MQB Mk7 ABS Module bleeding - basic settings (?)
Nuje
Canada
C?ID=120875
Finally got my new ABS module installed in my quest to get ACC retrofitted into my NAR 2015 GSW TDI.
I'm looking for how to do the ABS pump cycling and pumping of brake pedal (if needed?) that I had to do on my Mk4 when a line was opened and air got to the ABS pump.
I clicked on BASIC SETTINGS, and it provides a raft of things, but no instructions.
Questions:
1. Do I need to have pressure bleeder attached? 29psi I assume if so (that's what's referenced in manual for just about anything ABS hydraulics-related).
2. I did get the ABS pump pumping - but do I just let it run? With the pressure bleeder still attached?
Any opening of bleed valves and pumping brake pedal 10x or whatever?
Any info / experience would be appreciated.
Since there's no indication here that VCDS isn't working correctly, this does not belong in Product Support.
Since you've retrofit a different ABS, I've moved this to Retrofits.
Please post an Auto-Scan for context so people can see exactly what ABS module you've got in this car.
Nuje
Canada
C?ID=120875
Sorry, Uwe. Thanks for moving the thread.
Below is the auto-scan, as well as what I have available in Basic Settings and Output Tests.
Basic Settings:
Output Tests:
Auto-scan:
Saturday,26,October,2019,17:41:21:51218
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64(VMWare)
VCDS Version 19.6.2.0 (x64)  HEX-NET CB: 0.4508.4
Workshop Code: 790 06314 000000
VIN: 3VWCA7AUXFMxxxxxx   License Plate:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 02 03 05 08 09 13 15 16 17 19 20 2B 42 44 47 52 55 5F
VIN: 3VWCA7AUXFM500299   Mileage: 76852km-47753miles
20-High Beam Assist. -- Status: Malfunction 0010
Address 01: Engine (J623-CRUA)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 997 022 N    HW: 04L 907 309
   Component: R4 2.0l TDI   X23 9459
   Revision: 85X23---
   Coding: 011D0012834410081000
   Shop #: WSC 06314 790 00000
   ASAM Dataset: EV_ECM20TDI01104L997022N 004002
   ROD: EV_ECM20TDI01104L997022N.rod
   VCID: 3B36FBF0B2ADB297B2-806F
4971 - Glow Plug/Heater Indicator Circuit
          P0381 00 [039] - Implausible Signal
                    Mileage: 76852 km
                    Date: 2019.10.26
                    Time: 16:58:14
                    Coolant temperature: 16 °C
                    Intake air temperature: 17 °C
                    Voltage terminal 30: 11.080 V
                    Electric auxiliary heater: shut-off conditions-Bits 0-7: 0
                    Electric auxiliary heater: relay activation-Bits 0-7: 0
                    Preheat time: 1200 ms
                    Glow status-Bits 0-7: 0
                    Glow cycles above temperature threshold-Bits 0-7: 4
                    Glow cycles above temperature threshold-Bits 0-7: 35
                    Glow cycles below temperature threshold-Bits 0-7: 0
                    Glow cycles below temperature threshold-Bits 0-7: 1
                    Extern.temp.sens.1 bank 1: raw value: 13.5 °C
17149 - Check Coding of ECUs on Powertrain Data Bus
          P1647 00 [167] - -
          [Checking coding/versions ofcontrol modules in drivetrain]
                    Mileage: 76852 km
                    Date: 2019.10.26
                    Time: 16:58:14
                    ACC variants-Bits 0-7: 1
                    CCS Switch-Bits 0-7: 2
                    Cruise control switch actuation-Bits 0-7: 32
                    Cruise control switch actuation-Bits 0-7: 0
                    ACC variants (coding)-Bits 0-7: 2
                    Acceleration: 0.000 m/s²
Readiness: 0 0 0 1 1
   Part No SW: 0D9 300 041 N    HW: 02E 927 770 AQ
   Component: DQ250-6F MQB  H53 4512
   Revision: 03253104    Serial number: TFK01410290291
   Shop #: WSC 00066 790 00221
   ROD: EV_TCMDQ250021.rod
   VCID: 230623902A1DEA579A-8077
   Revision: 00000000    Serial number: 62535000000317
   Coding: 04FA6AA12420096C0079020981CC242056249000408124B216605050C002
   VCID: 7AB83EF4FD174B9FE9-802F
6 Faults Found:
0128 - Function Restricted due to Insufficient Voltage
          U1400 00 [008] - -
          [undervoltage]
                    Reset counter: 201
                    Mileage: 76852 km
                    Date: 2019.10.26
                    Time: 17:07:18
0212 - Longitudinal Acceleration Sensor
          C1017 54 [137] - Missing Calibration / Basic Setting
                    Reset counter: 161
                    Date: 2019.10.26
                    Time: 17:06:48
0270 - Lateral Acceleration Sensor
          C1079 54 [137] - Missing Calibration / Basic Setting
                    Reset counter: 161
                    Date: 2019.10.26
                    Time: 17:06:48
0295 - Steering angle sensor
                    Reset counter: 161
                    Date: 2019.10.26
                    Time: 17:06:48
8309 - Engine Control Module Incorrectly Coded
          P1612 00 [009] - -
                    Reset counter: 161
                    Mileage: 76852 km
                    Date: 2019.10.26
                    Time: 17:06:51
16413 - Display for Tire Pressure Monitoring
                    Reset counter: 161
                    Mileage: 76852 km
                    Date: 2019.10.26
                    Time: 17:06:57
   Revision: 00021000    Serial number: 0349846601
   Coding: 030C0C
   Shop #: WSC 01383 790 50316
   VCID: 3A38FEF4BD978B9FA9-806F
   Part No SW: 5GM 907 044 A    HW: 5GM 907 044 A
   Revision: 00001K01
   Coding: 02020124200100010005000000101400
   VCID: 42C88614D547C35FF1-8017
   Part No SW: 5Q0 937 087 R    HW: 5Q0 937 087 R
   Component: BCM PQ37BOSCH 028 0145
   Revision: --------    Serial number: 86580412141206
   Coding: 00511B464041A2E949E44000091407001800000000000000000000000000
   Shop #: WSC 00066 790 07031
   ROD: EV_BCMBOSCH_014.rod
   VCID: 4AD8AE34ED771B1F39-801F
   Component: WWS    140824  043 0581
   Serial number:         141224033541
   Component: RLHS  037 0059
   Serial number: S5Y14M12D09H11M16S22
   Coding: 06A8DD
   Sun Roof:
   Subsystem 3 - Part No SW: 5G0 959 591     HW: 7P0 959 591 C
   Component: J245 PS22.018  H01 0008
   Serial number:     WOO33584535
   Coding: 191800
   Roof Blind:
   Subsystem 4 - Part No SW: 5G0 959 591     HW: 7P0 959 591 C
   Component: J394 PS22.018  H01 0008
   Serial number:     WOO33583141
   Coding: 191800
131586 - Function Restricted due to Insufficient Voltage
          U1400 00 [008] - -
                    Reset counter: 201
                    Mileage: 76852 km
                    Date: 2019.10.26
                    Time: 17:07:15
Address 13: Auto Dist. Reg (J428)       Labels:| 5Q0-907-567.clb
   Part No SW: 5Q0 907 567 G    HW: 5Q0 907 567 G
   Component: ACC3          H08 0390
   Serial number: 14021376110493
   Coding: 01011000FE030B
   ASAM Dataset: EV_ACCBoschMQB 001021
   ROD: EV_ACCBoschMQB_VW37.rod
   VCID: 3FCE8FE0A6B5AEB79E-806B
6 Faults Found:
0077 - Function Restricted due to Insufficient Voltage
          U1400 00 [040] - -
          [FAULT_VMON_VZ_LOW]
                    Reset counter: 201
                    Control Module temperature: 23 °C
                    Voltage terminal 15: 8.4 V
                    Vehicle speed: 0.00 m/s
                    Acceleration: 0.00 m/s²
0078 - Function Restricted due to Insufficient Voltage
          U1400 00 [040] - -
          [FAULT_VMON_VZ_LOW1]
                    Reset counter: 201
1043 - Automatic Distance Control
          B10E7 F0 [047] - Disconnected
          [FAULT_CIS_TSK_IRREV_FAIL]
                    Reset counter: 161
                    Mileage: 76852 km
                    Date: 2019.10.26
                    Time: 16:58:32
                    Voltage terminal 15: 11.0 V
1058 - Databus
          U1123 00 [047] - Received Error Message
          [FAULT_CIS_ECD_NOTAVAILABLE]
                    Reset counter: 161
                    Mileage: 76852 km
                    Date: 2019.10.26
                    Time: 16:58:32
1059 - Databus
          [FAULT_CIS_ESP_FAIL]
                    Reset counter: 161
                    Mileage: 76852 km
                    Date: 2019.10.26
                    Time: 16:58:32
1071 - Databus
          [FAULT_CIS_AXV_INVALID]
   Part No SW: 5Q0 959 655 T    HW: 5Q0 959 655 T
   Serial number: 003MHM01GHAM
   ROD: EV_AirbaVW20SMEVW37X.rod
   VCID: 51EAB958002128C778-8005
   Occupant Detection:
   Component: BF-Gewichtss.  H10 0021
   Serial number: IBH0000J14000233FP0W
   Coding: 303136
   Subsystem 2 - Part No SW: -----------    HW: 480 000 511 14
   Serial number: 3570000000049398811F
   Subsystem 3 - Part No SW: -----------    HW: 480 000 511 14
   Serial number: 35800000000831388116
   Subsystem 4 - Part No SW: -----------    HW: 480 402 210 14
   Serial number: 3510002A91811BA1809.
   Subsystem 5 - Part No SW: -----------    HW: 480 402 210 14
   Serial number: 3520002B31811BA4D24
   Subsystem 6 - Part No SW: -----------    HW: 480 401 810 14
   Serial number: 35500029D175A8E2E2DR
   Front Sensor Passenger:
   Subsystem 7 - Part No SW: -----------    HW: 480 401 810 14
   Serial number: 35600029D175A8E4236C
9483008 - Seat Occupied Recognition
          B10B3 00 [008] - Function Restriction due to Implausible Message(s)
                    Reset counter: 201
                    Mileage: 76852 km
                    Date: 2019.10.26
                    Time: 17:18:35
   Revision: FF032032    Serial number: 20141031400890
   Coding: 0610
   ROD: EV_SMLSVALEOMQB.rod
   VCID: 0444400C8FD30D6F83-8051
          B1149 13 [009] - Open Circuit
                    Reset counter: 161
                    Mileage: 76852 km
                    Date: 2019.10.26
                    Time: 16:29:49
                    Ubat 30 Voltage: 11.20 V
                    Ignition State: On
                    Terminal 15: 10.40 V
                    A/D #1: 97.25 %
                    A/D #2: 35.69 %
                    A/D #3: 0.00 %
   Part No SW: 5G1 920 791 A    HW: 5G1 920 791 A
   Component: KOMBI         409 3197
   Coding: 03A551082D80880A02807B211C00000000000000
   VCID: 2A18CEB44D373B1FD9-807F
          U1014 00 [009] - -
                    Reset counter: 161
                    Mileage: 76852 km
                    Date: 2019.10.26
                    Time: 16:16:09
16776960 - Databus
          [ACC_02 keine Kommunikation]
                    Reset counter: 201
                    Mileage: 76852 km
                    Date: 2019.10.26
                    Time: 17:05:27
16776961 - Databus
          [ACC_04 keine Kommunikation]
                    Reset counter: 201
                    Mileage: 76852 km
                    Date: 2019.10.26
                    Time: 17:05:27
16776996 - Databus
          [FCW_01 keine Kommunikation]
                    Reset counter: 161
                    Mileage: 76852 km
                    Date: 2019.10.26
                    Time: 16:16:04
16777034 - Function Restricted due to Interrupted Communications
          U1110 00 [008] - -
          [BAP_DoorLocking_0x0D keine Kommunikation]
                    Reset counter: 201
                    Mileage: 76852 km
                    Date: 2019.10.26
                    Time: 15:58:46
   Revision: --------    Serial number: 12111410001103
   Coding: 0901000800087300FF00021A1C0F00000001050000000000000000000000
   Shop #: WSC 06314 790 12345
   ROD: EV_GatewConti_011.rod
   VCID: 72A816D4A56733DFA1-8027
   Component: E221__MFL-DC1  H16 0040
   Serial number: 29150001901890095392
   Coding: 2DFFFF
   Power Converter DC AC:
   Subsystem 3 - Part No SW: 5Q0 907 155 A    HW: 5Q0 907 155 A
   Component: WECHSELRICHTE  H53 0041
   Serial number: 0000431
          U1101 00 [009] - Active
                    Reset counter: 161
                    Mileage: 76852 km
                    Date: 2019.10.26
                    Time: 15:58:44
                    Supply voltage: Terminal 30: 10.8 V
                    Terminal 15: OFF
Address 20: High Beam Assist. (J844)       Labels:| 8X0-857-511.clb
   Part No SW: 5G0 857 511 D    HW: 5G0 857 511
   Component: FLA           H04 0002
   Revision: AA001001
   Coding: 02018864727264565625393E01
   VCID: 2B16CBB042CD221722-807F
114178 - Function Restricted due to Insufficient Voltage
          U1400 00 [008] - -
          [Funktionseinschränkung durch Unterspannung: unterer Grenzwert unterschrittenFunctional limitation due to under voltage: below lower limit]
                    Reset counter: 201
                    Mileage: 76852 km
                    Date: 2019.10.26
                    Time: 17:07:24
   Revision: 00000000    Serial number: 14000317831004
   Coding: 5D00000000000000
   Shop #: WSC 00066 790 07026
   ROD: EV_ELVMarquMQB.rod
   VCID: 3424D0CC9FF37DEF73-8061
          U1400 00 [008] - -
          [Under voltage (temporary)]
                    Reset counter: 201
                    Mileage: 76852 km
                    Date: 2019.10.26
                    Time: 17:07:12
                    ELV State: 24
                    Information Clamps: 77 62
                    CoCo State: A0 01
                    WFS State: 17 0E
                    Vehicle speed: 0.00 km/h
                    Voltage: 47
                    AD-Value H-bridge: 23
                    Clamp15 flip flop: SSTx: button contacts: 06
                    CAN signals: 00
   Serial number: 2611140605045J
   Coding: 007F1320D000040000000000
   VCID: 40CC8C1CDB4BD14FE7-8015
   Serial number: 00000000000000332757
   Coding: 011000
589829 - Window Regulator; Rear Driver side
          B131F F5 [008] - Supply Voltage too Low
                    Reset counter: 201
                    Mileage: 76852 km
                    Date: 2019.10.26
                    Time: 17:07:15
   Component: EPS_MQB_ZFLS  126 1061
   Coding: 0102
   VCID: 43C68310CA5DCA57FA-8017
Address 47: Sound System (J525)       Labels:| 5G0-035-456.clb
   Part No SW: 5G0 035 456     HW: 5G0 035 456
   Component: MIB_lite_amp  H40 0060
   Serial number: VWZ8Z1EC401VQM.
   Coding: 12000000AAAAAA0000
   ASAM Dataset: EV_AMPMst11CALPI 001006
   ROD: EV_AMPMst11CALPI.rod
   VCID: 638663906A9DAA57DA-8037
   Serial number: 021214060508AH
   Coding: 007F1320DC00040000000000
   Serial number: 00000000000000390612
   Coding: 091000
589845 - Window Regulator; Front Passenger side
          B1320 F5 [008] - Supply Voltage too Low
                    Reset counter: 201
                    Mileage: 76852 km
                    Date: 2019.10.26
                    Time: 17:07:15
   Coding: 060A00000B000400
   Subsystem 1 - Part No SW: 5N0 941 329     HW: 5N0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo links  H01 0004
   Coding: 2E0000
   Subsystem 2 - Part No SW: 5N0 941 329     HW: 5N0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H01 0004
   Coding: 2E0000
5275926 - Power Output Module for Left Headlamp
          C1081 16 [008] - Voltage Too Low
                    Reset counter: 201
                    Mileage: 76852 km
                    Date: 2019.10.26
                    Time: 17:07:39
5276182 - Power Output Module for Right Headlamp
          C1082 16 [008] - Voltage Too Low
                    Reset counter: 201
                    Mileage: 76852 km
                    Date: 2019.10.26
                    Time: 17:07:39
End----(Elapsed Time: 01:46, VBatt start/end: 11.4V/11.6V. VIgn 11.6V)-----
I imagine you would want the Basic Setting labeled:
IDE03649-ENG112323 -- Fill/bleed brake system
But I do not have any detailed instructions for this.
Nuje
Canada
C?ID=120875
That option opens up a window that has the usual "GO" button, along with two boxes that require "enter a one- to three-digit number" (in ms). Every number I tried failed. Without any instructions or guidance, I couldn't figure it out.
myounus
Northwest UK
C?ID=321059
Run all the basic setting options, drive car and see if any lights remain on. Re-scan car and post updated scan, don't worry if you can't run a specific basic setting
Careful -- that could be mis-interpreted. I'm pretty sure he does NOT want to run some of the Basic Settings in that list, for example "Resetting of all adaptation values" would probably be a Bad Thing (although I expect VCDS would warn about that one).
myounus
Northwest UK
C?ID=321059
Ah yes it could be, thus to clarify only run the options that start with 'basic setting':
Basic setting for brake pressure sensor
Basic setting for inlet / cut off valve
Basic setting of ESP sensor unit.
Hope it helps
Nuje
Canada
C?ID=120875
Like I mentioned, I had tried to do a couple of those Basic Settings or Output Tests in VCDS, but it asked for some parameter inputs ("input a number with one to three digits"), and whatever I entered always gave me errors.
I switched over to some Other Diagnostic Interface System which guided me through the process. Once I did that along with the basic settings of the steering angle sensor, all of the errors went away.
myounus
Northwest UK
C?ID=321059
That's odd as VCDS worked for me perfectly fine when I changed my ABS pump. Ah well at least you're sorted.
