How to activate OFF ROAD FUNCTIONS in MIBII fitted car?
Thx
bonoman: Here's an extract from my tweak instructions on VWW (thanks again Morde)
Off Road Display - Instructions:
WARNING: users that have a HEX+CAN, or Micro CAN Cable please note that this tweak (and any tweaks) on MIBII units (address Hex5F) should only be implemented with Ross Tech software version 15.7.3 (or later).
REQUIREMENT: This tweak will only work on MIBII units that have SATNAV installed (don't bother trying if a SATNAV is not present).
Step 1. On
Select Control Module screen click
"Select"
Step 2. Select
5F-information Elect
Step 3. Go to
step 4- Note: I've had reports from some forum colleagues that a security code was needed. If the adaptation channel settings in Step 5 are locked:
Step 3A. Go back to the Open Controller screen and select Security Access-16
Step 3B. Enter the magic number 31347 (if this doesn't work- exit RT software, wait a while with the ignition-on and try 20103)
Step 4. Select
Adaptation-10
Step 5. Change the following adaptation channels:
• (81)-Car_Function_Adaptations_Gen2-menu_display_compass - set to active (default not active)
• (83)-Car_Function_Adaptations_Gen2-menu_display_compass_over_threshold_high - set to active (default not active)
• (41)-Car_Function_List_BAP_Gen2-compass_0x15 - set to active (default not active)
Exit the Ross Tech software
Step 6. Reset the unit - press and hold the ON/OFF button on the infotainment unit for greater than 10 seconds.
Remember to do the last step- the tweak won't work without it! When the tweak is completed you should get these screens (in English if you are in an Anglo-Celtic country like USA)
Cheers
