is anyone able to provide me with Long Coding for this vehicle.
The VIN number on the windscreen is: WVWZZZ1KZ9W103390
The Scan shows a different VIN number as the cluster has been changed.
The advanced ID's of the Engine and Immobilizer are in the scan:
Friday,13,December,2019,14:15:34:08713
VCDS Version: 19.6.2.0 (x64) HEX-NET CB: 0.4508.4
VIN: WVWZZZ1KZ9W047340 License Plate: KING
Mileage: 165240km-102675mi Repair Order:
Chassis Type: 1K (1K0)
Scan: 01 03 08 09 15 16 17 19 25 37 42 44 46 52 56
VIN: WVWZZZ1KZ9W047340 Mileage: 165240km-102675miles
Address 01: Engine Labels: 03G-906-016-BKD.clb
Part No SW: 03G 906 021 PP HW: 03G 906 021 AN
Component: R4 2,0L EDC 000SG 4661
Revision: --H08--- Serial number: XXXXXXXXXXXXXX
Coding: 0000072
Shop #: WSC 66565 257 00032
VCID: 7CB40AD73FC96EAFFB-8028
008580 - Engine Coolant Temp Sensor on Radiator Outlet (G83)
P2184 - 000 - Signal too Low - Intermittent
Mileage: 164485 km
Time: 04:11:20
RPM: 1596 /min
Speed: 26.0 km/h
Voltage: 14.29 V
Bin. Bits: 00000111
Temperature: 72.9°C
Temperature: 70.2°C
000386 - Fuel Temp. Sensor A (G81)
P0182 - 000 - Short to GND - Intermittent
Mileage: 164838 km
Time: 13:50:15
RPM: 1197 /min
Speed: 31.0 km/h
Voltage: 14.29 V
Temperature: 17.1°C
Temperature: 63.0°C
Temperature: 123.3°C
000258 - Mass Air Flow Sensor (G70)
P0102 - 000 - Signal too Low - Intermittent
Fault Status: 00110000
Mileage: 165016 km
Time: 19:17:25
RPM: 924 /min
Duty Cycle: 79.7 %
Bin. Bits: 00000100
Mass Air / Rev.: 540.0 mg/str
Mass Air / Rev.: 0.0 mg/str
Part No SW: 1K0 907 379 AD HW: 1K0 907 379 AD
Component: ESP MK60EC1 H35 0104
Revision: 00H35001
Shop #: WSC 00153 210 92361
VCID: 74A422F7D79926EFB3-8020
6 Faults Found:
03306 - Coding Not Valid
Reset counter: 60
Mileage: 165240 km
Count: 3
Count: 2
Count: 12288
Count: 4161
Count: 43008
Fault Status: 01100101
Reset counter: 60
Mileage: 165016 km
Count: 16391
Count: 8192
Count: 279
Count: 43008
Reset counter: 60
Mileage: 165016 km
Count: 16391
Count: 8192
Count: 270
Count: 43008
Reset counter: 53
Mileage: 165016 km
Count: 16391
Count: 8192
Count: 195
Count: 43008
Reset counter: 60
Mileage: 165016 km
Count: 16391
Count: 8192
Count: 320
Count: 43008
Reset counter: 53
Mileage: 165016 km
Count: 16391
Count: 8192
Count: 291
Count: 43008
Part No SW: 1K0 820 047 HN HW: 1K0 820 047 HN
Component: Climatic PQ35 142 1111
Revision: 00142031 Serial number: 00000000000000
VCID: 77BE15FB06EF4DF796-8022
Revision: 00H54000 Serial number: 00000008750052
Coding: EF898F2700041500471400001400000000087F075C000100000000000000
Shop #: WSC 80093 222 69422
VCID: 3326E1EB521761D76A-8066
Subsystem 1 - Part No: 1K2 955 119 E Labels: 1KX-955-119.CLB
Component: Wischer 110808 021 0501
Coding: 00038805
Shop #: WSC 80093
Component: RLS 020908 054 0402
Coding: 00209069
Shop #: WSC 80093
10 Faults Found:
Fault Status: 00101100
Reset counter: 76
Mileage: 164595 km
Voltage: 12.45 V
Reset counter: 76
Mileage: 164595 km
Voltage: 11.70 V
Reset counter: 76
Mileage: 164595 km
Voltage: 12.50 V
Reset counter: 80
Mileage: 164595 km
Voltage: 12.15 V
Reset counter: 60
Mileage: 164339 km
Voltage: 12.50 V
Fault Status: 00101010
Reset counter: 76
Mileage: 164485 km
Voltage: 11.60 V
Reset counter: 76
Mileage: 164568 km
Voltage: 12.20 V
02385 - Rain / Light Recognition Sensor Function Restricted due to Under-Voltage
Reset counter: 73
Mileage: 164485 km
Voltage: 8.90 V
00154 - Windshield Wiper Motor; Passenger Side (V217)
Reset counter: 73
Mileage: 164485 km
Voltage: 8.85 V
02383 - Windshield Wiper Motor Function Restricted due to Under-Voltage
Reset counter: 73
Mileage: 164485 km
Voltage: 8.90 V
Part No SW: 1K0 909 605 T HW: 1K0 909 605 T
Component: 38 AIRBAG VW8 020 2300
Revision: 05020000 Serial number: 0038PD266V7F
Coding: 0013112
VCID: 3D32C7D36453A7A78C-8068
Subsystem 1 - Serial number: 6332MSME3F36226DL
Subsystem 2 - Serial number: 6342MSME3F532C76P
Subsystem 3 - Serial number: 6352QSME79085814J
Subsystem 4 - Serial number: 6362QSME6508233CH
00532 - Supply Voltage B+
Part No SW: 1K0 953 549 CB HW: 1K0 953 549 CB
Component: J0527 051 0101
Coding: 0002002
VCID: 74A422F7179926EFB3-8020
00576 - Terminal 15
00884 - Ignition Switch (D) Terminal X
01744 - Ignition Switch Terminal P (D)
Part No SW: 1K0 920 964 B HW: 1K0 920 964 B
Component: KOMBIINSTRUMENT VDD 1212
Revision: V0002000 Serial number: VWX7Z0H63N18TG
Coding: 0003403
Shop #: WSC 00867 210 91890
VCID: 2C14FA978F293E2F2B-8078
Fault Frequency: 14
Reset counter: 73
Mileage: 164484 km
Time: 06:48:15
Component: J533__Gateway €a 0202
Revision: €a Serial number: 2700
Coding: E9801F064002020003
VCID: 3522DFF35C637FE744-8060
Reset counter: 30
Mileage: 164436 km
Time: 13:41:00
Component: IMMO VDD 1212
01176 - Key
Mileage: 164359 km
Time: 14:39:56
Address 37: Navigation
Part No SW: 1K0 959 701 M HW: 1K0 959 701 M
Component: Tuer-SG 006 1208
Coding: 0000564
VCID: 383CD6C74B71828F5F-806C
00109 - Left Mirror Turn Signal Lamp (L131)
Part No: 1K0 909 144 C
Component: EPS_ZFLS Kl. 69 2301
Revision: 00H15000
Shop #: WSC 01324 785 00200
VCID: 2A18FC8F85DD201FD9-807E
Fault Status: 11100101
Mileage: 164359 km
Time: 14:40:01
Battery Volts: 12.0 V
DD
Temperature: 22.0°C
Count: 3
Steering Angle: 0.00°
SteerAng n.Init
Part No SW: 1K0 959 433 BT HW: 1K0 959 433 BT
Component: KSG PQ35 G2 020 0204
Revision: 00020000 Serial number: 00000000000000
Coding: 819002085103087F2D04840570085AC690BC00
Shop #: WSC 00000 785 00200
VCID: 0346712B42371157BA-8056
Subsystem 1 - Component: Sounder No Answer
Subsystem 2 - Part No: 1K0 951 178 A
Component: Neigungssensor 003 0203
Subsystem 3 - Part No: 1K0 951 178 A
Component: Innenraumueberw.003 0203
01134 - Alarm Horn (H12)
Reset counter: 33
Mileage: 164359 km
Time: 14:40:04
Part No SW: 1K0 959 702 M HW: 1K0 959 702 M
Coding: 0000564
VCID: 393AD3C3707B9B87A0-806C
Part No: 1K0 035 186 T
Component: Radio GR0 020 0023
Revision: 0002006S Serial number: VWZ2Z2G2281248
Coding: 0040402
Shop #: WSC 00028 028 00001
VCID: 373ED5FB466F8DF756-8062
00857 - CD Changer Unit (R41)
00856 - Radio Antenna
End----(Elapsed Time: 01:03, VBatt start/end: 11.9V/11.8V. VIgn 11.8V)-----
Address 01: Engine
Control Module Part Number: 03G 906 021 PP
Component and/or Version: R4 2,0L EDC 000SG 4661
Software Coding: 0000072
Work Shop Code: WSC 66565
Advanced Identification
Identification: BPG-810
Revision: --H08---
Date: 16.08.08
Test stand number: 1349
Manufacturer number: 0002
Flash Status
Programming Attempts: 2
Successful Attempts: 2
Programming Status: 00000000
Required Conditions: 00000000
Flash Tool Code: 00032 257 66565
Flash Date: 00.00.00
Software
P0101
HAXN
Misc.
Hardware number: 03G 906 021 AN
Immo Challenge: 5A 10 74 FF
Car Info
Chassis Number: XXXXXXXXXXXXXXXXX
VCDS Info:
Readiness: No script available
Control Module Part Number: 1K0 920 964 B
Component and/or Version: IMMO VDD 1212
Software Coding:
Work Shop Code: WSC 00000
Identification: VDD-024
Revision: V0002000
Date: 01.07.08
Test stand number: 7702
Manufacturer number: 1428
Flash Status
Programming Attempts: 0
Successful Attempts: 0
Required Conditions: 00000001
Flash Tool Code: 00000 000 00000
Flash Date: --.--.--
Software
DKBI339
Y012
Z0012
Misc.
Hardware number: 1K0 920 964 B
Lot Number: 000
Type Lock: 0000
Car Info
Chassis Number: WVWZZZ1KZ9W047340
VCDS Info:
Gateway Installation List: 1K0 907 530 Q
Address 19,1K0 907 530 Q,recoded (Installation List),from,E9801F064002020003,to,E9801F060002020003,,
