- Joined
- Mar 31, 2014
- Messages
- 33
- Reaction score
- 9
- Location
- United Kingdom
- VCDS Serial number
- C?ID=41543
Hi I have this Seat in which keeps coming up with NOx Catalyst efficiency below threshold.
We have fitted a genuine NOx sensor.
It also had an issue with adblue tank, always saying ad blue low, but after calibrating the tank that fault has not come back.
It there a way to also check the adblue injector via VCDS?
Autoscan attached below
Friday,22,November,2019,08:53:36:32967
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 8.1 x86
VCDS Version: 19.6.2.0 HEX-NET CB: 0.4508.4
VIN: VSSZZZ7NZEV517022 License Plate:
Chassis Type: 7N-VW36 (7N0)
Scan: 01 02 03 08 09 10 15 16 17 18 19 20 25 2E 37 42 44 46 4C 4F
52 53 56 61 62 6C 6D 72 BE BF
VIN: VSSZZZ7NZEV517022 Mileage: 153800km-95566miles
20-High Beam Assist. -- Status: Malfunction 0010
BE-Slid. Door Rear Left -- Status: OK 0000
BF-Slid. Door Rear Right -- Status: OK 0000
Address 01: Engine (J623-CFGC) Labels:. 03L-906-018-CFF.clb
Part No SW: 03L 906 018 RJ HW: 03L 906 018 M
Component: R4 2.0l TDI H28 9979
Revision: 44H28--- Serial number:
Coding: 001D001A042501080000
Shop #: WSC 00000 210 00000
ASAM Dataset: EV_ECM20TDI01103L906018RJ 003006
ROD: EV_ECM20TDI01103L906018F_VW36.rod
VCID: 834607500A955F573A-80D6
15733 - SCR NOx Catalyst Bank 1
P20EE 00 [096] - Efficiency too Low
Part No SW: 02E 300 062 M HW: 02E 927 770 AL
Component: GSG DSG AG6 521 4007
Revision: 05652104 Serial number: 00001401280999
Shop #: WSC 00020 000 90108
VCID: 9F0E6B204E3D9BB73E-80CA
Address 03: ABS Brakes Labels: 7N0-614-109.clb
Part No SW: 7N0 614 109 P HW: 7N0 614 109 P
Component: J104 C3 450M VD08 0030
Revision: --H07--- Serial number: 00000007906010
Coding: 0028295
Shop #: WSC 00020 790 00000
VCID: BA38BAB4F5DFDE9F29-80EE
Part No SW: 7N0 907 044 R HW: 7N0 907 044 R
Component: Clima-Sharan H02 0404
Revision: 00001K02
Coding: 021010C549
Shop #: WSC 00020 999 00000
VCID: BFCECBA026FDFBB71E-80EA
Slave 1:
Subsystem 1 - Part No SW: 7N0 907 049 C HW: 7N0 907 049 C
Component: KBT-H 004 0103
Serial number: 20140304000000153271
Part No SW: 5K0 937 086 Q HW: 5K0 937 086 Q
Component: BCM PQ35 M 122 0173
Revision: BC122001
Coding: 40590A3B8925F1C0508800C87400816443519288636D2D626480C72000C1
Shop #: WSC 53112 001 1048576
VCID: C2C8C2545D0F965F71-8096
Subsystem 1 - Part No SW: 7N2 955 119 A HW: 7N2 955 119 Labels: 1KX-955-119.CLB
Component: WWS 140129 033 0044
Serial number: 140131172019
Coding: 004DBD
Subsystem 2 - Part No SW: 5Q0 955 547 HW: 5Q0 955 547 Labels: 5Q0-955-547.CLB
Component: RLFS 024 0042
Serial number: Y14M03D08H14M31S43S8
Coding: 229597
Subsystem 3 - Part No: 7N0 951 171 A
Component: DWA-Sensor 00 002 0206
Reset counter: 44
Mileage: 153409 km
Date: 2014.04.07
Time: 17:58:02
Term 15 Off
Voltage: 12.65 V
Address 10: Park/Steer Assist (J446) Labels:| 1Q0-919-475.clb
Part No SW: 7N0 919 475 A HW: 7N0 919 475
Component: PARKHILFE 8K H06 0012
Revision: -------- Serial number: 28261406803424
Coding: 308102
ASAM Dataset: EV_EPHVA18VW4280000 001005
ROD: EV_EPHVA18VW4280000.rod
VCID: B93AA5B838D9D58720-80EC
Part No SW: 7N0 959 655 C HW: 7N0 959 655 C
Component: VW10Airbag00F H12 0014
Serial number: 003LGP4NSUG.
Coding: 003046
ASAM Dataset: EV_AirbaVW10TS6VW428 A01004
ROD: EV_AirbaVW10TS6VW428.rod
Subsystem 1 - Part No SW: --- HW: ---
Component: S.Sens.Fahr.V --- ---
Serial number: 3493ETS60D4495E199D5
Subsystem 2 - Part No SW: --- HW: ---
Component: S.Sens.Beif.V --- ---
Serial number: 3503ETS60A60565199DN
Subsystem 3 - Part No SW: --- HW: ---
Component: S.Sens.Fahr.H --- ---
Serial number: 3513ETS60A1785B199DY
Subsystem 4 - Part No SW: --- HW: ---
Component: S.Sens.Beif.H --- ---
Serial number: 3523ETS60CBF16419DD3
Subsystem 5 - Part No SW: --- HW: ---
Component: F.Sens.Fahr --- ---
Serial number: 35540TS6013E749199DL
Part No SW: 5K0 953 521 DF HW: 5K0 953 569 AE
Component: LENKS.MODUL 016 0140
Revision: FF010042 Serial number: 20140304200436
Coding: 189A240000
ROD: EV_SMLSNGVOLWS.rod
VCID: F3A657905A356FD72A-80A6
Subsystem 1 - Part No SW: 1P0 959 538 B HW: 1P0 959 538 B Labels: 3C8-959-537.CLB
Component: E221__MFL-TAP H02 0103
Coding: E30000
Part No SW: 7N5 920 970 J HW: 7N5 920 970 J
Component: KOMBI H04 0811
Coding: 441F01
Address 18: Aux. Heat Labels: 1K0-815-071.clb
Part No: 7N0 963 271 G
Component: Zuheizer 051 3041
Revision: 00051000 Serial number: 09028242000000
Coding: 0000041
VCID: B83CA0BCCBD3CC8FDF-80EC
00664 - Fuel gauge
Reset counter: 27
Mileage: 152656 km
Date: 2014.03.29
Time: 08:03:45
Part No SW: 7N0 907 530 AM HW: 7N0 907 530 AM
Component: J533 Gateway H55 1642
Revision: H55 Serial number: 110314F2000046
Coding: 468203
VCID: FBB67FB07A65279772-80AE
Address 20: High Beam Assist. (J844) Labels:. 8K0-857-511.clb
Part No SW: 7N0 857 511 P HW: 8P0 857 511 C
Component: FLA H04 0012
Revision: AA001002
Coding: 01020064747464545425363E00
VCID: C0CCC85C5303844F67-8094
03576 - Contol Module for High Beam Assistant: Visibility Limited
Reset counter: 18
Mileage: 152424 km
Date: 2014.03.25
Time: 17:46:33
Component: IMMO H04 0811
VCID: EA984AF40DFFAE1F99-80BE
Part No SW: 5N0 035 342 G HW: 5N0 035 342 G
Revision: A1001003 Serial number: 7665940771
Coding: 020100
VCID: AB168FF0CA857717A2-80FE
Address 37: Navigation (J794) Labels:| 1K0-035-27x-37.clb
Part No SW: 5P0 035 192 D HW: 5P0 035 192 D
Component: RNS315-EU H76 0415
Serial number: SEZAZ2P0053506
Coding: 040004010400240000061002
ROD: EV_RNS315EUV2UDS.rod
VCID: AD1281E8FC917927BC-80F8
Component: EUR_W_V5 0055
Address 42: Door Elect, Driver (J386) Labels:. 7N0-959-793.clb
Part No SW: 7N0 959 793 G HW: 7N0 959 793 G
Component: TSG FA H03 0553
Revision: Serial number: 0000093075804
Coding: 01112E209001411011
VCID: C6C0DE447127AA7F5D-8092
02111 - Motor for Window Regulator
Fault Status: 00100101
Fault Frequency: 34
Reset counter: 46
Mileage: 139346 km
Date: 2019.07.31
Time: 19:24:43
Address 44: Steering Assist Labels: None
Part No: 7N0 909 144 R
Component: EPS_ZFLS Kl. 278 3501
Revision: 00H21000
VCID: C2C8C2549D0F965F71-8096
Part No SW: 7N0 907 532 HW: 7N0 907 530 AM
Component: EZE_2 H55 1642
Coding: 050B0500
VCID: EFAE5BE03E1D4B37CE-80BA
Subsystem 1 - Part No SW: 7N0 959 591 B HW: 7N0 959 591 B
Component: J245EE04SKB03 H03 0090
Subsystem 2 - Part No SW: 7N0 959 591 B HW: 7N0 959 591 B
Component: J394EE04SKB03 H03 0090
Address 52: Door Elect, Pass. (J387) Labels:. 7N0-959-792.clb
Part No SW: 7N0 959 792 G HW: 7N0 959 792 G
Component: TSG BF H03 0553
Revision: Serial number: 0000092202067
Coding: 01112C209E01411011
VCID: C5C2D9484C21A16754-8090
Reset counter: 39
Mileage: 153581 km
Date: 2014.04.09
Time: 17:01:08
Part No SW: 3AA 907 801 H HW: 3AA 907 801 H
Component: J540 EPB4 VW-86594 0010
Revision: H19 Serial number: 00000002005168
Coding: 0024167
VCID: B620AE84C1C73AFFCD-80E2
Part No SW: 7N0 907 534 HW: 7N0 907 530 AM
Component: Batt.regelung H55 1642
Coding: 030F7859
VCID: F1AA5D9828295DC7D8-80A4
Component: J367-BDM H07 0180
Serial number: 31062716091491883216
Address 62: Door, Rear Left (J388) Labels:. 7N0-959-794.clb
Part No SW: 7N0 959 794 H HW: 7N0 959 794 H
Component: TSG HL H01 0554
Revision: Serial number: 0000093317722
Coding: 01006C200001411001
VCID: C8DCD07C7B33BC0FAF-809C
Address 6C: Back-up Cam. Labels: 5N0-907-441.clb
Part No SW: 7N0 907 441 HW: 7N0 907 441
Component: J772__Rearview 0020
Revision: 00H13000 Serial number: 525 PA8J420100
Coding: 0020011
VCID: EE9046E4F917423FC5-80BA
Address 6D: Trunk Elect. (----) Labels:| 7N0-959-107.clb
Part No SW: 7N0 959 107 E HW: 7N0 959 107 A
Component: HDSG-Modul H11 0243
Revision: 41011001 Serial number: 056400186
Coding: 0733334002
ASAM Dataset: EV_HDSGVW428 201138
ROD: EV_HDSGVW428_VW36.rod
Address 72: Door, Rear Right (J389) Labels:. 7N0-959-794.clb
Component: TSG HR H01 0554
Revision: Serial number: 0000093311283
Address BE: Slid. Door Rear Left (J558) Labels: 7N0-959-244.clb
Part No SW: 7N0 959 244 B HW: 7N0 959 244 B
Component: Schiebetuer_l 005 2414
Serial number: 14073691
ASAM Dataset: EV_AST A03704
ROD: EV_AST.rod
VCID: B83CA0BC03D3CC8FDF-80EC
Address BF: Slid. Door Rear Right (J731) Labels: 7N0-959-244.clb
Component: Schiebetuer_r 005 2414
Serial number: 14073993
ROD: EV_AST.rod
End----------(Elapsed Time: 02:11, VBatt start/end: 14.7V/14.8V)-----------
