Sharan 7N 2012 CFFB 2,0 103 kw/140 hp NOx issues
Slijo
Croatia
Hi to all. I am totally new at this. Had issues with my sharan because it had adblue and dpf software removed by previous owner. Check engine light came on several times during 30000 km,with message NOx sensor 2 bank 1 P229 E 00- electrical malfunction,and this was a reason to change it. The story short, I did a SW update at the dealer and everything was active again. Adblue heater,was permanent fault that was not possible to erase and I have changed it and it is gone now. On the other hand the NOx sensor message is back and I have no solution. It is possible to delete it but it keeps coming back. The sensor is new so I doubt that it is also faulty. Any ideas ?
Scan:
Friday,14,February,2020,17:41:36:18722
VIN: WVWZZZ7NZCV037472   License Plate:
Chassis Type: 7N-VW36 (7N0)
Scan: 01 03 08 09 15 16 17 18 19 25 42 44 46 4C 52 53 56 61 62 72
VIN: WVWZZZ7NZCV037472   Mileage: 183520km-114034miles
   Part No SW: 03L 906 018 HH    HW: 03L 907 309 Q
   Component: R4 2.0l TDI   H27 9982
   Revision: 44H27---    Serial number:
   Coding: 0019001A042401080000
   Shop #: WSC 03020 425 00000
   ASAM Dataset: EV_ECM20TDI01103L906018HH 003017
   ROD: EV_ECM20TDI01103L906018F_VW36.rod
   VCID: 77ABEC7BDF49D69FF8D-8022
9570 - NOx Sensor 2 Bank 1
          P229E 00 [039] - Electrical Malfunction
                    Mileage: 183529 km
                    Date: 2020.02.14
                    Time: 17:36:34
                    Engine speed: 781.00 /min
                    Normed load value: 14.9 %
                    Coolant temperature: 89 °C
                    Intake air temperature: 17 °C
                    Voltage terminal 30: 14.320 V
                    Air mass: actual value (mg/stroke): 305.1 mg/stroke
                    Mean injection quantity: 4.49 mg/stroke
                    EGR Vacuum Regulator Solen.val.: activation: 72.01 %
                    NOx Emission NOx-Sensor: 0 ppm
                    NOx emission NOx sensor 2: 0 ppm
                    Air mass for release of NOx sensor 2 offset test: 0.0 g
                    Calculated efficiency of NOx conversion: 0.660
Got you Verified. You weren't verified previously because you used a different e-mail address for the forum than the one you used when you registered your HEX-V2, and you didn't provide a serial number when you joined the forum either. Now moving to Car Repair Support.
The fault codes tells you which sensor it is and states "Electrical Malfunction". What have you done to trouble-shoot this so far? The sensor could be bad, or there could be a problem with the wiring to it.
Slijo
Croatia
The wiring is OK. Voltage feed is fine. Tried SCR efficiency test. Aborted - safety reasons after some 10 mins. Like I wrote, the sensor is new, just replaced, but the fault is the same like it was on the old one. I am gonna mount back the original sensor, and see what happens
Spacewalker
Poland
C?ID=159607
do you know the reason why they cutt off DPF ? maybe ECU faulty ?or maybe they damage ecu while open to read SW ??
you restore SW , but maybe is HW issue ?
Slijo
Croatia
As much as I know it was a faulty adblue heater,and due to previous owner was a cheap bastard he decided to kill the adblue and(probably) dpf with software solution. When doing autos can before software was updated it always showed the same values for soot, oil ash.... The only parameter that was changing was the distance and time since last regen. This number was about 30000km :(. After software update start stop was functional, vcds was registering dpf regen cycles... Warning light was activated for adblue heater. After changing the part this fault was gone. The problem with NOx2 from the first thread is still actual. Interesting thing is that it shows after random scans, and check engine light comes afterwards(cca 200 km after registered fault)
Slijo
Croatia
If the ecu is faulty, shouldn't it be obvious and readable by vcds?
Bruce
Near Philadelphia, PA, USA
The system under test (the ECU) is the system that does the test and reports its condition. VCDS just reads the conditions reported.
So the answer to your question is: Maybe... but not necessarily obvious.
That is if the ECU is functional enough to run its internal tests and report the results, then we can know what is malfunctioning.
If the ECU is not functional, then it may not give details.
Spacewalker
Poland
C?ID=159607
If SW update not fix a problem, and wires / sensors is 100% good - swap ECU even with IMMo OFF to test
