Monday,19,August,2019,17:13:25:06635
VCDS Version: 19.6.1.0 (x64) HEX-V2 CB: 0.4508.4
VIN: WV2ZZZ2KZJX088724 License Plate: CADDY
Mileage: 950km-590mi Repair Order:
Chassis Type: 2K-VN35 (7N0)
Scan: 01 02 03 08 09 10 13 15 16 17 18 19 25 42 44 46 4C 52 61
VIN: WV2ZZZ2KZJX088724 Mileage: 950km-590miles
Address 01: Engine (J623-DFSD) Labels: None
Part No SW: 04L 906 016 MJ HW: 04L 907 309 K
Component: R4 2.0l TDI H20 4092
Revision: 8AH20---
Coding: 011D0012042415090000
Shop #: WSC 12345 123 61029
ASAM Dataset: EV_ECM20TDI01104L906016MJ 001001
ROD: EV_ECM20TDI01104L906016GR_004.rod
VCID: 7DA7FB2CED70F05FA1F-8028
17158 - Implausible Data Received from ESP Control Module
U0416 00 [039] - -
Mileage: 959 km
Time: 00:00:00
Coolant temperature: 34 °C
Intake air temperature: 33 °C
Voltage terminal 30: 14.220 V
Drivetrain coordinator: brake fault status-Bits 0-7: 4
Drivetrain coordinator: brake function status-Bits 0-7: 32
Drivetrain coordinator: brake function status-Bits 0-7: 0
Acceleration: 0.000 m/s²
Part No SW: 02E 300 066 M HW: 02E 927 770 AT
Component: GSG DSG AG6 541 5201
Revision: 06454104 Serial number: 00001712090499
Shop #: WSC 35110 377 00147
VCID: 2313ED5427D466AFF7B-8076
Address 03: ABS Brakes (J104) Labels: 7E0-907-37x-MK100ESC.clb
Part No SW: 7E0 907 379 P HW: 7E0 907 379 M
Component: ESC H06 0133
Revision: 00000000 Serial number: 60048000001086
Coding: 1079409B936AA486087C0278C986259378F100
ROD: EV_Brake1ESCCONTIVN75XGP2_011.rod
VCID: 3FDB4124A7FC224FF33-806A
8252 - Databus
U1122 00 [137] - Implausible Message
[ACAN: SY1_Lenker signal coding missmatch]
Reset counter: 204
Mileage: 959 km
Date: 2019.08.19
Time: 02:07:43
Part No SW: 1K8 907 044 AE HW: 1K8 907 044 AE
Component: Climatronic H05 0304
Revision: 00001K03
Coding: 001000C003
ROD: EV_ClimaAutoBasis_VW32.rod
VCID: 72BDD810A42EBF27CCD-8026
7 Faults Found:
9471765 - Temperature Sensor for Left Vent
B1087 15 [009] - Open or Short to Plus
Reset counter: 204
Mileage: 959 km
Date: 2019.08.19
Time: 02:07:34
9472021 - Temperature Sensor for Right Vent
B1088 15 [009] - Open or Short to Plus
Reset counter: 204
Mileage: 959 km
Date: 2019.08.19
Time: 02:07:34
9481748 - High Pressure Sensor
B10AE 14 [009] - Open or Short to Ground
Reset counter: 204
Mileage: 959 km
Date: 2019.08.19
Time: 02:07:34
9480469 - Control Circuit for A/C Compressor
B10A9 15 [009] - Open or Short to Plus
Reset counter: 204
Mileage: 959 km
Date: 2019.08.19
Time: 02:07:36
9496597 - Sunlight Photo Sensor
B10E8 15 [009] - Open or Short to Plus
Reset counter: 204
Mileage: 959 km
Date: 2019.08.19
Time: 02:07:34
9496613 - Sunlight Photo Sensor
Reset counter: 204
Mileage: 959 km
Date: 2019.08.19
Time: 02:07:34
9478421 - Diagnostic Line for Front Air Blower
B10A1 15 [008] - Open or Short to Plus
Reset counter: 244
Mileage: 959 km
Date: 2019.08.19
Time: 02:07:38
Part No SW: 5K0 937 086 AA HW: 5K0 937 086 AA
Component: BCM PQ35 M+ 122 0186
Revision: BD122001
Coding: 491A0A3E8825E12D00080083940009CC03D5000842CD8320E48487040041
VCID: 73B3DD14DBB4B62FC7B-8026
Subsystem 1 - Part No: 7N0 951 172
Component: Sensor, DWA 0 005 0502
Subsystem 2 - Part No: 1K0 951 605 F
Component: LIN BACKUP HO H01 0008
Address 10: Park/Steer Assist (J446) Labels:| 5Q0-919-283.clb
Part No SW: 1K8 919 465 A HW: 5Q0 919 283
Component: PARKHILFE 4K H10 0480
Revision: -------- Serial number: 39261805103033
Coding: 0000050011
ASAM Dataset: EV_EPHVA14VW364GP00 001007
ROD: EV_EPHVA14VW364GP00_VW36.rod
VCID: 372B29048FCC1A0F3B3-8062
Address 13: Auto Dist. Reg (J428) Labels:| 7N0-907-572.clb
Part No SW: 7N0 907 572 C HW: 7N0 907 572
Component: ACC Bosch PQx H03 0211
Serial number: 3012170438A191
Coding: 00009000FE0339
ASAM Dataset: EV_ACCBEGVW361 001006
ROD: EV_ACCBEGVW361_VW32.rod
VCID: 3635240088C6E307205-8062
1058 - Databus
[FAULT_CIS_ECD_NOTAVAILABLE]
Reset counter: 204
Mileage: 958 km
Date: 2019.08.19
Time: 13:43:28
Control Module temperature: 37 °C
Voltage terminal 15: 13.3 V
Vehicle speed: 0.00 m/s
Acceleration: 0.00 m/s²
1059 - Databus
[FAULT_CIS_ESP_FAIL]
Reset counter: 204
Mileage: 958 km
Date: 2019.08.19
Time: 13:43:28
1037 - Databus
[FAULT_CIS_QDCACC_FAIL]
Reset counter: 204
Mileage: 958 km
Date: 2019.08.19
Time: 13:43:28
Part No SW: 2K5 959 655 C HW: 2K5 959 655 C
Component: VW10Airbag00K H08 0018
Revision: -------- Serial number: 003V2004E86P
Coding: 00000000000000000000000000000000304B
Shop #: WSC 35110 790 50316
ASAM Dataset: EV_AirbaVW10BPAVW12X 001028
VCID: 3C213628B6EA3957D61-8068
Serial number: 3497ARB400A59AHCKJ8D
Serial number: 3507ARB400259AHDABAP
Serial number: 3517ARB4059535RI9PKM
Serial number: 3527ARB405J535RIQ9IW
Part No SW: 5K0 953 521 FG HW: 5K0 953 569 BC
Component: LENKS.MODUL 018 0230
Revision: FF010042 Serial number: 20180104300417
Coding: 1882460008
ROD: EV_SMLSNGVOLWSR8C.rod
VCID: 76B5E400C846A307E05-8022
Subsystem 1 - Part No SW: 2K0 959 442 HW: 2K0 959 442 Labels: 3C8-959-537.CLB
Component: E221__MFL-TAT H06 0023
Serial number: 0021820173200980BA1B
Coding: 280000
Part No SW: 2K5 920 866 C HW: 2K5 920 866 C
Component: KOMBI H04 1107
Coding: 1102011200
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A05733
VCID: 34311E089EBAF1171E1-8060
13654544 - Databus
[Steuergerät für Telefon keine Kommunikation]
Reset counter: 204
Mileage: 958 km
Date: 2019.08.19
Time: 13:43:28
Address 18: Aux. Heat Labels: 1K0-815-007.clb
Part No: 7N0 963 272 E
Component: Standheizer 044 4941
Revision: 00044000 Serial number: 09028239000000
Coding: 0031032
Shop #: WSC 35110 377 00182
VCID: 372B2904834C1A0F3B3-8062
Part No SW: 7N0 907 530 BL HW: 7N0 907 530 AN
Component: J533 Gateway H56 1682
Revision: H56 Serial number: 030118F1001674
Coding: 357421
VCID: 7BA3F534F3E4FE6F9FB-802E
Component: IMMO H04 1107
VCID: 6A8DC0708CFE77E774D-803E
Part No SW: 2K5 959 701 HW: 2K5 959 701
Component: Tuer-SG 009 2144
Coding: 0133168
Shop #: WSC 11111 111 45799
VCID: 71BFD71CADA8843F357-8024
Part No: 1K0 909 144 R
Component: EPS_ZFLS Kl. 140 3501
Revision: 00H22000
Shop #: WSC 00046 000 00000
VCID: 392F2F3CB5580C7FCD7-806C
Part No SW: 2K5 959 702 HW: 2K5 959 702
Coding: 0132144
VCID: 72BDD810A8AEBF27CCD-8026
Part No SW: 7N0 907 534 HW: 7N0 907 530 AN
Component: Batt.regelung H56 1682
Coding: 030F7873
VCID: 71BFD71CA1A8843F357-8024
Subsystem 1 - Part No SW: 2K0 915 181 HW: 2K0 915 181
Component: J367-BDMConti H03 1050
Serial number: 75885800001801080C6D
End----------(Elapsed Time: 01:07, VBatt start/end: 14.3V/14.3V)-----------
