Retrofit: Front Fog lamps & Paddle shifters - Golf Mk7.5
nibose
Perth, Australia
C?ID=371170
I'm trying to install the front fog lamps; I've already ordered & received the fog lamp kits & wiring. I now need to ensure my BCM (Part No SW: 5Q0 937 084 DA HW: 5Q0 937 084 CD) is compatible and also find out which LDS to order. My existing LDS (shown in the pic does not support front fogs).
I'm also trying to install paddle shifters and understand this may require a steering wheel upgrade. I do not wish to spend a lot on the R-line wheel so trying to see if there's steering wheel similar to my existing one (shown in the pic) that comes with paddles.
regards,
Nitin
PetrolDave
Westbury, UK
C?ID=1423
A full VCDS Auto-Scan will help identify your BCM.
darkchina811
ITALY
C?ID=333184
all BCMs support front fogs so you're good.
if your steering wheel already has buttons like in the picture, paddles can be added no problems, they might even work straight away. if they don't it is a single adaptation in the gateway.
note: removing the black trim from the steering wheel is VERY DIFFICULT and 99% you'll break it. I suggest replacing the whole steering wheel and rotate yours on the used market.
nibose
Perth, Australia
C?ID=371170
Please find the full scan below:
Chassis Type: AU-VW37 (3Q0)
Scan: 01 02 03 05 08 09 10 13 15 17 19 2B 3C 42 44 47 52 5F A5
   Mileage: 4146km-2576miles
Address 01: Engine (J623-CZDA)       Labels:. 04E-907-309-V1.clb
   Part No SW: 04E 906 027 HD    HW: 04E 907 309 BH
   Component: R4 1.4l TFS   H26 3742
   Revision: R7H26---
   Coding: 0125003224641D083000
   Shop #: WSC 00028 028 00031
   ASAM Dataset: EV_ECM14TFS01104E906027HD 001007
   ROD: EV_ECM14TFS01104E906027HD.rod
   VCID: 6D87C8471D19A32F121-8038
   CAN Converter 01:
   Part No SW: 0CW 300 041 Q    HW: 0AM 927 769 E
   Component: GSG DQ200G2_M H05 1601
   Revision: 00005008    Serial number: CU501809226194
   Shop #: WSC 00028 028 00025
   ROD: EV_TCMDQ200021_VW31.rod
   VCID: 43D34EFF6B1D855F945-8016
   Part No SW: 5Q0 614 517 DE    HW: 5Q0 614 517 AD
   Component: ESC           H25 0524
   Revision: 00000000    Serial number: 62758000001212
   Coding: 01FA8AA12423216F4780060060C72980512484E26006947338225038C2A2430B00000012121212B835351919323200
   VCID: 77ABEA2F6F4519FFF8D-8022
   Part No SW: 3Q0 959 435 L    HW: 3Q0 959 435 L
   Component: VWKESSYMQB    037 1204
   Revision: 00037000    Serial number: 0494382608
   Coding: 132C0C0723
   Part No SW: 5G0 907 044 CE    HW: 5G0 907 044 CE
   Revision: 00001K08
   Coding: 0012000420010000110500401210142A
   VCID: 6C81C5432603AA2705F-8038
   Geber f¸r K‰ltemitteldruck/K‰ltemitteltemperatur:
   Component: BCM MQBAB B   H38 0273
   Serial number: 00001827100516
   ASAM Dataset: EV_BCMMQB 019001
   ROD: EV_BCMBOSCH_019_VW37.rod
   VCID: 7AADF31B5C570497873-802E
   Component: WWS    180903  042 0551
   Serial number:         180906231320
   Component: RLHS  052 0107
   Serial number: SBY18M10D01H22M30S34
   Coding: 00A8DD
   Steering Column Switch:
   Subsystem 3 - Part No SW: 5Q1 953 507 M    HW: 5Q1 953 549
   Component: J527 SMLS MQB  004 0060
   Serial number: 00000029091804400738
   Part No SW: 5QA 919 298 D    HW: 5QA 919 298 A
   Component: PLA 3.0 12KH07 0050
   Serial number: 000308417618267
   Coding: 0371167851
   ASAM Dataset: EV_EPHVA2CAU3700000 009041
   ROD: EV_EPHVA2CAU3700000.rod
   VCID: 51FF74B7A16167CF169-8004
   Part No SW: 5Q0 907 572 P    HW: 3QF 907 572 A
   Component: ACC BOSCH MQB H11 0682
   Coding: 330067C15DFFC728949C810580400600000000000000000004
   ASAM Dataset: EV_ACCBOSCHVW416 002008
   VCID: 44D14DE36E138267ADF-8010
   Part No SW: 5Q0 959 655 BJ    HW: 5Q0 959 655 BJ
   Component: AirbagVW21    006 0339
   Serial number: 003VWR4LAHN$
   Coding: 98CCC000000000005C000000008800000065
   Shop #: WSC 00028 028 00010
   ASAM Dataset: EV_AirbaVW20SMEVW37X 002160
   ROD: EV_AirbaVW20SMEVW37X.rod
   VCID: 094F9CD709B11F0F9E9-805C
   Belt Pretensioner left:
   Component: BeltPretRevFL  H37 0350
   Serial number: 34169677E02101830179
   Coding: 333135
   Belt Pretensioner right:
   Component: BeltPretRevFR  H37 0350
   Serial number: 34169676E04101820994
   Coding: 333135
   Subsystem 3 - Part No SW: -----------    HW: 480 002 609 18
   Serial number: 35700000000B9B40A33N
   Subsystem 4 - Part No SW: -----------    HW: 480 002 609 18
   Serial number: 35800000000F0944443G
   Subsystem 5 - Part No SW: -----------    HW: 480 400 410 18
   Component: SideSensor_Dr  003 6149
   Serial number: 3510001A52C8C773144%
   Subsystem 6 - Part No SW: -----------    HW: 480 400 410 18
   Component: SideSensor_Pr  004 6149
   Serial number: 3520001142B72252270D
   Subsystem 7 - Part No SW: -----------    HW: 480 402 709 18
   Component: FrontSensor_D  003 6149
   Serial number: 3550001B92E18363327/
   Part No SW: 5G1 920 791 B    HW: 5G1 920 791 B
   Component: KOMBI         403 4191
   Coding: 27A50118678C000801887B0B5401000080000000
   VCID: 2B03065FE38D6D1F4C5-807E
   Part No SW: 3Q0 907 530 Q    HW: 3Q0 907 530 C
   Component: GW MQB High   518 5344
   Serial number: 03101811601884
   Coding: 030100347F085708FB00025C1C0F00010001070000000000000000000000
   ROD: EV_GatewNF.rod
   VCID: 3D2738070DF9F3AFE21-8068
   Component: 1-01-02-01-04
   Subsystem 2 - Part No SW: 5G0 959 442 AB    HW: 5G0 959 442 AB  Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H17 0052
   Serial number: 39180001904730068382
   Coding: 2CFFFF
   Serial number: 5687909104
   Part No SW: 2Q0 905 861 A    HW: 2Q0 905 861 A
   Component: ELV-MQBB      H07 0021
   Serial number: 18000319799012
   Coding: 0800000000000000
   ROD: EV_ELVMarqMQBA0_VW37.rod
   VCID: 313F1437C1A107CF769-8064
   Component: HRE_Master    H12 0081
   Serial number: 0494054096
   Coding: 02011203
   ROD: EV_HREntryHella_VW37.rod
   Lane Change Assistant 2:
   Component: HRE_Slave  H12 0081
   Serial number: 0494018176
   Coding: 020112
   Part No SW: 5Q4 959 593 F    HW: 5Q4 959 593 F
   Component: TSG FS        006 0246
   Serial number: 0000346019991
   Coding: 00311320D001048000001000
   VCID: 48C959D3523BA607417-801C
   Subsystem 1 - Part No SW: 5Q4 959 812 F    HW: 5Q4 959 812 F
   Component: Fond FHSG DRV  010 0004
   Serial number: 00000000000010206048
   Coding: 0D0000
   Part No SW: 5Q0 909 144 AB    HW: 5Q0 909 144 AA
   Component: EPS_MQB_ZFLS  131 1082
   Coding: 93170000
   ROD: EV_SteerAssisMQB_015.rod
   VCID: 74B1DD237E3372E7DDF-8020
Address 47: Sound System (J525)       Labels:| 5Q0-035-456.clb
   Part No SW: 5Q0 035 456 A    HW: 5Q0 035 456 A
   Component: MIB2_lite_amp H40 0200
   Revision: 00000001    Serial number: VWZ8Z1JMD0397UU
   Coding: 12000000008AAA8A000000000000
   ASAM Dataset: EV_AMPMst11CGen2ALPI 001003
   ROD: EV_AMPMst11CGen2ALPI.rod
   VCID: 2E050F4BD09F18376BB-807A
   Part No SW: 5Q4 959 592 F    HW: 5Q4 959 592 F
   Component: TSG BFS       006 0246
   Serial number: 0000342857500
   Coding: 00311120DE01048000001000
   VCID: 47CB5AEF5F25A97F48D-8012
   Subsystem 1 - Part No SW: 5Q4 959 811 F    HW: 5Q4 959 811 F
   Component: Fond FHSG PSG  010 0004
   Serial number: 00000000000010199698
   Coding: 050000
   Part No SW: 5NA 035 045 C    HW: 5NA 035 045
   Component: MU-H-N-RW     H55 1161
   Serial number: A849J0JB002070
   Coding: 027310080000000051510002000808001F0100F601200402DF
   VCID: 3829291322DBD687317-806C
   Subsystem 1 - Part No SW: 5G6 919 606     HW: 5G6 919 606
   Component: ABT_High-2  H52 9130
   Serial number: VWZ6ZJV2773576
   Subsystem 2 - Part No SW: V03 959 806 FQ    HW: -----------
   Component: ROW 2019/2020  --- 0079
   Component: Gracenote2  --- 4013
   Part No SW: 3QD 980 654     HW: 3Q0 980 654 A
   Component: MQB_B_MFK     H09 1272
   Serial number: 23081841K12006
   Coding: 000307000000010100022354C150A90098000E000020
   VCID: 084999D312BB6607817-805C
End----------(Elapsed Time: 01:31, VBatt start/end: 12.1V/12.1V)-----------
The other confusion I have is on the switch. There are several switches (LDS) with different part codes, such as 3C8941431, 5ED941431D etc.
My existing steering is exactly as shown in the picture. How is it possible to attach paddle shifters? Please help me with the part numbers.
Please help me with the part number of a similarly shaped steering. How about Golf Altrack steering? I comes with paddle shifters and has the same shape, which means I can reuse my existing airbag, saving some significant cash. I love the R-line steering but I'll need to purchase the steering and the airbag, adding to cost.
darkchina811
ITALY
C?ID=333184
I might have talked too soon. all MID and HIGH BCMs support front fogs but you seem to have a LOW, which would need replacing. I am not totally sure, the best way to know would be to pull it out and check if the relevant pins are present.
for all the rest, I have very limited internet access for a couple of days as I am in the middle of the ocean, I'll get back to you asap.
nibose
Perth, Australia
C?ID=371170
Interesting, because the care has driver assistance package & sound/vision package. Is there any way to tell from the part number whether or not this is a low/mid/high bcm?
Sure! eagerly waiting to hear on the paddles/steering. :)
darkchina811
ITALY
C?ID=333184
I need the car's VIN, send me a PM if you don't want to share it here.
darkchina811
ITALY
C?ID=333184
got it, I'll be in touch soon. just to double check, your current light switch already has the AUTO position?
nibose
Perth, Australia
C?ID=371170
My existing light switch (LDS) is exactly as shown in the pic above. So is my steering. :)
darkchina811
ITALY
C?ID=333184
BCM needs to be replaced with 5Q0 937 084 DD, this would also facilitate other retrofits. honestly I am not completely sure, as there is no way to tell from the part number, but the higher BCM for your VIN is DD, and that's always the HIGH, the most complete. if you want to know if yours supports the fog lights, take it out and look if the relative pin is present.
light switch is 5G0 941 431 BD WZU, without any doubt. same I retrofitted (I lacked the AUTO position).
steering wheel is 5G0 419 091 GE, has the cruise control buttons and the paddle shifters.
nibose
Perth, Australia
C?ID=371170
Thanks for the reply.
I'm pretty sure the BCM swap is not a straight forward one. Any suggestions? Have you personally done a BCM upgrade?
The light switch seems like the one I already have, I thought I required the LDS with "Auto" on top and the "OFF" position on the left side.
Any recommendation on a seller, I can see lots on ebay but cant tell between genuine and counterfeit.
darkchina811
ITALY
C?ID=333184
of course I upgraded my BCM, the MID one I had from stock did not support heated seats. if you search the forum there was another guy retrofitting heated seats and I walked him through the BCM swap process step by step. you'll need a session with a dealer.
not sure what you're saying about the LDS, if it's like the picture you posted then it lacks the front fogs and you need to replace it with the part I said.
I don't have a favorite seller, I always bought parts around europe where it was cheapest. the majority comes from wrecked cars so I wouldn't worry about being non-genuine.
about the steering wheel, I gave you THE part number for your VIN but the same steering wheel exists across different years with different part numbers. just find one that has the buttons you want and the paddle shifters, it will work.
nibose
Perth, Australia
C?ID=371170
Hello darkchina811,
Sorry to disturb you.... Would you be in a position to assist me with the fog lamp coding?
I did search online but could only find for the older generation BCMs, those with long coding, whereas in my car's BCM, the long coding is all "zeros" and everything is in the adaptation channels. Please assist me with the static cornering coding as well.
TIA,
Nitin
darkchina811
ITALY
C?ID=333184
no problem, but since my BCM is also the old-style coding, I never researched much on the new generation. I am sure somebody will chime in soon.
anyways, did you replace it already? that was fast :P
nibose
Perth, Australia
C?ID=371170
No Its still the same. I'm trying to see if it has the required pins.
I did come across a site where someone had fog lamps on the VW Golf mk7 with the same BCM. So I'm assuming it may not require an upgrade. However, when it comes to coding, the long coding only displays all "zeros" and left everything to adaptation channels.
https://uk-polos.net/viewtopic.php?t=72376
regards,
Nitin
darkchina811
ITALY
C?ID=333184
if that guy has fogs then yes, BCM is good for fogs. he also published adaptation maps so compare his to yours with WinMerge.
I think fog lights in german are called Nebellichts.
nibose
Perth, Australia
C?ID=371170
Quick Update:
I've purchased the fog lamp kits, wiring harness & the switch. I'm now ordering the steering, which is when I notices some have the button "CNL" while others have the icon for ACC. Are these the same? Would there be any version difference due to this?
Thanks and regards,
Nitin
darkchina811
ITALY
C?ID=333184
the difference is between regular cruise control (CNL button) versus ACC (little car symbol). buy accordingly to your car's equipment.
nibose
Perth, Australia
C?ID=371170
I've finally got my steering delivered
It matches my existing steering and vehicle configuration.
I've also purchased the front fog lamp kit for my golf mk7.5. My car came factory fitted with the rear fog lights.
The kit came with the fog light units and wiring kit. I ordered the LDS separately, which has also arrived. Its today that I realised the wiring kit that came along is not the correct one as it came with a relay and connections to the battery. Guess this must be for a non-OEM installation.
Would you know the part code for the correct wiring for the Golf MK7.5 wiring? I came across these, will these work?: https://www.cars-equipment.com/en/shop/fog-lights/oem-wiring-harness-cable-for-fog/#prettyPhoto
I would also be interested in understanding the wiring a bit more. I'm aware the leads from each fog lamp unit should be connected to Pin 45 (for LHS) and Pin 5 (RHS) of the BCM. Shouldn't there be a connection from the LDS to the BCM as well or is it already taken care of, because I've already got rear fogs installed?
I tried posting the images but somehow its not appearing here
Many thanks!
