82 84 67
ENG98482-ENG100117    Checksum of flash-Checksumme ECU + CAL    00 00 E2 45
ENG98482-ENG102221    Checksum of flash-ECU Checksumme    5F AC DE 77
ENG110530    Clutch 1 adaption kiss point part 1 fault counter    0
ENG110536    Clutch 2 adaption kiss point part 1 fault counter    0
ENG99212    Common highside 1 specified condition    Common Highside soll eingeschaltet werden
ENG99878    Common highside 2 specified condition    Common Highside soll eingeschaltet werden
ENG103403    Converter Loss Torque    6.1     Nm
ENG100625    Coolant temperature    67     °C
ENG98602    Driver request torque    12     Nm
ENG100746    Driving strategy: sport factor    0     %
ENG120931    Eingelegtposition Seite A: Gangsteller 1-3    0     %
ENG120932    Eingelegtposition Seite A: Gangsteller 2-4    0     %
ENG120933    Eingelegtposition Seite A: Gangsteller 5-N    0     %
ENG120934    Eingelegtposition Seite A: Gangsteller 6-R    0     %
ENG120943    Eingelegtposition Seite B: Gangsteller 1-3    0     %
ENG120944    Eingelegtposition Seite B: Gangsteller 2-4    0     %
ENG120945    Eingelegtposition Seite B: Gangsteller 5-N    0     %
ENG120946    Eingelegtposition Seite B: Gangsteller 6-R    0     %
ENG101251    Empty    Empty
ENG98756    Engine torque    12     Nm
ENG104230    Engine torque loss    -21     Nm
ENG123019-ENG99024    Fahrgeschwindigkeit vom Getriebe-Vehicle speed from transmission    0     km/h
ENG120799    Gangsteller A Adaption Flags    00 1F
ENG120808    Gangsteller B Adaption Flags    00 1F
ENG120817    Gangsteller C Adaption Flags    00 15
ENG120826    Gangsteller D Adaption Flags    00 1F
ENG121005    Gangsteller Synchronposition G1 (Prozent)    55.61     %
ENG121006    Gangsteller Synchronposition G2 (Prozent)    45.41     %
ENG121007    Gangsteller Synchronposition G3 (Prozent)    46.08     %
ENG121008    Gangsteller Synchronposition G4 (Prozent)    54.99     %
ENG121009    Gangsteller Synchronposition G5 (Prozent)    53.89     %
ENG121010    Gangsteller Synchronposition G6 (Prozent)    54.41     %
ENG121011    Gangsteller Synchronposition GR (Prozent)    46.65     %
ENG120961    Gangsteller_Index    GS_13
ENG120962    Gangsteller_Seite    Neutrallage
ENG120957    Gangstellerposition zum Zeitpunkt eines Abbruchs    Neutral
ENG120969    Gefahrene km seit letztem Ereignis auf K1    30     km
ENG120971    Gefahrene km seit letztem Ereignis auf K2    30     km
ENG99720    Height info    994     mbar
ENG98604    Hill factor driving strategy    0     %
ENG99596    Indicated engine torque without external interventions    33     Nm
ENG99582    Intake air temperature    2     °C
ENG122357-ENG122524    Kommunikationsstatus Datenbus 1 MQB-ACC_06    Unknown
ENG122357-ENG122528    Kommunikationsstatus Datenbus 1 MQB-BEM_05    received
ENG122357-ENG113024    Kommunikationsstatus Datenbus 1 MQB-Charisma_01    received
ENG122357-ENG122523    Kommunikationsstatus Datenbus 1 MQB-Diagnose_01    received
ENG122357-ENG122522    Kommunikationsstatus Datenbus 1 MQB-EPB_01    received
ENG122357-ENG122513    Kommunikationsstatus Datenbus 1 MQB-ESP_02    received
ENG122357-ENG122514    Kommunikationsstatus Datenbus 1 MQB-ESP_05    received
ENG122357-ENG110808    Kommunikationsstatus Datenbus 1 MQB-ESP_07    received
ENG122357-ENG122515    Kommunikationsstatus Datenbus 1 MQB-ESP_10    Unknown
ENG122357-ENG122516    Kommunikationsstatus Datenbus 1 MQB-ESP_19    received
ENG122357-ENG122517    Kommunikationsstatus Datenbus 1 MQB-ESP_20    received
ENG122357-ENG122518    Kommunikationsstatus Datenbus 1 MQB-ESP_21    received
ENG122357-ENG122519    Kommunikationsstatus Datenbus 1 MQB-Gateway_72    received
ENG122357-ENG122520    Kommunikationsstatus Datenbus 1 MQB-Gateway_74    received
ENG122357-ENG122525    Kommunikationsstatus Datenbus 1 MQB-GRA_ACC_01    received
ENG122357-ENG00240    Kommunikationsstatus Datenbus 1 MQB-Klemmen_Status_01    received
ENG122357-ENG110802    Kommunikationsstatus Datenbus 1 MQB-Kombi_01    received
ENG122357-ENG122521    Kommunikationsstatus Datenbus 1 MQB-Kombi_02    received
ENG122357-ENG110799    Kommunikationsstatus Datenbus 1 MQB-LWI_01    received
ENG122357-ENG122512    Kommunikationsstatus Datenbus 1 MQB-Motor_04    received
ENG122357-ENG122502    Kommunikationsstatus Datenbus 1 MQB-Motor_07    received
ENG122357-ENG122503    Kommunikationsstatus Datenbus 1 MQB-Motor_11    received
ENG122357-ENG122504    Kommunikationsstatus Datenbus 1 MQB-Motor_12    received
ENG122357-ENG122505    Kommunikationsstatus Datenbus 1 MQB-Motor_14    received
ENG122357-ENG122506    Kommunikationsstatus Datenbus 1 MQB-Motor_16    received
ENG122357-ENG122507    Kommunikationsstatus Datenbus 1 MQB-Motor_17    received
ENG122357-ENG122529    Kommunikationsstatus Datenbus 1 MQB-Motor_18    received
ENG122357-ENG122508    Kommunikationsstatus Datenbus 1 MQB-Motor_20    received
ENG122357-ENG122509    Kommunikationsstatus Datenbus 1 MQB-Motor_26    Unknown
ENG122357-ENG06581    Kommunikationsstatus Datenbus 1 MQB-Motor_35    Unknown
ENG122357-ENG122510    Kommunikationsstatus Datenbus 1 MQB-Motor_Code_01    received
ENG122357-ENG122526    Kommunikationsstatus Datenbus 1 MQB-OBD_01    received
ENG122357-ENG122511    Kommunikationsstatus Datenbus 1 MQB-TSK_06    received
ENG122357-ENG122527    Kommunikationsstatus Datenbus 1 MQB-Waehlhebel_03    received
ENG121002    Korrekturwerte Hauptdruckadaption: großer Druck auf K1    0.75     bar
ENG121004    Korrekturwerte Hauptdruckadaption: großer Druck auf K2    0.85     bar
ENG121001    Korrekturwerte Hauptdruckadaption: kleiner Druck auf K1    0.8     bar
ENG121003    Korrekturwerte Hauptdruckadaption: kleiner Druck auf K2    0.75     bar
ENG99297    Kupplung 1 Adaption Grundkennlinie Bereich 1 Schnelladaptionen verbleibende Anzahl    0
ENG100826    Kupplung 2 Adaption Grundkennlinie Bereich 1 Schnelladaptionen verbleibende Anzahl    0
ENG120965    Kupplungsadaptionswerte: IKp0 fuer K1    270     mA
ENG120966    Kupplungsadaptionswerte: IKp0 fuer K2    245     mA
ENG120967    Kupplungsadaptionswerte: unterer Strompunkt Adaption K1    225     mA
ENG120968    Kupplungsadaptionswerte: unterer Strompunkt Adaption K2    225     mA
ENG110556-ENG110541    Leak oil compensation K1-Abbruch Zähler K1 Drucküberwachung    0
ENG110556-ENG110542    Leak oil compensation K1-Abbruch Zähler K1 Solldruckintegral zu groß    0
ENG110556-ENG110543    Leak oil compensation K1-Abbruch Zähler K1 Solldruckintegral zu klein    0
ENG110556-ENG120771    Leak oil compensation K1-Erfolgreiche K1 Leckölkompensationen    23945
ENG110557-ENG110545    Leak oil compensation K2-Abbruch Zähler K2 Drucküberwachung    0
ENG110557-ENG110546    Leak oil compensation K2-Abbruch Zähler K2 Solldruckintegral zu groß    0
ENG110557-ENG110547    Leak oil compensation K2-Abbruch Zähler K2 Solldruckintegral zu klein    0
ENG110557-ENG110544    Leak oil compensation K2-Erfolgreiche K2 Leckölkompensationen    15574
ENG120996    Maximale Spannung an UH1    9.2     V
ENG120998    Maximale Spannung an UH2    4.9     V
ENG120995    Minimale Spannung an UH1    0.2     V
ENG120997    Minimale Spannung an UH2    4.9     V
ENG111613-ENG101555    Motordrehmoment Begrenzung-Engine torque limitation    320     Nm
ENG120939    Neutralposition: Gangsteller 1-3    50.77     %
ENG120940    Neutralposition: Gangsteller 2-4    50.07     %
ENG120941    Neutralposition: Gangsteller 5-N    50.25     %
ENG120942    Neutralposition: Gangsteller 6-R    50.75     %
ENG120993    Oberer adaptierter Kupplungspunkt K1 aus Makroschlupfadaption    825     mA
ENG120994    Oberer adaptierter Kupplungspunkt K2 aus Makroschlupfadaption    750     mA
ENG105329-ENG101124    Operating time CU (temp range 1-6) / operating time CU (temp-Betriebszeit STG (Temperaturbereich 1)    489     H
ENG105329-ENG100216    Operating time CU (temp range 1-6) / operating time CU (temp-Betriebszeit STG (Temperaturbereich 2)    37.2     H
ENG105329-ENG103067    Operating time CU (temp range 1-6) / operating time CU (temp-Betriebszeit STG (Temperaturbereich 3)    0     H
ENG105329-ENG101168    Operating time CU (temp range 1-6) / operating time CU (temp-Betriebszeit STG (Temperaturbereich 4)    0     H
ENG105329-ENG104150    Operating time CU (temp range 1-6) / operating time CU (temp-Betriebszeit STG (Temperaturbereich 5)    0     H
ENG105329-ENG100130    Operating time CU (temp range 1-6) / operating time CU (temp-Betriebszeit STG (Temperaturbereich 6)    0     H
ENG120987    Ratio FID 256    100     %
ENG120989    Ratio FID 257    100     %
ENG120988    Ratio FID 330    100     %
ENG120990    Ratio FID 333    100     %
ENG120975    Ratio FID 52    100     %
ENG120976    Ratio FID 53    100     %
ENG120977    Ratio FID 54    100     %
ENG120978    Ratio FID 55    100     %
ENG120986    Ratio FID 56    100     %
ENG120973    Ratio FID 57    100     %
ENG120974    Ratio FID 58    100     %
ENG120979    Ratio FID 78    100     %
ENG120980    Ratio FID 79    100     %
ENG120981    Ratio FID 80    100     %
ENG120982    Ratio FID 81    100     %
ENG120983    Ratio FID 82    100     %
ENG120984    Ratio FID 83    100     %
ENG120985    Ratio FID 84    100     %
ENG100188    Reached maximum temperature control module    112     °C
ENG123020-ENG102793    Rollwiderstand-Road Resistance    0     %
ENG102748    Selector lever error flags    00 00
ENG122375-ENG122573    Snapshot 1 Ansteuerung Gangsteller / Sonderzustände-ABS-Flag    ABS-Flag nicht gesetzt
ENG122375-ENG122571    Snapshot 1 Ansteuerung Gangsteller / Sonderzustände-ASR-Flag    ASR-Flag nicht gesetzt
ENG122375-ENG122570    Snapshot 1 Ansteuerung Gangsteller / Sonderzustände-CHS-Flag    CHS1 oder CHS2 oder beide ausgeschaltet
ENG122375-ENG122574    Snapshot 1 Ansteuerung Gangsteller / Sonderzustände-EDS-Flag    EDS-Flag nicht gesetzt
ENG122375-ENG122575    Snapshot 1 Ansteuerung Gangsteller / Sonderzustände-FDR-Flag    FDR-Flag nicht gesetzt
ENG122375-ENG122563    Snapshot 1 Ansteuerung Gangsteller / Sonderzustände-GV1-Flag    GV1-Flag nicht gesetzt
ENG122375-ENG122564    Snapshot 1 Ansteuerung Gangsteller / Sonderzustände-GV2-Flag    GV2-Flag nicht gesetzt
ENG122375-ENG122565    Snapshot 1 Ansteuerung Gangsteller / Sonderzustände-GV3-Flag    GV3-Flag nicht gesetzt
ENG122375-ENG122566    Snapshot 1 Ansteuerung Gangsteller / Sonderzustände-GV4-Flag    GV4-Flag nicht gesetzt
ENG122375-ENG122569    Snapshot 1 Ansteuerung Gangsteller / Sonderzustände-MPX-Flag    MPX-Flag nicht gesetzt
ENG122375-ENG122572    Snapshot 1 Ansteuerung Gangsteller / Sonderzustände-MSR-Flag    MSR-Flag nicht gesetzt
ENG122375-ENG122567    Snapshot 1 Ansteuerung Gangsteller / Sonderzustände-SV1-Flag    SV1-Flag nicht gesetzt
ENG122375-ENG122568    Snapshot 1 Ansteuerung Gangsteller / Sonderzustände-SV2-Flag    SV2-Flag nicht gesetzt
ENG122375-ENG122576    Snapshot 1 Ansteuerung Gangsteller / Sonderzustände-Tipp-Gasse-Flag    Tipp-Gasse-Flag nicht gesetzt
ENG122375-ENG122578    Snapshot 1 Ansteuerung Gangsteller / Sonderzustände-Tipp-hoch-Flag    Tipp-hoch-Flag nicht gesetzt
ENG122375-ENG122577    Snapshot 1 Ansteuerung Gangsteller / Sonderzustände-Tipp-runter-Flag    Tipp-runter-Flag nicht gesetzt
ENG122369    Snapshot 1 Iststrom Hauptdruckventil    0     mA
ENG122367    Snapshot 1 Kupplungszustand    New
ENG122371    Snapshot 1 unterer Strompunkt Adaption K1    0     mA
ENG122372    Snapshot 1 unterer Strompunkt Adaption K2    0     mA
ENG122376-ENG122573    Snapshot 2 Ansteuerung Gangsteller / Sonderzustände-ABS-Flag    ABS-Flag nicht gesetzt
ENG122376-ENG122571    Snapshot 2 Ansteuerung Gangsteller / Sonderzustände-ASR-Flag    ASR-Flag nicht gesetzt
ENG122376-ENG122570    Snapshot 2 Ansteuerung Gangsteller / Sonderzustände-CHS-Flag    CHS1 oder CHS2 oder beide ausgeschaltet
ENG122376-ENG122574    Snapshot 2 Ansteuerung Gangsteller / Sonderzustände-EDS-Flag    EDS-Flag nicht gesetzt
ENG122376-ENG122575    Snapshot 2 Ansteuerung Gangsteller / Sonderzustände-FDR-Flag    FDR-Flag nicht gesetzt
ENG122376-ENG122563    Snapshot 2 Ansteuerung Gangsteller / Sonderzustände-GV1-Flag    GV1-Flag nicht gesetzt
ENG122376-ENG122564    Snapshot 2 Ansteuerung Gangsteller / Sonderzustände-GV2-Flag    GV2-Flag nicht gesetzt
ENG122376-ENG122565    Snapshot 2 Ansteuerung Gangsteller / Sonderzustände-GV3-Flag    GV3-Flag nicht gesetzt
ENG122376-ENG122566    Snapshot 2 Ansteuerung Gangsteller / Sonderzustände-GV4-Flag    GV4-Flag nicht gesetzt
ENG122376-ENG122569    Snapshot 2 Ansteuerung Gangsteller / Sonderzustände-MPX-Flag    MPX-Flag nicht gesetzt
ENG122376-ENG122572    Snapshot 2 Ansteuerung Gangsteller / Sonderzustände-MSR-Flag    MSR-Flag nicht gesetzt
ENG122376-ENG122567    Snapshot 2 Ansteuerung Gangsteller / Sonderzustände-SV1-Flag    SV1-Flag nicht gesetzt
ENG122376-ENG122568    Snapshot 2 Ansteuerung Gangsteller / Sonderzustände-SV2-Flag    SV2-Flag nicht gesetzt
ENG122376-ENG122576    Snapshot 2 Ansteuerung Gangsteller / Sonderzustände-Tipp-Gasse-Flag    Tipp-Gasse-Flag nicht gesetzt
ENG122376-ENG122578    Snapshot 2 Ansteuerung Gangsteller / Sonderzustände-Tipp-hoch-Flag    Tipp-hoch-Flag nicht gesetzt
ENG122376-ENG122577    Snapshot 2 Ansteuerung Gangsteller / Sonderzustände-Tipp-runter-Flag    Tipp-runter-Flag nicht gesetzt
ENG122370    Snapshot 2 Iststrom Hauptdruckventil    0     mA
ENG122368    Snapshot 2 Kupplungszustand    New
ENG122373    Snapshot 2 unterer Strompunkt Adaption K1    0     mA
ENG122374    Snapshot 2 unterer Strompunkt Adaption K2    0     mA
ENG120921    Sollgang der Fahrstrategie     R
ENG101057    Specified idle speed    700     /min
ENG100803    Speed: output    0     /min
ENG122358    Start Stopp Statusinformationen aktuell    not active
ENG122358-ENG122500    Start Stopp Statusinformationen aktuell-Start Stopp Stoppverbot Häufigkeitszähler 1    0
ENG122358-ENG122501    Start Stopp Statusinformationen aktuell-Start Stopp Stoppverbot Häufigkeitszähler 2    0
ENG120924    Strom oberer Druckpunkt Kupplung 1 aus Strom-zu-Druck-Adaption    1000     mA
ENG120926    Strom oberer Druckpunkt Kupplung 2 aus Strom-zu-Druck-Adaption    1000     mA
ENG120923    Strom unterer Druckpunkt Kupplung 1 aus Strom-zu-Druck-Adaption    225     mA
ENG120925    Strom unterer Druckpunkt Kupplung 2 aus Strom-zu-Druck-Adaption    225     mA
ENG120935    Synchronposition Seite A: Gangsteller 1-3    46.08     %
ENG120936    Synchronposition Seite A: Gangsteller 2-4    45.41     %
ENG120937    Synchronposition Seite A: Gangsteller 5-N    50.24     %
ENG120938    Synchronposition Seite A: Gangsteller 6-R    46.65     %
ENG120947    Synchronposition Seite B: Gangsteller 1-3    55.61     %
ENG120948    Synchronposition Seite B: Gangsteller 2-4    54.99     %
ENG120949    Synchronposition Seite B: Gangsteller 5-N    53.89     %
ENG120950    Synchronposition Seite B: Gangsteller 6-R    54.41     %
ENG120999    Tastverhältnis Sicherheitsventil 1    18     %
ENG121000    Tastverhältnis Sicherheitsventil 2    18     %
ENG120991    Unterer adaptierter Kupplungspunkt K1 aus Mikroschlupfadaption    260     mA
ENG120992    Unterer adaptierter Kupplungspunkt K2 aus Mikroschlupfadaption    220     mA
ENG120960    Unterzustand Gangstelleradaption    Synchron_GSA_SUB_SYNC_ADAPTION_SETZEMPX
ENG120956    Unterzustand Gangstelleradaption zum Zeitpunkt eines Abbruchs    Synchron_GSA_SUB_SYNC_ADAPTION_SETZEMPX
ENG101346    Version info driving strategy    Temic
ENG109005    Voltage Common Highside 1    13.7     V
ENG99955    Voltage Common Highside 2    13.8     V
ENG120922    Vorwahlgang der Fahrstrategie    2
ENG120952    Zählerstände der Hauptdruckadaption:Abbruchzähler auf K1    0
ENG120954    Zählerstände der Hauptdruckadaption:Abbruchzähler auf K2    0
ENG120951    Zählerstände der Hauptdruckadaption:Erfolgszähler auf K1    1929
ENG120953    Zählerstände der Hauptdruckadaption:Erfolgszähler auf K2    1626
ENG120959    Zustand Gangstelleradaption    Synchron_GSA_AUS
ENG120955    Zustand Gangstelleradaption zum Zeitpunkt eines Abbruchs    Synchron_GSA_AUS
Elapsed Time: 00:20
IDE00021-ENG99543    Engine speed-Engine RPM    701     /min
IDE00022-ENG103074    Transmission input speed-Transmission Input Speed Sensor    701     /min
IDE00024    Transmission fluid temperature    44     °C
IDE00102-ENG102028    Control Module temperature-Control modul temperature    49     °C
IDE00872-ENG102188    Current of main pressure valve-Oil Pressure Actual Current    819.6     mA
IDE02806-ENG103118    Current of valve for clutch 2 actual value-Current Valve Clutch 2 Actual Value    0     mA
IDE02864-ENG99505    Actual position of gear positioner A-Gearpositioner A Actual Position    0.13     mm
IDE02865-ENG104121    AD value 1 of actual position of gear positioner A-Gearpositioner A Actual Position AD Value 1    2087
IDE02873-ENG101728    AD value 1 of actual position of gear positioner B-Gearpositioner B Actual Position AD Value 1    1057
IDE02880-ENG103036    Actual position of gear positioner C-Gearpositioner C Actual Position    -0.15     mm
IDE02881-ENG99453    AD value 1 of actual position of gear positioner C-Gearpositioner C Actual Position AD Value 1    2075
IDE02888-ENG103826    Actual position of gear positioner D-Gearpositioner D Actual Position    -8.1     mm
IDE02889-ENG100525    AD value 1 of actual position of gear positioner D-Gearpositioner D Actual Position AD Value 1    1222
IDE04612-ENG101246    Clutch temperature air / splash oil-Centrifugal oil temperature    44     °C
IDE05988-ENG110505    Pressure of clutch 2: actual value-Clutch_2_actual_value    0.06     bar
IDE05989-ENG110503    Pressure of clutch 1: actual value-Clutch_1_actual_value    0.08     bar
ENG103403    Converter Loss Torque    5.1     Nm
ENG100625    Coolant temperature    110     °C
ENG98602    Driver request torque    5     Nm
ENG98756    Engine torque    6     Nm
ENG104230    Engine torque loss    -20     Nm
ENG99596    Indicated engine torque without external interventions    25     Nm
ENG105329-ENG101124    Operating time CU (temp range 1-6) / operating time CU (temp-Betriebszeit STG (Temperaturbereich 1)    489.2     H
ENG109005    Voltage Common Highside 1    13.9     V
Elapsed Time: 00:20
                Address 02: Auto Trans  (0D9 300 012 K)
18:40:20
  IDE00021-ENG99543   Engine speed-Engine RPM 696 /min
  IDE00024   Transmission fluid temperature 48 °C
  IDE00102-ENG102028   Control Module temperature-Control modul temperature 53 °C
  IDE00322-ENG100540   Status of basic setting-Basic Settings Status 16
  IDE02713   Brake Light Switch operated
  IDE02714   Brake test switch operated
These DTCs were the end result of the Basic settings of transmission operation:
                Address 02: Auto Trans       Labels: 0D9-927-770.CLB
Control Module Part Number: 0D9 300 012 K    HW: 02E 927 770 AQ
  Component and/or Version: DQ250-6A MQB  H53 4515
           Software Coding: 0014
            Work Shop Code: WSC 04742 780 00200
              ASAM Dataset: EV_TCMDQ250021 001001 (AU37)
                       ROD: EV_TCMDQ250021.rod
10731 - Valve 3 in Transmission Part 1
          P174A 00 [002] - Electrical malfunction
10732 - Valve 3 in Transmission Part 2
          P174E 00 [002] - Electrical malfunction
10909 - Cooling Oil Valve
          P179D 00 [002] - Electrical Malfunction
10906 - Cooling Oil Valve
Address 02: DTCs cleared
Fault Codes have been Erased
Final control module map after Basic settings of transmission reported Finished Correctly:
IDE00021-ENG99543    Engine speed-Engine RPM    704     /min
IDE00022-ENG103074    Transmission input speed-Transmission Input Speed Sensor    705     /min
IDE00095-ENG101643    Status of selector lever lock-Status Shift Lock    not active
IDE00102-ENG102028    Control Module temperature-Control modul temperature    55     °C
IDE00872-ENG102188    Current of main pressure valve-Oil Pressure Actual Current    819.2     mA
IDE02797-ENG100730    Current of valve for clutch 1 actual value-Current Valve Clutch 1 Actual Value    0.6     mA
IDE02864-ENG99505    Actual position of gear positioner A-Gearpositioner A Actual Position    0.16     mm
IDE02872-ENG102218    Actual position of gear adjuster B-Gearpositioner B Actual Position    -8.47     mm
IDE02873-ENG101728    AD value 1 of actual position of gear positioner B-Gearpositioner B Actual Position AD Value 1    1036
IDE02881-ENG99453    AD value 1 of actual position of gear positioner C-Gearpositioner C Actual Position AD Value 1    2074
IDE02888-ENG103826    Actual position of gear positioner D-Gearpositioner D Actual Position    -8.43     mm
IDE02889-ENG100525    AD value 1 of actual position of gear positioner D-Gearpositioner D Actual Position AD Value 1    1214
IDE04612-ENG101246    Clutch temperature air / splash oil-Centrifugal oil temperature    48     °C
ENG103403    Converter Loss Torque    4.4     Nm
ENG100625    Coolant temperature    111     °C
ENG98602    Driver request torque    3     Nm
ENG120931    Eingelegtposition Seite A: Gangsteller 1-3    26.12     %
ENG120932    Eingelegtposition Seite A: Gangsteller 2-4    24.7     %
ENG120934    Eingelegtposition Seite A: Gangsteller 6-R    28.96     %
ENG120943    Eingelegtposition Seite B: Gangsteller 1-3    78.38     %
ENG120944    Eingelegtposition Seite B: Gangsteller 2-4    74.27     %
ENG120945    Eingelegtposition Seite B: Gangsteller 5-N    76.45     %
ENG120946    Eingelegtposition Seite B: Gangsteller 6-R    77.4     %
ENG98756    Engine torque    4     Nm
ENG104230    Engine torque loss    -23     Nm
ENG120962    Gangsteller_Seite    Seite A
ENG99596    Indicated engine torque without external interventions    26     Nm
ENG111613-ENG101555    Motordrehmoment Begrenzung-Engine torque limitation    319     Nm
ENG105329-ENG101124    Operating time CU (temp range 1-6) / operating time CU (temp-Betriebszeit STG (Temperaturbereich 1)    489.4     H
ENG120960    Unterzustand Gangstelleradaption    Eingelegt_GSA_SUB_SYNC_ADAPTION_SETZEMPX
ENG120956    Unterzustand Gangstelleradaption zum Zeitpunkt eines Abbruchs    Eingelegt_GSA_SUB_EING_ADAPTION_GANG_AUSL_WARTEN
ENG120955    Zustand Gangstelleradaption zum Zeitpunkt eines Abbruchs    Eingelegt_GSA_FERTIG
Elapsed Time: 00:20
DV52
C?ID=194404
^^^^ Dana: Kudos for the excellent work - a valuable contribution to the seriously deficient MQB library !!! Any chance that this procedure can added to the "Golf AU" wiki page HERE?
Dana
Western PA, USA
Hi Don,
I created this 6-Speed Direct Shift Gearbox (DSG/0D9) page back on the 2nd of Nov. but I wasn't real proud of it :) It links to this thread instead of being an informative fact-packed page.
Your suggestion is great and I went ahead and made that live (linked) from the VW Golf VII (5G/AU) page. I'll drop a link on the Audi A3/S3 (8V/FF) chassis page also.
Mosquito
C?ID=14113
I'd like to add that I did this last night and the transmission is running smoother this morning after some adaptation.
Note that once reset, there will be a bunch of intermittent codes (like stated above) that while reset-able, will reappear (in my case) until the DSG transmission has been driven for some miles.
Background is:
'17 MK7R DSG, 1800 miles
Installed JB1 @ 5.0 for 4 days. Had a slight hint at slip (4th) followed by harsh shifting (all around).
Took off JB1, RESET DSG per above. I haven't checked DSG Fluid level, but car feels right again.
I think I'll drive stock for a while.
fmannix10
Ireland
C?ID=166285
Background is:
Did your clutch slip look anything like this?
I have the same problem with the JB1 and it was not fixed by doing adaptation and my DSG Oil level is fine. (Does not slip with the JB1 disabled)
Have you tried with the JB1 again after the adaption?
Mosquito
C?ID=14113
Hi.
Mine was a hint at a slip followed by a hard clamp. More like the DSG was over powered by the extra boost and the DSG either adjusted its pressure or I just got lucky. I've heard it can monitor slip and adjust if more pressure is needed.
In any case, mine was not like what you show.
The JB1 guys said it is normal for it to slip a little in 3rd and 4th for 200+400rpms. I don't think it is nor should it be considered normal.
I have since put the JB1 back on but at 4.8 this time. I've had no slip since.
JB1 will stay on until 5000 miles when I plan to sell it and flash UM ECU+TCU.
I plan to keep the car for a while so if it ever slips. I will flash back to stock if needed.
