Help! Can’t recode abs with vcds lite
RunsDeep
Verified VCDS-Lite User
C?ID=367120
Help! Can’t Recode ABS with VCDS Lite
Chassis Type: 4B - Audi A6 C5
Scan: 01,02,03,06,08,15,16,17,18,22,34,35,36,37,45,55,56,57,65,67,75,76,77
Address 01: Engine       Labels: None
   Controller: 4D0 907 560 CE
   Component: 4.2L V8/5V      G   0002
   Coding: 07752
   Shop #: WSC 02325
   VCID: 6BA94FB00A9D
   WAUML64B62N148552     AUZ7Z0B2121682
Readiness: 0110 1101
Address 02: Auto Trans       Labels: 01L-927-156.LBL
   Controller: 4D0 927 156 EA
   Component: AG5 01L 4.2l5V  RdW 1010
   Coding: 00001
   Shop #: WSC 02314
   VCID: 6CAB4CAC0F93
Address 03: ABS Brakes       Labels: 4B0-614-517.LBL
   Controller: 4B0 614 517 R
   Component: ABS/ESP allrad      2330
   Coding: 06397
   Shop #: WSC 12345
   VCID: 301398DCE33B
01486 -  System Function Test Activated
            35-00 -   -
Address 06: Seat Mem. Pass       Labels: None
   Controller: 4B0 959 760 C
   Component: Sitzmemory R1 BF    0103
   Coding: 00003
   VCID: 2D2D81A8F409
Address 08: Auto HVAC       Labels: 4B0-820-043-MY1.LBL
   Controller: 4B0 820 043 AD
   Component: A6-Klimavollautomat 0105
   Coding: 00010
   Shop #: WSC 02325
   VCID: 5CCB1C6CDF33
01810 -  Actuating Motor for Temperature Flap; Right (V159)
            41-10 -  Blocked or No Voltage - Intermittent
00716 -  Air recirculation Flap Positioning Motor (V113)
01592 -  Air Quality Sensor (G238)
            57-10 -  Electric Circuit Failure - Intermittent
01317 -  Control Module in Instrument Cluster (J285)
            49-10 -  No Communications - Intermittent
01314 -  Engine Control Module
Address 15: Airbags       Labels: 4B0-959-655-AI7.LBL
   Controller: 4B0 959 655 N
   Component: Airbag 8.4E         5001
   Coding: 0000305
   Shop #: WSC 02325
   VCID: 3B09BFF03A7D
Address 16: Steering wheel       Labels: 4B0-907-487.LBL
   Controller: 4B0 907 487 H
   Component: Lenkradelektronik   D01
   Coding: 01015
   Shop #: WSC 02325
   VCID: 31159DD8E831
Address 17: Instruments       Labels: 4B0-920-xxx-17.LBL
   Controller: 4B0 920 981 P
   Component: KOMBI+WEGFAHRS. VDO D11
   Coding: 03283
   Shop #: WSC 19411
   VCID: 331997D0122D
01176 -  Key
            07-10 -  Signal too Low - Intermittent
00849 -  S-contact at Ignition/Starter Switch (D)
            31-10 -  Open or Short to Ground - Intermittent
01315 -  Transmission Control Module
Address 35: Centr. Locks       Labels: 4B0-962-258.LBL
   Controller: 4B0 962 258 J
   Component: Central Lock/Alarm  D35
   Coding: 15885
   Shop #: WSC 02325
   VCID: 301398DCE33B
9 Faults Found:
01366 -  Opened Due to Crash Signal
            35-00 -   -
01371 -  Alarm triggered by Door Contact Switch; Driver's Side
            35-00 -   -
01572 -  Alarm triggered by Door Contact Switch; Passenger Side
            35-00 -   -
01374 -  Alarm triggered by Terminal 15
            35-00 -   -
01370 -  Alarm triggered by Interior Monitoring
            35-00 -   -
01368 -  Alarm triggered by Luggage Compartment Switch
            35-00 -   -
00955 -  Key 1
            09-10 -  Adaptation Limit Surpassed - Intermittent
00956 -  Key 2
01573 -  Alarm triggered by Door Contact Switch; Left Rear
            35-00 -   -
Address 36: Seat Mem. Drvr       Labels: None
   Controller: 4B0 959 760 B
   Component: Sitzmemory R1 F     0102
   Coding: 00001
   VCID: 2C2B8CACCF13
Address 45: Inter. Monitor       Labels: None
   Controller: 4B0 951 178 A
   Component: Innenraumueberw.    D04
   Coding: 00101
   Shop #: WSC 02325
   VCID: 263F7E84D1FF
01377 -  Ultra Sonic Sensor for Alarm System; Left (G170)
            27-00 -  Implausible Signal
Address 55: Xenon Range       Labels: 4Z7-907-357.LBL
   Controller: 4Z7 907 357
   Component: dynamische LWR       D07
   Coding: 00050
   Shop #: WSC 02325
   VCID: 047B040C0703
Address 56: Radio       Labels: 8D0-035-1xx-56.LBL
   Controller: 4B0 035 195 J
   Component: symphony II NP2    0050
   Coding: 00225
   VCID: 27217380D6F5
Address 75: Telematics       Labels: None
   Controller: 8E0 035 616
   Component: Telematik USA1
   Coding: 0002303
   Shop #: WSC 02325
   VCID: E2B7A2947D57
01528 -  Auxiliary Antenna for Telematic (R90)
            004 -  No Signal/Communication - Intermittent
00003 -  Control Module
            014 -  Defective - Intermittent
Address 76: Park Assist       Labels: 8Z0-919-283.LBL
   Controller: 8Z0 919 283
   Component: Parkingsyst. A6 USA D08
   Coding: 01166
   Shop #: WSC 02325
   VCID: 027702141D17
01547 -  Sensor for Parking Aid; Rear Mid-Right (G205)
            31-00 -  Open or Short to Ground
End   --------------------------------------------------------------------------------------------------
Hi - trying to code my abs as per Ross tech procedure but can’t get past the last necessary step of calibrating the steering angle sensor
- after coding & clearing any dtc’s when I open up basic settings 001 it doesn’t let me press “Go!” To activate the calibration -
I have tried many times, any help would be greatly appreciated- Thanks!!!
Zenerdiode
Newcastle, England
C?ID=24330
Because that BS Group is already selected and running. If you place your cursor in the TextBox with '001' in it; clear out the 001, re-enter it, the [Go!] button will now be Enabled to run BS on that group.
Yup, looks like the last button he clicked was [Up], which implicitly does a [Go!] on the next group.
The fact that field 3 shows "OK" also means it did the Basic Setting successfully. The scan also shows a Coding: 06397, so I'm not sure I understand what the problem is, other than he needs to carry out the System Function Test.
RunsDeep
C?ID=367120
Thanks for all your help, performed system function test and all lights went away and abs is now successfully coded
it was confusing as I was under the impression it would run some sort of test that took a few seconds. It should be noted that all you really have to do is go to 001 in basic functions - & it doesn’t matter how you get there
(pressing go is only necessary if you type 001 in the box; as just pressing the arrow up to one does the same exact thing) ... now to bleed the abs pump :0)
