e-Golf After Clearing DTC"S Drive Motor Stalls
e-Scott
C?ID=377420
So, is it possible that this error is related to when I clear DTC’s then drive my car the drive motor stalls for two or three seconds. VCDS versions before 20.4.0 would stall drive motor twice consecutively then is fine until next time DTC’s are cleared and version 20.4.0 only stalls once then is fine until next time DTC’s are cleared.
This Drive Motor stall happens ever time I clear DTC's.
"Fahrzeugabstellzeit_Error" translates to "Vehicle shut-off time Error".
239616 - Implausible Data Received from Engine Control Module
U0401 00 [040] - -
[iBoVAG_Scl_Motor_31_MO_Fahrzeugabstellzeit_Error]
Fault Frequency: 7
Mileage: 30297 km
Date: 2020.04.03
Time: 06:52:27
Thursday,16,April,2020,15:46:00:11757
Dealer/Shop Name:
VIN: WVWPP7AU4FW910714   License Plate:
Mileage: 30466km-18930mi   Repair Order: 4-16-2020
Chassis Type: AU-VW37 (5QE)
Scan: 01 03 05 08 09 10 15 16 17 19 23 2B 42 44 51 52 55 5F 75 8C
          BD C0 C5 C6
VIN: WVWPP7AU4FW910714   Mileage: 30466km-18930miles
23-Brake Booster -- Status: Malfunction 0010
BD-Hi Volt. Batt. Charg. -- Status: OK 0000
C5-Therm. mgt. -- Status: OK 0000
C6-Batt. Chrg. -- Status: OK 0000
Address 01: Engine (J623-EAGA)       Labels:. 0EA-907-309-V1.clb
   Part No SW: 0EA 906 016 C    HW: 0EA 907 309 A
   Component: E-Vehicle     H23 8073
   Revision: WMH23---
   Coding: 000D0016002400007000
   ASAM Dataset: EV_VCU00XXX0110EA906016C 002005
   ROD: EV_VCU00XXX0110EA906016C_002.rod
   VCID: 2F3B133CC79F92A3FA8-807A
Address 03: ABS Brakes (J104)       Labels: 5Q0-907-379-OMG-V1.clb
   Part No SW: 5Q0 907 379 AE    HW: 5Q0 907 379 H
   Component: ESC           H31 0808
   Revision: 00000000    Serial number: 60725000000723
   Coding: 01FA40A12C21316C017E020181C7298002348C80408194B202810058C242
   ASAM Dataset: EV_Brake1UDSContiMK100OMG 001001
   ROD: EV_Brake1UDSContiMK100OMG_001.rod
   VCID: 7F5B037C577FA2232A8-802A
   Revision: 00021000    Serial number: 0363463688
   Coding: 030C0C
   Shop #: WSC 12345 123 61029
   VCID: 3A2D32680CDD470B5D6-806E
   Part No SW: 5GE 907 044 AD    HW: 5GE 907 044 AD
   Component: Climatronic   H02 1105
   Revision: 00001K07
   Coding: 00022200100100000005004200111801
   ASAM Dataset: EV_ACClimaBHBVW37X 005132
   ROD: EV_ACClimaBHBVW37X_005_VW37.rod
   VCID: 7EA5FE785075AB2B21E-802A
   Part No SW: 5Q0 937 085 AB    HW: 5Q0 937 085 AB
   Component: BCM MQBAB MNA H18 0137
   Serial number: 01011507500860
   Coding: 00011A66434182E169E44000001407201C00000000000000000000000000
   ROD: EV_BCMBOSCH_013.rod
   VCID: 79AFED64495B8C1314C-802C
   Component: WWS    150321  043 0551
   Serial number:         150323130759
   Component: RLHS  037 0059
   Serial number: S2Y15M04D02H08M20S05
   Coding: 90A8DD
   Part No SW: 5Q0 919 294 E    HW: 5Q0 919 294 A
   Component: PARKHILFE 8K  H03 0048
   Revision: --------    Serial number: 39391506403262
   Coding: 2031151011
   VCID: 3D2739741DF37033784-8068
   Serial number: 003GCR01LJJW
   Coding: 8CCCFC00002000005000001AC24800000065
   VCID: 47CB5B9C4F2F2AE3D28-8012
   Occupant Detection:
   Component: BF-Gewichtss.  H10 0021
   Serial number: IBH0000J150002JLB10$
   Coding: 303139
   Subsystem 2 - Part No SW: -----------    HW: 480 002 603 15
   Serial number: 35700000000967DC631T
   Subsystem 3 - Part No SW: -----------    HW: 480 002 603 15
   Serial number: 3580000000072C59C31O
   Subsystem 4 - Part No SW: -----------    HW: 480 402 003 15
   Serial number: 3510002B719DB890F17H
   Subsystem 5 - Part No SW: -----------    HW: 480 402 303 15
   Serial number: 3520002A31A14CA501B.
   Subsystem 6 - Part No SW: -----------    HW: 480 402 403 15
   Serial number: 3550002A71A14CA161C4
   Front Sensor Passenger:
   Subsystem 7 - Part No SW: -----------    HW: 480 402 403 15
   Serial number: 3560002A71A14CA4E2FK
   Part No SW: 5Q0 953 507 EA    HW: 5Q0 953 549 C
   Revision: --------    Serial number: 26031504400235
   Coding: 0410
   ROD: EV_SMLSKLOMQB_009_VW37.rod
Address 17: Instruments (J285)       Labels:* None-SRI3
   Part No SW: 5GE 920 855     HW: 5GE 920 855
   Component: KOMBI         301 4311
   Coding: 0B35181A2B80CF05020868001700030000000000
Address 19: CAN Gateway (J533)       Labels:* Redir Fail!
   Part No SW: 5QE 907 530 C    HW: 5QE 907 530 A
   Component: GW MQB EV     312 3203
   Revision: --------    Serial number: 17031510800800
   Coding: 0201001746F81000EF001200081E00000001050100030000000000000000
   ASAM Dataset: EV_GatewEVConti 011020
   ROD: EV_GatewEVConti_011.rod
   VCID: 46D55698482533EB29E-8012
   Subsystem 1 - Part No SW: 5G0 959 442 P    HW: 5G0 959 442 P  Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H16 0101
   Serial number: 36150000204100115062
   Coding: 30FFFF
   Subsystem 2 - Part No SW: 5Q0 915 181 G    HW: 5Q0 915 181 G
   Serial number: 7315436103
Address 23: Brake Booster (J539)       Labels:* None
   Part No SW: 5QE 909 059 A    HW: 5QE 909 059 A
   Component: EBKV          H12 0160
   Serial number:   085430010671
   Coding: 01720100321A02030002000500
   ASAM Dataset: EV_BrakeBoostBoschMQBOMG 002014
   ROD: EV_BrakeBoostBoschMQBOMG_002_VW37.rod
   VCID: 4CC164B05649C9BBFFA-8018
   Brake Assistance Sub:
   Subsystem 1 - Part No SW: 5QE 909 057 A    HW: 5QE 909 057 A
   Component: VX70BrakeAssi  H04 0140
   Serial number: 05802861190315193505
          U0401 00 [040] - -
                    Fault Frequency: 7
                    Mileage: 30297 km
                    Date: 2020.04.03
                    Time: 06:52:27
   Revision: 00000000    Serial number: 15000082241003
   Coding: 7900000000000000
   ROD: EV_ELVMarquMQB.rod
   VCID: 34311C502EB9B17B87A-8060
   Part No SW: 5Q0 959 393 D    HW: 5Q0 959 393 B
   Serial number: 240315BCO09214
   Coding: 003013208000040000000000
   VCID: 40D940806A011DDB132-8014
   Serial number: 00000000000005663835
   Coding: 111000
   Component: EPS_MQB_ZFLS  126 1061
   Coding: C102
   VCID: 43D34F8C7B1706C30E0-8016
Address 51: Electric Drive (J841)       Labels: None
   Part No SW: 5QE 907 080 C    HW: 5QE 907 080 C
   Component: VW370E2615010 H06 2461
   Revision: 00H06000
   Coding: 40020000000000000000
   ASAM Dataset: EV_DMCM09550115QE907080C 001020
   ROD: EV_DMCM09550115QE907080C.rod
   Part No SW: 5Q0 959 392 D    HW: 5Q0 959 392 B
   Serial number: 150315BCF04831
   Coding: 003013208C00040000000000
   VCID: 3FDB437C17FF62236A8-806A
   Serial number: 00000000000005685172
   Coding: 091000
          B1487 54 [009] - Missing Calibration / Basic Setting
                    Reset counter: 83
                    Mileage: 30416 km
                    Date: 2020.04.12
                    Time: 22:57:43
   Coding: 051A000101000000
   VCID: 75B7E1546543E873704-8020
   Part No SW: 5G0 035 876     HW: 5G0 035 876
   Component: MU-S-NS-US    014 R025
   Serial number: V7B01203153393
   Coding: 02737002FF00000021220001001800001F0100140100010546
   ROD: EV_MUStd4CPASE_VW37.rod
   VCID: 698FBD2439FB3C93E4C-803C
   Subsystem 1 - Part No SW: 5G0 919 605 K    HW: 5G0 919 605 K
   Component: ABT_Std_Nav  H60 0030
   Serial number: VWZ8Z9RS600LEG
   Subsystem 2 - Part No SW: 5G0 919 866 S    HW: -----------
   Component:  NAR 2015  --- 0022
          B11CF 53 [009] - Deactivated
                    Reset counter: 80
                    Mileage: 30297 km
                    Date: 2020.04.02
                    Time: 16:35:00
                    Voltage terminal 30: 14.7 V
   Component: OCULowMQBUS   007 0564
   Coding: 02737002C2829A017FFE06000000
   ROD: EV_OCULowMQB.rod
Address 8C: Hybrid Battery (J840)       Labels: 5QE-915-227.clb
   Part No SW: 5QE 915 227 M    HW: 5QE 915 227 H
   Component: K8C           H13 0722
   Serial number: VWADFDA001
   ASAM Dataset: EV_BECM08820215QE915227M 003016
   ROD: EV_BECM08820215QE915227H.rod
   VCID: 52FD7AC8B46D9F4BB56-8006
Address BD: Hi Volt. Batt. Charg. (J966)       Labels:| 5QE-915-022.clb
   Part No SW: 5QE 915 022 G    HW: 12E 915 022 C
   Component: LMSG          H08 1075
   Serial number: 00920051020339
   Coding: 4A4904
   ASAM Dataset: EV_HVChargManagVWMQB 001001
   ROD: EV_HVChargManagVWMQB_001.rod
   VCID: 45D75194752338F3204-8010
Address C0: Act. for Ext. Noise (----)       Labels:| 5QE-035-335.clb
   Part No SW: 5QE 035 335 H    HW: 5QE 035 335 H
   Component: E_SOUND_SG    H07 0198
   Serial number: EN151201090000
   Coding: 04
   ASAM Dataset: EV_ENoiseS1NNVW3707 005012
   ROD: EV_ENoiseS1NNVW3707_005.rod
Address C5: Therm. mgt. (J1024)       Labels: None
   Part No SW: 5GE 907 458     HW: 5GE 907 458
   Component: TME-Min       H03 0108
   Serial number: 0007641
   ASAM Dataset: EV_ThermContrVISAU49X 001009
   ROD: EV_ThermContrVISAU49X_VW37.rod
   VCID: 025D8A88248DCFCB456-8056
   Subsystem 1 - Part No SW: 4M0 959 603     HW: 4M0 959 603
   Component: G395 pT-Sens1  H61 0006
   Subsystem 2 - Part No SW: 12E 963 231 E    HW: 12E 963 231 E
   Component: J848 HV-PTC  H09 0205
   Serial number:  T150863003805000145
   Subsystem 3 - Part No SW: 5QE 820 803     HW: 5QE 820 803
   Component: J842 eKK  H03 0006
   Geber für Kältemitteldruck/Kältemitteltemperatur 2:
   Subsystem 4 - Part No SW: 4M0 959 603     HW: 4M0 959 603
   Component: G826 pT-Sens2  H61 0006
   Geber für Kältemitteldruck/Kältemitteltemperatur 3:
   Subsystem 5 - Part No SW: 4M0 959 603     HW: 4M0 959 603
   Component: G827 pT-Sens3  H61 0006
   Geber für Kältemitteldruck/Kältemitteltemperatur 4:
   Subsystem 6 - Part No SW: 4M0 959 603     HW: 4M0 959 603
   Component: G828 pT-Sens4  H61 0006
   Geber für Kältemitteldruck/Kältemitteltemperatur 5:
   Subsystem 7 - Part No SW: 4M0 959 603     HW: 4M0 959 603
   Component: G829 pT-Sens5  H61 0006
   Refrigerant Expansion Valve 1:
   Subsystem 8 - Part No SW: 4M0 816 682     HW: 4M0 816 682
   Component: N636 EV1_KaMi  H09 0102
   Serial number: 00000000000020038311
   Refrigerant Expansion Valve 2:
   Subsystem 9 - Part No SW: 4M0 816 682     HW: 4M0 816 682
   Component: N637 EV2_KaMi  H09 0102
   Serial number: 00000000000020038312
   Refrigerant Expansion Valve 3:
   Subsystem 10 - Part No SW: 4M0 816 682     HW: 4M0 816 682
   Component: N638 EV3_KaMi  H09 0102
   Serial number: 00000000000020038313
   Refrigerant Shut Off Valve 1:
   Subsystem 11 - Part No SW: 4M0 816 703     HW: 4M0 816 703
   Component: V424 AV1_KaMi  H09 0102
   Serial number: 00000000000040038551
   Refrigerant Shut Off Valve 4:
   Subsystem 12 - Part No SW: 4M0 816 703     HW: 4M0 816 703
   Component: N642 AV4_KaMi  H09 0102
   Serial number: 00000000000040036930
   Refrigerant Shut Off Valve 5:
   Subsystem 13 - Part No SW: 4M0 816 703     HW: 4M0 816 703
   Component: N643 AV5_KaMi  H09 0102
   Serial number: 00000000000040036212
32837 - HV Electronics Coolant Pump Control
          P0CEB 00 [032] - Short to GND
                    Fault Frequency: 18
                    Mileage: 30297 km
                    Date: 2020.04.02
                    Time: 16:42:37
Address C6: Batt. Chrg. (J1050)       Labels: 5QE-915-681.clb
   Part No SW: 5QE 915 681 B    HW: 5QE 915 681 B
   Component: OBC Delta-ES  H52 1550
   ASAM Dataset: EV_OBCTwoPhaseDT2VW3707 003009
   ROD: EV_OBCTwoPhaseDT2VW3707.rod
   VCID: 4BC367AC5347CE83F60-801E
End----------(Elapsed Time: 01:55, VBatt start/end: 14.5V/14.5V)-----------
I do not think anything has changed about the manner in which VCDS requests the fault codes to be cleared in 20.4 vs earlier versions.
Are you clearing faults in while driving? That's probably not something you should do. ;)
If you're not clearing them while driving, are you cycling the ignition after clearing faults? That's probably something you should do. Based on the fault in 23-Brake Booster, it's possible there's a minimum amount of time the car would like the ignition off after clearing faults, before you turn it back on again too.
