MK7.5 Golf R, DRL Brightness settings?
wildstar87
C?ID=252770
I've been searching around the forums, it seems that no one has been able to figure out how to do this in the Mk7.5 Golf R. It seems the DRLs are no longer in the Leuchte adaptations. I know DV52 has mentioned it is probably in one of the new lighting modules. So I've tried to look at coding these new modules, and they seem to not really have any options. While logging, I've been able to see when the DRLs dim and brighten, but I haven't been able to find settings to set this. Any theories on how to change this, or am I overlooking something obvious?
I also did see a Lighting Configuration adaptation in Central Electronics, with a VERY long hex string, perhaps it is in here? Is there any way to decode this? Thanks
jyoung8607
FoRT
Cincinnati, OH
C?ID=25607
Please post a complete Auto Scan for context.
That said, as a fellow Mk7.5 Golf R owner, I can tell you that you'll find much of it moved from address 09 to 4B.
DV52
C?ID=194404
wildstar: my hypothesis about the illusive Lighting Configuration channel is a complete guess based purely on observation and a glass of single-malt by my side as I write this.
In older BCMs, there are an equal number of Lighting Configuration channels and Leuchte channels - so, 35 x config-sets (like Leuchte-sets), each with 19 x adaptation channels = 665 x lighting configuration channels in total. The structure of each config-set appears to be exactly the same as a Leuchte-set.
And each of these lighting configuration channels also appears to have a direct link to a twin leuchte channel by virtue of the "link-number" in the "child name" of the descriptor - like this:
IDE05145-ENG116480-Light configuration-Lasttyp 32 & ENG116968-ENG116480-Leuchte32AMBL 2C35-Lasttyp 32
There are 6 x config-sets in which the settings appear to have a close correlation to the settings in its twin Leuchte-set. For these closely correlated config-sets, whenever a stored valued of a matching Leutche channel is changed, the corresponding stored value of the Lighting configuration channel automatically appears to change to the altered value.
The close correlation config-sets are: Low Beam Headlamp, Front Turn Indicator and Daytime Running Lamp (left and Right lamps in each case). The only linking aspect for these lights is that they are all part of the front headlight assembly albeit the High beam lamp is curiously missing from the list.
In the newer style BCM, my hunch is that the individual config channels have been coalesced into a single channel and the very-long hex-string is simply the concatenation of the setting values in the older style BCM. I haven't actually counted the number of hex-pairs in IDE05145-Light configuration channel - but I'm not sure that it matters if there aren't 665 x bytes (i.e. there appears to be no point in duplicating the settings in the old closely correlated config-sets)
As to how to decode each of the individual Bytes in the new Light configuration channel - I suspect that the only ones who know are the wizened elves that Uwe keeps imprisoned in chains in the moldy dungeons at Ross Tech HQ. And as all forum members know - VCDS elves tell no tales ;)
As to how to decode each of the individual Bytes in the light configuration channel - I suspect that the only ones who know are the wizened elves that Uwe keeps imprisoned in chains in the moldy dungeons at Ross Tech HQ.
Eh? If we knew, we'd come up with some way to document that.
wildstar87
C?ID=252770
Not sure how much help it will be, but here is my scan.
Sunday,29,April,2018,21:22:03:57508
VIN: WVWVF7AU7JW069037   License Plate:
Mileage: 265km-164mi   Repair Order:
Chassis Type: AU-VW37 (3Q0)
Scan: 01 02 03 05 08 09 10 13 14 15 16 17 19 22 29 2B 39 3C 42 44
          47 4B 52 5F 75 A5 A9 D6 D7
VIN: WVWVF7AU7JW069037   Mileage: 265km-164miles
Address 01: Engine (J623-DJJA)       Labels: None
   Part No SW: 8V0 906 259 P    HW: 06K 907 425 E
   Component: 2.0l R4 TFSI  H13 0001
   Revision: --H13---
   Coding: 092500122466010E3004
   ASAM Dataset: EV_ECM20TFS0208V0906259P 001003
   ROD: EV_ECM20TFS0208V0906259P.rod
   VCID: 4DC7957FCD5F142FC9E-8018
Address 02: Auto Trans (J743)       Labels: None
   Part No SW: 0GC 300 012 A    HW: 0GC 927 711 G
   Component: GSG DQ381     H06 1403
   Revision: 00H06V07
   ASAM Dataset: EV_TCMDQ381061 001
   ROD: EV_TCMDQ381061.rod
   VCID: 211F19CFE147E04F5D6-8074
   Revision: 00000000    Serial number: 62257000002121
   Coding: 01FA6BA1542621754577030340CA6980D62A84A2C0029677384250D8C2A8430000000012121212B835351919323200
   ROD: EV_Brake1UDSContiMK100IPB_036_VW27.rod
   VCID: 77AB17971F434EFF432-8022
Address 05: Acc/Start Auth. (J518)       Labels:* None
   Part No SW: 5Q0 959 435 C    HW: 5Q0 959 435
   Component: VWKESSYMQB    021 0803
   Revision: 00021000    Serial number: 0452468002
   Coding: 032C0C
   ASAM Dataset: EV_KessyHellaMQBAB 002020
   VCID: 3C21C8BB66E5ADA76E0-8068
Address 08: Auto HVAC (J255)       Labels:* None
   Part No SW: 5G0 907 044 CF    HW: 5G0 907 044 CF
   Revision: 00001K08
   Coding: 0002000420010000110500001211140A
   VCID: 6D8735FF6D1FF42FA9E-8038
   Part No SW: 5Q0 937 085 BN    HW: 5Q0 937 085 BF
   Component: BCM MQBAB MNA H36 0253
   Serial number: 01001723400255
   ROD: EV_BCMCONTI.rod
   VCID: 06556A5368A92777484-8052
   Subsystem 1 - Part No SW: 5G1 955 119 A    HW: 5G1 955 119 A
   Component: WWS    170725  043 0551
   Serial number:         170816023311
   Subsystem 2 - Part No SW: 5Q0 955 547 B    HW: 5Q0 955 547 B
   Component: RLHS  047 0105
   Serial number: S5Y17M08D28H13M25S04
   Coding: 00A8DD
Address 10: Park/Steer Assist (J446)       Labels:* None
   Serial number: 000308418617230
   Coding: 0471155811
   VCID: 4BC39B67334B1A1FD7A-801E
   Part No SW: 5Q0 907 572 J    HW: 3QF 907 572
   Component: ACC BOSCH MQB H10 0654
   Coding: 330000C159FFC728949C810580401600000000000000000000
   ASAM Dataset: EV_ACCBOSCHVW416 002006
   VCID: 3E25C2B370F9BFB7404-806A
0836 - Databus
          [FAULT_PREDICTIVE_ROUTEDATA_SIGNALERROR_RECEIVED]
                    Fault Frequency: 133
                    Reset counter: 73
                    Mileage: 256 km
                    Date: 2018.04.29
                    Time: 18:17:22
                    Control Module temperature: 34 °C
                    Voltage terminal 15: 13.9 V
Address 14: Susp. Elect. (J250)       Labels: None
   Serial number: 25071741350359
   ROD: EV_DRCONTITEMIC_VW27.rod
   VCID: 3829D4AB52DD81878A8-806C
   Serial number: 003GCR08SP3-
   VCID: 47CBA7572F23FE7FF32-8012
   Occupant Detection:
   Serial number: IBH000000000007OCPYJ
   Coding: 303344
   Subsystem 2 - Part No SW: -----------    HW: 480 002 108 17
   Serial number: 35700000000F0084862F
   Subsystem 3 - Part No SW: -----------    HW: 480 001 908 17
   Serial number: 35800000000D30DC962V
   Subsystem 4 - Part No SW: -----------    HW: 480 401 808 17
   Serial number: 3510001A5264534301AK
   Subsystem 5 - Part No SW: -----------    HW: 480 401 908 17
   Serial number: 3520001A3268527391C-
   Subsystem 6 - Part No SW: -----------    HW: 480 401 908 17
   Serial number: 3550001A7269997582AC
   Front Sensor Passenger:
   Subsystem 7 - Part No SW: -----------    HW: 480 401 908 17
   Component: FrontSensor_P  000 6149
   Serial number: 3560001A72699974D3EM
Address 16: Steering wheel (J527)       Labels:* None
   Part No SW: 5Q0 953 507 HN    HW: 5Q0 953 549 E
   Revision: --------    Serial number: 20081704221101
   Coding: 0C10
   ROD: EV_SMLSKLOMQB_VW37.rod
   VCID: 094F616F79B7480F256-805C
Address 17: Instruments (J285)       Labels:* None-SRI3
   Part No SW: 5G1 920 891 A    HW: 5G1 920 891 A
   Component: KOMBI         407 3193
   Coding: 0BAD301A7F88CF0502886B0B54010000A0000000
   VCID: 2B03FBE7938B3A1FF7A-807E
   Part No SW: 3Q0 907 530 G    HW: 3Q0 907 530 C
   Component: GW MQB High   433 4303
   Revision: --------    Serial number: 0006717811
   Coding: 030100047F085900FB00827A9C0F00010001070000000000000000000000
   ROD: EV_GatewNF_VW27.rod
   VCID: 3333E3874BBB62DFBFA-8066
   Subsystem 2 - Part No SW: 5G0 959 442 S    HW: 5G0 959 442 S
   Serial number: 29170001549280017287
   Coding: 35FFFF
197175 - Control unit for battery monitoring
          U1050 00 [009] - No Communication
          [BDM (LIN#1) Timeout]
                    Reset counter: 30
                    Mileage: 167 km
                    Date: 2018.04.28
                    Time: 18:32:39
                    Supply voltage: Terminal 30: 11.8 V
                    Terminal 15: On
Address 22: AWD (J492)       Labels:* None
   Serial number: HA1-00028.06.17
   Coding: 0001
   VCID: 4ACD9E633C310317ECC-801E
Address 29: Left Light (J1018)       Labels: None
   Part No SW: 8V0 907 399 D    HW: 8V0 907 399 D
   Component: LCM_MLBevoH08 0014
Address 2B: Steer. Col. Lock (J764)       Labels:* None
   Revision: 00000000    Serial number: 17000222091007
   Coding: 5D00000000000000
   ROD: EV_ELVMarquMQB.rod
   VCID: 3431E09B4EB565E7A60-8060
Address 39: Right Light (J1023)       Labels: None
Address 3C: Lane Change (J1086)       Labels:* None
   Component: HRE_Master    H12 0080
   Serial number: 0449834454
   Coding: 02011103
   ROD: EV_HREntryHella_VW37.rod
   VCID: 3D27C5BF7DFFA4AF59E-8068
   Lane Change Assistant 2:
   Component: HRE_Slave  H12 0080
   Serial number: 0451581530
   Coding: 020111
   Serial number: 120817EHC17354
   Coding: 003E13208000040000000000
   VCID: 43D3B3471B1BD25F2FA-8016
   Subsystem 1 - Part No SW: 5Q0 959 811 D    HW: 5Q0 959 811 D
   Component: FOND_FHSG_DRV  006 0007
   Serial number: 00000000000016039421
   Coding: 111000
   Coding: 9107
   ROD: EV_SteerAssisMQB_013.rod
   VCID: 3A2DCEA36CD193977CC-806E
   Part No SW: 5Q0 035 456 A    HW: 5Q0 035 456 A
   Component: MIB2_lite_amp H40 0200
   Revision: 00000001    Serial number: VWZ8Z1HMD00TQ2-
   Coding: 2200000000AAAAAA000000000000
   ASAM Dataset: EV_AMPMst12C1Gen2ALPI 001003
   ROD: EV_AMPMst12C1Gen2ALPI.rod
   VCID: 2E05F2F3A0994F37D04-807A
   Serial number: 18081710523518
   Coding: 000000050100165206710F01020000000000000000000000000000000000
   VCID: 72BD268374212BD774C-8026
   Serial number: 220717EGL20026
   Coding: 003E13208000040000800000
   VCID: 42DDB6430401DB5724C-8016
   Subsystem 1 - Part No SW: 5Q0 959 812 D    HW: 5Q0 959 812 D
   Component: FOND_FHSG_PSG  006 0007
   Serial number: 00000000000015854860
   Coding: 091000
   Part No SW: 3Q0 035 876 B    HW: 3Q0 035 876 B
   Component: MU-S-NS-US    851 0842
   Coding: 027310020000000051220002001808009F0507F401200405C6
   ROD: EV_MUStd4CDELP_VW27.rod
   Subsystem 1 - Part No SW: 5G6 919 605 D    HW: 5G6 919 605 D
   Component: ABT_Std-2_Nav  H50 8130
   Serial number: VWZ6ZJT2130996
   Subsystem 2 - Part No SW: 3G0 919 866 BH    HW: -----------
   Component: NAR 2017/18  --- 0620
Address 75: Telematics (J949)       Labels:* None
   Component: OCULowMQBUS   009 0570
   Coding: 02730002C2821A017F1E06020000
   ROD: EV_OCULowMQB.rod
Address A5: Frt Sens. Drv. Assist (R242)       Labels:* None
   Part No SW: 3Q0 980 654 H    HW: 3Q0 980 654 A
   Component: MQB_B_MFK     H08 0272
   Serial number: 08081711K22422
   Coding: 0003070000000201002213548150490084000E200120
   ROD: EV_MFKBoschMQBB_VW27.rod
Address A9: Struct. Borne Sound (J869)       Labels: None
   Part No SW: 5G0 907 159 D    HW: 4H0 907 159 A
   Serial number: 170714200548
   VCID: 2F3BEFF7A793463FDB2-807A
Address D6: Light Ctrl Left 2 (A31)       Labels: None
   Part No SW: 7P5 941 572 A    HW: 7P5 941 572 A
   Component: LED1L         H06 0002
   ASAM Dataset: EV_LEDMinMaxL_KEBODAVW481 001003
   ROD: EV_LEDMinMaxL_KEBODAVW481.rod
   VCID: 392FD1AF69D7988F756-806C
Address D7: Light Ctrl Right 2 (A27)       Labels: None
   Component: LED1R         H06 0002
   ASAM Dataset: EV_LEDMinMaxR_KEBODAVW481 001003
   ROD: EV_LEDMinMaxR_KEBODAVW481.rod
End------(Elapsed Time: 16:01, VBatt start/end: 12.1V/12.1V, Deb=2)--------
wildstar87
C?ID=252770
Thanks Don, your supposition matches my thinking on it as well. It's so strange that the DRLs seem to be the only ones they did this with on the Mk7.5.
quailallstar
Florida & the Nation's Capital
C?ID=53119
Any updates to this? I would like to disable the wink feature for the MK7.5 DRLs when using the front turn indicator in exchange for having the DRL/indicator be in phase/out of phase.
