Mk7 Headlight Issue
GTIronic
New Member
Hello everyone. I am trying to activate high beam assist in my 2016 GTI. It has all the hardware but when I go to the last step it shows my car as having halogens for some reason. I have a scan and screenshots as well.
https://www.golfmk7.com/forums/showthread.php?t=23366
Please post your scan for context.
GTIronic
New Member
Address 01: Engine (J623-CXCB)       Labels:. 06K-907-425-V1.clb
   Part No SW: 5G0 906 259 D    HW: 06K 907 425 B
   Revision: --H13---
   Coding: 091D00324464002F1000
   Shop #: WSC 00066 790 00060
   ASAM Dataset: EV_ECM20TFS0205G0906259D 001003
   ROD: EV_ECM20TFS_VW37.rod
   VCID:
   Part No SW: 0D9 300 020 J    HW: 02E 927 770 AQ
   Component: DQ250-6V MQB  H54 4902
   Revision: 06354004    Serial number: TFK01608300581
   Shop #: WSC 04742 780 00200
   ROD: EV_TCMDQ250021.rod
   VCID: 1C19375A17C279AA21-8048
10657 - RPM Signal from ECU
          P0726 00 [002] - Implausible Signal
   Revision: 00000000    Serial number: 62285000001610
   Coding: 01FA6BA15424096E0078020741C86880D62A9000408216B6164350D3C089
   Shop #: WSC 01383 790 50316
   VCID: 7AD511C2FDB6E79A93-802E
16401 - Tire Pressure Warning
          C102D 00 [008] -  -
                    Reset counter: 180
                    Mileage: 48198 km
                    Date: 2019.02.09
                    Time: 13:09:24
   Revision: 00021000    Serial number: 0379425094
   Coding: 030C0C
   VCID: 3A55D1C2BD36279AD3-806E
   Part No SW: 5GM 907 426 A    HW: 5GM 907 426 A
   Component: AC Manuell    H02 1001
   Revision: 00001K01
   Coding: 00020004200100000100000000000002
   ROD: EV_ACManueBHBVW37X_003_VW37.rod
   VCID: 46ADB532F9CE537AA7-8012
   Part No SW: 5Q0 937 087 AA    HW: 5Q0 937 087 AA
   Revision: --------    Serial number: 86582810151122
   Coding: 00111A464001A26969644000001407201800000000000000000000000000
   Shop #: WSC 00066 790 00058
   ROD: EV_BCMBOSCH_015.rod
   Component: WWS    150801  043 0581
   Serial number:         151211160041
   Subsystem 2 - Part No SW: 5Q0 955 559 A    HW: 5Q0 955 559 A  Labels: 5Q0-955-547.CLB
   Component: RLS  037 0059
   Serial number: S4Y15M11D19H03M32S42
   Coding: 90A8DD
   Sun Roof:
   Subsystem 3 - Part No SW: 5GD 959 591     HW: 5GD 959 591
   Component: J245 PS60.036  H06 0150
   Serial number: 03691611990808151259
   Coding: 181803
                    Fault Frequency: 53
                    Reset counter: 206
                    Mileage: 48072 km
                    Date: 2019.02.07
                    Time: 15:28:28
   Part No SW: 5Q0 919 298 K    HW: 5Q0 919 298
   Component: PARKHILFE PLA H12 0054
   Revision: --------    Serial number: 39431526403760
   Coding: 0031165011
   ASAM Dataset: EV_EPHVA2CAU3700000 003021
   ROD: EV_EPHVA2CAU3700000_003.rod
   VCID: 47B3B836FEC44A725C-8012
13638913 - Databus
                    Reset counter: 201
                    Mileage: 51957 km
                    Date: 2019.04.01
                    Time: 21:06:03
   Part No SW: 5Q0 907 572 F    HW: 5Q0 907 572 F
   Component: ACC Bosch MQB H05 0400
   Serial number: 03071503210256
   Coding: 011C5600FE0739
   ASAM Dataset: EV_ACCMRRBoschVW372 001016
   Part No SW: 5Q0 907 376 A    HW: 5Q0 907 376 A
   Component: DAEMPFUNGS-SG H17 0120
   Serial number: 13101541350006
   ROD: EV_DRCONTITEMIC_VW37.rod
   VCID: 3753C8F68E243AF22C-8062
   Part No SW: 5Q0 953 521 BB    HW: 5Q0 953 569 A
   Revision: FF033033    Serial number: 20150917400437
   Coding: 0C10
   ROD: EV_SMLSVALEOMQB.rod
   VCID: 73CB3CE6DADC96D2D0-8026
   Part No SW: 5G1 920 856 A    HW: 5G1 920 856 A
   Component: KOMBI         342 6420
   Coding: 0BAD011AFD98CF0502887A0B5000000000000000
   VCID: 2C79E79A4762892A51-8078
   Part No SW: 5Q0 907 530 AJ    HW: 5Q0 907 530 M
   Component: GW MQB High   212 2246
   Revision: --------    Serial number: 11101510521839
   Coding: 0101000830085900FB00003B9C0F00000001050000000000000000000000
   Shop #: WSC 00066 790 00199
   ROD: EV_GatewConti_013_VW37.rod
   VCID: 79D70ECEF8B0EC829A-802C
   Subsystem 2 - Part No SW: 5G0 959 442 S    HW: 5G0 959 442 S  Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H10 0040
   Serial number: 29150001210340085241
   Coding: 35FFFF
   Revision: 00000000    Serial number: 15000215903004
   Coding: 5D00000000000000
   ROD: EV_ELVMarquMQB.rod
   VCID: 3449FFFA9F52D1EA09-8060
Address 32: Differential Locks (J492)       Labels:* 0CQ-907-554.clb
   Part No SW: 0CQ 907 554 E    HW: 0CQ 907 554 E
   Component: Quersperre    H52 8042
   Serial number: HA1-00011.01.17
   Coding: 0001
   ASAM Dataset: EV_LockElectHA1VW37X 001007
   ROD: EV_LockElectHA1VW37X.rod
   Component: HRE_Master    H11 0071
   Serial number: 0381240400
   Coding: 02011103
   ROD: EV_HREntryHella_VW37.rod
   VCID: 3C59D7DAB70219AAC1-8068
   Lane Change Assistant 2:
   Component: HRE_Slave  H11 0071
   Serial number: 0381951715
   Coding: 020111
   Serial number: 20111506050A2X
   Coding: 003E13200000020100000000
   VCID: 43ABAC26CAFC665280-8016
   Part No SW: 3Q0 909 144 J    HW: 3Q0 909 144 H
   Component: EPS_MQB_ZFLS  505 5063
   Coding: 9302
   VCID: 3957CECEB8302C82DA-806C
Address 47: Sound System (J525)       Labels:| 5Q0-035-456.clb
   Part No SW: 5Q0 035 456     HW: 5Q0 035 456
   Component: MIB2_lite_amp H20 0130
   Revision: 00000001    Serial number: VWZ8Z1FBA0139W8
   Coding: 2200000000AAAAAA000000000000
   ASAM Dataset: EV_AMPMst12C1Gen2ALPI 001003
   ROD: EV_AMPMst12C1Gen2ALPI.rod
   VCID: 6DFF2A9EBCF8402206-8038
   Serial number: 20111506050BUX
   Coding: 003E13200C00020100000000
   VCID: 42A5A922D5E66F5A8B-8016
   Coding: 021203010B000400
   VCID: 40A1A32ADBEA7D4A9D-8014
   Subsystem 1 - Part No SW: 5N0 941 329     HW: 5N0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo links  H01 0004
   Coding: 2E0000
   Subsystem 2 - Part No SW: 5N0 941 329     HW: 5N0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H01 0004
   Coding: 2E0000
google
   Part No SW: 3Q0 035 844     HW: 3Q0 035 844
   Component: MU-S-S-US     620 0613
   Coding: 027300000000000051220002001808001F0203F40120010002
   ROD: EV_MUStd4CDELP_VW26.rod
   VCID: 6CF9279A87E2492A11-8038
   Subsystem 1 - Part No SW: 3G0 919 605 H    HW: 3G0 919 605 H
   Component: ABT_Std-2  H52 1028
   Serial number: VWZ8Z9RES010PF
   Component: OCULowMQBUS   007 0568
   Coding: 02730002C28234017F1E06000000
   ROD: EV_OCULowMQB.rod
Address A5: Frt Sens. Drv. Assist (R242)       Labels:| 5Q0-980-653.clb
   Part No SW: 5Q0 980 653 G    HW: 5Q0 980 653
   Component: MQB_MFK       H06 0060
   Serial number: 10000420865
   Coding: 0100010100020300000400010100000100
   ROD: EV_MFKBoschAU370.rod
   Serial number: 150827200861
   VCID: 6BFB248682EC4E1218-803E
End-------------------------(Elapsed Time: 04:34)--------------------------
GTIronic
New Member
Also running into an issue getting the adaptive cruise resume tweak to work. Did many other little tweaks but for some reason those tied to DAP donÂ’t seem to be showing? Have been asking around a lot.
My car is a 2016 GTI SE w/ PP DCC DSG LP DAP (the full version with adaptive cruise, lane assist, park assist)
GTIronic
New Member
Thread bump- any idea as to why VAGCOM isn’t recognizing my hardware? Do these adapt settings to individual cars?
To
It's not that VCDS doesn't recognize your hardware; it clearly does. This is a question of what's documented.
In the case of your lighting configuration, BCM coding, Byte 2, bits 0-2, there are eight possible values for that bit field, only one of which is documented. It does not show your car has having halogens. It shows halogens as the only documented value for that bit-field.
As for your ACC module, it's possible that the value for 00 Byte 01, bit 0~1 is incorrectly described. The other possibilities are:
01 Adaptive Cruise Control (ACC) with Follow-to-Stop (not documented)
02 Adaptive Cruise Control (ACC) with Follow-to-Stop/Stop-and-Go
Now since these "ACC" sensors are also installed in plenty of cars that don't actually have ACC in order to accommodate the regulatory requirement for automatic emergency braking, it's possible that 00 is what's used on those, in addition cars that have ACC without follow-to-stop or stop-and-go.
It's also not clear that the cars in the Golf MK7 thread you're following have the same modules. Their Golfs are European produced ones, whereas your NAR GTI is likely Hecho en Mexico.
Uwe-
