No ROD file found...
Dukedesmo
C?ID=288946
Did an autoscan of my Audi S4 today, no faults and AFAIK everything working OK but at the end of the scan I get a popup;
"No ROD file found"
with the description;
" Unable to find a .ROD file for: EV_SoundAc 002005 (AU48)
Please make sure you are using the latest version (including BETA).
If you are using the latest version, please send an Autoscan from this car to Ross-Tech."
At the end of the autoscan is an extra paragraph to previous scans;
"No ASAM data for: "EV_SoundAc" (AU48)
No fault code found."
VCDS is Ver 18.1.0 which I believe is the latest version?
Is this a VCDS fault or something on my car?
Eric
HC800000
No autoscan? :)
If this is this car it sounds like you had a comms issue reading the ASAM ID of that controller, which should be EV_SoundActuaGen2AU64X.
Dukedesmo
C?ID=288946
No autoscan? :)
Yes that's the car, here's the autoscan;
Tuesday,13,February,2018,12:38:07:24986
VCDS Version: 18.1.0.2
VIN: WAUZZZ8K7EA150192   License Plate:
Chassis Type: 8K-AU48 (8R0)
Scan: 01 02 03 05 08 09 15 16 17 19 30 36 42 44 46 47 52 53 56 5F
          62 6D 72 A9
VIN: WAUZZZ8K7EA150192   Mileage: 38310km-23804miles
Address 01: Engine (J623-CGWC)       Labels:. 06E-907-551-CGW.clb
   Part No SW: 8K5 907 551 D    HW: 4H0 907 551
   Component: 3.0l V6 TFSIX07 0004
   Revision: --X07---
   Coding: 12250034052701020800
   Shop #: WSC 06208 000 00000
   ASAM Dataset: EV_ECM30TFS0218K5907551D 001004
   ROD: EV_ECM30TFS0218K5907551D.rod
   VCID: 377CA0AB8E2C1EFD44-8062
   Part No SW: 8K5 927 156 B    HW: 0B5 927 156 K
   Component: 0B5 30TFSIRdW H03 0003
   Revision: --H03---
   Coding: 000001
   Shop #: WSC 04742 780 00200
   ROD: EV_TCMDL501021.rod
   VCID: 387EA397833211854D-806C
Address 03: ABS Brakes (J104)       Labels:. 8K0-907-379-V2.clb
   Part No SW: 8K0 907 379 CP    HW: 8K0 907 379 CP
   Component: ESP8 quattro  H09 0020
   Coding: 291DCC01
   Shop #: WSC 06335 000 00000
   VCID: 09181653A058D80DE2-805C
   Part No SW: 8K0 907 064 JG    HW: 8K0 907 064 JG
   Component: BCM2 2.0      H14 0650
   Coding: 01B24040000000000000
   VCID: 7EF2758FE996EFB5C7-802A
   Subsystem 1 - Part No SW: 8K0 959 754 BH    HW: 8K0 959 754 BH
   Serial number: 0514000046830011
   Subsystem 2 - Part No SW: 8K0 905 852 E    HW: 8K0 905 852 E
   Serial number: 0214000068278002
   Part No SW: 8K2 820 043 AQ    HW: 8K2 820 043 AQ
   Component: KLIMA 3 ZONEN H04 0122
   Revision: D1000000    Serial number: 01100420140302
   Coding: 6624028000
   VCID: 78FE6397CBB2D1858D-802C
   Revision: 08016001    Serial number: 00000789946701
   Coding: 260000118034AFC00081404300001D0D0F1D470A27090201000008004400030100000024000000
   Subsystem 1 - Part No SW: 8K2 955 119 A    HW: 8T2 955 119   Labels: 1KX-955-119.CLB
   Component: WWS 010414  H06 0080
   Serial number: SWF14044015610
   Coding: 00FD11
   Serial number: 22487512
   Coding: 02005D
   Component: E1 - LDS  H03 0031
   Serial number: 00000000000104144832
   Serial number: FA780227000000000001
   Component: AirbagVW-AU10 H48 0610
   Serial number: 003KFDC0WUTP
   Coding: 30534435363030303030554A3052384B3053
   Shop #: WSC 60782 001 1048576
   VCID: 489ED357F3D261053D-801C
   Serial number: 6334MSME443A333AD
   Serial number: 6344MSME443C6E75T
   Serial number: 6352QSME1E400648E
   Serial number: 6362QSME1A401B6EP
   Serial number: 63732SME40404A66X
   Serial number: 63832SME4F400F689
   Part No SW: 8K0 953 568 Q    HW: 8K0 953 568 Q
   Component: Lenks.Modul   H03 0003
   Revision: C0062331    Serial number: 90862NDE001IC
   Coding: 000037
   VCID: 489ED357FBD261053D-801C
   Part No SW: 8K0 920 982 T    HW: 8K0 920 982 T
   Component: KOMBIINSTR.   H35 0564
   Revision: 00100000    Serial number: ZAE62M34F
   Coding: 33BF110003012600010000
   VCID: 4580DA63CCC07C6DC6-8010
   Component: GW-BEM 4CAN-M H11 0060
   Revision: 1Y080030    Serial number: 3041Y143310158
   Coding: 80CF07FF00
   VCID: 4A9AE95FE5DE93152B-801E
   Serial number: 9802233103
   Serial number: 14099003849011200410
   Part No SW: 8K0 907 440 B    HW: 8K0 907 440
   Component: STS           H04 0020
   Revision: S0H04000    Serial number: 00000000084090
   Coding: 01010101000000000001000102
   VCID: 2D5082C37470A42D2E-8078
   Part No SW: 8K0 959 760 D    HW: 8K0 959 760 D
   Component: MEM-FS        H06 0077
   Revision: AA000000    Serial number: 00000097259421
   Coding: 01781300000000000000
   VCID: 3B74BC9BBA043A9DA0-806E
   Component: TSG FA        H02 0510
   Revision:             Serial number: 0000098884238
   Coding: 011C02205E21410001
   VCID: 4FACF84B1EBCB63D7C-801A
   Part No SW: 8K0 909 144 G    HW: 8K0 909 144 B
   Component: RCEPS         H40 0508
   Revision: 00001000    Serial number: 0003457337
   Coding: 100000000001
   Shop #: WSC 06334 000 00000
   ASAM Dataset: EV_RCEPSAU48X 008015
   ROD: EV_RCEPSAU48X_008.rod
   VCID: 3560AAA39420ECED56-8060
   Revision: 00002001    Serial number: 0332027708
   Coding: 013B0622A0B938948330023680000047
   Subsystem 3 - Part No SW: 8K0 959 591 C    HW: 8K0 959 591
   Component: J245 PS151  H08 0043
   Subsystem 4 - Part No SW: 8K0 959 591 C    HW: 8K0 959 591
   Component: J394 PS240  H08 0043
   Revision: 00005001    Serial number: 94813028507104
   Revision:             Serial number: 0000098720192
   VCID: 4E92E54F19B6BF3577-801A
   Part No SW: 8K0 907 801 N    HW: 8K0 907 801 J
   Component: EPB-4         H01 0005
   Revision: --------    Serial number: 20000000431915
   ROD: EV_ParkiBrake_AU48.rod
   VCID: 3A7AB99FBD3E0395BB-806E
   Part No SW: 4G0 035 061 N    HW: 4G0 035 061
   Component: Radio U DAB   H60 0139
   Revision: AB001007    Serial number: 109D20E7915856
   Coding: 010103010000000001
   VCID: 285E73D75B928105DD-807C
   Part No SW: 8R2 035 666 E    HW: 8R2 035 666 C
   Component: H-BN-EU       H47 0793
   Revision: --------    Serial number: 206DZ0E7560780
   Coding: 110101010206A1ED41808F5E00000403E40100020000000000
   Subsystem 1 - Part No: 8R0 060 884 BK
   Component: EUR 2014  1703
   Component: DU7 High  H42 0104
   Serial number: A130DI0E3000809
   Subsystem 3 - Part No SW: 8T0 919 611 K    HW: 8T0 919 611 B
   Serial number: 00000001824649
   Component: CD-Database  5571
   Component: TSG HL        H01 0510
   Revision:             Serial number: 0000098922402
   Coding: 010C02204021210001
   VCID: 4682DD6FF1C67775CF-8012
   Part No SW: 8K9 827 851 C    HW: 8K9 827 851 C
   Component: J605  Master  H53 0330
   Revision: --------    Serial number: 8K9827851C
   VCID: 3E72B58FA9162FB587-806A
   Subsystem 1 - Part No SW: 8K9 827 852 C    HW: 8K9 827 852 C
   Component: J756  Slave  H53 0330
   Serial number: 8K9827852C
   Component: TSG HR        H01 0510
   Revision:             Serial number: 0000098919842
   Part No SW: 8K0 907 159     HW: 4H0 907 159 A
   Component: SAS-GEN 2     H06 0005
   Serial number: 140301200807
   ASAM Dataset: EV_SoundAc 002005
   ROD: N/A
   VCID: 72EA51BFA5CEBBD5B3-8026
End-------------------------(Elapsed Time: 05:33)--------------------------
Dukedesmo
C?ID=288946
Here's the error popup;
If it matters, I think this is the first autoscan on this car since the recent update of VCDS software?
Eric
HC800000
Does it happen all the time? PC specs?
Dukedesmo
C?ID=288946
I've only done the one autoscan with this software and this PC combination on this car. But it didn't show any errors before with this PC and the older software.
The PC is an old, small Samsung notebook; Intel Atom CPU N570 @1.66GHz with 2mb RAM on Win7. I do have a couple of more modern laptops with Win10 which I also use (the scan you linked to was done with a newer Win10 PC) but not tried with the new software yet.
I generally use the Samsung though because it's a 10" screen so convenient size to be easily portable, has a huge battery life and is of low enough value that if I drop it, it doesn't matter too much. I have noticed that it takes longer to do an autoscan than a newer PC though.
Eric
HC800000
Well I did say a long time ago that if you insist on using an Atom under UDS with the ever-growing dataset that VAG is forcing down everyone's throat, a HEX-v2 or HEX-NET would be the way forward... :)
Dukedesmo
C?ID=288946
OK, I'll do a scan with a better PC and get back to you. :thumbs:
Dukedesmo
C?ID=288946
I've done some more scans, using 4 different PCs including the above mentioned Atom and all are OK this time. There was quite a difference in time taken though which I suppose is down to processor speed?
From 5:38 slowest (mighty Atom) to 4:07 fastest (Pentium i7), all scans show the 'missing' ROD file.
Tuesday,13,February,2018,17:52:05:24986
VCDS Version: 18.1.0.2 (x64)
          62 6D 72 A9
   Revision: --X07---
   Revision: --H03---
   Coding: 000001
   Coding: 291DCC01
   Coding: 6624028000
   Coding: 00FD11
   Coding: 02005D
   Coding: 000037
   Coding: 80CF07FF00
   ASAM Dataset: EV_SoundActuaGen2AU64X 002005
   ROD: EV_SoundActuaGen2AU64X_002.rod
End-------------------------(Elapsed Time: 04:07)--------------------------
Happy to know it's not a car problem. :thumbs:
Yup. Processor speed can be a limiting factor in how fast VCDS can load the data required for each module.
Sounds like you encountered a one-time, sporadic communications glitch on the first scan. Part of that module's data identifier either didn't get sent by the car or got dropped somewhere before it got to VCDS, so with an incomplete identifier, VCDS was unable to find the corresponding data.
