Just 2 weeks ago I replaced the water pump, timing belt, thermostat and left cooling fan due to leaking pump and now I am still in this puzzle thinking I am done with the repairs over the car but NOT really.
Yesterday as I was driving the Speeding indicator on my dashboard had flashing D and repair tool. The vehicle was shifting rough and after trying to turn off and on the car the problem continued. I drove for another 20 minutes and the car started getting stuck in 1st speed going to 3 odometers until shifting to 2nd speed and then is fine, for a little while but not long the car lost all power. I would make a full stop, then push the gas pedal all the way to the bottom had pushing but the car wont move a bit. I parked waited 30 minutes until engine cool, started the car and it drove as new from the dealer, no lights on the dashboard no D and repair key flashing anymore and as powerful as this Turbo can get. I have no idea what could this be. I need advice. Please help me. I have a copy of the VAG scan below, there are 2 engine codes and 2 transmission codes that I tried to research on my own but they suggest about 10 different thing each and I am very confused from where should I start.
Thanks,
Daisy
Thanks,
Daisy
Monday,22,April,2019,22:31:55:42313
VCDS Version: 18.9.0.2 (x64)
VIN: 1VWCN7A35CC060811 License Plate: 7KQP428
Mileage: 380480km-236419mi Repair Order:
Chassis Type: A3-VW41 (7N0)
Scan: 01 02 03 05 08 09 15 16 17 19 25 2B 2E 36 37 42 44 46 47 4F
52 56 62 72 77
VIN: 1VWCN7A35CC060811 Mileage: 380480km-236419miles
Address 01: Engine (J623-CKRA) Labels:. 03L-906-022-CFC.clb
Part No SW: 03L 997 009 J HW: 03L 907 309 S
Component: R4 2.0l TDI H21 9982
Revision: 71H21--- Serial number:
Coding: 001D0012042400008000
Shop #: WSC 26061 444 00000
ASAM Dataset: EV_ECM20TDI01103L997009J 004005
ROD: EV_ECM20TDI01103L997009J.rod
VCID: 3B74BECFB2C0E992C0-806E
8215 - Exhaust Gas Recirculation System
P2457 00 [237] - Insufficient Cooling Performance
Mileage: 380315 km
Date: 2019.04.22
Time: 17:55:59
Engine speed: 1235.00 /min
Normed load value: 66.7 %
Vehicle speed: 28 km/h
Coolant temperature: 98 °C
Intake air temperature: 35 °C
Voltage terminal 30: 14.040 V
Sensor for engine block temperature: raw value: 98.5 °C
Exh.gas temp.sen 4: 277.5 °C
Exhaust mass flow of low-pressure EGR: 15.2 kg/h
Temp sensor for low-pressure EGR after cooler: raw value: 157.6 °C
Low-pressure EGR cooling: model temperature: 154.4 °C
Low-pressure EGR cooling: request status-Bits 0-7: 0
Low-pressure EGR cooling: request status-Bits 0-7: 1
38303 - NOx Sensor 1 Bank 1
P2201 00 [096] - Implausible Signal
Mileage: 379015 km
Date: 2019.04.14
Time: 15:00:58
Intake air temperature: 28 °C
Voltage terminal 30: 12.820 V
Unlearning counter according OBD: 38
Air mass: actual value (mg/stroke): 0.0 mg/stroke
Mean injection quantity: 0.00 mg/stroke
EGR Vacuum Regulator Solen.val.: activation: 100.00 %
NOx emission NOx sensor 1: 0 ppm
Air mass for release of NOx sensor 1 offset test: 0.0 g
Calculated efficiency of NOx conversion: 0.950
Readiness: 1 1 0 0 0
Part No SW: 02E 300 057 P HW: 02E 927 770 AL
Component: GSG DSG AG6 512 9435
Revision: 05551213 Serial number: 00001112090944
Shop #: WSC 40321 001 1048576
VCID: 26427FBB9142447A8F-8072
19143 - Unexpected / Implausible Mechanical Gear Disengagement
P2711 - 007 - - Intermittent
Fault Status: 00100111
Reset counter: 36
Mileage: 379789 km
Date: 2013.09.07
Time: 21:04:52
18172 - Transmission Temperature Monitoring
P1764 - 001 - - Intermittent
Fault Status: 00100001
Reset counter: 5
Mileage: 379960 km
Date: 2013.09.08
Time: 18:07:36
Part No SW: 1K0 907 379 BL HW: 1K0 907 379 BL
Component: ESP MK60EC1 H31 0152
Revision: 00H31001
Coding: C54BC0F5492800FAA31303E5921A0042A71000
Shop #: WSC 09003 957 00200
VCID: 7DF070D7E45427A2BE-8028
Address 05: Acc/Start Auth. (J518) Labels:| 5K0-959-434.clb
Part No SW: 5K0 959 434 B HW: 5K0 959 434
Revision: 00085000 Serial number: 0161487923
Coding: 130C0C
VCID: 346695F39F9E26EA01-8060
Part No SW: 561 907 044 H HW: 561 907 044 H
Component: Climatronic 043 0202
Revision: 00001001
Coding: 0010001012
ROD: EV_ACClimaBHBVW411_VW41.rod
VCID: 1C365D53170E8EAA29-8048
Part No SW: 5K0 937 087 AA HW: 5K0 937 087 AA
Component: BCM PQ35 H+ 121 0164
Revision: BL121001
Coding: 6F200E3B982B08D4088802013600814800710086458005F0648060009C70
VCID: 74E655F3D71E66EAC1-8020
Subsystem 1 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB
Component: RLS 030212 05 54 0403
Coding: 06300A
010 - Open or Short to Plus
Fault Status: 01101010
Fault Frequency: 15
Reset counter: 195
Mileage: 378963 km
Date: 2013.09.04
Time: 12:57:35
Voltage: 12.00 V
Part No SW: 5C0 959 655 HW: 5C0 959 655
Component: AirbagVW10G 013 0809
Serial number: 003ENM01EMZ5
Coding: 00003548
ASAM Dataset: EV_AirbaVW10SMEVW360 A01024
ROD: EV_AirbaVW10SMEVW360.rod
VCID: 6FEC5A9FB63845323C-803A
Subsystem 1 - Part No SW: 5C6 959 339 A HW: 5C6 959 339 A
Component: BF-Gewichtss. H10 0045
Serial number: 6940000Y120000AUAB0V
Coding: 303047
Component: S.Sens.Fahr.V H01 ----
Serial number: 3572MSME326F3068ZZZ-
Component: S.Sens.Beif.V H01 ----
Serial number: 3582MSME47507466ZZZX
Serial number: 3516KSME574E1417ZZZW
Subsystem 5 - Part No SW: 5K0 959 351 A HW: 5K0 959 351 A
Serial number: 3526KSME23681F16ZZZW
Subsystem 6 - Part No SW: 5K0 959 659 A HW: 5K0 959 659 A
Serial number: 3556LSME3A201414ZZZJ
Subsystem 7 - Part No SW: 5K0 959 659 A HW: 5K0 959 659 A
Component: F.Sens.Beif H02 ----
Serial number: 3566LSME34051414ZZZH
Part No SW: 1K5 953 521 AR HW: 5K0 953 569 E
Revision: FF010040 Serial number: 20110729100513
Coding: 000A140000
ROD: EV_SMLSNGVOLWS.rod
VCID: 7DF070D7EC5427A2BE-8028
Component: E221__MFL-YVJ H06 0022
Coding: E20000
Address 17: Instruments (J285) Labels:| 5K0-920-XXX-17.clb-SRI1
Part No SW: 561 920 970 C HW: 561 920 970 C
Component: KOMBI H07 0507
Coding: 231E01
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04093
VCID: 1A3A5B4B1D3AF09A3B-804E
Part No SW: 7N0 907 530 P HW: 1K0 907 951
Component: J533 Gateway H40 1623
Revision: H40 Serial number: 07021201290602
Coding: 461000
VCID: 3D70B0D7A4D4E7A2FE-8068
Component: IMMO H07 0507
Coding: 000007
VCID: 6ADA4B8B8DDAA01A6B-803E
Address 2B: Steer. Col. Lock (J764) Labels:* 5K0-905-861.clb
Part No SW: 5K0 905 861 A HW: 5K0 905 861 A
Component: ELV-PQ35 H20 0230
Revision: 00000000 Serial number: 11000274387004
Coding: 4900000000000000
ROD: EV_ELVMarquMPVW36X.rod
VCID: 2E52879B71B20C3A77-807A
Part No SW: 5N0 035 342 E HW: 5N0 035 342 E
Revision: A1001003 Serial number: 7661543498
VCID: 29587487405C6B02A2-807C
Part No SW: 561 959 760 HW: 561 959 760
Component: MEM-FS H04 0181
Revision: AA000000 Serial number: 00000022806321
Coding: 0000000000000000000000000000000000000000000000
VCID: 60CE29A373E6EA4AB5-8034
Address 37: Navigation (J0506) Labels:. 1T0-035-680.clb
Part No SW: 3C8 035 684 E HW: 3C8 035 684 E
Component: RNS-MID H61 3690
Revision: AB001001 Serial number: VWZ6Z7M4047073
Coding: 04090002010000A6000B
VCID: 2D50809774B477224E-8078
Fault Frequency: 45
Reset counter: 194
Mileage: 378920 km
Part No SW: 561 959 701 A HW: 3C0 959 793 C
Component: TUER-SG FT 002 0525
Revision: 12110009 Serial number: 0003494557
Coding: 0405FD
ASAM Dataset: EV_TSGFPQ25BRFVW46X A04001
ROD: EV_TSGFPQ25BRFVW46X.rod
Slave Driver:
Subsystem 1 - Part No SW: 561 959 811 HW: 561 959 811 Labels: 1K0-959-70X-GEN4.CLB
Component: J388__TSG_HL 004 4472
Coding: 800000
Part No: 1K0 909 144 N
Component: EPS_ZFLS Kl. 290 3301
Revision: 00H22000
VCID: 3560A8F75CE43FE236-8060
Part No SW: 5C6 035 456 HW: 5C6 035 456
Component: KonzernAmp10K H07 0468
Revision: -------- Serial number: EAA083A0006189
VCID: 65C038B764C48F6246-8030
Part No SW: 7N0 907 532 HW: 1K0 907 951
Component: EZE_2 H40 1623
Coding: 01030108
VCID: 6FEC5A9FBE3845323C-803A
Subsystem 1 - Part No SW: 561 959 591 HW: 561 959 591
Component: J245 P05 FFD7 H07 0004
Serial number: 53388786011134400591
Coding: 181100
Subsystem 2 - Part No SW: 561 919 204 B HW: 561 919 204 B
Component: Analoguhr 008 0004
Part No SW: 561 959 702 A HW: 3C0 959 792 C
Component: TUER-SG BT 002 0525
Revision: 14110009 Serial number: 0003546138
Coding: 0405FC
ASAM Dataset: EV_TSGBPQ25BRFVW46X A04001
ROD: EV_TSGBPQ25BRFVW46X.rod
VCID: 1D3050570C1487A2DE-8048
Slave Passenger:
Subsystem 1 - Part No SW: 561 959 812 HW: 561 959 812 Labels: 1K0-959-70X-GEN4.CLB
Component: J389__TSG_HR 004 4472
Coding: 800000
Address 56: Radio (J0506) Labels:. 1T0-035-680.clb
Fault Frequency: 45
Reset counter: 194
Mileage: 378920 km
Part No SW: 5K0 035 730 E HW: 5K0 035 730 E
Component: TELEFON H09 2902
Revision: 1B001001 Serial number: 00007661523680
Coding: 0A10040000010110
ASAM Dataset: EV_UHVNA A01719
ROD: UHVNA.rod
VCID: 275C72BF5E485D72B4-8072
End-------------------------(Elapsed Time: 03:24)--------------------------
