- Joined
- Jan 2, 2020
- Messages
- 16
- Reaction score
- 8
- Location
- Pennsylvania, USA
- VCDS Serial number
- C?ID=391688
I was enabling windows w/ remote, driving school mode, disabled seat belt chime and attempted to disable all the screens about "this function not available while vehicle in motion..."
I noticed today that the map in my MFD is gone.
Also noticed that this toggle switch is now inactive:
Any ideas?
Any ideas?
Wednesday,08,January,2020,17:22:26:62459
VCDS Version: 19.6.2.0 (x64) HEX-V2 CB: 0.4508.4
VIN: WVWWA7AU6KW165357 License Plate: DA802Z
Mileage: 819km-508mi Repair Order:
Chassis Type: AU-VW37 (3Q0)
Scan: 01 03 05 08 09 10 13 14 15 17 19 22 29 2B 39 3C 42 44 47 4B
52 5F 75 A5 A9 D6 D7
VIN: WVWWA7AU6KW165357 Mileage: 819km-508miles
29-Left Light -- Status: Malfunction 0010
39-Right Light -- Status: Malfunction 0010
4B-Multifunc. Module -- Status: Malfunction 0010
A9-Struct. Borne Sound -- Status: Malfunction 0010
Address 01: Engine (J623-DLRA) Labels:. 06K-907-425-V1.clb
Part No SW: 8V0 906 259 Q HW: 06K 907 425 J
Component: R4 2.0l TFSI H13 0002
Revision: --H13---
Coding: 091900122446000E3004
ASAM Dataset: EV_ECM20TFS0208V0906259Q 001003
ROD: EV_ECM20TFS0208V0906259Q.rod
VCID: 4EC569D060581AC70BB-801A
15368 - ROD - Unknown Error Code
- 00 [032]
Mileage: 34 km
Date: 2019.11.12
Time: 00:47:53
Vehicle speed: 255 km/h
Coolant temperature: 87 °C
Intake air temperature: 32 °C
Voltage terminal 30: 8.906 V
Unlearning counter according OBD: 10
Engine: operating status: ES
ECU_STATE: PWL
T_AST_SAE: 2849 s
T_IGK: 0.00 s
N_TOOTH: 0 /min
TAA: 8.000 °C
FUP_H_SAE: 14580.0 kPa
17178 - Implausible Data Received from ESP Control Module
U0416 00 [040] - -
Mileage: 34 km
Date: 2019.11.12
Time: 00:00:26
Engine speed: 1289.25 /min
Normed load value: 12.2 %
Coolant temperature: 7 °C
Intake air temperature: 8 °C
Voltage terminal 30: 12.089 V
Drivetrain coordinator: ACC fault status-ACC is active despite EPB deceleration: No
Drivetrain coordinator: ACC fault status-ACC active: although TSK passive: No
Drivetrain coordinator: ACC fault status-Start off or stop request at stopping speed not set: No
Drivetrain coordinator: ACC fault status-Start off and stop request sent simultaneously: No
Drivetrain coordinator: ACC fault status-ACC active: although limiter active: No
Drivetrain coordinator: ACC fault status-ACC reactivates itself after locking: No
Drivetrain coordinator: ACC fault status-ACC sends undefined signals: No
Drivetrain coordinator: ACC fault status-ACC active although main switch off: No
Drivetrain coordinator: ACC fault status-ACC is active despite driver braking: No
Drivetrain coordinator: ACC fault status-ACC is active despite ESP/ASR passive sampling: No
Part No SW: 5Q0 614 517 DS HW: 5Q0 614 517 BN
Component: ESC H35 0108
Revision: 00000000 Serial number: 60269000000189
Coding: 01FA6BA150260971457A030560CA6980D60A90A2C0069637344050D4D0A84B0B0000000012121212B835351919323200
ASAM Dataset: EV_Brake1UDSContiMK100IPB 038007
ROD: EV_Brake1UDSContiMK100IPB_038.rod
VCID: 055796FCF5AE199FFA1-8050
0128 - Function Restricted due to Insufficient Voltage
U1400 00 [008] - -
[undervoltage]
Reset counter: 41
Mileage: 34 km
Date: 2019.11.11
Time: 00:00:05
0297 - Steering Angle Sensor
B1168 F2 [008] - Not Initialized
Reset counter: 41
Mileage: 34 km
Date: 2019.11.12
Time: 00:00:25
16401 - Tire Pressure Warning
C102D 00 [008] - -
Reset counter: 42
Mileage: 55 km
Date: 2019.12.26
Time: 13:55:04
32830 - Parking Brake Motors
C10E1 29 [008] - Signal Implausible
[IPB-Actuator: Actuator state UNKNOWN]
Reset counter: 41
Mileage: 34 km
32928 - Function Restricted due to Insufficient Voltage
U1400 00 [008] - -
[IPB: Supply Voltage below undervoltage threshold]
Reset counter: 41
Mileage: 34 km
Date: 2019.11.12
Time: 22:23:44
Part No SW: 3Q0 959 435 L HW: 3Q0 959 435 L
Component: VWKESSYMQB 037 1204
Revision: 00037000 Serial number: 6097481000
Coding: 132C0C0623
VCID: 43D348E4BB1AE7AF945-8016
U1400 00 [008] - -
Fault Frequency: 43
Reset counter: 41
Mileage: 35 km
Date: 2019.11.07
Time: 11:20:00
Terminal_50_Kessy_specified_value: On
Terminal_50_Kessy_actual_value: On
ZAT_pressed: On
Park selector lever position: Not engaged and not locked
Control Module Voltage: 7.190 V
Vehicle speed: 0.0 km/h
Engine speed: 0.0 /min
Coding information: coded
Coding information: Not coded
Driver door: closed
Front Passenger Door: closed
Left rear door: closed
Right rear door: closed
Active_LF_scans: Init
SPN_Byte 0: 00
SPN_Byte 1: 00
SPN_Byte 2: 00
65813 - Supply voltage
[Error Kessy Supply voltage too low]
Reset counter: 41
Mileage: 34 km
Date: 2019.11.11
Time: 00:01:29
ZAT_pressed: OFF
Enabling immobilizer: Condition not met
Control Module Voltage: 6.732 V
Driver door: closed
SPN_Byte 0: 00
SPN_Byte 1: 00
SPN_Byte 2: 00
Part No SW: 5G0 907 044 CF HW: 5G0 907 044 CF
Component: Climatronic H04 1801
Revision: 00001K08
Coding: 0002000420010000010500401211140A
VCID: 6D87CE5CCD1EC1DF121-8038
B10CD 00 [008] - -
Fault Frequency: 9
Reset counter: 41
Mileage: 35 km
Date: 2019.11.03
Time: 23:26:50
Voltage terminal 30: 10.9 V
Part No SW: 5Q0 937 085 BS HW: 5Q0 937 085 BF
Component: BCM MQBAB MNA H38 0273
Serial number: 00001908300182
ASAM Dataset: EV_BCMMQB 019001
ROD: EV_BCMBOSCH_019_VW37.rod
VCID: 0B43A0C4D3CA6FEFAC5-805E
Subsystem 1 - Part No SW: 5G1 955 119 A HW: 5G1 955 119 A Labels: 5QX-955-119-V1.CLB
Component: WWS 190220 043 0551
Serial number: 190307012831
Subsystem 2 - Part No SW: 5Q0 955 547 B HW: 5Q0 955 547 B Labels: 5Q0-955-547.CLB
Component: RLHS 052 0107
Serial number: SBY19M03D20H23M27S34
Coding: 00A8DD
Steering Column Switch:
Subsystem 3 - Part No SW: 5Q1 953 507 M HW: 5Q1 953 549
Component: J527 SMLS MQB 004 0060
Serial number: 00000013031904220145
131330 - Supply voltage
[Versorgungsspannung - unterer Grenzwert unterschritten >]
Reset counter: 41
Time: 00:00:00
131586 - Function Restricted due to Insufficient Voltage
U1400 00 [008] - -
[Funktionseinschränkung durch Unterspannung - unterer Grenzwert unterschritten >]
Reset counter: 41
Mileage: 34 km
Date: 2019.11.12
Time: 00:02:30
796961 - Steering Column Control Module
B105D F1 [008] - Function Restricted to to Under-Voltage
[Schaltermodul Lenksäule (SMLS)->FUNKTIONSEINSCHRÄNKUNG durch Unterspannung]
Reset counter: 41
Mileage: 34 km
Date: 2019.11.11
Time: 00:00:04
Part No SW: 5QA 919 294 C HW: 5QA 919 294
Serial number: 000308418019085
Coding: 0471155801
VCID: 4CC163D8964428D765F-8018
13635840 - Supply voltage
[Versorgungsspannung - zu niedrig]
Reset counter: 41
Mileage: 34 km
Date: 2019.11.11
Time: 00:01:16
U1400 00 [008] - -
[Funktionseinschränkung durch Unterspannung - unterer Grenzwert unterschritten]
Reset counter: 41
Time: 00:00:00
13637426 - Databus
Reset counter: 41
Mileage: 34 km
Date: 2019.11.12
Time: 00:00:25
13637120 - Databus
[Parkbremse - EPB_01.EPB_Status - Fehlerspeicher auslesen]
Reset counter: 41
Mileage: 34 km
Date: 2019.11.12
Time: 00:04:41
Address 13: Auto Dist. Reg (J428) Labels:| 3Q0-907-572.clb
Part No SW: 5Q0 907 572 P HW: 3QF 907 572 A
Component: ACC BOSCH MQB H11 0682
Coding: 2B0000C159FFC728949C810560401600000000000000000004
ASAM Dataset: EV_ACCBOSCHVW416 002008
VCID: 44D14BF8BE14E097ADF-8010
9 Faults Found:
2055 - Databus
[FAULT_ALP_STEERINGWHEEL_INIT]
Reset counter: 41
Mileage: 34 km
Date: 2019.11.12
Time: 00:00:26
Control Module temperature: 7 °C
Voltage terminal 15: 11.9 V
0803 - Databus
[FAULT_BV1_FEHLER]
Reset counter: 41
Mileage: 34 km
Date: 2019.11.12
Time: 00:00:26
Voltage terminal 15: 12.0 V
2086 - Databus
[FAULT_EPB_ACTUATOR_FAIL]
Reset counter: 41
Mileage: 34 km
Date: 2019.11.12
Time: 00:04:42
Voltage terminal 15: 11.5 V
2101 - Databus
[FAULT_ESP_STATUS_SYSTEM]
Reset counter: 41
Mileage: 34 km
Date: 2019.11.12
Time: 00:00:25
1091 - Databus
[FAULT_TIMEOUT_ESP_20]
Reset counter: 41
Mileage: 34 km
Date: 2019.11.11
Time: 00:00:11
Control Module temperature: 22 °C
1074 - Databus
[FAULT_TIMEOUT_ESP_33]
Reset counter: 41
Mileage: 34 km
Date: 2019.11.11
Time: 00:00:11
Voltage terminal 15: 11.4 V
2068 - Databus
[FAULT_TSK_IRREV_FAIL]
Reset counter: 41
Mileage: 34 km
Date: 2019.11.12
Time: 00:00:26
Voltage terminal 15: 12.1 V
1391 - Function Restricted due to Excessive Voltage
U1401 00 [008] - -
[FAULT_VBAT_BUSMON_HIGH]
Reset counter: 41
Mileage: 34 km
Date: 2019.11.12
Time: 00:03:55
Control Module temperature: 14 °C
Voltage terminal 15: 17.9 V
Velocity_vehicle_reference: -0.40 m/s
Longitudinal_acceleration_vehicle_reference: -2.43 m/s²
Status_ACC_System: ACC_irreversible error
1387 - Supply voltage
[FAULT_VBAT_LOW]
Reset counter: 41
Mileage: 34 km
Date: 2019.11.11
Time: 00:01:29
Control Module temperature: 20 °C
Voltage terminal 15: 6.6 V
Status_ACC_System: ACC_Init
Address 14: Susp. Elect. (J250) Labels: 5Q0-907-376.clb
Part No SW: 5Q0 907 376 B HW: 5Q0 907 376 A
Serial number: 13031941351533
ROD: EV_DRCONTITEMIC_VW37.rod
VCID: 38292F08F2DCB477317-806C
Component: AirbagVW20 010 0830
Serial number: 003GCR0BFTC$
ROD: EV_AirbaVW20SMEVW37X.rod
VCID: 47CB5CF48F22CB8F48D-8012
Occupant Detection:
Component: BF-Gewichtss. H13 0022
Serial number: IBH00000000000B51X2C
Coding: 303344
Subsystem 2 - Part No SW: ----------- HW: 480 002 103 19
Serial number: 357000000009E9DC7A36
Subsystem 3 - Part No SW: ----------- HW: 480 002 103 19
Serial number: 358000000006DB754A3W
Subsystem 4 - Part No SW: ----------- HW: 480 402 303 19
Component: SideSensor_Dr 005 6149
Serial number: 3510001A6EEFCE08499$
Subsystem 5 - Part No SW: ----------- HW: 480 402 303 19
Component: SideSensor_Pr 005 6149
Serial number: 3520001C4EEE84E86B3.
Subsystem 6 - Part No SW: ----------- HW: 480 402 603 19
Component: FrontSensor_D 005 6149
Serial number: 3550001A8EEE84E92AA2
Front Sensor Passenger:
Subsystem 7 - Part No SW: ----------- HW: 480 402 603 19
Component: FrontSensor_P 005 6149
Serial number: 3560001A6EEE84E68A2$
9483264 - Seat Occupied Recognition
B10B4 00 [008] - Function Restriction due to Undervoltage
[Bladder Mat: functional restriction because of low voltage]
Reset counter: 41
Mileage: 34 km
Date: 2019.11.11
Time: 00:01:33
Part No SW: 5G1 920 891 B HW: 5G1 920 891 B
Component: KOMBI 403 4191
Coding: 0BAD40127F88CF0502887F0B5401000080000000
VCID: 2C010358368408D745F-8078
[Versorgungsspannung - unterer Grenzwert unterschritten Versorgungsspannung Spannung dauerhaft zu niedrig]
Reset counter: 41
Time: 00:00:00
16776988 - Databus
[TSK_07 keine Kommunikation]
Reset counter: 41
Mileage: 34 km
Date: 2019.11.11
Time: 00:00:00
Part No SW: 3Q0 907 530 AA HW: 3Q0 907 530 C
Component: GW MQB High 442 4368
Revision: -------- Serial number: 0009355191
Coding: 0101000838085900FB00823A880F00000001070000000000000000000000
ROD: EV_GatewNF.rod
VCID: 6E85C950C0183AC72BB-803A
Component: 0-00-00-00-00
Subsystem 2 - Part No SW: 5G0 959 442 AE HW: 5G0 959 442 AE Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H11 0052
Serial number: 29190000416750069084
Coding: 2CFFFF
1282 - Supply voltage
[Versorgungsspannung - unterer Grenzwert unterschritten]
